[GIT PULL v2] TI changes for v2020.10-rc3
Hi Tom, Please find the pull request for v2020.10-rc3 containing TI specific changes. This should have been sent for rc2 but delayed due to some comments in the last minute. Please look at the PR description for the details on the PR. Also tag message is updated with details.
Changes since v1: - Dropped an invalid commit - Updated Tag message
Travis-CI build: https://travis-ci.org/github/lokeshvutla/u-boot/builds/716955604
The following changes since commit c045207f96f7f7ae8c7f1341111a6010e636176b:
Prepare v2020.10-rc2 (2020-08-10 16:10:09 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-ti.git tags/ti-v2020.10-rc3
for you to fetch changes up to db6451ec0e8483f76f3364293d48e86249c52322:
arm: dts: k3-j7200-common-proc-board: Enable CPSW2G port (2020-08-11 20:34:46 +0530)
---------------------------------------------------------------- - Added support for J7200 evm - DM_ETH and DM_USB migrations for omap3 - USB DFU and mass storage support for AM65x evm - RTI watchdog support for K3 devices - Fix an issue with L3 cache on K3 devices
---------------------------------------------------------------- Andrew F. Davis (1): arm: mach-k3: Clean non-coherent lines out of L3 cache
Dave Gerlach (1): arm: dts: k3-j7200: Add R5 specific dts support
Derald D. Woods (1): ARM: omap3: evm: Complete DM_ETH and DM_USB migrations
Faiz Abbas (14): mmc: am654_sdhci: Use MMC_MODES_END value instead of hardcoded value spl: usb: Create an API spl_usb_load() spl: usb: Only init usb once armv7R: K3: am654: Use full malloc in SPL both pre and post reloc arm: mach-k3: sysfw-loader: Add support to load SYSFW from USB arm: mach-k3: am6_init: Gate mmc related configurations with the appropriate config arm: mach-k3: am6_init: Do USB fixups to facilitate host and device boot modes arm: mach-k3: am6_init: Add support for USB boot mode arm: dts: k3-am654-r5-base-board: Add USB0 nodes arm: dts: k3-am654-base-board: Add support for USB0 in SPL configs: am65x_evm: Add support for DFU related configs configs: am65x_evm_a53: Enable USB Mass storage and DFU boot modes configs: Add defconfig for USB DFU bootmode configs: Add new config for supporting USB mass storage boot
Jan Kiszka (2): watchdog: Add support for K3 RTI watchdog arm: dts: k3: Add RTI watchdogs
Jean-Jacques Hiblot (1): arm: mach-k3: Fix platform hang when SPL_MULTI_DTB_FIT is not enabled
Kishon Vijay Abraham I (1): soc: soc_ti_k3: Add device identification for J7200 SoC
Lokesh Vutla (15): board: ti: board_detect: Add stub functions for EEPROM detection apis board: ti: j721e: Probe eeprom only when CONFIG_TI_I2C_BOARD_DETECT is defined arm: mach-k3: Move mmr_unlock to a common location arm: mach-k3: sysfw-loader: Add support for rom loading sysfw image arm: mach-k3: j721e: Add detection for j721e arm: mach-k3: j721e: Fix unlocking control module registers arm: mach-k3: j7200: Add support for SOC detection arm: mach-k3: j7200: Add support for storing extended boot info from ROM arm: mach-k3: j7200: Detect if ROM has already loaded sysfw board: ti: j7200: Introduce support for j7200 build targets board: ti: j7200: Add board detection support for j7200 ram: k3-j721e: Relax version checks for memory controller arm: dts: k3-j7200: Add dts support configs: j7200_evm_r5: Add initial support configs: j7200_evm_a72: Add Initial support
Suman Anna (4): arm: dts: k3-am65: Fix interconnect node names arm: dts: k3-j721e: Fix interconnect node names board: ti: am65x: Update fdt fixup logic for interconnect nodes board: ti: j721e: Update fdt fixup logic for interconnect nodes
Vignesh Raghavendra (6): arm: dts: k3-j7200: Add USB related DT entries board: ti: j721e: Add support for HyperFlash detection ARM: dts: k3-j7200: Add wkup gpio node ARM: dts: k3-j7200: Add HyperBus and HyperFlash nodes ARM: dts: k3-j7200-mcu-wakeup: Add CPSW2G support arm: dts: k3-j7200-common-proc-board: Enable CPSW2G port
arch/arm/dts/Makefile | 4 +- arch/arm/dts/k3-am65-mcu.dtsi | 9 + arch/arm/dts/k3-am65.dtsi | 6 +- arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 27 + arch/arm/dts/k3-am654-r5-base-board.dts | 35 + .../arm/dts/k3-j7200-common-proc-board-u-boot.dtsi | 133 ++ arch/arm/dts/k3-j7200-common-proc-board.dts | 195 ++ arch/arm/dts/k3-j7200-ddr-evm-lp4-1600.dtsi | 2195 ++++++++++++++++++++ arch/arm/dts/k3-j7200-main.dtsi | 343 +++ arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 272 +++ arch/arm/dts/k3-j7200-r5-common-proc-board.dts | 217 ++ arch/arm/dts/k3-j7200-som-p0.dtsi | 62 + arch/arm/dts/k3-j7200.dtsi | 177 ++ arch/arm/dts/k3-j721e-main.dtsi | 18 + arch/arm/dts/k3-j721e.dtsi | 4 +- arch/arm/dts/omap3-evm-37xx-u-boot.dtsi | 10 + arch/arm/dts/omap3-evm-u-boot.dtsi | 10 + arch/arm/mach-k3/Makefile | 1 + arch/arm/mach-k3/am6_init.c | 80 +- arch/arm/mach-k3/cache.S | 24 + arch/arm/mach-k3/common.c | 38 + arch/arm/mach-k3/common.h | 6 + arch/arm/mach-k3/config.mk | 8 +- arch/arm/mach-k3/include/mach/am6_hardware.h | 2 + arch/arm/mach-k3/include/mach/am6_spl.h | 3 +- arch/arm/mach-k3/include/mach/hardware.h | 8 + arch/arm/mach-k3/include/mach/j721e_hardware.h | 3 + arch/arm/mach-k3/include/mach/sys_proto.h | 3 + arch/arm/mach-k3/include/mach/sysfw-loader.h | 4 +- arch/arm/mach-k3/j721e_init.c | 30 +- arch/arm/mach-k3/sysfw-loader.c | 67 +- arch/arm/mach-omap2/omap3/Kconfig | 3 + board/ti/am65x/MAINTAINERS | 2 + board/ti/am65x/evm.c | 10 +- board/ti/common/board_detect.h | 13 + board/ti/evm/evm.c | 82 +- board/ti/j721e/Kconfig | 53 + board/ti/j721e/MAINTAINERS | 2 + board/ti/j721e/evm.c | 56 +- common/spl/spl_usb.c | 31 +- configs/am65x_evm_a53_defconfig | 10 + configs/am65x_evm_r5_usbdfu_defconfig | 120 ++ configs/am65x_evm_r5_usbmsc_defconfig | 119 ++ configs/j7200_evm_a72_defconfig | 173 ++ configs/j7200_evm_r5_defconfig | 130 ++ configs/omap3_evm_defconfig | 14 +- drivers/mmc/am654_sdhci.c | 2 +- drivers/ram/k3-j721e/lpddr4.c | 16 +- drivers/soc/soc_ti_k3.c | 4 + drivers/watchdog/Kconfig | 7 + drivers/watchdog/Makefile | 1 + drivers/watchdog/rti_wdt.c | 123 ++ include/configs/am65x_evm.h | 6 +- include/configs/j721e_evm.h | 4 +- include/spl.h | 14 + 55 files changed, 4821 insertions(+), 168 deletions(-) create mode 100644 arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi create mode 100644 arch/arm/dts/k3-j7200-common-proc-board.dts create mode 100644 arch/arm/dts/k3-j7200-ddr-evm-lp4-1600.dtsi create mode 100644 arch/arm/dts/k3-j7200-main.dtsi create mode 100644 arch/arm/dts/k3-j7200-mcu-wakeup.dtsi create mode 100644 arch/arm/dts/k3-j7200-r5-common-proc-board.dts create mode 100644 arch/arm/dts/k3-j7200-som-p0.dtsi create mode 100644 arch/arm/dts/k3-j7200.dtsi create mode 100644 arch/arm/mach-k3/cache.S create mode 100644 configs/am65x_evm_r5_usbdfu_defconfig create mode 100644 configs/am65x_evm_r5_usbmsc_defconfig create mode 100644 configs/j7200_evm_a72_defconfig create mode 100644 configs/j7200_evm_r5_defconfig create mode 100644 drivers/watchdog/rti_wdt.c
Changes since v1:
Lokesh Vutla
