[U-Boot] [PATCH v2] ARM: tegra: fix colibri_t20 machine type
A while ago I got Russell to change the machine type of our Colibri T20 from COLIBRI_TEGRA2 to COLIBRI_T20 which at least in parts is also reflected in his machine registry:
http://www.arm.linux.org.uk/developer/machines/list.php?id=3323
For us it is really very beneficial to actually still be able to boot downstream L4T kernel with its working hardware accelerated graphics/multimedia stack albeit it being proprietary/closed-source.
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com Acked-by: Stephen Warren swarren@nvidia.com --- Changes in v2: - clarified commit message based on Stephen's comments - added my previously missing signed-off-by
arch/arm/include/asm/mach-types.h | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index d4a447b..c424a22 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -936,7 +936,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_CWME9210 3320 #define MACH_TYPE_CWME9210JS 3321 #define MACH_TYPE_PGS_SITARA 3322 -#define MACH_TYPE_COLIBRI_TEGRA2 3323 +#define MACH_TYPE_COLIBRI_T20 3323 #define MACH_TYPE_W21 3324 #define MACH_TYPE_POLYSAT1 3325 #define MACH_TYPE_DATAWAY 3326 @@ -12197,16 +12197,16 @@ extern unsigned int __machine_arch_type; # define machine_is_pgs_v1() (0) #endif
-#ifdef CONFIG_MACH_COLIBRI_TEGRA2 +#ifdef CONFIG_MACH_COLIBRI_T20 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_COLIBRI_TEGRA2 +# define machine_arch_type MACH_TYPE_COLIBRI_T20 # endif -# define machine_is_colibri_tegra2() (machine_arch_type == MACH_TYPE_COLIBRI_TEGRA2) +# define machine_is_colibri_t20() (machine_arch_type == MACH_TYPE_COLIBRI_T20) #else -# define machine_is_colibri_tegra2() (0) +# define machine_is_colibri_t20() (0) #endif
#ifdef CONFIG_MACH_W21
Marcel Ziswiler
