[U-Boot] [PATCH v1 0/3] Fixes for the DWC3-generic glue driver
This series fixes the current breakage of the DWC3 generic driver
Those patches were part of a larger series that also fixes the K2 platforms. However since the other series will not make it in this release, sending in a much smaller one.
JJ
Jean-Jacques Hiblot (3): usb: dwc3-generic: remove dm_scan_fdt_dev() from the remove() callback dm: Add a No-op uclass usb: dwc3: Use UCLASS_NOP instead of UCLASS_MISC for the DWC3 generic glue
arch/sandbox/dts/test.dts | 12 ++++++ drivers/core/uclass.c | 5 +++ drivers/usb/dwc3/dwc3-generic.c | 4 +- include/dm/uclass-id.h | 1 + test/dm/Makefile | 1 + test/dm/nop.c | 73 +++++++++++++++++++++++++++++++++ 6 files changed, 94 insertions(+), 2 deletions(-) create mode 100644 test/dm/nop.c
There is simply no reason to do that here.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com ---
drivers/usb/dwc3/dwc3-generic.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 3e6c494dc6..70431facb3 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -337,7 +337,7 @@ static int dwc3_glue_remove(struct udevice *dev)
clk_release_bulk(&glue->clks);
- return dm_scan_fdt_dev(dev); + return 0; }
static const struct udevice_id dwc3_glue_ids[] = {
This uclass is intended for devices that do not need any features from the uclass, including binding children. This will typically be used by devices that are used to bind child devices but do not use dm_scan_fdt_dev() to do it. That is for example the case of several USB wrappers that have 2 child devices (1 for device and 1 for host) but bind only one at a any given time.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Simon Glass sjg@chromium.org ---
arch/sandbox/dts/test.dts | 12 +++++++ drivers/core/uclass.c | 5 +++ include/dm/uclass-id.h | 1 + test/dm/Makefile | 1 + test/dm/nop.c | 73 +++++++++++++++++++++++++++++++++++++++ 5 files changed, 92 insertions(+) create mode 100644 test/dm/nop.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 8b2d6451c6..c328258901 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -400,6 +400,18 @@ sandbox,silent; /* Don't emit sounds while testing */ };
+ nop-test_0 { + compatible = "sandbox,nop_sandbox1"; + nop-test_1 { + compatible = "sandbox,nop_sandbox2"; + bind = "True"; + }; + nop-test_2 { + compatible = "sandbox,nop_sandbox2"; + bind = "False"; + }; + }; + misc-test { compatible = "sandbox,misc_sandbox"; }; diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index fc3157de39..dc9eb62893 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -757,3 +757,8 @@ int uclass_pre_remove_device(struct udevice *dev) return 0; } #endif + +UCLASS_DRIVER(nop) = { + .id = UCLASS_NOP, + .name = "nop", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 09e0ad5391..418392875c 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -62,6 +62,7 @@ enum uclass_id { UCLASS_MMC, /* SD / MMC card or chip */ UCLASS_MOD_EXP, /* RSA Mod Exp device */ UCLASS_MTD, /* Memory Technology Device (MTD) device */ + UCLASS_NOP, /* No-op devices */ UCLASS_NORTHBRIDGE, /* Intel Northbridge / SDRAM controller */ UCLASS_NVME, /* NVM Express device */ UCLASS_PANEL, /* Display panel, such as an LCD */ diff --git a/test/dm/Makefile b/test/dm/Makefile index 49857c5092..aeb3aa0ca7 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -3,6 +3,7 @@ # Copyright (c) 2013 Google, Inc
obj-$(CONFIG_UT_DM) += bus.o +obj-$(CONFIG_UT_DM) += nop.o obj-$(CONFIG_UT_DM) += test-driver.o obj-$(CONFIG_UT_DM) += test-fdt.o obj-$(CONFIG_UT_DM) += test-main.o diff --git a/test/dm/nop.c b/test/dm/nop.c new file mode 100644 index 0000000000..2df29f3d15 --- /dev/null +++ b/test/dm/nop.c @@ -0,0 +1,73 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Test for the NOP uclass + * + * (C) Copyright 2019 - Texas Instruments Incorporated - http://www.ti.com/ + * Jean-Jacques Hiblot jjhiblot@ti.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/ofnode.h> +#include <dm/lists.h> +#include <dm/device.h> +#include <dm/test.h> +#include <misc.h> +#include <test/ut.h> + +static int noptest_bind(struct udevice *parent) +{ + ofnode ofnode = dev_read_first_subnode(parent); + + while (ofnode_valid(ofnode)) { + struct udevice *dev; + const char *bind_flag = ofnode_read_string(ofnode, "bind"); + + if (bind_flag && (strcmp(bind_flag, "True") == 0)) + lists_bind_fdt(parent, ofnode, &dev, false); + ofnode = dev_read_next_subnode(ofnode); + } + + return 0; +} + +static const struct udevice_id noptest1_ids[] = { + { + .compatible = "sandbox,nop_sandbox1", + }, + { } +}; + +U_BOOT_DRIVER(noptest_drv1) = { + .name = "noptest1_drv", + .of_match = noptest1_ids, + .id = UCLASS_NOP, + .bind = noptest_bind, +}; + +static const struct udevice_id noptest2_ids[] = { + { + .compatible = "sandbox,nop_sandbox2", + }, + { } +}; + +U_BOOT_DRIVER(noptest_drv2) = { + .name = "noptest2_drv", + .of_match = noptest2_ids, + .id = UCLASS_NOP, +}; + +static int dm_test_nop(struct unit_test_state *uts) +{ + struct udevice *dev; + + ut_assertok(uclass_get_device_by_name(UCLASS_NOP, "nop-test_0", &dev)); + ut_assertok(uclass_get_device_by_name(UCLASS_NOP, "nop-test_1", &dev)); + ut_asserteq(-ENODEV, + uclass_get_device_by_name(UCLASS_NOP, "nop-test_2", &dev)); + + return 0; +} + +DM_TEST(dm_test_nop, DM_TESTF_FLAT_TREE | DM_TESTF_SCAN_FDT);
dwc3-generic has been broken since MISC uclass has been modified to scan DT sub-nodes after bind. Fixing it by a using the no-op uclass.
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 70431facb3..406bf0b362 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -350,7 +350,7 @@ static const struct udevice_id dwc3_glue_ids[] = {
U_BOOT_DRIVER(dwc3_generic_wrapper) = { .name = "dwc3-generic-wrapper", - .id = UCLASS_MISC, + .id = UCLASS_NOP, .of_match = dwc3_glue_ids, .bind = dwc3_glue_bind, .probe = dwc3_glue_probe,
Marek,
Ideally this series should be merged in u-boot-usb/master.
JJ
JJ
On 05/07/2019 14:16, Marek Vasut wrote:
On 7/5/19 9:43 AM, Jean-Jacques Hiblot wrote:
Marek,
I was hoping for something which doesn't add uclasses, but maybe that's not easily possible? So, I'll apply this and we'll see.
unfortunately not. That is the core of the fix.
Jean-Jacques Hiblot
