[U-Boot] [PATCH 1/3] wandboard: Remove hardcoded baudrate from "console" variable
We should use the baudrate variable available inside U-Boot environment to allow it to be changed dynamically.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br ---
include/configs/wandboard.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 1edd7a8827..cb32cd11f9 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -78,7 +78,7 @@ #endif
#define CONFIG_EXTRA_ENV_SETTINGS \ - "console=ttymxc0,115200\0" \ + "console=ttymxc0\0" \ "splashpos=m,m\0" \ "fdtfile=undefined\0" \ "fdt_high=0xffffffff\0" \
ARCH_MX6 has default values for SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR and SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR.
Do the same for ARCH_MX7 so that users may have a consistent experience through the i.MX families.
Signed-off-by: Fabio Estevam festevam@gmail.com Signed-off-by: Otavio Salvador otavio@ossystems.com.br ---
common/spl/Kconfig | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 431710a93b..db33af9f76 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -152,7 +152,8 @@ config SPL_DISPLAY_PRINT
config SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR bool "MMC raw mode: by sector" - default y if ARCH_SUNXI || ARCH_DAVINCI || ARCH_UNIPHIER ||ARCH_MX6 || \ + default y if ARCH_SUNXI || ARCH_DAVINCI || ARCH_UNIPHIER || \ + ARCH_MX6 || ARCH_MX7 || \ ARCH_ROCKCHIP || ARCH_MVEBU || ARCH_SOCFPGA || \ ARCH_AT91 || ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || \ OMAP44XX || OMAP54XX || AM33XX || AM43XX @@ -165,7 +166,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR depends on SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR default 0x50 if ARCH_SUNXI default 0x75 if ARCH_DAVINCI - default 0x8a if ARCH_MX6 + default 0x8a if ARCH_MX6 || ARCH_MX7 default 0x100 if ARCH_UNIPHIER default 0x140 if ARCH_MVEBU default 0x200 if ARCH_SOCFPGA || ARCH_AT91
Since kernel commit 41bbeadceb03 ("ARM: dts: imx7d-pico-pi: Separate into cpu and baseboard dts") the dtb name has changed.
Fix it accordingly.
include/configs/pico-imx7d.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index b208d7f4d9..d2ffa70fc5 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -41,7 +41,7 @@ "console=ttymxc4\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ - "fdt_file=imx7d-pico.dtb\0" \ + "fdt_file=imx7d-pico-pi.dtb\0" \ "fdt_addr=0x83000000\0" \ "ip_dyn=yes\0" \ "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \
- "console=ttymxc0\0" \ "splashpos=m,m\0" \ "fdtfile=undefined\0" \ "fdt_high=0xffffffff\0" \
Series applied to u-boot-imx, thanks !
Best regards, Stefano Babic
Otavio Salvador
Stefano Babic
