[PATCH v2] board:pm9261 - Enable DM_ETH
This patch remove the network support for PM9261 because currently there is no DM suport for Davicom D9000.
Signed-off-by: Ilko Iliev iliev@ronetix.at --- Changes for v2: - add Signed-off-by
board/ronetix/pm9261/pm9261.c | 54 ----------------------------------- configs/pm9261_defconfig | 1 + include/configs/pm9261.h | 9 ------ 3 files changed, 1 insertion(+), 63 deletions(-)
diff --git a/board/ronetix/pm9261/pm9261.c b/board/ronetix/pm9261/pm9261.c index 5be2c5e192..fe52c7c176 100644 --- a/board/ronetix/pm9261/pm9261.c +++ b/board/ronetix/pm9261/pm9261.c @@ -20,10 +20,6 @@ #include <asm/arch/at91_matrix.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> -#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_DRIVER_DM9000) -#include <net.h> -#endif -#include <netdev.h> #include <asm/mach-types.h>
DECLARE_GLOBAL_DATA_PTR; @@ -80,36 +76,6 @@ static void pm9261_nand_hw_init(void) } #endif
- -#ifdef CONFIG_DRIVER_DM9000 -static void pm9261_dm9000_hw_init(void) -{ - struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; - - /* Configure SMC CS2 for DM9000 */ - writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | - AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), - &smc->cs[2].setup); - - writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(8) | - AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(8), - &smc->cs[2].pulse); - - writel(AT91_SMC_CYCLE_NWE(16) | AT91_SMC_CYCLE_NRD(16), - &smc->cs[2].cycle); - - writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | - AT91_SMC_MODE_EXNW_DISABLE | - AT91_SMC_MODE_BAT | AT91_SMC_MODE_DBW_16 | - AT91_SMC_MODE_TDF_CYCLE(1), - &smc->cs[2].mode); - - /* Configure Interrupt pin as input, no pull-up */ - at91_periph_clk_enable(ATMEL_ID_PIOA); - at91_set_pio_input(AT91_PIO_PORTA, 24, 0); -} -#endif - int board_early_init_f(void) { return 0; @@ -132,13 +98,6 @@ int board_init(void) return 0; }
-#ifdef CONFIG_DRIVER_DM9000 -int board_eth_init(struct bd_info *bis) -{ - return dm9000_initialize(bis); -} -#endif - int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ @@ -155,19 +114,6 @@ int dram_init_banksize(void) return 0; }
-#ifdef CONFIG_RESET_PHY_R -void reset_phy(void) -{ -#ifdef CONFIG_DRIVER_DM9000 - /* - * Initialize ethernet HW addr prior to starting Linux, - * needed for nfsroot - */ - eth_init(); -#endif -} -#endif - #ifdef CONFIG_DISPLAY_BOARDINFO int checkboard (void) { diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index e0a2ae18c6..774039e8bc 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -50,6 +50,7 @@ CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_DATAFLASH=y +CONFIG_DM_ETH=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 2cc47d1237..382d19a241 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -173,15 +173,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_MAX_FLASH_BANKS 1
-/* Ethernet */ -#define CONFIG_DRIVER_DM9000 1 -#define CONFIG_DM9000_BASE 0x30000000 -#define DM9000_IO CONFIG_DM9000_BASE -#define DM9000_DATA (CONFIG_DM9000_BASE + 4) -#define CONFIG_DM9000_USE_16BIT 1 -#define CONFIG_NET_RETRY_COUNT 20 -#define CONFIG_RESET_PHY_R 1 - /* USB */ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB -- 2.25.1
If I look at the commit message, I would expect something is enabled, but in fact something is removed. Could you update the short commit subject according to what you are doing in the commit itself ?
Also, if you are removing the dm9000, why do you still enable the DM_ETH ? what is it used for ?
Eugen
Changes for v2:
- add Signed-off-by
&smc->cs[2].setup);
&smc->cs[2].pulse);
&smc->cs[2].cycle);
&smc->cs[2].mode);
-} -#endif
-} -#endif
eth_init();
-#endif -} -#endif
-- 2.25.1
Eugen
Hi, The DM9000 is removed because there is no DM support. DM_ETH is enabled, because of the warning that the board will be removed without DM_ETH. Is there a way to build U-BOOT without ETH support and without the warning for missing DM_ETH?
Regards, Ilko ILEV
Changes for v2:
- add Signed-off-by
&smc->cs[2].setup);
&smc->cs[2].pulse);
&smc->cs[2].cycle);
&smc->cs[2].mode);
-} -#endif
-} -#endif
eth_init();
-#endif -} -#endif
-- 2.25.1
Eugen
We should be able to have the board without ETH at all, probably something else causes the warning trigger. Something out of date may be detected that requires DM_ETH
I noticed this in Makefile
$(call deprecated,CONFIG_DM_ETH,Ethernet drivers,v2020.07,$(CONFIG_NET))
it is likely that you have to remove CONFIG_NET first, and then you won't be prompted to have DM_ETH set.
Could you look at this please ?
Thanks
Regards, Ilko ILEV
-- With best regards, Ilko Iliev Ronetix Development Tools GmbH Hirschstettner Str. 19/Z110 1220 Vienna, Austria Tel: +43 1 236 1101 - 10 E-Mail: iliev@ronetix.at Web: www.ronetix.at
Ilko Iliev
