[U-Boot-Users] u-boot for MPC8266-PCI board
Rune and Yuli,
thank you for your replies. I tried out Rune's hints and found the board resetting continously after initialization of the SDRAM. I enabled the debug messages in the SDRAM initialization sequence and found the following memory controller settings:
U-Boot 0.4.5 (Jul 28 2003 - 14:18:33)
MPC8260 Reset Status: External Soft, External Hard
MPC8260 Clock Configuration - Bus-to-Core Mult 3x, VCO Div 2, 60x Bus Freq 33-100, Core Freq 100-300 - dfbrg 0, corecnf 0x08, busdf 3, cpmdf 1, plldf 0, pllmf 1 - vco_out 264000000, scc_clk 66000000, brg_clk 66000000 - cpu_clk 198000000, cpm_clk 132000000, bus_clk 66000000
CPU: MPC8260 (HiP4 Rev 14, Mask A.0(A) 2K25A) at 198 MHz Board: Motorola MPC8266ADS I2C: ready DRAM: memctl->memc_mptpr = 0x00001900 memctl->memc_psrt = 0x00000021 memctl->memc_br2 = 0x00000041 memctl->memc_or2 = 0xff001080 memctl->memc_psdmr = 0xeb6eb493 ramaddr = 0x00000008 memctl->memc_psdmr = 0xcb6eb493 memctl->memc_psdmr = 0xdb6eb493 memctl->memc_psdmr = 0xc36eb493 SDRAM configuration read from SPD Size per side = 16MB Organization: 1 sides, 2 banks, 9 Columns, 11 Rows, Data width = 64 bits Refresh rate = 33, CAS latency = 3 Total size: 16 MB
In the u-boot-0.3.0 source tree I found that the memory controller was programmed with hard-set values. Trying these values I found that u-boot started to the prompt without problems. The settings are listed below:
U-Boot 0.4.5 (Jul 28 2003 - 16:44:07)
MPC8260 Reset Status: Software Watchdog, External Soft, External Hard
CPU: MPC8260 (HiP4 Rev 14, Mask A.0(A) 2K25A) at 198 MHz Board: Motorola MPC8266ADS I2C: ready DRAM: memctl->memc_mptpr = 0x00001900 memctl->memc_psrt = 0x00000021 memctl->memc_br2 = 0x00000041 memctl->memc_or2 = 0xff001080 memctl->memc_psdmr = 0x296eb452 <=> 0xeb6eb493 ramaddr = 0x00000008 memctl->memc_psdmr = 0x096eb452 <=> 0xcb6eb493 memctl->memc_psdmr = 0x196eb452 <=> 0xdb6eb493 memctl->memc_psdmr = 0x416eb452 <=> 0xc36eb493 SDRAM configuration read from SPD Size per side = 16MB Organization: 1 sides, 2 banks, 9 Columns, 11 Rows, Data width = 64 bits Refresh rate = 33, CAS latency = 3 Total size: 16 MB FLASH: 8 MB *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: FCC2 ETHERNET Hit any key to stop autoboot =>
Playing with the parameters I found that the problem is located in the SDAM bits of the PSDMR register which have to be programmed for my board as shown in the second setting. Any ideas?
I have another question according the CIP and BMS settings of the HRCW. They are both set to '1' which means that exceptions are vectored to 0x000n_nnnn and boot memory region is located at 0x0000_0000. I tried out to set those bits to '0', it didn't work. Why?
Thomas Schäfer
____________________________________
GIGA STREAM GmbH
Konrad-Zuse-Str. 7 66115 Saarbrücken
Tel.: + 49 (0)681 / 95916 - 203 Fax: + 49 (0)681 / 95916 - 100 E-mail: tschaefer@giga-stream.de
Hi all,
actually I traced down this problem. It has something to do with the setting of the address multiplexing bits in the PSDMR register.
As stated in chapter 10.4.5.1 of the "MPC8260 PowerQUICC Users's Manual" the SDAM setting has to equal to the shift count of the address lines lowered by 8 (sdma = <address_shift> - 8) In chapter 10.4.12.1 there is a example of the page based interleaving configuration. From tbale 10-22 you get that the shift count to multiplex the address for row and column is (rows + banks) where banks is the number of address lines used to address the internal banks. This would conclude to a setting of the SDAM bits to sdam = cols + banks - 8;
Would you agree? In that case line 430 of board/mpc8266ads/mpc8266ads.c (sdam = cols - 6) would need to be corrected. That line failed in our case because we have only 2 banks (which makes the banks setting to 1). I assume you only tested with a 4 bank SDRAM.
Any comment would be apreciated. Georg
Rune and Yuli,
Thomas Schäfer
GIGA STREAM GmbH
This SF.Net email sponsored by: Free pre-built ASP.NET sites including Data Reports, E-commerce, Portals, and Forums are available now. Download today and enter to win an XBOX or Visual Studio .NET. http://aspnet.click-url.com/go/psa00100003ave/direct;at.aspnet_072303_01/01 _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Thomas Schäfer writes:
[SDRAM discussion deleted]
Thomas> I have another question according the CIP and BMS settings Thomas> of the HRCW. They are both set to '1' which means that Thomas> exceptions are vectored to 0x000n_nnnn and boot memory Thomas> region is located at 0x0000_0000. I tried out to set those Thomas> bits to '0', it didn't work. Why?
This depends on your memory map. What is TEXT_BASE? How do you initialise chip selects? At what flash offset do you burn U-Boot?
Georg Klug
Thomas Schäfer
Yuli Barcohen
