[U-Boot] [PATCH v2 00/26] dm: Conversion of code to the new driver model PCI API
PCI devices should be accessed just by their device pointer (which is struct udevice *). At present the hose (PCI controller) is often passed along with a pci_dev_t (bus/device/function) value.
With driver model this is not necessary but most PCI code has not been converted over to use this new API yet.
This series converts over various drivers with the goal of moving both Tegra and x86 to use PCI fully for driver model. In addition, both move to use driver model for Ethernet, which on x86 is related.
The process is not complete with this series. Remaining are the Intel E1000 Ethernet driver and various x86-specific things like ICH SPI.
Changes in v2: - Add a new pci_internal.h header file for internal PCI functions - Add missing code in dm_pci_phys_to_bus() - Drop non-DM PCI code - Drop unnecessary and confusing '#ifdef CONFIG_DM_ETH' in rtl8169_eth_probe() - Drop unnecessary comment at the top of pci_auto.c - Fix the indentation of the 'bar' for() loop - Fix use of 'pdev' instead of 'dev' - Get the vendor from the PCI parent platdata - Move the functions into pci_common.c so they can be used by old code - Put this code behind CONFIG_DM_PCI to avoid PowerPC build errors - Rename _dm_pci_hose_bus_to_phys() to _dm_pci_bus_to_phys() - Rename pci_run_vga_bios() to dm_pci_run_vga_bios() - Require driver model with pci_rom.c - Reword the commit message for clarity - Use dev_get_parent_platdata() instead of re-reading values from the device - Use dm_pci_get_bdf() - Use pci_bus_find_bdf() - Use u32 instead of uint32_t - Use uintptr_t to cast the hcor address
Simon Glass (26): dm: pci: Mark legacy files as such dm: pci: Add a dm_ prefix to pci_get_bdf() dm: pci: Add a dm_ prefix to pci_bus_find_bdf() dm: pci: Use driver model PCI API in auto-config dm: pci: Add a driver-model version of pci_find_device() dm: pci: scsi: Use driver-model PCI API dm: pci: Add a driver-model version of pci_find_class() dm: pci: Add a function to read a PCI BAR dm: serial: Convert ns16550 driver to use driver model PCI API dm: x86: ivybridge: Convert graphics init to use DM PCI API dm: Convert bios_interrupts to use DM PCI API dm: pci: video: Convert video and pci_rom to use DM PCI API dm: x86: pci: Adjust bios_run_on_x86() to use the DM PCI API dm: pci: Drop the old version of pci_find_device/s() dm: pci: Drop the old version of pci_find_class() dm: tegra: net: Convert tegra boards to driver model for Ethernet dm: test: Convert PCI tests to use the DM PCI API dm: pci: Add driver model API functions for address mapping dm: net: Convert rtl8169 to use DM PCI API dm: pci: Switch to DM API for PCI address mapping dm: ahci: Convert to use new DM PCI API dm: usb: Convert echi-pci to use new DM PCI API dm: Convert PCI MMC over to use DM PCI API pci: Tidy up comments in pci_bind_bus_devices() dm: net: usb: Refactor mcs7830 driver ready for DM conversion dm: net: usb: Convert mcs7830 driver to support driver model
arch/arm/mach-tegra/Kconfig | 1 + arch/x86/cpu/baytrail/valleyview.c | 4 +- arch/x86/cpu/ivybridge/bd82x6x.c | 6 +- arch/x86/cpu/ivybridge/gma.c | 15 +- arch/x86/cpu/quark/quark.c | 4 +- arch/x86/cpu/queensbay/topcliff.c | 4 +- arch/x86/include/asm/arch-ivybridge/bd82x6x.h | 3 +- arch/x86/lib/bios.c | 3 +- arch/x86/lib/bios_interrupts.c | 36 ++- board/compulab/trimslice/trimslice.c | 8 - board/nvidia/cardhu/cardhu.c | 6 - board/nvidia/jetson-tk1/jetson-tk1.c | 6 - board/nvidia/p2371-2180/p2371-2180.c | 6 - board/toradex/apalis_t30/apalis_t30.c | 6 - common/cmd_pci.c | 2 +- common/cmd_scsi.c | 14 +- drivers/block/ahci.c | 70 ++++- drivers/mmc/pci_mmc.c | 15 +- drivers/net/designware.c | 2 +- drivers/net/e1000.c | 4 +- drivers/net/pch_gbe.c | 2 +- drivers/net/rtl8169.c | 84 ++++-- drivers/pci/Makefile | 7 +- drivers/pci/pci-uclass.c | 240 ++++++++++++++-- drivers/pci/pci.c | 5 +- drivers/pci/pci_auto.c | 386 ++++++++++++++++++++++++++ drivers/pci/pci_auto_old.c | 54 +--- drivers/pci/pci_common.c | 86 +++--- drivers/pci/pci_compat.c | 2 +- drivers/pci/pci_internal.h | 50 ++++ drivers/pci/pci_rom.c | 47 ++-- drivers/serial/ns16550.c | 5 +- drivers/usb/eth/mcs7830.c | 370 ++++++++++++++++-------- drivers/usb/host/ehci-pci.c | 51 +++- drivers/video/vesa_fb.c | 10 +- include/ahci.h | 4 + include/bios_emul.h | 2 +- include/fdtdec.h | 23 +- include/mmc.h | 6 +- include/pci.h | 102 ++++++- include/pci_rom.h | 6 +- lib/fdtdec.c | 57 +--- test/dm/pci.c | 15 +- 43 files changed, 1349 insertions(+), 480 deletions(-) create mode 100644 drivers/pci/pci_auto.c create mode 100644 drivers/pci/pci_internal.h
We don't want people changing the legacy PCI files while migration is in progress. Update the file headers to indicate that.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: None
drivers/pci/pci.c | 5 ++++- drivers/pci/pci_auto_old.c | 9 ++++++--- 2 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 645ecd4..4619089 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -9,7 +9,10 @@ */
/* - * PCI routines + * Old PCI routines + * + * Do not change this file. Instead, convert your board to use CONFIG_DM_PCI + * and change pci-uclass.c. */
#include <common.h> diff --git a/drivers/pci/pci_auto_old.c b/drivers/pci/pci_auto_old.c index 932eab8..1ff88b1 100644 --- a/drivers/pci/pci_auto_old.c +++ b/drivers/pci/pci_auto_old.c @@ -1,7 +1,5 @@ /* - * arch/powerpc/kernel/pci_auto.c - * - * PCI autoconfiguration library + * PCI autoconfiguration library (legacy version, do not change) * * Author: Matt Porter mporter@mvista.com * @@ -14,6 +12,11 @@ #include <errno.h> #include <pci.h>
+/* + * Do not change this file. Instead, convert your board to use CONFIG_DM_PCI + * and change pci_auto.c. + */ + /* the user can define CONFIG_SYS_PCI_CACHE_LINE_SIZE to avoid problems */ #ifndef CONFIG_SYS_PCI_CACHE_LINE_SIZE #define CONFIG_SYS_PCI_CACHE_LINE_SIZE 8
Applied to u-boot-dm/next.
Most driver model PCI functions have a dm_ prefix. At some point, when the old code is converted to driver model and the old functions are removed, we will drop that prefix.
For consistency, we should use the dm_ prefix for all driver model functions. Update pci_get_bdf() accordingly.
Changes in v2: None
drivers/net/designware.c | 2 +- drivers/net/e1000.c | 4 ++-- drivers/net/pch_gbe.c | 2 +- drivers/net/rtl8169.c | 11 ++++++----- drivers/pci/pci-uclass.c | 9 +++++---- drivers/pci/pci_compat.c | 2 +- drivers/usb/host/ehci-pci.c | 2 +- include/pci.h | 4 ++-- 8 files changed, 19 insertions(+), 17 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index a6c39c3..df853af 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -588,7 +588,7 @@ static int designware_eth_probe(struct udevice *dev) * or via a PCI bridge, fill in platdata before we probe the hardware. */ if (device_is_on_pci_bus(dev)) { - pci_dev_t bdf = pci_get_bdf(dev); + pci_dev_t bdf = dm_pci_get_bdf(dev);
dm_pci_read_config32(dev, PCI_BASE_ADDRESS_0, &iobase); iobase &= PCI_BASE_ADDRESS_MEM_MASK; diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index 2ba03ed..195833a 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -5628,8 +5628,8 @@ static int e1000_eth_probe(struct udevice *dev) int ret;
hw->name = dev->name; - ret = e1000_init_one(hw, trailing_strtol(dev->name), pci_get_bdf(dev), - plat->enetaddr); + ret = e1000_init_one(hw, trailing_strtol(dev->name), + dm_pci_get_bdf(dev), plat->enetaddr); if (ret < 0) { printf(pr_fmt("failed to initialize card: %d\n"), ret); return ret; diff --git a/drivers/net/pch_gbe.c b/drivers/net/pch_gbe.c index dfc0100..1b4dd56 100644 --- a/drivers/net/pch_gbe.c +++ b/drivers/net/pch_gbe.c @@ -424,7 +424,7 @@ int pch_gbe_probe(struct udevice *dev) pci_dev_t devno; u32 iobase;
- devno = pci_get_bdf(dev); + devno = dm_pci_get_bdf(dev);
/* * The priv structure contains the descriptors and frame buffers which diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index 19422c4..f210005 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -576,7 +576,7 @@ int rtl8169_eth_recv(struct udevice *dev, int flags, uchar **packetp) { struct rtl8169_private *priv = dev_get_priv(dev);
- return rtl_recv_common(pci_get_bdf(dev), priv->iobase, packetp); + return rtl_recv_common(dm_pci_get_bdf(dev), priv->iobase, packetp); } #else static int rtl_recv(struct eth_device *dev) @@ -661,7 +661,8 @@ int rtl8169_eth_send(struct udevice *dev, void *packet, int length) { struct rtl8169_private *priv = dev_get_priv(dev);
- return rtl_send_common(pci_get_bdf(dev), priv->iobase, packet, length); + return rtl_send_common(dm_pci_get_bdf(dev), priv->iobase, packet, + length); }
#else @@ -837,7 +838,7 @@ static int rtl8169_eth_start(struct udevice *dev) { struct eth_pdata *plat = dev_get_platdata(dev);
- rtl8169_common_start(pci_get_bdf(dev), plat->enetaddr); + rtl8169_common_start(dm_pci_get_bdf(dev), plat->enetaddr);
return 0; } @@ -1130,10 +1131,10 @@ static int rtl8169_eth_probe(struct udevice *dev) region = 1; break; } - pci_read_config32(pci_get_bdf(dev), PCI_BASE_ADDRESS_0 + region * 4, + pci_read_config32(dm_pci_get_bdf(dev), PCI_BASE_ADDRESS_0 + region * 4, &iobase); iobase &= ~0xf; - priv->iobase = (int)pci_mem_to_phys(pci_get_bdf(dev), iobase); + priv->iobase = (int)pci_mem_to_phys(dm_pci_get_bdf(dev), iobase);
ret = rtl_init(priv->iobase, dev->name, plat->enetaddr); if (ret < 0) { diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 5fe3072..f6ca58b 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -61,7 +61,7 @@ struct udevice *pci_get_controller(struct udevice *dev) return dev; }
-pci_dev_t pci_get_bdf(struct udevice *dev) +pci_dev_t dm_pci_get_bdf(struct udevice *dev) { struct pci_child_platdata *pplat = dev_get_parent_platdata(dev); struct udevice *bus = dev->parent; @@ -225,7 +225,8 @@ int dm_pci_write_config(struct udevice *dev, int offset, unsigned long value,
for (bus = dev; device_is_on_pci_bus(bus);) bus = bus->parent; - return pci_bus_write_config(bus, pci_get_bdf(dev), offset, value, size); + return pci_bus_write_config(bus, dm_pci_get_bdf(dev), offset, value, + size); }
@@ -290,7 +291,7 @@ int dm_pci_read_config(struct udevice *dev, int offset, unsigned long *valuep,
for (bus = dev; device_is_on_pci_bus(bus);) bus = bus->parent; - return pci_bus_read_config(bus, pci_get_bdf(dev), offset, valuep, + return pci_bus_read_config(bus, dm_pci_get_bdf(dev), offset, valuep, size); }
@@ -403,7 +404,7 @@ int pci_auto_config_devices(struct udevice *bus) int ret;
debug("%s: device %s\n", __func__, dev->name); - ret = pciauto_config_device(hose, pci_get_bdf(dev)); + ret = pciauto_config_device(hose, dm_pci_get_bdf(dev)); if (ret < 0) return ret; max_bus = ret; diff --git a/drivers/pci/pci_compat.c b/drivers/pci/pci_compat.c index 712c48f..dd15eb1 100644 --- a/drivers/pci/pci_compat.c +++ b/drivers/pci/pci_compat.c @@ -34,5 +34,5 @@ pci_dev_t pci_find_devices(struct pci_device_id *ids, int index)
if (pci_find_device_id(ids, index, &dev)) return -1; - return pci_get_bdf(dev); + return dm_pci_get_bdf(dev); } diff --git a/drivers/usb/host/ehci-pci.c b/drivers/usb/host/ehci-pci.c index 0cb9fcc..d607088 100644 --- a/drivers/usb/host/ehci-pci.c +++ b/drivers/usb/host/ehci-pci.c @@ -94,7 +94,7 @@ static int ehci_pci_probe(struct udevice *dev) struct ehci_hccr *hccr; struct ehci_hcor *hcor;
- ehci_pci_common_init(pci_get_bdf(dev), &hccr, &hcor); + ehci_pci_common_init(dm_pci_get_bdf(dev), &hccr, &hcor);
return ehci_register(dev, hccr, hcor, NULL, 0, USB_INIT_HOST); } diff --git a/include/pci.h b/include/pci.h index 2adca85..5d45cdc 100644 --- a/include/pci.h +++ b/include/pci.h @@ -862,12 +862,12 @@ struct dm_pci_ops { #define pci_get_ops(dev) ((struct dm_pci_ops *)(dev)->driver->ops)
/** - * pci_get_bdf() - Get the BDF value for a device + * dm_pci_get_bdf() - Get the BDF value for a device * * @dev: Device to check * @return bus/device/function value (see PCI_BDF()) */ -pci_dev_t pci_get_bdf(struct udevice *dev); +pci_dev_t dm_pci_get_bdf(struct udevice *dev);
/** * pci_bind_bus_devices() - scan a PCI bus and bind devices
For consistency, we should use the dm_ prefix for all driver model functions. Update pci_bus_find_bdf() accordingly.
Changes in v2: None
common/cmd_pci.c | 2 +- drivers/pci/pci-uclass.c | 2 +- include/pci.h | 4 ++-- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index 4e0951f..8094d33 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -606,7 +606,7 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
#ifdef CONFIG_DM_PCI - ret = pci_bus_find_bdf(bdf, &dev); + ret = dm_pci_bus_find_bdf(bdf, &dev); if (ret) { printf("No such device\n"); return CMD_RET_FAILURE; diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index f6ca58b..2828055 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -128,7 +128,7 @@ int pci_bus_find_devfn(struct udevice *bus, pci_dev_t find_devfn, return -ENODEV; }
-int pci_bus_find_bdf(pci_dev_t bdf, struct udevice **devp) +int dm_pci_bus_find_bdf(pci_dev_t bdf, struct udevice **devp) { struct udevice *bus; int ret; diff --git a/include/pci.h b/include/pci.h index 5d45cdc..5861976 100644 --- a/include/pci.h +++ b/include/pci.h @@ -902,13 +902,13 @@ int pci_bind_bus_devices(struct udevice *bus); int pci_auto_config_devices(struct udevice *bus);
/** - * pci_bus_find_bdf() - Find a device given its PCI bus address + * dm_pci_bus_find_bdf() - Find a device given its PCI bus address * * @bdf: PCI device address: bus, device and function -see PCI_BDF() * @devp: Returns the device for this address, if found * @return 0 if OK, -ENODEV if not found */ -int pci_bus_find_bdf(pci_dev_t bdf, struct udevice **devp); +int dm_pci_bus_find_bdf(pci_dev_t bdf, struct udevice **devp);
/** * pci_bus_find_devfn() - Find a device on a bus
At present we are using legacy functions even in the auto-configuration code used by driver model. Add a new pci_auto.c version which uses the correct API.
Create a new pci_internal.h header to hold functions that are used within the PCI subsystem, but are not exported to other drivers.
Changes in v2: - Add a new pci_internal.h header file for internal PCI functions - Drop unnecessary comment at the top of pci_auto.c - Fix the indentation of the 'bar' for() loop
drivers/pci/Makefile | 6 +- drivers/pci/pci-uclass.c | 19 +-- drivers/pci/pci_auto.c | 386 +++++++++++++++++++++++++++++++++++++++++++++ drivers/pci/pci_auto_old.c | 45 ------ drivers/pci/pci_internal.h | 50 ++++++ include/pci.h | 2 +- 6 files changed, 445 insertions(+), 63 deletions(-) create mode 100644 drivers/pci/pci_auto.c create mode 100644 drivers/pci/pci_internal.h
diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 6b761b4..62232fc 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -6,15 +6,15 @@ #
ifneq ($(CONFIG_DM_PCI),) -obj-$(CONFIG_PCI) += pci-uclass.o +obj-$(CONFIG_PCI) += pci-uclass.o pci_auto.o obj-$(CONFIG_DM_PCI_COMPAT) += pci_compat.o obj-$(CONFIG_PCI_SANDBOX) += pci_sandbox.o obj-$(CONFIG_SANDBOX) += pci-emul-uclass.o obj-$(CONFIG_X86) += pci_x86.o else -obj-$(CONFIG_PCI) += pci.o +obj-$(CONFIG_PCI) += pci.o pci_auto_old.o endif -obj-$(CONFIG_PCI) += pci_auto_common.o pci_auto_old.o pci_common.o pci_rom.o +obj-$(CONFIG_PCI) += pci_auto_common.o pci_common.o pci_rom.o
obj-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o obj-$(CONFIG_PCI_INDIRECT_BRIDGE) += pci_indirect.o diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 2828055..792d9cb 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -17,6 +17,7 @@ #if defined(CONFIG_X86) && defined(CONFIG_HAVE_FSP) #include <asm/fsp/fsp_support.h> #endif +#include "pci_internal.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -404,7 +405,7 @@ int pci_auto_config_devices(struct udevice *bus) int ret;
debug("%s: device %s\n", __func__, dev->name); - ret = pciauto_config_device(hose, dm_pci_get_bdf(dev)); + ret = dm_pciauto_config_device(dev); if (ret < 0) return ret; max_bus = ret; @@ -419,26 +420,16 @@ int pci_auto_config_devices(struct udevice *bus) return sub_bus; }
-int dm_pci_hose_probe_bus(struct pci_controller *hose, pci_dev_t bdf) +int dm_pci_hose_probe_bus(struct udevice *bus) { - struct udevice *parent, *bus; int sub_bus; int ret;
debug("%s\n", __func__); - parent = hose->bus; - - /* Find the bus within the parent */ - ret = pci_bus_find_devfn(parent, PCI_MASK_BUS(bdf), &bus); - if (ret) { - debug("%s: Cannot find device %x on bus %s: %d\n", __func__, - bdf, parent->name, ret); - return ret; - }
sub_bus = pci_get_bus_max() + 1; debug("%s: bus = %d/%s\n", __func__, sub_bus, bus->name); - pciauto_prescan_setup_bridge(hose, bdf, sub_bus); + dm_pciauto_prescan_setup_bridge(bus, sub_bus);
ret = device_probe(bus); if (ret) { @@ -452,7 +443,7 @@ int dm_pci_hose_probe_bus(struct pci_controller *hose, pci_dev_t bdf) return -EPIPE; } sub_bus = pci_get_bus_max(); - pciauto_postscan_setup_bridge(hose, bdf, sub_bus); + dm_pciauto_postscan_setup_bridge(bus, sub_bus);
return sub_bus; } diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c new file mode 100644 index 0000000..842eafc --- /dev/null +++ b/drivers/pci/pci_auto.c @@ -0,0 +1,386 @@ +/* + * PCI autoconfiguration library + * + * Author: Matt Porter mporter@mvista.com + * + * Copyright 2000 MontaVista Software Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <pci.h> + +/* the user can define CONFIG_SYS_PCI_CACHE_LINE_SIZE to avoid problems */ +#ifndef CONFIG_SYS_PCI_CACHE_LINE_SIZE +#define CONFIG_SYS_PCI_CACHE_LINE_SIZE 8 +#endif + +void dm_pciauto_setup_device(struct udevice *dev, int bars_num, + struct pci_region *mem, + struct pci_region *prefetch, struct pci_region *io, + bool enum_only) +{ + u32 bar_response; + pci_size_t bar_size; + u16 cmdstat = 0; + int bar, bar_nr = 0; + u8 header_type; + int rom_addr; + pci_addr_t bar_value; + struct pci_region *bar_res; + int found_mem64 = 0; + u16 class; + + dm_pci_read_config16(dev, PCI_COMMAND, &cmdstat); + cmdstat = (cmdstat & ~(PCI_COMMAND_IO | PCI_COMMAND_MEMORY)) | + PCI_COMMAND_MASTER; + + for (bar = PCI_BASE_ADDRESS_0; + bar < PCI_BASE_ADDRESS_0 + (bars_num * 4); bar += 4) { + /* Tickle the BAR and get the response */ + if (!enum_only) + dm_pci_write_config32(dev, bar, 0xffffffff); + dm_pci_read_config32(dev, bar, &bar_response); + + /* If BAR is not implemented go to the next BAR */ + if (!bar_response) + continue; + + found_mem64 = 0; + + /* Check the BAR type and set our address mask */ + if (bar_response & PCI_BASE_ADDRESS_SPACE) { + bar_size = ((~(bar_response & PCI_BASE_ADDRESS_IO_MASK)) + & 0xffff) + 1; + if (!enum_only) + bar_res = io; + + debug("PCI Autoconfig: BAR %d, I/O, size=0x%llx, ", + bar_nr, (unsigned long long)bar_size); + } else { + if ((bar_response & PCI_BASE_ADDRESS_MEM_TYPE_MASK) == + PCI_BASE_ADDRESS_MEM_TYPE_64) { + u32 bar_response_upper; + u64 bar64; + + if (!enum_only) { + dm_pci_write_config32(dev, bar + 4, + 0xffffffff); + } + dm_pci_read_config32(dev, bar + 4, + &bar_response_upper); + + bar64 = ((u64)bar_response_upper << 32) | + bar_response; + + bar_size = ~(bar64 & PCI_BASE_ADDRESS_MEM_MASK) + + 1; + if (!enum_only) + found_mem64 = 1; + } else { + bar_size = (u32)(~(bar_response & + PCI_BASE_ADDRESS_MEM_MASK) + 1); + } + if (!enum_only) { + if (prefetch && (bar_response & + PCI_BASE_ADDRESS_MEM_PREFETCH)) { + bar_res = prefetch; + } else { + bar_res = mem; + } + } + + debug("PCI Autoconfig: BAR %d, %s, size=0x%llx, ", + bar_nr, bar_res == prefetch ? "Prf" : "Mem", + (unsigned long long)bar_size); + } + + if (!enum_only && pciauto_region_allocate(bar_res, bar_size, + &bar_value) == 0) { + /* Write it out and update our limit */ + dm_pci_write_config32(dev, bar, (u32)bar_value); + + if (found_mem64) { + bar += 4; +#ifdef CONFIG_SYS_PCI_64BIT + dm_pci_write_config32(dev, bar, + (u32)(bar_value >> 32)); +#else + /* + * If we are a 64-bit decoder then increment to + * the upper 32 bits of the bar and force it to + * locate in the lower 4GB of memory. + */ + dm_pci_write_config32(dev, bar, 0x00000000); +#endif + } + } + + cmdstat |= (bar_response & PCI_BASE_ADDRESS_SPACE) ? + PCI_COMMAND_IO : PCI_COMMAND_MEMORY; + + debug("\n"); + + bar_nr++; + } + + if (!enum_only) { + /* Configure the expansion ROM address */ + dm_pci_read_config8(dev, PCI_HEADER_TYPE, &header_type); + header_type &= 0x7f; + if (header_type != PCI_HEADER_TYPE_CARDBUS) { + rom_addr = (header_type == PCI_HEADER_TYPE_NORMAL) ? + PCI_ROM_ADDRESS : PCI_ROM_ADDRESS1; + dm_pci_write_config32(dev, rom_addr, 0xfffffffe); + dm_pci_read_config32(dev, rom_addr, &bar_response); + if (bar_response) { + bar_size = -(bar_response & ~1); + debug("PCI Autoconfig: ROM, size=%#x, ", + (unsigned int)bar_size); + if (pciauto_region_allocate(mem, bar_size, + &bar_value) == 0) { + dm_pci_write_config32(dev, rom_addr, + bar_value); + } + cmdstat |= PCI_COMMAND_MEMORY; + debug("\n"); + } + } + } + + /* PCI_COMMAND_IO must be set for VGA device */ + dm_pci_read_config16(dev, PCI_CLASS_DEVICE, &class); + if (class == PCI_CLASS_DISPLAY_VGA) + cmdstat |= PCI_COMMAND_IO; + + dm_pci_write_config16(dev, PCI_COMMAND, cmdstat); + dm_pci_write_config8(dev, PCI_CACHE_LINE_SIZE, + CONFIG_SYS_PCI_CACHE_LINE_SIZE); + dm_pci_write_config8(dev, PCI_LATENCY_TIMER, 0x80); +} + +void dm_pciauto_prescan_setup_bridge(struct udevice *dev, int sub_bus) +{ + struct pci_region *pci_mem; + struct pci_region *pci_prefetch; + struct pci_region *pci_io; + u16 cmdstat, prefechable_64; + /* The root controller has the region information */ + struct pci_controller *ctlr_hose = pci_bus_to_hose(0); + + pci_mem = ctlr_hose->pci_mem; + pci_prefetch = ctlr_hose->pci_prefetch; + pci_io = ctlr_hose->pci_io; + + dm_pci_read_config16(dev, PCI_COMMAND, &cmdstat); + dm_pci_read_config16(dev, PCI_PREF_MEMORY_BASE, &prefechable_64); + prefechable_64 &= PCI_PREF_RANGE_TYPE_MASK; + + /* Configure bus number registers */ + dm_pci_write_config8(dev, PCI_PRIMARY_BUS, + PCI_BUS(dm_pci_get_bdf(dev))); + dm_pci_write_config8(dev, PCI_SECONDARY_BUS, sub_bus); + dm_pci_write_config8(dev, PCI_SUBORDINATE_BUS, 0xff); + + if (pci_mem) { + /* Round memory allocator to 1MB boundary */ + pciauto_region_align(pci_mem, 0x100000); + + /* + * Set up memory and I/O filter limits, assume 32-bit + * I/O space + */ + dm_pci_write_config16(dev, PCI_MEMORY_BASE, + (pci_mem->bus_lower & 0xfff00000) >> 16); + + cmdstat |= PCI_COMMAND_MEMORY; + } + + if (pci_prefetch) { + /* Round memory allocator to 1MB boundary */ + pciauto_region_align(pci_prefetch, 0x100000); + + /* + * Set up memory and I/O filter limits, assume 32-bit + * I/O space + */ + dm_pci_write_config16(dev, PCI_PREF_MEMORY_BASE, + (pci_prefetch->bus_lower & 0xfff00000) >> 16); + if (prefechable_64 == PCI_PREF_RANGE_TYPE_64) +#ifdef CONFIG_SYS_PCI_64BIT + dm_pci_write_config32(dev, PCI_PREF_BASE_UPPER32, + pci_prefetch->bus_lower >> 32); +#else + dm_pci_write_config32(dev, PCI_PREF_BASE_UPPER32, 0x0); +#endif + + cmdstat |= PCI_COMMAND_MEMORY; + } else { + /* We don't support prefetchable memory for now, so disable */ + dm_pci_write_config16(dev, PCI_PREF_MEMORY_BASE, 0x1000); + dm_pci_write_config16(dev, PCI_PREF_MEMORY_LIMIT, 0x0); + if (prefechable_64 == PCI_PREF_RANGE_TYPE_64) { + dm_pci_write_config16(dev, PCI_PREF_BASE_UPPER32, 0x0); + dm_pci_write_config16(dev, PCI_PREF_LIMIT_UPPER32, 0x0); + } + } + + if (pci_io) { + /* Round I/O allocator to 4KB boundary */ + pciauto_region_align(pci_io, 0x1000); + + dm_pci_write_config8(dev, PCI_IO_BASE, + (pci_io->bus_lower & 0x0000f000) >> 8); + dm_pci_write_config16(dev, PCI_IO_BASE_UPPER16, + (pci_io->bus_lower & 0xffff0000) >> 16); + + cmdstat |= PCI_COMMAND_IO; + } + + /* Enable memory and I/O accesses, enable bus master */ + dm_pci_write_config16(dev, PCI_COMMAND, cmdstat | PCI_COMMAND_MASTER); +} + +void dm_pciauto_postscan_setup_bridge(struct udevice *dev, int sub_bus) +{ + struct pci_region *pci_mem; + struct pci_region *pci_prefetch; + struct pci_region *pci_io; + + /* The root controller has the region information */ + struct pci_controller *ctlr_hose = pci_bus_to_hose(0); + + pci_mem = ctlr_hose->pci_mem; + pci_prefetch = ctlr_hose->pci_prefetch; + pci_io = ctlr_hose->pci_io; + + /* Configure bus number registers */ + dm_pci_write_config8(dev, PCI_SUBORDINATE_BUS, sub_bus); + + if (pci_mem) { + /* Round memory allocator to 1MB boundary */ + pciauto_region_align(pci_mem, 0x100000); + + dm_pci_write_config16(dev, PCI_MEMORY_LIMIT, + (pci_mem->bus_lower - 1) >> 16); + } + + if (pci_prefetch) { + u16 prefechable_64; + + dm_pci_read_config16(dev, PCI_PREF_MEMORY_LIMIT, + &prefechable_64); + prefechable_64 &= PCI_PREF_RANGE_TYPE_MASK; + + /* Round memory allocator to 1MB boundary */ + pciauto_region_align(pci_prefetch, 0x100000); + + dm_pci_write_config16(dev, PCI_PREF_MEMORY_LIMIT, + (pci_prefetch->bus_lower - 1) >> 16); + if (prefechable_64 == PCI_PREF_RANGE_TYPE_64) +#ifdef CONFIG_SYS_PCI_64BIT + dm_pci_write_config32(dev, PCI_PREF_LIMIT_UPPER32, + (pci_prefetch->bus_lower - 1) >> 32); +#else + dm_pci_write_config32(dev, PCI_PREF_LIMIT_UPPER32, 0x0); +#endif + } + + if (pci_io) { + /* Round I/O allocator to 4KB boundary */ + pciauto_region_align(pci_io, 0x1000); + + dm_pci_write_config8(dev, PCI_IO_LIMIT, + ((pci_io->bus_lower - 1) & 0x0000f000) >> 8); + dm_pci_write_config16(dev, PCI_IO_LIMIT_UPPER16, + ((pci_io->bus_lower - 1) & 0xffff0000) >> 16); + } +} + +/* + * HJF: Changed this to return int. I think this is required + * to get the correct result when scanning bridges + */ +int dm_pciauto_config_device(struct udevice *dev) +{ + struct pci_region *pci_mem; + struct pci_region *pci_prefetch; + struct pci_region *pci_io; + unsigned int sub_bus = PCI_BUS(dm_pci_get_bdf(dev)); + unsigned short class; + bool enum_only = false; + int n; + +#ifdef CONFIG_PCI_ENUM_ONLY + enum_only = true; +#endif + /* The root controller has the region information */ + struct pci_controller *ctlr_hose = pci_bus_to_hose(0); + + pci_mem = ctlr_hose->pci_mem; + pci_prefetch = ctlr_hose->pci_prefetch; + pci_io = ctlr_hose->pci_io; + + dm_pci_read_config16(dev, PCI_CLASS_DEVICE, &class); + + switch (class) { + case PCI_CLASS_BRIDGE_PCI: + debug("PCI Autoconfig: Found P2P bridge, device %d\n", + PCI_DEV(dm_pci_get_bdf(dev))); + + dm_pciauto_setup_device(dev, 2, pci_mem, pci_prefetch, pci_io, + enum_only); + + n = dm_pci_hose_probe_bus(dev); + if (n < 0) + return n; + sub_bus = (unsigned int)n; + break; + + case PCI_CLASS_BRIDGE_CARDBUS: + /* + * just do a minimal setup of the bridge, + * let the OS take care of the rest + */ + dm_pciauto_setup_device(dev, 0, pci_mem, pci_prefetch, pci_io, + enum_only); + + debug("PCI Autoconfig: Found P2CardBus bridge, device %d\n", + PCI_DEV(dm_pci_get_bdf(dev))); + + break; + +#if defined(CONFIG_PCIAUTO_SKIP_HOST_BRIDGE) + case PCI_CLASS_BRIDGE_OTHER: + debug("PCI Autoconfig: Skipping bridge device %d\n", + PCI_DEV(dm_pci_get_bdf(dev))); + break; +#endif +#if defined(CONFIG_MPC834x) && !defined(CONFIG_VME8349) + case PCI_CLASS_BRIDGE_OTHER: + /* + * The host/PCI bridge 1 seems broken in 8349 - it presents + * itself as 'PCI_CLASS_BRIDGE_OTHER' and appears as an _agent_ + * device claiming resources io/mem/irq.. we only allow for + * the PIMMR window to be allocated (BAR0 - 1MB size) + */ + debug("PCI Autoconfig: Broken bridge found, only minimal config\n"); + dm_pciauto_setup_device(dev, 0, hose->pci_mem, + hose->pci_prefetch, hose->pci_io, + enum_only); + break; +#endif + + case PCI_CLASS_PROCESSOR_POWERPC: /* an agent or end-point */ + debug("PCI AutoConfig: Found PowerPC device\n"); + + default: + dm_pciauto_setup_device(dev, 6, pci_mem, pci_prefetch, pci_io, + enum_only); + break; + } + + return sub_bus; +} diff --git a/drivers/pci/pci_auto_old.c b/drivers/pci/pci_auto_old.c index 1ff88b1..9126f78 100644 --- a/drivers/pci/pci_auto_old.c +++ b/drivers/pci/pci_auto_old.c @@ -180,18 +180,9 @@ void pciauto_prescan_setup_bridge(struct pci_controller *hose, struct pci_region *pci_io; u16 cmdstat, prefechable_64;
-#ifdef CONFIG_DM_PCI - /* The root controller has the region information */ - struct pci_controller *ctlr_hose = pci_bus_to_hose(0); - - pci_mem = ctlr_hose->pci_mem; - pci_prefetch = ctlr_hose->pci_prefetch; - pci_io = ctlr_hose->pci_io; -#else pci_mem = hose->pci_mem; pci_prefetch = hose->pci_prefetch; pci_io = hose->pci_io; -#endif
pci_hose_read_config_word(hose, dev, PCI_COMMAND, &cmdstat); pci_hose_read_config_word(hose, dev, PCI_PREF_MEMORY_BASE, @@ -199,15 +190,10 @@ void pciauto_prescan_setup_bridge(struct pci_controller *hose, prefechable_64 &= PCI_PREF_RANGE_TYPE_MASK;
/* Configure bus number registers */ -#ifdef CONFIG_DM_PCI - pci_hose_write_config_byte(hose, dev, PCI_PRIMARY_BUS, PCI_BUS(dev)); - pci_hose_write_config_byte(hose, dev, PCI_SECONDARY_BUS, sub_bus); -#else pci_hose_write_config_byte(hose, dev, PCI_PRIMARY_BUS, PCI_BUS(dev) - hose->first_busno); pci_hose_write_config_byte(hose, dev, PCI_SECONDARY_BUS, sub_bus - hose->first_busno); -#endif pci_hose_write_config_byte(hose, dev, PCI_SUBORDINATE_BUS, 0xff);
if (pci_mem) { @@ -274,26 +260,13 @@ void pciauto_postscan_setup_bridge(struct pci_controller *hose, struct pci_region *pci_prefetch; struct pci_region *pci_io;
/* Configure bus number registers */ -#ifdef CONFIG_DM_PCI - pci_hose_write_config_byte(hose, dev, PCI_SUBORDINATE_BUS, sub_bus); -#else pci_hose_write_config_byte(hose, dev, PCI_SUBORDINATE_BUS, sub_bus - hose->first_busno); -#endif
if (pci_mem) { /* Round memory allocator to 1MB boundary */ @@ -353,18 +326,9 @@ int pciauto_config_device(struct pci_controller *hose, pci_dev_t dev) unsigned short class; int n;
pci_hose_read_config_word(hose, dev, PCI_CLASS_DEVICE, &class);
@@ -376,12 +340,6 @@ int pciauto_config_device(struct pci_controller *hose, pci_dev_t dev) pciauto_setup_device(hose, dev, 2, pci_mem, pci_prefetch, pci_io);
-#ifdef CONFIG_DM_PCI - n = dm_pci_hose_probe_bus(hose, dev); - if (n < 0) - return n; - sub_bus = (unsigned int)n; -#else /* Passing in current_busno allows for sibling P2P bridges */ hose->current_busno++; pciauto_prescan_setup_bridge(hose, dev, hose->current_busno); @@ -396,7 +354,6 @@ int pciauto_config_device(struct pci_controller *hose, pci_dev_t dev) pciauto_postscan_setup_bridge(hose, dev, sub_bus);
sub_bus = hose->current_busno; -#endif break;
case PCI_CLASS_BRIDGE_CARDBUS: @@ -410,9 +367,7 @@ int pciauto_config_device(struct pci_controller *hose, pci_dev_t dev) debug("PCI Autoconfig: Found P2CardBus bridge, device %d\n", PCI_DEV(dev));
-#ifndef CONFIG_DM_PCI hose->current_busno++; -#endif break;
#if defined(CONFIG_PCIAUTO_SKIP_HOST_BRIDGE) diff --git a/drivers/pci/pci_internal.h b/drivers/pci/pci_internal.h new file mode 100644 index 0000000..0867575 --- /dev/null +++ b/drivers/pci/pci_internal.h @@ -0,0 +1,50 @@ +/* + * Internal PCI functions, not exported outside drivers/pci + * + * Copyright (c) 2015 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __pci_internal_h +#define __pci_internal_h + +/** + * dm_pciauto_prescan_setup_bridge() - Set up a bridge for scanning + * + * This gets a bridge ready so that its downstream devices can be scanned. + * It sets up the bus number and memory range registers. Once the scan is + * completed, dm_pciauto_postscan_setup_bridge() should be called. + * + * @dev: Bridge device to be scanned + * @sub_bus: Bus number of the 'other side' of the bridge + */ +void dm_pciauto_prescan_setup_bridge(struct udevice *dev, int sub_bus); + +/** + * dm_pciauto_postscan_setup_bridge() - Finish set up of a bridge after scanning + * + * This should be called after a bus scan is complete. It adjusts the memory + * ranges to fit with the devices actually found on the other side (downstream) + * of the bridge. + * + * @dev: Bridge device that was scanned + * @sub_bus: Bus number of the 'other side' of the bridge + */ +void dm_pciauto_postscan_setup_bridge(struct udevice *dev, int sub_bus); + +/** + * dm_pciauto_config_device() - Configure a PCI device ready for use + * + * If the device is a bridge, downstream devices will be probed. + * + * @dev: Device to configure + * @return the maximum PCI bus number found by this device. If there are no + * bridges, this just returns the device's bus number. If the device is a + * bridge then it will return a larger number, depending on the devices on + * that bridge. On error, returns a -ve error number. + */ +int dm_pciauto_config_device(struct udevice *dev); + +#endif diff --git a/include/pci.h b/include/pci.h index 5861976..182290c 100644 --- a/include/pci.h +++ b/include/pci.h @@ -995,7 +995,7 @@ int pci_find_device_id(struct pci_device_id *ids, int index, * @bdf: PCI bus address to scan (PCI_BUS(bdf) is the bus number) * @return 0 if OK, -ve on error */ -int dm_pci_hose_probe_bus(struct pci_controller *hose, pci_dev_t bdf); +int dm_pci_hose_probe_bus(struct udevice *bus);
/** * pci_bus_read_config() - Read a configuration value from a device
Changes in v2:
Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
Add a function which scans the driver model device information rather than scanning the PCI bus again.
Changes in v2: None
drivers/pci/pci-uclass.c | 39 +++++++++++++++++++++++++++++++++++++++ include/pci.h | 12 ++++++++++++ 2 files changed, 51 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 792d9cb..af6de51 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -195,6 +195,45 @@ int pci_find_device_id(struct pci_device_id *ids, int index, return -ENODEV; }
+static int dm_pci_bus_find_device(struct udevice *bus, unsigned int vendor, + unsigned int device, int *indexp, + struct udevice **devp) +{ + struct pci_child_platdata *pplat; + struct udevice *dev; + + for (device_find_first_child(bus, &dev); + dev; + device_find_next_child(&dev)) { + pplat = dev_get_parent_platdata(dev); + if (pplat->vendor == vendor && pplat->device == device) { + if (!(*indexp)--) { + *devp = dev; + return 0; + } + } + } + + return -ENODEV; +} + +int dm_pci_find_device(unsigned int vendor, unsigned int device, int index, + struct udevice **devp) +{ + struct udevice *bus; + + /* Scan all known buses */ + for (uclass_first_device(UCLASS_PCI, &bus); + bus; + uclass_next_device(&bus)) { + if (!dm_pci_bus_find_device(bus, vendor, device, &index, devp)) + return device_probe(*devp); + } + *devp = NULL; + + return -ENODEV; +} + int pci_bus_write_config(struct udevice *bus, pci_dev_t bdf, int offset, unsigned long value, enum pci_size_t size) { diff --git a/include/pci.h b/include/pci.h index 182290c..347dd0a 100644 --- a/include/pci.h +++ b/include/pci.h @@ -1167,6 +1167,18 @@ int pci_get_regions(struct udevice *dev, struct pci_region **iop, struct pci_region **memp, struct pci_region **prefp);
/** + * dm_pci_find_device() - find a device by vendor/device ID + * + * @vendor: Vendor ID + * @device: Device ID + * @index: 0 to find the first match, 1 for second, etc. + * @devp: Returns pointer to the device, if found + * @return 0 if found, -ve on error + */ +int dm_pci_find_device(unsigned int vendor, unsigned int device, int index, + struct udevice **devp); + +/** * struct dm_pci_emul_ops - PCI device emulator operations */ struct dm_pci_emul_ops {
Changes in v2: None
Adjust the SCSI command to use driver model for its PCI interface.
Changes in v2: - Use dm_pci_get_bdf()
common/cmd_scsi.c | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/common/cmd_scsi.c b/common/cmd_scsi.c index 31c4319..8695408 100644 --- a/common/cmd_scsi.c +++ b/common/cmd_scsi.c @@ -184,7 +184,7 @@ int scsi_get_disk_count(void) #if defined(CONFIG_PCI) && !defined(CONFIG_SCSI_AHCI_PLAT) void scsi_init(void) { - int busdevfunc; + int busdevfunc = -1; int i; /* * Find a device from the list, this driver will support a single @@ -192,9 +192,21 @@ void scsi_init(void) */ for (i = 0; i < ARRAY_SIZE(scsi_device_list); i++) { /* get PCI Device ID */ +#ifdef CONFIG_DM_PCI + struct udevice *dev; + int ret; + + ret = dm_pci_find_device(scsi_device_list[i].vendor, + scsi_device_list[i].device, 0, &dev); + if (!ret) { + busdevfunc = dm_pci_get_bdf(dev); + break; + } +#else busdevfunc = pci_find_device(scsi_device_list[i].vendor, scsi_device_list[i].device, 0); +#endif if (busdevfunc != -1) break; }
Changes in v2:
Changes in v2: None
drivers/pci/pci-uclass.c | 20 ++++++++++++++++++++ include/pci.h | 10 ++++++++++ 2 files changed, 30 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index af6de51..dea0cb6 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -234,6 +234,26 @@ int dm_pci_find_device(unsigned int vendor, unsigned int device, int index, return -ENODEV; }
+int dm_pci_find_class(uint find_class, int index, struct udevice **devp) +{ + struct udevice *dev; + + /* Scan all known buses */ + for (pci_find_first_device(&dev); + dev; + pci_find_next_device(&dev)) { + struct pci_child_platdata *pplat = dev_get_parent_platdata(dev); + + if (pplat->class == find_class && !index--) { + *devp = dev; + return device_probe(*devp); + } + } + *devp = NULL; + + return -ENODEV; +} + int pci_bus_write_config(struct udevice *bus, pci_dev_t bdf, int offset, unsigned long value, enum pci_size_t size) { diff --git a/include/pci.h b/include/pci.h index 347dd0a..443af83 100644 --- a/include/pci.h +++ b/include/pci.h @@ -1179,6 +1179,16 @@ int dm_pci_find_device(unsigned int vendor, unsigned int device, int index, struct udevice **devp);
/** + * dm_pci_find_class() - find a device by class + * + * @find_class: 3-byte (24-bit) class value to find + * @index: 0 to find the first match, 1 for second, etc. + * @devp: Returns pointer to the device, if found + * @return 0 if found, -ve on error + */ +int dm_pci_find_class(uint find_class, int index, struct udevice **devp); + +/** * struct dm_pci_emul_ops - PCI device emulator operations */ struct dm_pci_emul_ops {
Changes in v2: None
Add a driver-model function for reading the PCI BAR from a device.
Changes in v2: None
drivers/pci/pci-uclass.c | 13 +++++++++++++ include/pci.h | 9 +++++++++ 2 files changed, 22 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index dea0cb6..7a886f2 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -1055,6 +1055,19 @@ int pci_get_regions(struct udevice *dev, struct pci_region **iop, return (*iop != NULL) + (*memp != NULL) + (*prefp != NULL); }
+u32 dm_pci_read_bar32(struct udevice *dev, int barnum) +{ + u32 addr; + int bar; + + bar = PCI_BASE_ADDRESS_0 + barnum * 4; + dm_pci_read_config32(dev, bar, &addr); + if (addr & PCI_BASE_ADDRESS_SPACE_IO) + return addr & PCI_BASE_ADDRESS_IO_MASK; + else + return addr & PCI_BASE_ADDRESS_MEM_MASK; +} + UCLASS_DRIVER(pci) = { .id = UCLASS_PCI, .name = "pci", diff --git a/include/pci.h b/include/pci.h index 443af83..dcbe978 100644 --- a/include/pci.h +++ b/include/pci.h @@ -1167,6 +1167,15 @@ int pci_get_regions(struct udevice *dev, struct pci_region **iop, struct pci_region **memp, struct pci_region **prefp);
/** + * dm_pci_read_bar32() - read a base address register from a device + * + * @dev: Device to check + * @barnum: Bar number to read (numbered from 0) + * @return: value of BAR + */ +u32 dm_pci_read_bar32(struct udevice *dev, int barnum); + +/** * dm_pci_find_device() - find a device by vendor/device ID * * @vendor: Vendor ID
Use the driver model version of the function to find the BAR. This updates the fdtdec function, of which ns16550 is the only user.
The fdtdec_get_pci_bdf() function is dropped for several reasons: - with driver model we should use 'struct udevice *' rather than passing the device tree offset explicitly - there are no other users in the tree - the function parses for information which is already available in the PCI device structure (specifically struct pci_child_platdata which is available at dev_get_parent_platdata(dev)
Changes in v2: - Put this code behind CONFIG_DM_PCI to avoid PowerPC build errors
drivers/serial/ns16550.c | 5 ++--- include/fdtdec.h | 23 +++---------------- lib/fdtdec.c | 57 +++++------------------------------------------- 3 files changed, 10 insertions(+), 75 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index d5bcbc3..28259e6 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -368,7 +368,7 @@ int ns16550_serial_ofdata_to_platdata(struct udevice *dev)
/* try Processor Local Bus device first */ addr = dev_get_addr(dev); -#ifdef CONFIG_PCI +#if defined(CONFIG_PCI) && defined(CONFIG_DM_PCI) if (addr == FDT_ADDR_T_NONE) { /* then try pci device */ struct fdt_pci_addr pci_addr; @@ -389,8 +389,7 @@ int ns16550_serial_ofdata_to_platdata(struct udevice *dev) return ret; }
- ret = fdtdec_get_pci_bar32(gd->fdt_blob, dev->of_offset, - &pci_addr, &bar); + ret = fdtdec_get_pci_bar32(dev, &pci_addr, &bar); if (ret) return ret;
diff --git a/include/fdtdec.h b/include/fdtdec.h index 7fe657d..018d151 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -444,32 +444,15 @@ int fdtdec_get_pci_vendev(const void *blob, int node,
/** * Look at the pci address of a device node that represents a PCI device - * and parse the bus, device and function number from it. For some cases - * like the bus number encoded in reg property is not correct after pci - * enumeration, this function looks through the node's compatible strings - * to get these numbers extracted instead. - * - * @param blob FDT blob - * @param node node to examine - * @param addr pci address in the form of fdt_pci_addr - * @param bdf returns bus, device, function triplet - * @return 0 if ok, negative on error - */ -int fdtdec_get_pci_bdf(const void *blob, int node, - struct fdt_pci_addr *addr, pci_dev_t *bdf); - -/** - * Look at the pci address of a device node that represents a PCI device * and return base address of the pci device's registers. * - * @param blob FDT blob - * @param node node to examine + * @param dev device to examine * @param addr pci address in the form of fdt_pci_addr * @param bar returns base address of the pci device's registers * @return 0 if ok, negative on error */ -int fdtdec_get_pci_bar32(const void *blob, int node, - struct fdt_pci_addr *addr, u32 *bar); +int fdtdec_get_pci_bar32(struct udevice *dev, struct fdt_pci_addr *addr, + u32 *bar);
/** * Look up a 32-bit integer property in a node and return it. The property diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 82d0090..f6f23ae 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -5,6 +5,7 @@
#ifndef USE_HOSTCC #include <common.h> +#include <dm.h> #include <errno.h> #include <serial.h> #include <libfdt.h> @@ -189,7 +190,7 @@ fdt_addr_t fdtdec_get_addr(const void *blob, int node, return fdtdec_get_addr_size(blob, node, prop_name, NULL); }
-#ifdef CONFIG_PCI +#if defined(CONFIG_PCI) && defined(CONFIG_DM_PCI) int fdtdec_get_pci_addr(const void *blob, int node, enum fdt_pci_space type, const char *prop_name, struct fdt_pci_addr *addr) { @@ -282,58 +283,10 @@ int fdtdec_get_pci_vendev(const void *blob, int node, u16 *vendor, u16 *device) return -ENOENT; }
-int fdtdec_get_pci_bdf(const void *blob, int node, - struct fdt_pci_addr *addr, pci_dev_t *bdf) +int fdtdec_get_pci_bar32(struct udevice *dev, struct fdt_pci_addr *addr, + u32 *bar) { - u16 dt_vendor, dt_device, vendor, device; - int ret; - - /* get vendor id & device id from the compatible string */ - ret = fdtdec_get_pci_vendev(blob, node, &dt_vendor, &dt_device); - if (ret) - return ret; - - /* extract the bdf from fdt_pci_addr */ - *bdf = addr->phys_hi & 0xffff00; - - /* read vendor id & device id based on bdf */ - pci_read_config_word(*bdf, PCI_VENDOR_ID, &vendor); - pci_read_config_word(*bdf, PCI_DEVICE_ID, &device); - - /* - * Note there are two places in the device tree to fully describe - * a pci device: one is via compatible string with a format of - * "pciVVVV,DDDD" and the other one is the bdf numbers encoded in - * the device node's reg address property. We read the vendor id - * and device id based on bdf and compare the values with the - * "VVVV,DDDD". If they are the same, then we are good to use bdf - * to read device's bar. But if they are different, we have to rely - * on the vendor id and device id extracted from the compatible - * string and locate the real bdf by pci_find_device(). This is - * because normally we may only know device's device number and - * function number when writing device tree. The bus number is - * dynamically assigned during the pci enumeration process. - */ - if ((dt_vendor != vendor) || (dt_device != device)) { - *bdf = pci_find_device(dt_vendor, dt_device, 0); - if (*bdf == -1) - return -ENODEV; - } - - return 0; -} - -int fdtdec_get_pci_bar32(const void *blob, int node, - struct fdt_pci_addr *addr, u32 *bar) -{ - pci_dev_t bdf; int barnum; - int ret; - - /* get pci devices's bdf */ - ret = fdtdec_get_pci_bdf(blob, node, addr, &bdf); - if (ret) - return ret;
/* extract the bar number from fdt_pci_addr */ barnum = addr->phys_hi & 0xff; @@ -341,7 +294,7 @@ int fdtdec_get_pci_bar32(const void *blob, int node, return -EINVAL;
barnum = (barnum - PCI_BASE_ADDRESS_0) / 4; - *bar = pci_read_bar32(pci_bus_to_hose(PCI_BUS(bdf)), bdf, barnum); + *bar = dm_pci_read_bar32(dev, barnum);
return 0; }
Changes in v2:
&pci_addr, &bar);
- Look at the pci address of a device node that represents a PCI device
- and parse the bus, device and function number from it. For some cases
- like the bus number encoded in reg property is not correct after pci
- enumeration, this function looks through the node's compatible strings
- to get these numbers extracted instead.
- @param blob FDT blob
- @param node node to examine
- @param addr pci address in the form of fdt_pci_addr
- @param bdf returns bus, device, function triplet
- @return 0 if ok, negative on error
- and return base address of the pci device's registers.
- @param dev device to examine
- @param bar returns base address of the pci device's registers
u32 *bar);
- Look up a 32-bit integer property in a node and return it. The property
u32 *bar)
int ret;
if (ret)
return ret;
if (*bdf == -1)
return -ENODEV;
int ret;
if (ret)
return ret; /* extract the bar number from fdt_pci_addr */ barnum = addr->phys_hi & 0xff;
*bar = dm_pci_read_bar32(dev, barnum); return 0;
With the following two patches applied to fix the PCI UART broken issue first, http://patchwork.ozlabs.org/patch/553319/ http://patchwork.ozlabs.org/patch/553385/ Tested-by: Bin Meng bmeng.cn@gmail.com
Use the driver-model PCI functions here where possible. For now we have to search for the device with pci_bus_find_bdf() but at some point we can put this in a proper driver and avoid this.
Changes in v2: - Use pci_bus_find_bdf()
arch/x86/cpu/ivybridge/bd82x6x.c | 6 ++++-- arch/x86/cpu/ivybridge/gma.c | 15 +++++++-------- arch/x86/include/asm/arch-ivybridge/bd82x6x.h | 3 +-- 3 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/arch/x86/cpu/ivybridge/bd82x6x.c b/arch/x86/cpu/ivybridge/bd82x6x.c index 3e7a907..434dfd6 100644 --- a/arch/x86/cpu/ivybridge/bd82x6x.c +++ b/arch/x86/cpu/ivybridge/bd82x6x.c @@ -86,8 +86,10 @@ static int bd82x6x_probe(struct udevice *dev) debug("%s: Cannot find GMA node\n", __func__); return -EINVAL; } - ret = gma_func0_init(PCH_VIDEO_DEV, pci_bus_to_hose(0), blob, - gma_node); + ret = dm_pci_bus_find_bdf(PCH_VIDEO_DEV, &dev); + if (ret) + return ret; + ret = gma_func0_init(dev, blob, gma_node); if (ret) return ret;
diff --git a/arch/x86/cpu/ivybridge/gma.c b/arch/x86/cpu/ivybridge/gma.c index 89d4a5e..695578b 100644 --- a/arch/x86/cpu/ivybridge/gma.c +++ b/arch/x86/cpu/ivybridge/gma.c @@ -728,8 +728,7 @@ static int int15_handler(void) return res; }
-int gma_func0_init(pci_dev_t dev, struct pci_controller *hose, - const void *blob, int node) +int gma_func0_init(struct udevice *dev, const void *blob, int node) { #ifdef CONFIG_VIDEO ulong start; @@ -740,16 +739,16 @@ int gma_func0_init(pci_dev_t dev, struct pci_controller *hose, int ret;
/* IGD needs to be Bus Master */ - reg32 = x86_pci_read_config32(dev, PCI_COMMAND); + dm_pci_read_config32(dev, PCI_COMMAND, ®32); reg32 |= PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY | PCI_COMMAND_IO; - x86_pci_write_config32(dev, PCI_COMMAND, reg32); + dm_pci_write_config32(dev, PCI_COMMAND, reg32);
/* Use write-combining for the graphics memory, 256MB */ - base = pci_read_bar32(hose, dev, 2); + base = dm_pci_read_bar32(dev, 2); mtrr_add_request(MTRR_TYPE_WRCOMB, base, 256 << 20); mtrr_commit(true);
- gtt_bar = (void *)pci_read_bar32(pci_bus_to_hose(0), dev, 0); + gtt_bar = (void *)dm_pci_read_bar32(dev, 0); debug("GT bar %p\n", gtt_bar); ret = gma_pm_init_pre_vbios(gtt_bar); if (ret) @@ -757,8 +756,8 @@ int gma_func0_init(pci_dev_t dev, struct pci_controller *hose,
#ifdef CONFIG_VIDEO start = get_timer(0); - ret = pci_run_vga_bios(dev, int15_handler, PCI_ROM_USE_NATIVE | - PCI_ROM_ALLOW_FALLBACK); + ret = pci_run_vga_bios(dm_pci_get_bdf(dev), int15_handler, + PCI_ROM_USE_NATIVE | PCI_ROM_ALLOW_FALLBACK); debug("BIOS ran in %lums\n", get_timer(start)); #endif /* Post VBIOS init */ diff --git a/arch/x86/include/asm/arch-ivybridge/bd82x6x.h b/arch/x86/include/asm/arch-ivybridge/bd82x6x.h index 7786493..fcdf6e2 100644 --- a/arch/x86/include/asm/arch-ivybridge/bd82x6x.h +++ b/arch/x86/include/asm/arch-ivybridge/bd82x6x.h @@ -12,8 +12,7 @@ void bd82x6x_sata_enable(pci_dev_t dev, const void *blob, int node); void bd82x6x_pci_init(pci_dev_t dev); void bd82x6x_usb_ehci_init(pci_dev_t dev); void bd82x6x_usb_xhci_init(pci_dev_t dev); -int gma_func0_init(pci_dev_t dev, struct pci_controller *hose, - const void *blob, int node); +int gma_func0_init(struct udevice *dev, const void *blob, int node); int bd82x6x_init(void);
Changes in v2:
gma_node);
if (ret)
return ret;
dm_pci_write_config32(dev, PCI_COMMAND, reg32); /* Use write-combining for the graphics memory, 256MB */
Adjust this code to use driver model for devices where possible. Since existing users have not been converted the old code must remain.
Changes in v2: - Drop non-DM PCI code - Use dm_pci_get_bdf() - Use pci_bus_find_bdf()
arch/x86/lib/bios_interrupts.c | 36 +++++++++++++++++++++++------------- 1 file changed, 23 insertions(+), 13 deletions(-)
diff --git a/arch/x86/lib/bios_interrupts.c b/arch/x86/lib/bios_interrupts.c index 47d9f59..e8ca6e6 100644 --- a/arch/x86/lib/bios_interrupts.c +++ b/arch/x86/lib/bios_interrupts.c @@ -105,13 +105,15 @@ int int1a_handler(void) unsigned short func = (unsigned short)M.x86.R_EAX; int retval = 1; unsigned short devid, vendorid, devfn; + struct udevice *dev; /* Use short to get rid of gabage in upper half of 32-bit register */ short devindex; unsigned char bus; - pci_dev_t dev; + pci_dev_t bdf; u32 dword; u16 word; u8 byte, reg; + int ret;
switch (func) { case 0xb101: /* PCIBIOS Check */ @@ -131,17 +133,20 @@ int int1a_handler(void) devid = M.x86.R_ECX; vendorid = M.x86.R_EDX; devindex = M.x86.R_ESI; - dev = pci_find_device(vendorid, devid, devindex); - if (dev != -1) { + bdf = -1; + ret = dm_pci_find_device(vendorid, devid, devindex, &dev); + if (!ret) { unsigned short busdevfn; + + bdf = dm_pci_get_bdf(dev); M.x86.R_EAX &= 0xffff00ff; /* Clear AH */ M.x86.R_EAX |= PCIBIOS_SUCCESSFUL; /* * busnum is an unsigned char; * devfn is an int, so we mask it off. */ - busdevfn = (PCI_BUS(dev) << 8) | PCI_DEV(dev) << 3 | - PCI_FUNC(dev); + busdevfn = (PCI_BUS(bdf) << 8) | PCI_DEV(bdf) << 3 | + PCI_FUNC(bdf); debug("0x%x: return 0x%x\n", func, busdevfn); M.x86.R_EBX = busdevfn; retval = 1; @@ -160,35 +165,40 @@ int int1a_handler(void) devfn = M.x86.R_EBX & 0xff; bus = M.x86.R_EBX >> 8; reg = M.x86.R_EDI; - dev = PCI_BDF(bus, devfn >> 3, devfn & 7); + bdf = PCI_BDF(bus, devfn >> 3, devfn & 7); + + ret = dm_pci_bus_find_bdf(bdf, &dev); + if (ret) { + debug("%s: Device %x not found\n", __func__, bdf); + break; + }
switch (func) { case 0xb108: /* Read Config Byte */ - byte = x86_pci_read_config8(dev, reg); + dm_pci_read_config8(dev, reg, &byte); M.x86.R_ECX = byte; break; case 0xb109: /* Read Config Word */ - word = x86_pci_read_config16(dev, reg); + dm_pci_read_config16(dev, reg, &word); M.x86.R_ECX = word; break; case 0xb10a: /* Read Config Dword */ - dword = x86_pci_read_config32(dev, reg); + dm_pci_read_config32(dev, reg, &dword); M.x86.R_ECX = dword; break; case 0xb10b: /* Write Config Byte */ byte = M.x86.R_ECX; - x86_pci_write_config8(dev, reg, byte); + dm_pci_write_config8(dev, reg, byte); break; case 0xb10c: /* Write Config Word */ word = M.x86.R_ECX; - x86_pci_write_config16(dev, reg, word); + dm_pci_write_config16(dev, reg, word); break; case 0xb10d: /* Write Config Dword */ dword = M.x86.R_ECX; - x86_pci_write_config32(dev, reg, dword); + dm_pci_write_config32(dev, reg, dword); break; } - #ifdef CONFIG_REALMODE_DEBUG debug("0x%x: bus %d devfn 0x%x reg 0x%x val 0x%x\n", func, bus, devfn, reg, M.x86.R_ECX);
Changes in v2:
pci_dev_t dev;
int ret; switch (func) { case 0xb101: /* PCIBIOS Check */
if (dev != -1) {
bdf = -1;
PCI_FUNC(dev);
if (ret) {
break;
} switch (func) { case 0xb108: /* Read Config Byte */
#ifdef CONFIG_REALMODE_DEBUG debug("0x%x: bus %d devfn 0x%x reg 0x%x val 0x%x\n", func, bus, devfn, reg, M.x86.R_ECX); --
Adjust these files to use the driver-model PCI API instead of the legacy functions.
Changes in v2: - Rename pci_run_vga_bios() to dm_pci_run_vga_bios() - Require driver model with pci_rom.c - Use dev_get_parent_platdata() instead of re-reading values from the device
arch/x86/cpu/ivybridge/gma.c | 4 ++-- drivers/pci/Makefile | 3 ++- drivers/pci/pci_rom.c | 51 +++++++++++++++++++++----------------------- drivers/video/vesa_fb.c | 10 ++++----- include/pci_rom.h | 6 +++--- 5 files changed, 36 insertions(+), 38 deletions(-)
diff --git a/arch/x86/cpu/ivybridge/gma.c b/arch/x86/cpu/ivybridge/gma.c index 695578b..85a09c6 100644 --- a/arch/x86/cpu/ivybridge/gma.c +++ b/arch/x86/cpu/ivybridge/gma.c @@ -756,8 +756,8 @@ int gma_func0_init(struct udevice *dev, const void *blob, int node)
#ifdef CONFIG_VIDEO start = get_timer(0); - ret = pci_run_vga_bios(dm_pci_get_bdf(dev), int15_handler, - PCI_ROM_USE_NATIVE | PCI_ROM_ALLOW_FALLBACK); + ret = dm_pci_run_vga_bios(dev, int15_handler, + PCI_ROM_USE_NATIVE | PCI_ROM_ALLOW_FALLBACK); debug("BIOS ran in %lums\n", get_timer(start)); #endif /* Post VBIOS init */ diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 62232fc..f8be9bf 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -6,6 +6,7 @@ #
ifneq ($(CONFIG_DM_PCI),) +obj-y += pci_rom.o obj-$(CONFIG_PCI) += pci-uclass.o pci_auto.o obj-$(CONFIG_DM_PCI_COMPAT) += pci_compat.o obj-$(CONFIG_PCI_SANDBOX) += pci_sandbox.o @@ -14,7 +15,7 @@ obj-$(CONFIG_X86) += pci_x86.o else obj-$(CONFIG_PCI) += pci.o pci_auto_old.o endif -obj-$(CONFIG_PCI) += pci_auto_common.o pci_common.o pci_rom.o +obj-$(CONFIG_PCI) += pci_auto_common.o pci_common.o
obj-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o obj-$(CONFIG_PCI_INDIRECT_BRIDGE) += pci_indirect.o diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index d244543..5989bad 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -25,6 +25,7 @@
#include <common.h> #include <bios_emul.h> +#include <dm.h> #include <errno.h> #include <malloc.h> #include <pci.h> @@ -37,12 +38,12 @@ #include <asm/acpi.h> #endif
-__weak bool board_should_run_oprom(pci_dev_t dev) +__weak bool board_should_run_oprom(struct udevice *dev) { return true; }
-static bool should_load_oprom(pci_dev_t dev) +static bool should_load_oprom(struct udevice *dev) { #ifdef CONFIG_HAVE_ACPI_RESUME if (acpi_get_slp_type() == 3) @@ -61,21 +62,18 @@ __weak uint32_t board_map_oprom_vendev(uint32_t vendev) return vendev; }
-static int pci_rom_probe(pci_dev_t dev, uint class, - struct pci_rom_header **hdrp) +static int pci_rom_probe(struct udevice *dev, struct pci_rom_header **hdrp) { + struct pci_child_platdata *pplat = dev_get_parent_platdata(dev); struct pci_rom_header *rom_header; struct pci_rom_data *rom_data; - u16 vendor, device; u16 rom_vendor, rom_device; u32 rom_class; u32 vendev; u32 mapped_vendev; u32 rom_address;
- pci_read_config_word(dev, PCI_VENDOR_ID, &vendor); - pci_read_config_word(dev, PCI_DEVICE_ID, &device); - vendev = vendor << 16 | device; + vendev = pplat->vendor << 16 | pplat->device; mapped_vendev = board_map_oprom_vendev(vendev); if (vendev != mapped_vendev) debug("Device ID mapped to %#08x\n", mapped_vendev); @@ -84,15 +82,15 @@ static int pci_rom_probe(pci_dev_t dev, uint class, rom_address = CONFIG_VGA_BIOS_ADDR; #else
- pci_read_config_dword(dev, PCI_ROM_ADDRESS, &rom_address); + dm_pci_read_config32(dev, PCI_ROM_ADDRESS, &rom_address); if (rom_address == 0x00000000 || rom_address == 0xffffffff) { debug("%s: rom_address=%x\n", __func__, rom_address); return -ENOENT; }
/* Enable expansion ROM address decoding. */ - pci_write_config_dword(dev, PCI_ROM_ADDRESS, - rom_address | PCI_ROM_ADDRESS_ENABLE); + dm_pci_write_config32(dev, PCI_ROM_ADDRESS, + rom_address | PCI_ROM_ADDRESS_ENABLE); #endif debug("Option ROM address %x\n", rom_address); rom_header = (struct pci_rom_header *)(unsigned long)rom_address; @@ -106,7 +104,7 @@ static int pci_rom_probe(pci_dev_t dev, uint class, le16_to_cpu(rom_header->signature)); #ifndef CONFIG_VGA_BIOS_ADDR /* Disable expansion ROM address decoding */ - pci_write_config_dword(dev, PCI_ROM_ADDRESS, rom_address); + dm_pci_write_config32(dev, PCI_ROM_ADDRESS, rom_address); #endif return -EINVAL; } @@ -119,7 +117,7 @@ static int pci_rom_probe(pci_dev_t dev, uint class, rom_vendor, rom_device);
/* If the device id is mapped, a mismatch is expected */ - if ((vendor != rom_vendor || device != rom_device) && + if ((pplat->vendor != rom_vendor || pplat->device != rom_device) && (vendev == mapped_vendev)) { printf("ID mismatch: vendor ID %04x, device ID %04x\n", rom_vendor, rom_device); @@ -130,9 +128,9 @@ static int pci_rom_probe(pci_dev_t dev, uint class, debug("PCI ROM image, Class Code %06x, Code Type %02x\n", rom_class, rom_data->type);
- if (class != rom_class) { + if (pplat->class != rom_class) { debug("Class Code mismatch ROM %06x, dev %06x\n", - rom_class, class); + rom_class, pplat->class); } *hdrp = rom_header;
@@ -259,27 +257,26 @@ void setup_video(struct screen_info *screen_info) screen_info->rsvd_pos = vesa->reserved_mask_pos; }
-int pci_run_vga_bios(pci_dev_t dev, int (*int15_handler)(void), int exec_method) +int dm_pci_run_vga_bios(struct udevice *dev, int (*int15_handler)(void), + int exec_method) { + struct pci_child_platdata *pplat = dev_get_parent_platdata(dev); struct pci_rom_header *rom, *ram; int vesa_mode = -1; - uint class; bool emulate; int ret;
/* Only execute VGA ROMs */ - pci_read_config_dword(dev, PCI_REVISION_ID, &class); - if (((class >> 16) ^ PCI_CLASS_DISPLAY_VGA) & 0xff00) { - debug("%s: Class %#x, should be %#x\n", __func__, class, + if (((pplat->class >> 8) ^ PCI_CLASS_DISPLAY_VGA) & 0xff00) { + debug("%s: Class %#x, should be %#x\n", __func__, pplat->class, PCI_CLASS_DISPLAY_VGA); return -ENODEV; } - class >>= 8;
if (!should_load_oprom(dev)) return -ENXIO;
- ret = pci_rom_probe(dev, class, &rom); + ret = pci_rom_probe(dev, &rom); if (ret) return ret;
@@ -322,12 +319,12 @@ int pci_run_vga_bios(pci_dev_t dev, int (*int15_handler)(void), int exec_method) #ifdef CONFIG_BIOSEMU BE_VGAInfo *info;
- ret = biosemu_setup(dev, &info); + ret = biosemu_setup(dm_pci_get_bdf(dev), &info); if (ret) return ret; biosemu_set_interrupt_handler(0x15, int15_handler); - ret = biosemu_run(dev, (uchar *)ram, 1 << 16, info, true, - vesa_mode, &mode_info); + ret = biosemu_run(dm_pci_get_bdf(dev), (uchar *)ram, 1 << 16, + info, true, vesa_mode, &mode_info); if (ret) return ret; #endif @@ -335,8 +332,8 @@ int pci_run_vga_bios(pci_dev_t dev, int (*int15_handler)(void), int exec_method) #ifdef CONFIG_X86 bios_set_interrupt_handler(0x15, int15_handler);
- bios_run_on_x86(dev, (unsigned long)ram, vesa_mode, - &mode_info); + bios_run_on_x86(dm_pci_get_bdf(dev), (unsigned long)ram, + vesa_mode, &mode_info); #endif } debug("Final vesa mode %#x\n", mode_info.video_mode); diff --git a/drivers/video/vesa_fb.c b/drivers/video/vesa_fb.c index a19651f..021c1d6 100644 --- a/drivers/video/vesa_fb.c +++ b/drivers/video/vesa_fb.c @@ -19,8 +19,8 @@ GraphicDevice ctfb; void *video_hw_init(void) { GraphicDevice *gdev = &ctfb; + struct udevice *dev; int bits_per_pixel; - pci_dev_t dev; int ret;
printf("Video: "); @@ -33,14 +33,14 @@ void *video_hw_init(void) return NULL; } if (vbe_get_video_info(gdev)) { - dev = pci_find_class(PCI_CLASS_DISPLAY_VGA << 8, 0); - if (dev < 0) { + ret = dm_pci_find_class(PCI_CLASS_DISPLAY_VGA << 8, 0, &dev); + if (ret) { printf("no card detected\n"); return NULL; } bootstage_start(BOOTSTAGE_ID_ACCUM_LCD, "vesa display"); - ret = pci_run_vga_bios(dev, NULL, PCI_ROM_USE_NATIVE | - PCI_ROM_ALLOW_FALLBACK); + ret = dm_pci_run_vga_bios(dev, NULL, PCI_ROM_USE_NATIVE | + PCI_ROM_ALLOW_FALLBACK); bootstage_accum(BOOTSTAGE_ID_ACCUM_LCD); if (ret) { printf("failed to run video BIOS: %d\n", ret); diff --git a/include/pci_rom.h b/include/pci_rom.h index 2f1665d..95c6d07 100644 --- a/include/pci_rom.h +++ b/include/pci_rom.h @@ -44,14 +44,14 @@ enum pci_rom_emul { };
/** - * pci_run_vga_bios() - Run the VGA BIOS in an x86 PC + * dm_pci_run_vga_bios() - Run the VGA BIOS in an x86 PC * * @dev: Video device containing the BIOS * @int15_handler: Function to call to handle int 0x15 * @exec_method: flags from enum pci_rom_emul */ -int pci_run_vga_bios(pci_dev_t dev, int (*int15_handler)(void), - int exec_method); +int dm_pci_run_vga_bios(struct udevice *dev, int (*int15_handler)(void), + int exec_method);
/** * board_map_oprom_vendev() - map several PCI IDs to the one the ROM expects
Hi Simon,
Changes in v2:
Acked-by: Anatolij Gustschin agust@denx.de
Changes in v2:
dm_pci_read_config32(dev, PCI_ROM_ADDRESS, &rom_address); if (rom_address == 0x00000000 || rom_address == 0xffffffff) { debug("%s: rom_address=%x\n", __func__, rom_address); return -ENOENT; } /* Enable expansion ROM address decoding. */
rom_class, class);
int exec_method)
uint class; bool emulate; int ret; /* Only execute VGA ROMs */
class >>= 8; if (!should_load_oprom(dev)) return -ENXIO;
&mode_info);
pci_dev_t dev; int ret; printf("Video: ");
if (dev < 0) {
- pci_run_vga_bios() - Run the VGA BIOS in an x86 PC
- dm_pci_run_vga_bios() - Run the VGA BIOS in an x86 PC
- @dev: Video device containing the BIOS
- @int15_handler: Function to call to handle int 0x15
- @exec_method: flags from enum pci_rom_emul
int exec_method);
int exec_method);
- board_map_oprom_vendev() - map several PCI IDs to the one the ROM expects
This function should take a struct udevice rather than pci_dev_t. Update it.
Changes in v2: None
arch/x86/lib/bios.c | 3 ++- drivers/pci/pci_rom.c | 4 ++-- include/bios_emul.h | 2 +- 3 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/arch/x86/lib/bios.c b/arch/x86/lib/bios.c index 1d75cfc..9324bdb 100644 --- a/arch/x86/lib/bios.c +++ b/arch/x86/lib/bios.c @@ -242,9 +242,10 @@ static void vbe_set_graphics(int vesa_mode, struct vbe_mode_info *mode_info) vbe_set_mode(mode_info); }
-void bios_run_on_x86(pci_dev_t pcidev, unsigned long addr, int vesa_mode, +void bios_run_on_x86(struct udevice *dev, unsigned long addr, int vesa_mode, struct vbe_mode_info *mode_info) { + pci_dev_t pcidev = dm_pci_get_bdf(dev); u32 num_dev;
num_dev = PCI_BUS(pcidev) << 8 | PCI_DEV(pcidev) << 3 | diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index 5989bad..c4112cb 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -332,8 +332,8 @@ int dm_pci_run_vga_bios(struct udevice *dev, int (*int15_handler)(void), #ifdef CONFIG_X86 bios_set_interrupt_handler(0x15, int15_handler);
- bios_run_on_x86(dm_pci_get_bdf(dev), (unsigned long)ram, - vesa_mode, &mode_info); + bios_run_on_x86(dev, (unsigned long)ram, vesa_mode, + &mode_info); #endif } debug("Final vesa mode %#x\n", mode_info.video_mode); diff --git a/include/bios_emul.h b/include/bios_emul.h index 3643b82..80979ed 100644 --- a/include/bios_emul.h +++ b/include/bios_emul.h @@ -42,7 +42,7 @@ struct vbe_mode_info; int BootVideoCardBIOS(pci_dev_t pcidev, BE_VGAInfo **pVGAInfo, int cleanUp);
/* Run a BIOS ROM natively (only supported on x86 machines) */ -void bios_run_on_x86(pci_dev_t pcidev, unsigned long addr, int vesa_mode, +void bios_run_on_x86(struct udevice *dev, unsigned long addr, int vesa_mode, struct vbe_mode_info *mode_info);
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com
Changes in v2: None
pci_dev_t pcidev = dm_pci_get_bdf(dev); u32 num_dev; num_dev = PCI_BUS(pcidev) << 8 | PCI_DEV(pcidev) << 3 |
&mode_info);
Move these functions into the compatibility file so that they are not available by default.
Changes in v2: - Move the functions into pci_common.c so they can be used by old code - Reword the commit message for clarity
drivers/pci/pci_common.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/pci/pci_common.c b/drivers/pci/pci_common.c index 2a14902..a4573b0 100644 --- a/drivers/pci/pci_common.c +++ b/drivers/pci/pci_common.c @@ -313,6 +313,7 @@ pci_addr_t pci_hose_phys_to_bus(struct pci_controller *hose, return bus_addr; }
+#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) pci_dev_t pci_find_device(unsigned int vendor, unsigned int device, int index) { struct pci_device_id ids[2] = { {}, {0, 0} }; @@ -363,3 +364,4 @@ pci_dev_t pci_hose_find_devices(struct pci_controller *hose, int busnum,
return -1; } +#endif /* !CONFIG_DM_PCI || CONFIG_DM_PCI_COMPAT */
Changes in v2:
return -1;
Applied to u-boot-dm/next.
Move this function into the compatibility file so that it is not available by default.
drivers/pci/pci_common.c | 84 ++++++++++++++++++++++++------------------------ 1 file changed, 42 insertions(+), 42 deletions(-)
diff --git a/drivers/pci/pci_common.c b/drivers/pci/pci_common.c index a4573b0..b388a1c 100644 --- a/drivers/pci/pci_common.c +++ b/drivers/pci/pci_common.c @@ -79,48 +79,6 @@ const char *pci_class_str(u8 class) }; }
-pci_dev_t pci_find_class(uint find_class, int index) -{ - int bus; - int devnum; - pci_dev_t bdf; - uint32_t class; - - for (bus = 0; bus <= pci_last_busno(); bus++) { - for (devnum = 0; devnum < PCI_MAX_PCI_DEVICES - 1; devnum++) { - pci_read_config_dword(PCI_BDF(bus, devnum, 0), - PCI_CLASS_REVISION, &class); - if (class >> 16 == 0xffff) - continue; - - for (bdf = PCI_BDF(bus, devnum, 0); - bdf <= PCI_BDF(bus, devnum, - PCI_MAX_PCI_FUNCTIONS - 1); - bdf += PCI_BDF(0, 0, 1)) { - pci_read_config_dword(bdf, PCI_CLASS_REVISION, - &class); - class >>= 8; - - if (class != find_class) - continue; - /* - * Decrement the index. We want to return the - * correct device, so index is 0 for the first - * matching device, 1 for the second, etc. - */ - if (index) { - index--; - continue; - } - /* Return index'th controller. */ - return bdf; - } - } - } - - return -ENODEV; -} - __weak int pci_skip_dev(struct pci_controller *hose, pci_dev_t dev) { /* @@ -364,4 +322,46 @@ pci_dev_t pci_hose_find_devices(struct pci_controller *hose, int busnum,
return -1; } + +pci_dev_t pci_find_class(uint find_class, int index) +{ + int bus; + int devnum; + pci_dev_t bdf; + uint32_t class; + + for (bus = 0; bus <= pci_last_busno(); bus++) { + for (devnum = 0; devnum < PCI_MAX_PCI_DEVICES - 1; devnum++) { + pci_read_config_dword(PCI_BDF(bus, devnum, 0), + PCI_CLASS_REVISION, &class); + if (class >> 16 == 0xffff) + continue; + + for (bdf = PCI_BDF(bus, devnum, 0); + bdf <= PCI_BDF(bus, devnum, + PCI_MAX_PCI_FUNCTIONS - 1); + bdf += PCI_BDF(0, 0, 1)) { + pci_read_config_dword(bdf, PCI_CLASS_REVISION, + &class); + class >>= 8; + + if (class != find_class) + continue; + /* + * Decrement the index. We want to return the + * correct device, so index is 0 for the first + * matching device, 1 for the second, etc. + */ + if (index) { + index--; + continue; + } + /* Return index'th controller. */ + return bdf; + } + } + } + + return -ENODEV; +} #endif /* !CONFIG_DM_PCI || CONFIG_DM_PCI_COMPAT */
Changes in v2:
int bus;
int devnum;
pci_dev_t bdf;
uint32_t class;
continue;
&class);
class >>= 8;
continue;
if (index) {
index--;
continue;
return bdf;
return -ENODEV;
return -1;
int bus;
int devnum;
pci_dev_t bdf;
uint32_t class;
continue;
&class);
class >>= 8;
continue;
if (index) {
index--;
continue;
return bdf;
return -ENODEV;
Adjust all Tegra boards to use driver model for Ethernet, now that the required drivers are converted.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: None
arch/arm/mach-tegra/Kconfig | 1 + board/compulab/trimslice/trimslice.c | 8 -------- board/nvidia/cardhu/cardhu.c | 6 ------ board/nvidia/jetson-tk1/jetson-tk1.c | 6 ------ board/nvidia/p2371-2180/p2371-2180.c | 6 ------ board/toradex/apalis_t30/apalis_t30.c | 6 ------ 6 files changed, 1 insertion(+), 32 deletions(-)
diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index fbfb204..48a387c 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -3,6 +3,7 @@ if TEGRA config TEGRA_COMMON bool "Tegra common options" select DM + select DM_ETH select DM_GPIO select DM_I2C select DM_KEYBOARD diff --git a/board/compulab/trimslice/trimslice.c b/board/compulab/trimslice/trimslice.c index c9da80d..723293f 100644 --- a/board/compulab/trimslice/trimslice.c +++ b/board/compulab/trimslice/trimslice.c @@ -13,7 +13,6 @@ #include <asm/arch/pinmux.h> #include <asm/gpio.h> #include <i2c.h> -#include <netdev.h>
void pin_mux_usb(void) { @@ -41,10 +40,3 @@ void pin_mux_mmc(void) /* For CD GPIO PP1 */ pinmux_tristate_disable(PMUX_PINGRP_DAP3); } - -#ifdef CONFIG_PCI -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} -#endif diff --git a/board/nvidia/cardhu/cardhu.c b/board/nvidia/cardhu/cardhu.c index 1540526..ba15e2e 100644 --- a/board/nvidia/cardhu/cardhu.c +++ b/board/nvidia/cardhu/cardhu.c @@ -13,7 +13,6 @@ #include <asm/gpio.h> #include "pinmux-config-cardhu.h" #include <i2c.h> -#include <netdev.h>
#define PMU_I2C_ADDRESS 0x2D #define MAX_I2C_RETRY 3 @@ -129,9 +128,4 @@ int tegra_pcie_board_init(void)
return 0; } - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} #endif /* PCI */ diff --git a/board/nvidia/jetson-tk1/jetson-tk1.c b/board/nvidia/jetson-tk1/jetson-tk1.c index 52425a8..6f189aa 100644 --- a/board/nvidia/jetson-tk1/jetson-tk1.c +++ b/board/nvidia/jetson-tk1/jetson-tk1.c @@ -6,7 +6,6 @@ */
#include <common.h> -#include <netdev.h> #include <power/as3722.h>
#include <asm/arch/gpio.h> @@ -73,9 +72,4 @@ int tegra_pcie_board_init(void)
return 0; } - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} #endif /* PCI */ diff --git a/board/nvidia/p2371-2180/p2371-2180.c b/board/nvidia/p2371-2180/p2371-2180.c index 57f577d8..0f587ea 100644 --- a/board/nvidia/p2371-2180/p2371-2180.c +++ b/board/nvidia/p2371-2180/p2371-2180.c @@ -6,7 +6,6 @@ */
#include <common.h> -#include <netdev.h> #include <i2c.h> #include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> @@ -73,9 +72,4 @@ int tegra_pcie_board_init(void)
return 0; } - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} #endif /* PCI */ diff --git a/board/toradex/apalis_t30/apalis_t30.c b/board/toradex/apalis_t30/apalis_t30.c index 879006f..3f56971 100644 --- a/board/toradex/apalis_t30/apalis_t30.c +++ b/board/toradex/apalis_t30/apalis_t30.c @@ -14,7 +14,6 @@ #include <asm/io.h> #include <dm.h> #include <i2c.h> -#include <netdev.h>
#include "pinmux-config-apalis_t30.h"
@@ -92,9 +91,4 @@ int tegra_pcie_board_init(void)
return 0; } - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} #endif /* CONFIG_PCI_TEGRA */
This change has removed/disabled/... PCIe support on at least Jetson TK1. I haven't checked the other Tegra boards.
Hi Stephen,
My local copy works OK. I suspect something else (perhaps a later or earlier change) has broken this.
The problem is that PCI is no-longer probed on start-up. With driver model I'm trying to make things start when needed. It doesn't work with networking as it is currently implemented.
I'll send some patches to probe PCI from the network code, and tidy up a few things. My jetson-tk1 is a bit broken (the PMIC settings) but I've reproduced the problem on beaver.
On 01/17/2016 08:58 PM, Simon Glass wrote:
Hi Stephen,
What did you test? My test was to look at the U-Boot boot logs and verify that the RTL8169#0 device was probed, and that "dhcp zImage" worked as expected once the prompt appeared.
This change is definitely the cause. If I check out this change, the NIC doesn't work. If I check out the previous change, the NIC does work. If I check out u-boot/master, the NIC does not work. If I then revert this change, the NIC does work.
Isn't that going to be a regression; users will have to type extra commands to get PCIe NICs working if they don't automatically probe, won't they? I don't think that having PCI probed when it's first used is a good solution, since that means that any environment variables that are set during probing (such as ethact, ethaddr) won't be set, which will be a regression for any scripts that use them.
Hi Stephen,
Hi Stephen,
I mean the patch series that I sent at the time. I suppose PCI probing has changed since then. Possibly I made the change, not sure.
Something to think about. For now I sent a patch which probes PCI in the Ethernet uclass.
I've found another strange problem, at least triggered/exposed by this patch:
On at least either Dalmore or Jetson TK1, using USB Ethernet (hence with RTL8169 support disabled in include/configs/jetson-tk1.h[1]), I find that if I execute the following commands at or after this patch, then the system reboots during DHCP operation:
save mmc 1:1 $loadaddr /dfu_dummy.bin 0x3c0 usb start setenv autoload no dhcp
yields:
==================== Tegra124 (Jetson TK1) # dhcp Waiting for Ethernet connection... done. BOOTP broadcast 1 DHCP client bound to address 10.20.204.50 (1 ms) data abort pc : [<fff6f1d4>] lr : [<fff59fd0>] reloc pc : [<801291d4>] lr : [<80113fd0>] sp : fda4e720 ip : 450088df fp : fda60048 r10: fffa4fe3 r9 : fda53ee0 r8 : 00000000 r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : fda60048 r3 : 00000383 r2 : 00000000 r1 : 00000000 r0 : e10f354b Flags: NzCv IRQs off FIQs off Mode SVC_32 Resetting CPU ...
resetting ... ====================
However, if I execute those commands at the commit before this patch, then everything is OK.
The "save" command is definitely required to trigger this issue. The partition being saved to is a 1024MiB ext4 filesystem that's almost empty. If I omit the save, or save to a 1024MiB FAT filesystem instead, there's no error. This leads me to suspect some kind of memory corruption rather than a direct problem with this patch. Due to ext4 interaction, also CCing Łukasz in case he has any quick ideas.
I'll go track down the PC where the error occurs and try and add some debug spew etc. to see what's up. Any other ideas appreciated though.
(This is the problem with writing test systems; they show up bugs!)
[1] i.e. I have this change made locally so that no PCIe Ethernet device exists, which causes the USB Ethernet to be used by default:
diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index 23b2e436167c..af26b055b70b 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -62,7 +62,6 @@ #define CONFIG_CMD_PCI
/* PCI networking support */ -#define CONFIG_RTL8169
/* General networking support */ #define CONFIG_CMD_DHCP
Hi Stephen,
yields:
resetting ...
I have seen some odd things on Seaboard which is a bit more forgiving with RAM at 0 (although not Jetson-TK1, right?). It can sometimes mask an issue where a driver has not auto-allocated space, but the driver is using it anyway (i.e. using a NULL pointer as its private data).
I can't see anything wrong from inspection. The per-child data (struct usb_device) appears to be cache-aligned as expected.
Which USB Ethernet driver are you using?
It would be great to fix this.
On 02/11/2016 05:10 PM, Simon Glass wrote:
Hi Stephen,
yields:
resetting ...
asix.
It looks like something inside the dhcp command is trashing something in the hush shell "pipe" state...
BTW, can sandbox support USB Ethernet and MMC (or perhaps any block device that I can "save" on)? I'd be curious if the problem could repro there, what with its better debugging tools. However, if the issue is fluky malloc heap layout due to command history, I guess we'd have to be pretty lucky...
Hi Stephen,
Hi Stephen,
yields:
resetting ...
asix.
Wow, that's novel.
It supports USB keyboard and Flash. You could probably add a simulated USB Ethernet without much trouble. See drivers/usb/emul.
It supports MMC at the top level but there is no back-end. As it happens I'm working on driver model blk support but it isn't ready. The USB flash device only supports read at present, but I suppose adding it wouldn't be hard. But I'm not sure savenv supports USB devices. You could use SPI flash but it isn't a block device.
Hmmm...
Update these tests to use driver model API functions.
test/dm/pci.c | 15 ++++++--------- 1 file changed, 6 insertions(+), 9 deletions(-)
diff --git a/test/dm/pci.c b/test/dm/pci.c index 3ab4ba8..a5b1290 100644 --- a/test/dm/pci.c +++ b/test/dm/pci.c @@ -35,20 +35,17 @@ DM_TEST(dm_test_pci_busnum, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); /* Test that we can use the swapcase device correctly */ static int dm_test_pci_swapcase(struct unit_test_state *uts) { - pci_dev_t pci_dev = PCI_BDF(0, 0x1f, 0); - struct pci_controller *hose; - struct udevice *bus, *swap; + struct udevice *emul, *swap; ulong io_addr, mem_addr; char *ptr;
/* Check that asking for the device automatically fires up PCI */ - ut_assertok(uclass_get_device(UCLASS_PCI_EMUL, 0, &swap)); - - ut_assertok(uclass_get_device(UCLASS_PCI, 0, &bus)); - hose = dev_get_uclass_priv(bus); + ut_assertok(uclass_get_device(UCLASS_PCI_EMUL, 0, &emul)); + ut_assertok(dm_pci_bus_find_bdf(PCI_BDF(0, 0x1f, 0), &swap)); + ut_assert(device_active(swap));
/* First test I/O */ - io_addr = pci_read_bar32(hose, pci_dev, 0); + io_addr = dm_pci_read_bar32(swap, 0); outb(2, io_addr); ut_asserteq(2, inb(io_addr));
@@ -56,7 +53,7 @@ static int dm_test_pci_swapcase(struct unit_test_state *uts) * Now test memory mapping - note we must unmap and remap to cause * the swapcase emulation to see our data and response. */ - mem_addr = pci_read_bar32(hose, pci_dev, 1); + mem_addr = dm_pci_read_bar32(swap, 1); ptr = map_sysmem(mem_addr, 20); strcpy(ptr, "This is a TesT"); unmap_sysmem(ptr);
At present the PCI address map functions use the old API. Add new functions for this so that drivers can be converted.
Changes in v2: - Add missing code in dm_pci_phys_to_bus() - Rename _dm_pci_hose_bus_to_phys() to _dm_pci_bus_to_phys()
drivers/pci/pci-uclass.c | 136 +++++++++++++++++++++++++++++++++++++++++++++++ include/pci.h | 59 ++++++++++++++++++++ 2 files changed, 195 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 7a886f2..80e234b 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <inttypes.h> #include <pci.h> +#include <asm/io.h> #include <dm/lists.h> #include <dm/root.h> #include <dm/device-internal.h> @@ -1068,6 +1069,141 @@ u32 dm_pci_read_bar32(struct udevice *dev, int barnum) return addr & PCI_BASE_ADDRESS_MEM_MASK; }
+static int _dm_pci_bus_to_phys(struct udevice *ctlr, + pci_addr_t bus_addr, unsigned long flags, + unsigned long skip_mask, phys_addr_t *pa) +{ + struct pci_controller *hose = dev_get_uclass_priv(ctlr); + struct pci_region *res; + int i; + + for (i = 0; i < hose->region_count; i++) { + res = &hose->regions[i]; + + if (((res->flags ^ flags) & PCI_REGION_TYPE) != 0) + continue; + + if (res->flags & skip_mask) + continue; + + if (bus_addr >= res->bus_start && + (bus_addr - res->bus_start) < res->size) { + *pa = (bus_addr - res->bus_start + res->phys_start); + return 0; + } + } + + return 1; +} + +phys_addr_t dm_pci_bus_to_phys(struct udevice *dev, pci_addr_t bus_addr, + unsigned long flags) +{ + phys_addr_t phys_addr = 0; + struct udevice *ctlr; + int ret; + + /* The root controller has the region information */ + ctlr = pci_get_controller(dev); + + /* + * if PCI_REGION_MEM is set we do a two pass search with preference + * on matches that don't have PCI_REGION_SYS_MEMORY set + */ + if ((flags & PCI_REGION_TYPE) == PCI_REGION_MEM) { + ret = _dm_pci_bus_to_phys(ctlr, bus_addr, + flags, PCI_REGION_SYS_MEMORY, + &phys_addr); + if (!ret) + return phys_addr; + } + + ret = _dm_pci_bus_to_phys(ctlr, bus_addr, flags, 0, &phys_addr); + + if (ret) + puts("pci_hose_bus_to_phys: invalid physical address\n"); + + return phys_addr; +} + +int _dm_pci_phys_to_bus(struct udevice *dev, phys_addr_t phys_addr, + unsigned long flags, unsigned long skip_mask, + pci_addr_t *ba) +{ + struct pci_region *res; + struct udevice *ctlr; + pci_addr_t bus_addr; + int i; + struct pci_controller *hose; + + /* The root controller has the region information */ + ctlr = pci_get_controller(dev); + hose = dev_get_uclass_priv(ctlr); + + for (i = 0; i < hose->region_count; i++) { + res = &hose->regions[i]; + + if (((res->flags ^ flags) & PCI_REGION_TYPE) != 0) + continue; + + if (res->flags & skip_mask) + continue; + + bus_addr = phys_addr - res->phys_start + res->bus_start; + + if (bus_addr >= res->bus_start && + (bus_addr - res->bus_start) < res->size) { + *ba = bus_addr; + return 0; + } + } + + return 1; +} + +pci_addr_t dm_pci_phys_to_bus(struct udevice *dev, phys_addr_t phys_addr, + unsigned long flags) +{ + pci_addr_t bus_addr = 0; + int ret; + + /* + * if PCI_REGION_MEM is set we do a two pass search with preference + * on matches that don't have PCI_REGION_SYS_MEMORY set + */ + if ((flags & PCI_REGION_TYPE) == PCI_REGION_MEM) { + ret = _dm_pci_phys_to_bus(dev, phys_addr, flags, + PCI_REGION_SYS_MEMORY, &bus_addr); + if (!ret) + return bus_addr; + } + + ret = _dm_pci_phys_to_bus(dev, phys_addr, flags, 0, &bus_addr); + + if (ret) + puts("pci_hose_phys_to_bus: invalid physical address\n"); + + return bus_addr; +} + +void *dm_pci_map_bar(struct udevice *dev, int bar, int flags) +{ + pci_addr_t pci_bus_addr; + u32 bar_response; + + /* read BAR address */ + dm_pci_read_config32(dev, bar, &bar_response); + pci_bus_addr = (pci_addr_t)(bar_response & ~0xf); + + /* + * Pass "0" as the length argument to pci_bus_to_virt. The arg + * isn't actualy used on any platform because u-boot assumes a static + * linear mapping. In the future, this could read the BAR size + * and pass that as the size if needed. + */ + return dm_pci_bus_to_virt(dev, pci_bus_addr, flags, 0, MAP_NOCACHE); +} + UCLASS_DRIVER(pci) = { .id = UCLASS_PCI, .name = "pci", diff --git a/include/pci.h b/include/pci.h index dcbe978..2be49be 100644 --- a/include/pci.h +++ b/include/pci.h @@ -1176,6 +1176,65 @@ int pci_get_regions(struct udevice *dev, struct pci_region **iop, u32 dm_pci_read_bar32(struct udevice *dev, int barnum);
/** + * dm_pci_bus_to_phys() - convert a PCI bus address to a physical address + * + * @dev: Device containing the PCI address + * @addr: PCI address to convert + * @flags: Flags for the region type (PCI_REGION_...) + * @return physical address corresponding to that PCI bus address + */ +phys_addr_t dm_pci_bus_to_phys(struct udevice *dev, pci_addr_t addr, + unsigned long flags); + +/** + * dm_pci_phys_to_bus() - convert a physical address to a PCI bus address + * + * @dev: Device containing the bus address + * @addr: Physical address to convert + * @flags: Flags for the region type (PCI_REGION_...) + * @return PCI bus address corresponding to that physical address + */ +pci_addr_t dm_pci_phys_to_bus(struct udevice *dev, phys_addr_t addr, + unsigned long flags); + +/** + * dm_pci_map_bar() - get a physical address associated with a BAR region + * + * Looks up a base address register and finds the physical memory address + * that corresponds to it + * + * @dev: Device to check + * @bar: Bar number to read (numbered from 0) + * @flags: Flags for the region type (PCI_REGION_...) + * @return: pointer to the physical address to use + */ +void *dm_pci_map_bar(struct udevice *dev, int bar, int flags); + +#define dm_pci_virt_to_bus(dev, addr, flags) \ + dm_pci_phys_to_bus(dev, (virt_to_phys(addr)), (flags)) +#define dm_pci_bus_to_virt(dev, addr, flags, len, map_flags) \ + map_physmem(dm_pci_bus_to_phys(dev, (addr), (flags)), \ + (len), (map_flags)) + +#define dm_pci_phys_to_mem(dev, addr) \ + dm_pci_phys_to_bus((dev), (addr), PCI_REGION_MEM) +#define dm_pci_mem_to_phys(dev, addr) \ + dm_pci_bus_to_phys((dev), (addr), PCI_REGION_MEM) +#define dm_pci_phys_to_io(dev, addr) \ + dm_pci_phys_to_bus((dev), (addr), PCI_REGION_IO) +#define dm_pci_io_to_phys(dev, addr) \ + dm_pci_bus_to_phys((dev), (addr), PCI_REGION_IO) + +#define dm_pci_virt_to_mem(dev, addr) \ + dm_pci_virt_to_bus((dev), (addr), PCI_REGION_MEM) +#define dm_pci_mem_to_virt(dev, addr, len, map_flags) \ + dm_pci_bus_to_virt((dev), (addr), PCI_REGION_MEM, (len), (map_flags)) +#define dm_pci_virt_to_io(dev, addr) \ + dm_dm_pci_virt_to_bus((dev), (addr), PCI_REGION_IO) +#define dm_pci_io_to_virt(dev, addr, len, map_flags) \ + dm_dm_pci_bus_to_virt((dev), (addr), PCI_REGION_IO, (len), (map_flags)) + +/** * dm_pci_find_device() - find a device by vendor/device ID * * @vendor: Vendor ID
Hi Simon,
Changes in v2:
nits: the indention of the above 2 lines looks wrong.
int i;
continue;
continue;
return 1;
int ret;
&phys_addr);
if (!ret)
return phys_addr;
if (ret)
return phys_addr;
pci_addr_t *ba)
int i;
continue;
continue;
*ba = bus_addr;
return 1;
int ret;
if (!ret)
return bus_addr;
if (ret)
return bus_addr;
u32 bar_response;
- dm_pci_bus_to_phys() - convert a PCI bus address to a physical address
- @dev: Device containing the PCI address
- @addr: PCI address to convert
- @flags: Flags for the region type (PCI_REGION_...)
- @return physical address corresponding to that PCI bus address
- dm_pci_phys_to_bus() - convert a physical address to a PCI bus address
- @dev: Device containing the bus address
- @addr: Physical address to convert
- @return PCI bus address corresponding to that physical address
- dm_pci_map_bar() - get a physical address associated with a BAR region
It should be virtual address, not physical address.
- Looks up a base address register and finds the physical memory address
- that corresponds to it
- @dev: Device to check
- @bar: Bar number to read (numbered from 0)
- @return: pointer to the physical address to use
virtual address.
(len), (map_flags))
- dm_pci_find_device() - find a device by vendor/device ID
- @vendor: Vendor ID
Other than above nits,
Regards, Bin
On 7 December 2015 at 04:14, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Changes in v2:
int i;
continue;
continue;
return 1;
int ret;
&phys_addr);
if (!ret)
return phys_addr;
if (ret)
return phys_addr;
pci_addr_t *ba)
int i;
continue;
continue;
*ba = bus_addr;
return 1;
int ret;
if (!ret)
return bus_addr;
if (ret)
return bus_addr;
u32 bar_response;
virtual address.
(len), (map_flags))
Fix these and:
Regards, Bin
Update this driver to use the proper driver-model PCI API functions.
Changes in v2: - Drop unnecessary and confusing '#ifdef CONFIG_DM_ETH' in rtl8169_eth_probe()
drivers/net/rtl8169.c | 85 +++++++++++++++++++++++++++++++++++++++------------ 1 file changed, 66 insertions(+), 19 deletions(-)
diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index f210005..9e60adf 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -513,8 +513,13 @@ static void rtl_flush_buffer(void *buf, size_t size) /************************************************************************** RECV - Receive a frame ***************************************************************************/ -static int rtl_recv_common(pci_dev_t bdf, unsigned long dev_iobase, +#ifdef CONFIG_DM_ETH +static int rtl_recv_common(struct udevice *dev, unsigned long dev_iobase, + uchar **packetp) +#else +static int rtl_recv_common(pci_dev_t dev, unsigned long dev_iobase, uchar **packetp) +#endif { /* return true if there's an ethernet packet ready to read */ /* nic->packet should contain data on return */ @@ -545,9 +550,16 @@ static int rtl_recv_common(pci_dev_t bdf, unsigned long dev_iobase, else tpc->RxDescArray[cur_rx].status = cpu_to_le32(OWNbit + RX_BUF_SIZE); +#ifdef CONFIG_DM_ETH tpc->RxDescArray[cur_rx].buf_addr = cpu_to_le32( - pci_mem_to_phys(bdf, (pci_addr_t)(unsigned long) + dm_pci_mem_to_phys(dev, + (pci_addr_t)(unsigned long) + tpc->RxBufferRing[cur_rx])); +#else + tpc->RxDescArray[cur_rx].buf_addr = cpu_to_le32( + pci_mem_to_phys(dev, (pci_addr_t)(unsigned long) tpc->RxBufferRing[cur_rx])); +#endif rtl_flush_rx_desc(&tpc->RxDescArray[cur_rx]); #ifdef CONFIG_DM_ETH *packetp = rxdata; @@ -576,7 +588,7 @@ int rtl8169_eth_recv(struct udevice *dev, int flags, uchar **packetp) { struct rtl8169_private *priv = dev_get_priv(dev);
- return rtl_recv_common(dm_pci_get_bdf(dev), priv->iobase, packetp); + return rtl_recv_common(dev, priv->iobase, packetp); } #else static int rtl_recv(struct eth_device *dev) @@ -590,8 +602,13 @@ static int rtl_recv(struct eth_device *dev) /************************************************************************** SEND - Transmit a frame ***************************************************************************/ -static int rtl_send_common(pci_dev_t bdf, unsigned long dev_iobase, +#ifdef CONFIG_DM_ETH +static int rtl_send_common(struct udevice *dev, unsigned long dev_iobase, void *packet, int length) +#else +static int rtl_send_common(pci_dev_t dev, unsigned long dev_iobase, + void *packet, int length) +#endif { /* send the packet to destination */
@@ -618,8 +635,13 @@ static int rtl_send_common(pci_dev_t bdf, unsigned long dev_iobase, ptxb[len++] = '\0';
tpc->TxDescArray[entry].buf_Haddr = 0; +#ifdef CONFIG_DM_ETH tpc->TxDescArray[entry].buf_addr = cpu_to_le32( - pci_mem_to_phys(bdf, (pci_addr_t)(unsigned long)ptxb)); + dm_pci_mem_to_phys(dev, (pci_addr_t)(unsigned long)ptxb)); +#else + tpc->TxDescArray[entry].buf_addr = cpu_to_le32( + pci_mem_to_phys(dev, (pci_addr_t)(unsigned long)ptxb)); +#endif if (entry != (NUM_TX_DESC - 1)) { tpc->TxDescArray[entry].status = cpu_to_le32((OWNbit | FSbit | LSbit) | @@ -661,8 +683,7 @@ int rtl8169_eth_send(struct udevice *dev, void *packet, int length) { struct rtl8169_private *priv = dev_get_priv(dev);
- return rtl_send_common(dm_pci_get_bdf(dev), priv->iobase, packet, - length); + return rtl_send_common(dev, priv->iobase, packet, length); }
#else @@ -696,7 +717,11 @@ static void rtl8169_set_rx_mode(void) RTL_W32(MAR0 + 4, mc_filter[1]); }
-static void rtl8169_hw_start(pci_dev_t bdf) +#ifdef CONFIG_DM_ETH +static void rtl8169_hw_start(struct udevice *dev) +#else +static void rtl8169_hw_start(pci_dev_t dev) +#endif { u32 i;
@@ -741,11 +766,21 @@ static void rtl8169_hw_start(pci_dev_t bdf)
tpc->cur_rx = 0;
- RTL_W32(TxDescStartAddrLow, pci_mem_to_phys(bdf, +#ifdef CONFIG_DM_ETH + RTL_W32(TxDescStartAddrLow, dm_pci_mem_to_phys(dev, (pci_addr_t)(unsigned long)tpc->TxDescArray)); +#else + RTL_W32(TxDescStartAddrLow, pci_mem_to_phys(dev, + (pci_addr_t)(unsigned long)tpc->TxDescArray)); +#endif RTL_W32(TxDescStartAddrHigh, (unsigned long)0); +#ifdef CONFIG_DM_ETH + RTL_W32(RxDescStartAddrLow, dm_pci_mem_to_phys( + dev, (pci_addr_t)(unsigned long)tpc->RxDescArray)); +#else RTL_W32(RxDescStartAddrLow, pci_mem_to_phys( - bdf, (pci_addr_t)(unsigned long)tpc->RxDescArray)); + dev, (pci_addr_t)(unsigned long)tpc->RxDescArray)); +#endif RTL_W32(RxDescStartAddrHigh, (unsigned long)0);
/* RTL-8169sc/8110sc or later version */ @@ -767,7 +802,11 @@ static void rtl8169_hw_start(pci_dev_t bdf) #endif }
-static void rtl8169_init_ring(pci_dev_t bdf) +#ifdef CONFIG_DM_ETH +static void rtl8169_init_ring(struct udevice *dev) +#else +static void rtl8169_init_ring(pci_dev_t dev) +#endif { int i;
@@ -795,8 +834,13 @@ static void rtl8169_init_ring(pci_dev_t bdf) cpu_to_le32(OWNbit + RX_BUF_SIZE);
tpc->RxBufferRing[i] = &rxb[i * RX_BUF_SIZE]; +#ifdef CONFIG_DM_ETH + tpc->RxDescArray[i].buf_addr = cpu_to_le32(dm_pci_mem_to_phys( + dev, (pci_addr_t)(unsigned long)tpc->RxBufferRing[i])); +#else tpc->RxDescArray[i].buf_addr = cpu_to_le32(pci_mem_to_phys( - bdf, (pci_addr_t)(unsigned long)tpc->RxBufferRing[i])); + dev, (pci_addr_t)(unsigned long)tpc->RxBufferRing[i])); +#endif rtl_flush_rx_desc(&tpc->RxDescArray[i]); }
@@ -805,7 +849,11 @@ static void rtl8169_init_ring(pci_dev_t bdf) #endif }
-static void rtl8169_common_start(pci_dev_t bdf, unsigned char *enetaddr) +#ifdef CONFIG_DM_ETH +static void rtl8169_common_start(struct udevice *dev, unsigned char *enetaddr) +#else +static void rtl8169_common_start(pci_dev_t dev, unsigned char *enetaddr) +#endif { int i;
@@ -814,8 +862,8 @@ static void rtl8169_common_start(pci_dev_t bdf, unsigned char *enetaddr) printf ("%s\n", __FUNCTION__); #endif
- rtl8169_init_ring(bdf); - rtl8169_hw_start(bdf); + rtl8169_init_ring(dev); + rtl8169_hw_start(dev); /* Construct a perfect filter frame with the mac address as first match * and broadcast for all others */ for (i = 0; i < 192; i++) @@ -838,7 +886,7 @@ static int rtl8169_eth_start(struct udevice *dev) { struct eth_pdata *plat = dev_get_platdata(dev);
- rtl8169_common_start(dm_pci_get_bdf(dev), plat->enetaddr); + rtl8169_common_start(dev, plat->enetaddr);
return 0; } @@ -1131,10 +1179,9 @@ static int rtl8169_eth_probe(struct udevice *dev) region = 1; break; } - pci_read_config32(dm_pci_get_bdf(dev), PCI_BASE_ADDRESS_0 + region * 4, - &iobase); + dm_pci_read_config32(dev, PCI_BASE_ADDRESS_0 + region * 4, &iobase); iobase &= ~0xf; - priv->iobase = (int)pci_mem_to_phys(dm_pci_get_bdf(dev), iobase); + priv->iobase = (int)dm_pci_mem_to_phys(dev, iobase);
ret = rtl_init(priv->iobase, dev->name, plat->enetaddr); if (ret < 0) {
Hi Simon,
Changes in v2:
uchar **packetp)
+#else
+#else
length);
tpc->cur_rx = 0;
+#else
rtl8169_common_start(dev, plat->enetaddr); return 0;
&iobase);
I see. This function is already wrapped in a #ifdef CONFIG_DM_ETH that is invisible in the diff. Thanks.
iobase &= ~0xf;
priv->iobase = (int)dm_pci_mem_to_phys(dev, iobase); ret = rtl_init(priv->iobase, dev->name, plat->enetaddr); if (ret < 0) {
We should use the new address mapping functions unless we are in compatibility mode. Disable the old functions by default.
Changes in v2: None
drivers/pci/pci_common.c | 2 +- include/pci.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/pci_common.c b/drivers/pci/pci_common.c index b388a1c..1755914 100644 --- a/drivers/pci/pci_common.c +++ b/drivers/pci/pci_common.c @@ -99,6 +99,7 @@ __weak int pci_skip_dev(struct pci_controller *hose, pci_dev_t dev) return 0; }
+#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) /* Get a virtual address associated with a BAR region */ void *pci_map_bar(pci_dev_t pdev, int bar, int flags) { @@ -271,7 +272,6 @@ pci_addr_t pci_hose_phys_to_bus(struct pci_controller *hose, return bus_addr; }
-#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) pci_dev_t pci_find_device(unsigned int vendor, unsigned int device, int index) { struct pci_device_id ids[2] = { {}, {0, 0} }; diff --git a/include/pci.h b/include/pci.h index 2be49be..9e811ca 100644 --- a/include/pci.h +++ b/include/pci.h @@ -621,6 +621,7 @@ static inline void pci_set_ops(struct pci_controller *hose, extern void pci_setup_indirect(struct pci_controller* hose, u32 cfg_addr, u32 cfg_data); #endif
+#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) extern phys_addr_t pci_hose_bus_to_phys(struct pci_controller* hose, pci_addr_t addr, unsigned long flags); extern pci_addr_t pci_hose_phys_to_bus(struct pci_controller* hose, @@ -656,7 +657,6 @@ extern pci_addr_t pci_hose_phys_to_bus(struct pci_controller* hose, pci_bus_to_virt((dev), (addr), PCI_REGION_IO, (len), (map_flags))
/* For driver model these are defined in macros in pci_compat.c */ -#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) extern int pci_hose_read_config_byte(struct pci_controller *hose, pci_dev_t dev, int where, u8 *val); extern int pci_hose_read_config_word(struct pci_controller *hose,
Convert this driver to use the new driver model PCI API.
Changes in v2: - Fix use of 'pdev' instead of 'dev' - Get the vendor from the PCI parent platdata - Use pci_bus_find_bdf()
drivers/block/ahci.c | 70 ++++++++++++++++++++++++++++++++++++++++++++++------ include/ahci.h | 4 +++ 2 files changed, 67 insertions(+), 7 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 1ad638e..e5f4a04 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -10,6 +10,7 @@ #include <common.h>
#include <command.h> +#include <dm.h> #include <pci.h> #include <asm/processor.h> #include <asm/errno.h> @@ -168,9 +169,14 @@ int ahci_reset(void __iomem *base) static int ahci_host_init(struct ahci_probe_ent *probe_ent) { #ifndef CONFIG_SCSI_AHCI_PLAT +# ifdef CONFIG_DM_PCI + struct udevice *dev = probe_ent->dev; + struct pci_child_platdata *pplat = dev_get_parent_platdata(dev); +# else pci_dev_t pdev = probe_ent->dev; - u16 tmp16; unsigned short vendor; +# endif + u16 tmp16; #endif void __iomem *mmio = probe_ent->mmio_base; u32 tmp, cap_save, cmd; @@ -193,6 +199,14 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) writel_with_flush(0xf, mmio + HOST_PORTS_IMPL);
#ifndef CONFIG_SCSI_AHCI_PLAT +# ifdef CONFIG_DM_PCI + if (pplat->vendor == PCI_VENDOR_ID_INTEL) { + u16 tmp16; + + dm_pci_read_config16(dev, 0x92, &tmp16); + dm_pci_write_config16(dev, 0x92, tmp16 | 0xf); + } +# else pci_read_config_word(pdev, PCI_VENDOR_ID, &vendor);
if (vendor == PCI_VENDOR_ID_INTEL) { @@ -201,6 +215,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) tmp16 |= 0xf; pci_write_config_word(pdev, 0x92, tmp16); } +# endif #endif probe_ent->cap = readl(mmio + HOST_CAP); probe_ent->port_map = readl(mmio + HOST_PORTS_IMPL); @@ -313,9 +328,15 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) tmp = readl(mmio + HOST_CTL); debug("HOST_CTL 0x%x\n", tmp); #ifndef CONFIG_SCSI_AHCI_PLAT +# ifdef CONFIG_DM_PCI + dm_pci_read_config16(dev, PCI_COMMAND, &tmp16); + tmp |= PCI_COMMAND_MASTER; + dm_pci_write_config16(dev, PCI_COMMAND, tmp16); +# else pci_read_config_word(pdev, PCI_COMMAND, &tmp16); tmp |= PCI_COMMAND_MASTER; pci_write_config_word(pdev, PCI_COMMAND, tmp16); +# endif #endif return 0; } @@ -324,7 +345,11 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) static void ahci_print_info(struct ahci_probe_ent *probe_ent) { #ifndef CONFIG_SCSI_AHCI_PLAT +# ifdef CONFIG_DM_PCI + struct udevice *dev = probe_ent->dev; +# else pci_dev_t pdev = probe_ent->dev; +# endif u16 cc; #endif void __iomem *mmio = probe_ent->mmio_base; @@ -350,7 +375,11 @@ static void ahci_print_info(struct ahci_probe_ent *probe_ent) #ifdef CONFIG_SCSI_AHCI_PLAT scc_s = "SATA"; #else +# ifdef CONFIG_DM_PCI + dm_pci_read_config16(dev, 0x0a, &cc); +# else pci_read_config_word(pdev, 0x0a, &cc); +# endif if (cc == 0x0101) scc_s = "IDE"; else if (cc == 0x0106) @@ -395,7 +424,11 @@ static void ahci_print_info(struct ahci_probe_ent *probe_ent) }
#ifndef CONFIG_SCSI_AHCI_PLAT -static int ahci_init_one(pci_dev_t pdev) +# ifdef CONFIG_DM_PCI +static int ahci_init_one(struct udevice *dev) +# else +static int ahci_init_one(pci_dev_t dev) +# endif { u16 vendor; int rc; @@ -407,7 +440,7 @@ static int ahci_init_one(pci_dev_t pdev) }
memset(probe_ent, 0, sizeof(struct ahci_probe_ent)); - probe_ent->dev = pdev; + probe_ent->dev = dev;
probe_ent->host_flags = ATA_FLAG_SATA | ATA_FLAG_NO_LEGACY @@ -417,18 +450,31 @@ static int ahci_init_one(pci_dev_t pdev) probe_ent->pio_mask = 0x1f; probe_ent->udma_mask = 0x7f; /*Fixme,assume to support UDMA6 */
- probe_ent->mmio_base = pci_map_bar(pdev, PCI_BASE_ADDRESS_5, +#ifdef CONFIG_DM_PCI + probe_ent->mmio_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_5, + PCI_REGION_MEM); + + /* Take from kernel: + * JMicron-specific fixup: + * make sure we're in AHCI mode + */ + dm_pci_read_config16(dev, PCI_VENDOR_ID, &vendor); + if (vendor == 0x197b) + dm_pci_write_config8(dev, 0x41, 0xa1); +#else + probe_ent->mmio_base = pci_map_bar(dev, PCI_BASE_ADDRESS_5, PCI_REGION_MEM); - debug("ahci mmio_base=0x%p\n", probe_ent->mmio_base);
/* Take from kernel: * JMicron-specific fixup: * make sure we're in AHCI mode */ - pci_read_config_word(pdev, PCI_VENDOR_ID, &vendor); + pci_read_config_word(dev, PCI_VENDOR_ID, &vendor); if (vendor == 0x197b) - pci_write_config_byte(pdev, 0x41, 0xa1); + pci_write_config_byte(dev, 0x41, 0xa1); +#endif
+ debug("ahci mmio_base=0x%p\n", probe_ent->mmio_base); /* initialize adapter */ rc = ahci_host_init(probe_ent); if (rc) @@ -915,7 +961,17 @@ void scsi_low_level_init(int busdevfunc) u32 linkmap;
#ifndef CONFIG_SCSI_AHCI_PLAT +# ifdef CONFIG_DM_PCI + struct udevice *dev; + int ret; + + ret = dm_pci_bus_find_bdf(busdevfunc, &dev); + if (ret) + return; + ahci_init_one(dev); +# else ahci_init_one(busdevfunc); +# endif #endif
linkmap = probe_ent->link_port_map; diff --git a/include/ahci.h b/include/ahci.h index 0bdedac..a956c6f 100644 --- a/include/ahci.h +++ b/include/ahci.h @@ -145,7 +145,11 @@ struct ahci_ioports { };
struct ahci_probe_ent { +#ifdef CONFIG_DM_PCI + struct udevice *dev; +#else pci_dev_t dev; +#endif struct ahci_ioports port[AHCI_MAX_PORTS]; u32 n_ports; u32 hard_port_no;
Changes in v2:
+# endif
u16 tmp16;
u16 tmp16;
probe_ent->dev = dev; probe_ent->host_flags = ATA_FLAG_SATA | ATA_FLAG_NO_LEGACY
PCI_REGION_MEM);
+#else
debug("ahci mmio_base=0x%p\n", probe_ent->mmio_base); /* Take from kernel: * JMicron-specific fixup: * make sure we're in AHCI mode */
int ret;
if (ret)
return;
ahci_init_one(dev);
+#else pci_dev_t dev; +#endif struct ahci_ioports port[AHCI_MAX_PORTS]; u32 n_ports; u32 hard_port_no; --
Changes in v2: - Use u32 instead of uint32_t - Use uintptr_t to cast the hcor address
drivers/usb/host/ehci-pci.c | 51 ++++++++++++++++++++++++++++++++++----------- 1 file changed, 39 insertions(+), 12 deletions(-)
diff --git a/drivers/usb/host/ehci-pci.c b/drivers/usb/host/ehci-pci.c index d607088..cda1c6d 100644 --- a/drivers/usb/host/ehci-pci.c +++ b/drivers/usb/host/ehci-pci.c @@ -18,32 +18,34 @@ struct ehci_pci_priv { struct ehci_ctrl ehci; };
-static void ehci_pci_common_init(pci_dev_t pdev, struct ehci_hccr **ret_hccr, - struct ehci_hcor **ret_hcor) +#ifdef CONFIG_DM_USB + +static void ehci_pci_init(struct udevice *dev, struct ehci_hccr **ret_hccr, + struct ehci_hcor **ret_hcor) { struct ehci_hccr *hccr; struct ehci_hcor *hcor; - uint32_t cmd; + u32 cmd;
- hccr = (struct ehci_hccr *)pci_map_bar(pdev, + hccr = (struct ehci_hccr *)dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM); - hcor = (struct ehci_hcor *)((uint32_t) hccr + + hcor = (struct ehci_hcor *)((uintptr_t) hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
debug("EHCI-PCI init hccr 0x%x and hcor 0x%x hc_length %d\n", - (uint32_t)hccr, (uint32_t)hcor, - (uint32_t)HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + (u32)hccr, (u32)hcor, + (u32)HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
*ret_hccr = hccr; *ret_hcor = hcor;
/* enable busmaster */ - pci_read_config_dword(pdev, PCI_COMMAND, &cmd); + dm_pci_read_config32(dev, PCI_COMMAND, &cmd); cmd |= PCI_COMMAND_MASTER; - pci_write_config_dword(pdev, PCI_COMMAND, cmd); + dm_pci_write_config32(dev, PCI_COMMAND, cmd); }
-#ifndef CONFIG_DM_USB +#else
#ifdef CONFIG_PCI_EHCI_DEVICE static struct pci_device_id ehci_pci_ids[] = { @@ -55,6 +57,31 @@ static struct pci_device_id ehci_pci_ids[] = { }; #endif
+static void ehci_pci_legacy_init(pci_dev_t pdev, struct ehci_hccr **ret_hccr, + struct ehci_hcor **ret_hcor) +{ + struct ehci_hccr *hccr; + struct ehci_hcor *hcor; + u32 cmd; + + hccr = (struct ehci_hccr *)pci_map_bar(pdev, + PCI_BASE_ADDRESS_0, PCI_REGION_MEM); + hcor = (struct ehci_hcor *)((uintptr_t) hccr + + HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + + debug("EHCI-PCI init hccr 0x%x and hcor 0x%x hc_length %d\n", + (u32)hccr, (u32)hcor, + (u32)HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + + *ret_hccr = hccr; + *ret_hcor = hcor; + + /* enable busmaster */ + pci_read_config_dword(pdev, PCI_COMMAND, &cmd); + cmd |= PCI_COMMAND_MASTER; + pci_write_config_dword(pdev, PCI_COMMAND, cmd); +} + /* * Create the appropriate control structures to manage * a new EHCI host controller. @@ -73,7 +100,7 @@ int ehci_hcd_init(int index, enum usb_init_type init, printf("EHCI host controller not found\n"); return -1; } - ehci_pci_common_init(pdev, ret_hccr, ret_hcor); + ehci_pci_legacy_init(pdev, ret_hccr, ret_hcor);
return 0; } @@ -94,7 +121,7 @@ static int ehci_pci_probe(struct udevice *dev) struct ehci_hccr *hccr; struct ehci_hcor *hcor;
- ehci_pci_common_init(dm_pci_get_bdf(dev), &hccr, &hcor); + ehci_pci_init(dev, &hccr, &hcor);
return ehci_register(dev, hccr, hcor, NULL, 0, USB_INIT_HOST); }
ad subject -- it's EHCI, not ECHI .
Changes in v2:
- uint32_t cmd;
- u32 cmd;
- hccr = (struct ehci_hccr *)dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM);
Use uintptr here as well then ?
- dm_pci_read_config32(dev, PCI_COMMAND, &cmd); cmd |= PCI_COMMAND_MASTER;
- dm_pci_write_config32(dev, PCI_COMMAND, cmd);
Looks good otherwise,
Acked-by: Marek Vasut marex@denx.de
Hi Marek,
Changes in v2:
uint32_t cmd;
u32 cmd;
hcor = (struct ehci_hcor *)((uintptr_t) hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase))); debug("EHCI-PCI init hccr 0x%x and hcor 0x%x hc_length %d\n",
That's a length rather than a pointer isn't it? Also it looks the same as the other example.
*ret_hccr = hccr; *ret_hcor = hcor; /* enable busmaster */
I can always update this with a patch or even rework this patch. But for now:
At present pci_mmc_init() does not correctly use the PCI function since the list it passes is not terminated. The array size passed to pci_mmc_init() is actually not used correctly. Fix this and adjust the pci_mmc_init() to scan all available MMC devices.
Adjust this code to use the new driver model PCI API.
This should move over to the new MMC uclass at some point.
Changes in v2: None
arch/x86/cpu/baytrail/valleyview.c | 4 ++-- arch/x86/cpu/quark/quark.c | 4 ++-- arch/x86/cpu/queensbay/topcliff.c | 4 ++-- drivers/mmc/pci_mmc.c | 15 +++++++-------- include/mmc.h | 6 ++---- 5 files changed, 15 insertions(+), 18 deletions(-)
diff --git a/arch/x86/cpu/baytrail/valleyview.c b/arch/x86/cpu/baytrail/valleyview.c index 9b30451..7299f2c 100644 --- a/arch/x86/cpu/baytrail/valleyview.c +++ b/arch/x86/cpu/baytrail/valleyview.c @@ -14,12 +14,12 @@ static struct pci_device_id mmc_supported[] = { { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_VALLEYVIEW_SDIO }, { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_VALLEYVIEW_SDCARD }, + {}, };
int cpu_mmc_init(bd_t *bis) { - return pci_mmc_init("ValleyView SDHCI", mmc_supported, - ARRAY_SIZE(mmc_supported)); + return pci_mmc_init("ValleyView SDHCI", mmc_supported); }
#ifndef CONFIG_EFI_APP diff --git a/arch/x86/cpu/quark/quark.c b/arch/x86/cpu/quark/quark.c index c2bf497..37ce394 100644 --- a/arch/x86/cpu/quark/quark.c +++ b/arch/x86/cpu/quark/quark.c @@ -19,6 +19,7 @@
static struct pci_device_id mmc_supported[] = { { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_QRK_SDIO }, + {}, };
/* @@ -337,8 +338,7 @@ int arch_early_init_r(void)
int cpu_mmc_init(bd_t *bis) { - return pci_mmc_init("Quark SDHCI", mmc_supported, - ARRAY_SIZE(mmc_supported)); + return pci_mmc_init("Quark SDHCI", mmc_supported); }
void cpu_irq_init(void) diff --git a/arch/x86/cpu/queensbay/topcliff.c b/arch/x86/cpu/queensbay/topcliff.c index 9faf1b9..b76dd7d 100644 --- a/arch/x86/cpu/queensbay/topcliff.c +++ b/arch/x86/cpu/queensbay/topcliff.c @@ -11,10 +11,10 @@ static struct pci_device_id mmc_supported[] = { { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_TCF_SDIO_0 }, { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_TCF_SDIO_1 }, + {}, };
int cpu_mmc_init(bd_t *bis) { - return pci_mmc_init("Topcliff SDHCI", mmc_supported, - ARRAY_SIZE(mmc_supported)); + return pci_mmc_init("Topcliff SDHCI", mmc_supported); } diff --git a/drivers/mmc/pci_mmc.c b/drivers/mmc/pci_mmc.c index 37171bf..5fb7151 100644 --- a/drivers/mmc/pci_mmc.c +++ b/drivers/mmc/pci_mmc.c @@ -11,26 +11,25 @@ #include <sdhci.h> #include <asm/pci.h>
-int pci_mmc_init(const char *name, struct pci_device_id *mmc_supported, - int num_ids) +int pci_mmc_init(const char *name, struct pci_device_id *mmc_supported) { struct sdhci_host *mmc_host; - pci_dev_t devbusfn; u32 iobase; int ret; int i;
- for (i = 0; i < num_ids; i++) { - devbusfn = pci_find_devices(mmc_supported, i); - if (devbusfn == -1) - return -ENODEV; + for (i = 0; ; i++) { + struct udevice *dev;
+ ret = pci_find_device_id(mmc_supported, i, &dev); + if (ret) + return ret; mmc_host = malloc(sizeof(struct sdhci_host)); if (!mmc_host) return -ENOMEM;
mmc_host->name = (char *)name; - pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_0, &iobase); + dm_pci_read_config32(dev, PCI_BASE_ADDRESS_0, &iobase); mmc_host->ioaddr = (void *)iobase; mmc_host->quirks = 0; ret = add_sdhci(mmc_host, 0, 0); diff --git a/include/mmc.h b/include/mmc.h index cda9a19..a844cf5 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -484,11 +484,9 @@ struct pci_device_id; * This finds all the matching PCI IDs and sets them up as MMC devices. * * @name: Name to use for devices - * @mmc_supported: PCI IDs to search for - * @num_ids: Number of elements in @mmc_supported + * @mmc_supported: PCI IDs to search for, terminated by {0, 0} */ -int pci_mmc_init(const char *name, struct pci_device_id *mmc_supported, - int num_ids); +int pci_mmc_init(const char *name, struct pci_device_id *mmc_supported);
/* Set block count limit because of 16 bit register limit on some hardware*/ #ifndef CONFIG_SYS_MMC_MAX_BLK_COUNT
Changes in v2: None
int num_ids)
if (devbusfn == -1)
return -ENODEV;
if (ret)
return ret; mmc_host = malloc(sizeof(struct sdhci_host)); if (!mmc_host) return -ENOMEM; mmc_host->name = (char *)name;
- This finds all the matching PCI IDs and sets them up as MMC devices.
- @name: Name to use for devices
- @mmc_supported: PCI IDs to search for
- @num_ids: Number of elements in @mmc_supported
- @mmc_supported: PCI IDs to search for, terminated by {0, 0}
int num_ids);
The current comments are confusing. We don't actually bind a generic device when the device tree has no information. We try to scan available PCI drivers. Update the comments to reflect this.
Changes in v2: None
drivers/pci/pci-uclass.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 80e234b..54b5dbc 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -674,9 +674,7 @@ int pci_bind_bus_devices(struct udevice *bus) /* Find this device in the device tree */ ret = pci_bus_find_devfn(bus, PCI_MASK_BUS(bdf), &dev);
- /* Search for a driver */ - - /* If nothing in the device tree, bind a generic device */ + /* If nothing in the device tree, bind a device */ if (ret == -ENODEV) { struct pci_device_id find_id; ulong val;
Remove stamp data and create common functions for the main Ethernet operations. This will make it easier to convert this driver to support driver model.
Signed-off-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v2: None
drivers/usb/eth/mcs7830.c | 265 +++++++++++++++++++++++++--------------------- 1 file changed, 144 insertions(+), 121 deletions(-)
diff --git a/drivers/usb/eth/mcs7830.c b/drivers/usb/eth/mcs7830.c index bbdad8b..de40bd6 100644 --- a/drivers/usb/eth/mcs7830.c +++ b/drivers/usb/eth/mcs7830.c @@ -89,13 +89,13 @@ struct mcs7830_private {
/* * mcs7830_read_reg() - read a register of the network adapter - * @dev: network device to read from + * @udev: network device to read from * @idx: index of the register to start reading from * @size: number of bytes to read * @data: buffer to read into * Return: zero upon success, negative upon error */ -static int mcs7830_read_reg(struct ueth_data *dev, uint8_t idx, +static int mcs7830_read_reg(struct usb_device *udev, uint8_t idx, uint16_t size, void *data) { int len; @@ -103,8 +103,8 @@ static int mcs7830_read_reg(struct ueth_data *dev, uint8_t idx,
debug("%s() idx=0x%04X sz=%d\n", __func__, idx, size);
- len = usb_control_msg(dev->pusb_dev, - usb_rcvctrlpipe(dev->pusb_dev, 0), + len = usb_control_msg(udev, + usb_rcvctrlpipe(udev, 0), MCS7830_RD_BREQ, USB_DIR_IN | USB_TYPE_VENDOR | USB_RECIP_DEVICE, 0, idx, buf, size, @@ -119,13 +119,13 @@ static int mcs7830_read_reg(struct ueth_data *dev, uint8_t idx,
/* * mcs7830_write_reg() - write a register of the network adapter - * @dev: network device to write to + * @udev: network device to write to * @idx: index of the register to start writing to * @size: number of bytes to write * @data: buffer holding the data to write * Return: zero upon success, negative upon error */ -static int mcs7830_write_reg(struct ueth_data *dev, uint8_t idx, +static int mcs7830_write_reg(struct usb_device *udev, uint8_t idx, uint16_t size, void *data) { int len; @@ -134,8 +134,8 @@ static int mcs7830_write_reg(struct ueth_data *dev, uint8_t idx, debug("%s() idx=0x%04X sz=%d\n", __func__, idx, size);
memcpy(buf, data, size); - len = usb_control_msg(dev->pusb_dev, - usb_sndctrlpipe(dev->pusb_dev, 0), + len = usb_control_msg(udev, + usb_sndctrlpipe(udev, 0), MCS7830_WR_BREQ, USB_DIR_OUT | USB_TYPE_VENDOR | USB_RECIP_DEVICE, 0, idx, buf, size, @@ -149,12 +149,12 @@ static int mcs7830_write_reg(struct ueth_data *dev, uint8_t idx,
/* * mcs7830_phy_emit_wait() - emit PHY read/write access, wait for its execution - * @dev: network device to talk to + * @udev: network device to talk to * @rwflag: PHY_CMD1_READ or PHY_CMD1_WRITE opcode * @index: number of the PHY register to read or write * Return: zero upon success, negative upon error */ -static int mcs7830_phy_emit_wait(struct ueth_data *dev, +static int mcs7830_phy_emit_wait(struct usb_device *udev, uint8_t rwflag, uint8_t index) { int rc; @@ -164,14 +164,14 @@ static int mcs7830_phy_emit_wait(struct ueth_data *dev, /* send the PHY read/write request */ cmd[0] = rwflag | PHY_CMD1_PHYADDR; cmd[1] = PHY_CMD2_PEND | (index & 0x1f); - rc = mcs7830_write_reg(dev, REG_PHY_CMD, sizeof(cmd), cmd); + rc = mcs7830_write_reg(udev, REG_PHY_CMD, sizeof(cmd), cmd); if (rc < 0) return rc;
/* wait for the response to become available (usually < 1ms) */ retry = 10; do { - rc = mcs7830_read_reg(dev, REG_PHY_CMD, sizeof(cmd), cmd); + rc = mcs7830_read_reg(udev, REG_PHY_CMD, sizeof(cmd), cmd); if (rc < 0) return rc; if (cmd[1] & PHY_CMD2_READY) @@ -185,50 +185,51 @@ static int mcs7830_phy_emit_wait(struct ueth_data *dev,
/* * mcs7830_read_phy() - read a PHY register of the network adapter - * @dev: network device to read from + * @udev: network device to read from * @index: index of the PHY register to read from * Return: non-negative 16bit register content, negative upon error */ -static int mcs7830_read_phy(struct ueth_data *dev, uint8_t index) +static int mcs7830_read_phy(struct usb_device *udev, uint8_t index) { int rc; uint16_t val;
/* issue the PHY read request and wait for its execution */ - rc = mcs7830_phy_emit_wait(dev, PHY_CMD1_READ, index); + rc = mcs7830_phy_emit_wait(udev, PHY_CMD1_READ, index); if (rc < 0) return rc;
/* fetch the PHY data which was read */ - rc = mcs7830_read_reg(dev, REG_PHY_DATA, sizeof(val), &val); + rc = mcs7830_read_reg(udev, REG_PHY_DATA, sizeof(val), &val); if (rc < 0) return rc; rc = le16_to_cpu(val); - debug("%s(%s, %d) => 0x%04X\n", __func__, dev->eth_dev.name, index, rc); + debug("%s(%d) => 0x%04X\n", __func__, index, rc); return rc; }
/* * mcs7830_write_phy() - write a PHY register of the network adapter - * @dev: network device to write to + * @udev: network device to write to * @index: index of the PHY register to write to * @val: value to write to the PHY register * Return: zero upon success, negative upon error */ -static int mcs7830_write_phy(struct ueth_data *dev, uint8_t index, uint16_t val) +static int mcs7830_write_phy(struct usb_device *udev, uint8_t index, + uint16_t val) { int rc;
- debug("%s(%s, %d, 0x%04X)\n", __func__, dev->eth_dev.name, index, val); + debug("%s(%d, 0x%04X)\n", __func__, index, val);
/* setup the PHY data which is to get written */ val = cpu_to_le16(val); - rc = mcs7830_write_reg(dev, REG_PHY_DATA, sizeof(val), &val); + rc = mcs7830_write_reg(udev, REG_PHY_DATA, sizeof(val), &val); if (rc < 0) return rc;
/* issue the PHY write request and wait for its execution */ - rc = mcs7830_phy_emit_wait(dev, PHY_CMD1_WRITE, index); + rc = mcs7830_phy_emit_wait(udev, PHY_CMD1_WRITE, index); if (rc < 0) return rc;
@@ -237,21 +238,21 @@ static int mcs7830_write_phy(struct ueth_data *dev, uint8_t index, uint16_t val)
/* * mcs7830_write_config() - write to the network adapter's config register - * @eth: network device to write to + * @udev: network device to write to + * @priv: private data * Return: zero upon success, negative upon error * * the data which gets written is taken from the shadow config register * within the device driver's private data */ -static int mcs7830_write_config(struct ueth_data *dev) +static int mcs7830_write_config(struct usb_device *udev, + struct mcs7830_private *priv) { - struct mcs7830_private *priv; int rc;
debug("%s()\n", __func__); - priv = dev->dev_priv;
- rc = mcs7830_write_reg(dev, REG_CONFIG, + rc = mcs7830_write_reg(udev, REG_CONFIG, sizeof(priv->config), &priv->config); if (rc < 0) { debug("writing config to adapter failed\n"); @@ -263,21 +264,21 @@ static int mcs7830_write_config(struct ueth_data *dev)
/* * mcs7830_write_mchash() - write the network adapter's multicast filter - * @eth: network device to write to + * @udev: network device to write to + * @priv: private data * Return: zero upon success, negative upon error * * the data which gets written is taken from the shadow multicast hashes * within the device driver's private data */ -static int mcs7830_write_mchash(struct ueth_data *dev) +static int mcs7830_write_mchash(struct usb_device *udev, + struct mcs7830_private *priv) { - struct mcs7830_private *priv; int rc;
- rc = mcs7830_write_reg(dev, REG_MULTICAST_HASH, + rc = mcs7830_write_reg(udev, REG_MULTICAST_HASH, sizeof(priv->mchash), &priv->mchash); if (rc < 0) { debug("writing multicast hash to adapter failed\n"); @@ -289,12 +290,12 @@ static int mcs7830_write_mchash(struct ueth_data *dev)
/* * mcs7830_set_autoneg() - setup and trigger ethernet link autonegotiation - * @eth: network device to run link negotiation on + * @udev: network device to run link negotiation on * Return: zero upon success, negative upon error * * the routine advertises available media and starts autonegotiation */ -static int mcs7830_set_autoneg(struct ueth_data *dev) +static int mcs7830_set_autoneg(struct usb_device *udev) { int adv, flg; int rc; @@ -310,39 +311,39 @@ static int mcs7830_set_autoneg(struct ueth_data *dev) */
adv = ADVERTISE_PAUSE_CAP | ADVERTISE_ALL | ADVERTISE_CSMA; - rc = mcs7830_write_phy(dev, MII_ADVERTISE, adv); + rc = mcs7830_write_phy(udev, MII_ADVERTISE, adv);
flg = 0; if (!rc) - rc = mcs7830_write_phy(dev, MII_BMCR, flg); + rc = mcs7830_write_phy(udev, MII_BMCR, flg);
flg |= BMCR_ANENABLE; if (!rc) - rc = mcs7830_write_phy(dev, MII_BMCR, flg); + rc = mcs7830_write_phy(udev, MII_BMCR, flg);
flg |= BMCR_ANRESTART; if (!rc) - rc = mcs7830_write_phy(dev, MII_BMCR, flg); + rc = mcs7830_write_phy(udev, MII_BMCR, flg);
return rc; }
/* * mcs7830_get_rev() - identify a network adapter's chip revision - * @eth: network device to identify + * @udev: network device to identify * Return: non-negative number, reflecting the revision number * * currently, only "rev C and higher" and "below rev C" are needed, so * the return value is #1 for "below rev C", and #2 for "rev C and above" */ -static int mcs7830_get_rev(struct ueth_data *dev) +static int mcs7830_get_rev(struct usb_device *udev) { uint8_t buf[2]; int rc; int rev;
/* register 22 is readable in rev C and higher */ - rc = mcs7830_read_reg(dev, REG_FRAME_DROP_COUNTER, sizeof(buf), buf); + rc = mcs7830_read_reg(udev, REG_FRAME_DROP_COUNTER, sizeof(buf), buf); if (rc < 0) rev = 1; else @@ -353,19 +354,19 @@ static int mcs7830_get_rev(struct ueth_data *dev)
/* * mcs7830_apply_fixup() - identify an adapter and potentially apply fixups - * @eth: network device to identify and apply fixups to + * @udev: network device to identify and apply fixups to * Return: zero upon success (no errors emitted from here) * * this routine identifies the network adapter's chip revision, and applies * fixups for known issues */ -static int mcs7830_apply_fixup(struct ueth_data *dev) +static int mcs7830_apply_fixup(struct usb_device *udev) { int rev; int i; uint8_t thr;
- rev = mcs7830_get_rev(dev); + rev = mcs7830_get_rev(udev); debug("%s() rev=%d\n", __func__, rev);
/* @@ -374,10 +375,10 @@ static int mcs7830_apply_fixup(struct ueth_data *dev) * exactly", the introductory comment says "rev C and above") */ if (rev == 2) { - debug("%s: applying rev C fixup\n", dev->eth_dev.name); + debug("%s: applying rev C fixup\n", __func__); thr = PAUSE_THRESHOLD_DEFAULT; for (i = 0; i < 2; i++) { - (void)mcs7830_write_reg(dev, REG_PAUSE_THRESHOLD, + (void)mcs7830_write_reg(udev, REG_PAUSE_THRESHOLD, sizeof(thr), &thr); mdelay(1); } @@ -395,13 +396,12 @@ static int mcs7830_apply_fixup(struct ueth_data *dev) * of the interface callbacks can exchange ethernet frames; link negotiation is * triggered from here already and continues in background */ -static int mcs7830_basic_reset(struct ueth_data *dev) +static int mcs7830_basic_reset(struct usb_device *udev, + struct mcs7830_private *priv) { - struct mcs7830_private *priv; int rc;
/* * comment from the respective Linux driver, which @@ -411,25 +411,25 @@ static int mcs7830_basic_reset(struct ueth_data *dev) priv->config = CONF_TXENABLE; priv->config |= CONF_ALLMULTICAST;
- rc = mcs7830_set_autoneg(dev); + rc = mcs7830_set_autoneg(udev); if (rc < 0) { error("setting autoneg failed\n"); return rc; }
- rc = mcs7830_write_mchash(dev); + rc = mcs7830_write_mchash(udev, priv); if (rc < 0) { error("failed to set multicast hash\n"); return rc; }
- rc = mcs7830_write_config(dev); + rc = mcs7830_write_config(udev, priv); if (rc < 0) { error("failed to set configuration\n"); return rc; }
- rc = mcs7830_apply_fixup(dev); + rc = mcs7830_apply_fixup(udev); if (rc < 0) { error("fixup application failed\n"); return rc; @@ -440,51 +440,38 @@ static int mcs7830_basic_reset(struct ueth_data *dev)
/* * mcs7830_read_mac() - read an ethernet adapter's MAC address - * @eth: network device to read from + * @udev: network device to read from + * @enetaddr: place to put ethernet MAC address * Return: zero upon success, negative upon error * * this routine fetches the MAC address stored within the ethernet adapter, * and stores it in the ethernet interface's data structure */ -static int mcs7830_read_mac(struct eth_device *eth) +static int mcs7830_read_mac(struct usb_device *udev, unsigned char enetaddr[]) { - struct ueth_data *dev; int rc; uint8_t buf[ETH_ALEN];
debug("%s()\n", __func__); - dev = eth->priv;
- rc = mcs7830_read_reg(dev, REG_ETHER_ADDR, ETH_ALEN, buf); + rc = mcs7830_read_reg(udev, REG_ETHER_ADDR, ETH_ALEN, buf); if (rc < 0) { debug("reading MAC from adapter failed\n"); return rc; }
- memcpy(ð->enetaddr[0], buf, ETH_ALEN); + memcpy(enetaddr, buf, ETH_ALEN); return 0; }
-/* - * mcs7830_write_mac() - write an ethernet adapter's MAC address - * @eth: network device to write to - * Return: zero upon success, negative upon error - * - * this routine takes the MAC address from the ethernet interface's data - * structure, and writes it into the ethernet adapter such that subsequent - * exchange of ethernet frames uses this address - */ -static int mcs7830_write_mac(struct eth_device *eth) +static int mcs7830_write_mac_common(struct usb_device *udev, + unsigned char enetaddr[]) { - struct ueth_data *dev; int rc;
- if (sizeof(eth->enetaddr) != ETH_ALEN) - return -EINVAL; - rc = mcs7830_write_reg(dev, REG_ETHER_ADDR, ETH_ALEN, eth->enetaddr); + rc = mcs7830_write_reg(udev, REG_ETHER_ADDR, ETH_ALEN, enetaddr); if (rc < 0) { debug("writing MAC to adapter failed\n"); return rc; @@ -492,28 +479,16 @@ static int mcs7830_write_mac(struct eth_device *eth) return 0; }
-/* - * mcs7830_init() - network interface's init callback - * @eth: network device to initialize - * @bd: board information - * Return: zero upon success, negative upon error - * - * after initial setup during probe() and get_info(), this init() callback - * ensures that the link is up and subsequent send() and recv() calls can - * exchange ethernet frames - */ -static int mcs7830_init(struct eth_device *eth, bd_t *bd) +static int mcs7830_init_common(struct usb_device *udev) { - struct ueth_data *dev; int timeout; int have_link;
timeout = 0; do { - have_link = mcs7830_read_phy(dev, MII_BMSR) & BMSR_LSTATUS; + have_link = mcs7830_read_phy(udev, MII_BMSR) & BMSR_LSTATUS; if (have_link) break; udelay(LINKSTATUS_TIMEOUT_RES * 1000); @@ -526,28 +501,18 @@ static int mcs7830_init(struct eth_device *eth, bd_t *bd) return 0; }
-/* - * mcs7830_send() - network interface's send callback - * @eth: network device to send the frame from - * @packet: ethernet frame content - * @length: ethernet frame length - * Return: zero upon success, negative upon error - * - * this routine send an ethernet frame out of the network interface - */ -static int mcs7830_send(struct eth_device *eth, void *packet, int length) +static int mcs7830_send_common(struct ueth_data *ueth, void *packet, + int length) { - struct ueth_data *dev; + struct usb_device *udev = ueth->pusb_dev; int rc; int gotlen; /* there is a status byte after the ethernet frame */ ALLOC_CACHE_ALIGN_BUFFER(uint8_t, buf, PKTSIZE + sizeof(uint8_t));
- dev = eth->priv; - memcpy(buf, packet, length); - rc = usb_bulk_msg(dev->pusb_dev, - usb_sndbulkpipe(dev->pusb_dev, dev->ep_out), + rc = usb_bulk_msg(udev, + usb_sndbulkpipe(udev, ueth->ep_out), &buf[0], length, &gotlen, USBCALL_TIMEOUT); debug("%s() TX want len %d, got len %d, rc %d\n", @@ -555,28 +520,17 @@ static int mcs7830_send(struct eth_device *eth, void *packet, int length) return rc; }
-/* - * mcs7830_recv() - network interface's recv callback - * @eth: network device to receive frames from - * Return: zero upon success, negative upon error - * - * this routine checks for available ethernet frames that the network - * interface might have received, and notifies the network stack - */ -static int mcs7830_recv(struct eth_device *eth) +static int mcs7830_recv_common(struct ueth_data *ueth, uint8_t *buf) { - struct ueth_data *dev; - ALLOC_CACHE_ALIGN_BUFFER(uint8_t, buf, MCS7830_RX_URB_SIZE); int rc, wantlen, gotlen; uint8_t sts;
/* fetch input data from the adapter */ wantlen = MCS7830_RX_URB_SIZE; - rc = usb_bulk_msg(dev->pusb_dev, - usb_rcvbulkpipe(dev->pusb_dev, dev->ep_in), + rc = usb_bulk_msg(ueth->pusb_dev, + usb_rcvbulkpipe(ueth->pusb_dev, ueth->ep_in), &buf[0], wantlen, &gotlen, USBCALL_TIMEOUT); debug("%s() RX want len %d, got len %d, rc %d\n", @@ -601,8 +555,7 @@ static int mcs7830_recv(struct eth_device *eth)
if (sts == STAT_RX_FRAME_CORRECT) { debug("%s() got a frame, len=%d\n", __func__, gotlen); - net_process_received_packet(buf, gotlen); - return 0; + return gotlen; }
debug("RX: frame error (sts 0x%02X, %s %s %s %s %s)\n", @@ -616,6 +569,60 @@ static int mcs7830_recv(struct eth_device *eth) }
/* + * mcs7830_init() - network interface's init callback + * @udev: network device to initialize + * @bd: board information + * Return: zero upon success, negative upon error + * + * after initial setup during probe() and get_info(), this init() callback + * ensures that the link is up and subsequent send() and recv() calls can + * exchange ethernet frames + */ +static int mcs7830_init(struct eth_device *eth, bd_t *bd) +{ + struct ueth_data *dev = eth->priv; + + return mcs7830_init_common(dev->pusb_dev); +} + +/* + * mcs7830_send() - network interface's send callback + * @eth: network device to send the frame from + * @packet: ethernet frame content + * @length: ethernet frame length + * Return: zero upon success, negative upon error + * + * this routine send an ethernet frame out of the network interface + */ +static int mcs7830_send(struct eth_device *eth, void *packet, int length) +{ + struct ueth_data *dev = eth->priv; + + return mcs7830_send_common(dev, packet, length); +} + +/* + * mcs7830_recv() - network interface's recv callback + * @eth: network device to receive frames from + * Return: zero upon success, negative upon error + * + * this routine checks for available ethernet frames that the network + * interface might have received, and notifies the network stack + */ +static int mcs7830_recv(struct eth_device *eth) +{ + ALLOC_CACHE_ALIGN_BUFFER(uint8_t, buf, MCS7830_RX_URB_SIZE); + struct ueth_data *ueth = eth->priv; + int len; + + len = mcs7830_recv_common(ueth, buf); + if (len <= 0) + net_process_received_packet(buf, len); + + return 0; +} + +/* * mcs7830_halt() - network interface's halt callback * @eth: network device to cease operation of * Return: none @@ -629,6 +636,22 @@ static void mcs7830_halt(struct eth_device *eth) }
/* + * mcs7830_write_mac() - write an ethernet adapter's MAC address + * @eth: network device to write to + * Return: zero upon success, negative upon error + * + * this routine takes the MAC address from the ethernet interface's data + * structure, and writes it into the ethernet adapter such that subsequent + * exchange of ethernet frames uses this address + */ +static int mcs7830_write_mac(struct eth_device *eth) +{ + struct ueth_data *ueth = eth->priv; + + return mcs7830_write_mac_common(ueth->pusb_dev, eth->enetaddr); +} + +/* * mcs7830_iface_idx - index of detected network interfaces * * this counter keeps track of identified supported interfaces, @@ -802,10 +825,10 @@ int mcs7830_eth_get_info(struct usb_device *dev, struct ueth_data *ss, eth->write_hwaddr = mcs7830_write_mac; eth->priv = ss;
- if (mcs7830_basic_reset(ss)) + if (mcs7830_basic_reset(ss->pusb_dev, ss->dev_priv)) return 0;
- if (mcs7830_read_mac(eth)) + if (mcs7830_read_mac(ss->pusb_dev, eth->enetaddr)) return 0; debug("MAC %pM\n", eth->enetaddr);
Applied to u-boot-dm/next.
Adjust this driver to support driver model for Ethernet.
Changes in v2: None
drivers/usb/eth/mcs7830.c | 105 ++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 105 insertions(+)
diff --git a/drivers/usb/eth/mcs7830.c b/drivers/usb/eth/mcs7830.c index de40bd6..9d6cf8c 100644 --- a/drivers/usb/eth/mcs7830.c +++ b/drivers/usb/eth/mcs7830.c @@ -11,6 +11,7 @@ */
#include <common.h> +#include <dm.h> #include <errno.h> #include <linux/mii.h> #include <malloc.h> @@ -83,6 +84,10 @@ struct mcs7830_regs { * @mchash: shadow for the network adapter's multicast hash registers */ struct mcs7830_private { +#ifdef CONFIG_DM_ETH + uint8_t rx_buf[MCS7830_RX_URB_SIZE]; + struct ueth_data ueth; +#endif uint8_t config; uint8_t mchash[8]; }; @@ -568,6 +573,7 @@ static int mcs7830_recv_common(struct ueth_data *ueth, uint8_t *buf) return -EIO; }
+#ifndef CONFIG_DM_ETH /* * mcs7830_init() - network interface's init callback * @udev: network device to initialize @@ -834,3 +840,102 @@ int mcs7830_eth_get_info(struct usb_device *dev, struct ueth_data *ss,
return 1; } +#endif + + +#ifdef CONFIG_DM_ETH +static int mcs7830_eth_start(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + + return mcs7830_init_common(udev); +} + +void mcs7830_eth_stop(struct udevice *dev) +{ + debug("** %s()\n", __func__); +} + +int mcs7830_eth_send(struct udevice *dev, void *packet, int length) +{ + struct mcs7830_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + + return mcs7830_send_common(ueth, packet, length); +} + +int mcs7830_eth_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct mcs7830_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + int len; + + len = mcs7830_recv_common(ueth, priv->rx_buf); + *packetp = priv->rx_buf; + + return len; +} + +static int mcs7830_free_pkt(struct udevice *dev, uchar *packet, int packet_len) +{ + struct mcs7830_private *priv = dev_get_priv(dev); + + packet_len = ALIGN(packet_len, 4); + usb_ether_advance_rxbuf(&priv->ueth, sizeof(u32) + packet_len); + + return 0; +} + +int mcs7830_write_hwaddr(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + + return mcs7830_write_mac_common(udev, pdata->enetaddr); +} + +static int mcs7830_eth_probe(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct mcs7830_private *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + struct ueth_data *ueth = &priv->ueth; + + if (mcs7830_basic_reset(udev, priv)) + return 0; + + if (mcs7830_read_mac(udev, pdata->enetaddr)) + return 0; + + return usb_ether_register(dev, ueth, MCS7830_RX_URB_SIZE); +} + +static const struct eth_ops mcs7830_eth_ops = { + .start = mcs7830_eth_start, + .send = mcs7830_eth_send, + .recv = mcs7830_eth_recv, + .free_pkt = mcs7830_free_pkt, + .stop = mcs7830_eth_stop, + .write_hwaddr = mcs7830_write_hwaddr, +}; + +U_BOOT_DRIVER(mcs7830_eth) = { + .name = "mcs7830_eth", + .id = UCLASS_ETH, + .probe = mcs7830_eth_probe, + .ops = &mcs7830_eth_ops, + .priv_auto_alloc_size = sizeof(struct mcs7830_private), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +}; + +static const struct usb_device_id mcs7830_eth_id_table[] = { + { USB_DEVICE(0x9710, 0x7832) }, /* Moschip 7832 */ + { USB_DEVICE(0x9710, 0x7830), }, /* Moschip 7830 */ + { USB_DEVICE(0x9710, 0x7730), }, /* Moschip 7730 */ + { USB_DEVICE(0x0df6, 0x0021), }, /* Sitecom LN 30 */ + { } /* Terminating entry */ +}; + +U_BOOT_USB_DEVICE(mcs7830_eth, mcs7830_eth_id_table); +#endif
participants (6)
Anatolij Gustschin
Bin Meng
Joe Hershberger
Stephen Warren
