[PATCH v2] Revert "mmc: fsl_esdhc_imx: use VENDORSPEC_FRC_SDCLK_ON to control card clock output"
This reverts commit 63756575b42b8b4fb3f59cbbf0cedf03331bc2d2.
Since this commit a imx6qdl-pico board boots extremely slowly in both SPL as well as U-Boot proper.
Fix this regression by reverting the offending commit for now.
Signed-off-by: Fabio Estevam festevam@gmail.com --- Changes since v1: - Include the author of the offending commit on Cc.
drivers/mmc/fsl_esdhc_imx.c | 29 ++++++++--------------------- include/fsl_esdhc_imx.h | 2 -- 2 files changed, 8 insertions(+), 23 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index a4675838e58a..b49d5ede2711 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -653,10 +653,7 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) clk = (pre_div << 8) | (div << 4);
#ifdef CONFIG_FSL_USDHC - esdhc_clrbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); - ret = readx_poll_timeout(esdhc_read32, ®s->prsstat, tmp, tmp & PRSSTAT_SDOFF, 100); - if (ret) - pr_warn("fsl_esdhc_imx: Internal clock never gate off.\n"); + esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); #else esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); #endif @@ -668,7 +665,7 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) pr_warn("fsl_esdhc_imx: Internal clock never stabilised.\n");
#ifdef CONFIG_FSL_USDHC - esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); + esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | VENDORSPEC_CKEN); #else esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); #endif @@ -723,14 +720,8 @@ static void esdhc_set_strobe_dll(struct mmc *mmc) struct fsl_esdhc_priv *priv = dev_get_priv(mmc->dev); struct fsl_esdhc *regs = priv->esdhc_regs; u32 val; - u32 tmp; - int ret;
if (priv->clock > ESDHC_STROBE_DLL_CLK_FREQ) { - esdhc_clrbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); - ret = readx_poll_timeout(esdhc_read32, ®s->prsstat, tmp, tmp & PRSSTAT_SDOFF, 100); - if (ret) - pr_warn("fsl_esdhc_imx: Internal clock never gate off.\n"); esdhc_write32(®s->strobe_dllctrl, ESDHC_STROBE_DLL_CTRL_RESET);
/* @@ -748,7 +739,6 @@ static void esdhc_set_strobe_dll(struct mmc *mmc) pr_warn("HS400 strobe DLL status REF not lock!\n"); if (!(val & ESDHC_STROBE_DLL_STS_SLV_LOCK)) pr_warn("HS400 strobe DLL status SLV not lock!\n"); - esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); } }
@@ -980,18 +970,14 @@ static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) #ifdef MMC_SUPPORTS_TUNING if (mmc->clk_disable) { #ifdef CONFIG_FSL_USDHC - u32 tmp; - - esdhc_clrbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); - ret = readx_poll_timeout(esdhc_read32, ®s->prsstat, tmp, tmp & PRSSTAT_SDOFF, 100); - if (ret) - pr_warn("fsl_esdhc_imx: Internal clock never gate off.\n"); + esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); #else esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); #endif } else { #ifdef CONFIG_FSL_USDHC - esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); + esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | + VENDORSPEC_CKEN); #else esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); #endif @@ -1067,7 +1053,7 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) #ifndef CONFIG_FSL_USDHC esdhc_setbits32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN); #else - esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); + esdhc_setbits32(®s->vendorspec, VENDORSPEC_HCKEN | VENDORSPEC_IPGEN); #endif
/* Set the initial clock speed */ @@ -1205,7 +1191,8 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, esdhc_write32(®s->autoc12err, 0); esdhc_write32(®s->clktunectrlstatus, 0); #else - esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); + esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | + VENDORSPEC_HCKEN | VENDORSPEC_IPGEN | VENDORSPEC_CKEN); #endif
if (priv->vs18_enable) diff --git a/include/fsl_esdhc_imx.h b/include/fsl_esdhc_imx.h index b0920344641c..45ed635a77bf 100644 --- a/include/fsl_esdhc_imx.h +++ b/include/fsl_esdhc_imx.h @@ -39,7 +39,6 @@ #define VENDORSPEC_HCKEN 0x00001000 #define VENDORSPEC_IPGEN 0x00000800 #define VENDORSPEC_INIT 0x20007809 -#define VENDORSPEC_FRC_SDCLK_ON 0x00000100
#define IRQSTAT 0x0002e030 #define IRQSTAT_DMAE (0x10000000) @@ -97,7 +96,6 @@ #define PRSSTAT_CINS (0x00010000) #define PRSSTAT_BREN (0x00000800) #define PRSSTAT_BWEN (0x00000400) -#define PRSSTAT_SDOFF (0x00000080) #define PRSSTAT_SDSTB (0X00000008) #define PRSSTAT_DLA (0x00000004) #define PRSSTAT_CICHB (0x00000002)
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: 2021年6月8日 4:40 To: Peng Fan peng.fan@nxp.com Cc: Bough Chen haibo.chen@nxp.com; u-boot@lists.denx.de; tharvey@gateworks.com; Fabio Estevam festevam@gmail.com Subject: [PATCH v2] Revert "mmc: fsl_esdhc_imx: use VENDORSPEC_FRC_SDCLK_ON to control card clock output"
Hi Fabio,
Force clock on did help us fix some issue, like voltage switch for UHS card. According to your commit log, seems this patch affect the booting time, do you mean the API readx_poll_timeout() cost a lot time? Can you show us the detail info about booting time effected by this patch?
Regards, Haibo Chen
Changes since v1:
- if (ret)
- esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN);
stabilised.\n");
- esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN |
+VENDORSPEC_CKEN); #else esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); #endif @@ -723,14 +720,8 @@ static void esdhc_set_strobe_dll(struct mmc *mmc) struct fsl_esdhc_priv *priv = dev_get_priv(mmc->dev); struct fsl_esdhc *regs = priv->esdhc_regs; u32 val;
u32 tmp;
int ret;
tmp
if (ret)
off.\n");
u32 tmp;
tmp
if (ret)
off.\n");
VENDORSPEC_CKEN);
- esdhc_setbits32(®s->vendorspec, VENDORSPEC_HCKEN |
+VENDORSPEC_IPGEN); #endif
2.25.1
Hi Haibo,
On Mon, Jun 7, 2021 at 10:57 PM Bough Chen haibo.chen@nxp.com wrote:
Hi Fabio,
If I revert the patch SPL/U-Boot boot in one second.
With this patch, it takes around 20 seconds, which is unacceptable.
Thanks
On 6/8/21 11:07 AM, Fabio Estevam wrote:
Hi Haibo,
Hi Fabio,
Is your target success to boot finally after 20sec? I didn't have target to use fsl_esdhc_imx driver.
If booted after 20sec, how about below code?
#ifdef CONFIG_FSL_ESDHC_IMX_TIMEOUT #define FSL_ESDHC_IMX_TIMEOUT CONFIG_FSL_ESDHC_IMX_TIMEOUT #else #define FSL_ESDHC_IMX_TIMEOUT 0 #endif
ret = readx_poll_timeout(..., FSL_ESDHC_IMX_TIMEOUT); if (FSL_ESDHC_IMX_TIMEOUT && ret) pr_warn("...");
If there isn't other issue,
Best Regards, Jaehoon Chung
Thanks
Hi Jaehoon,
Yes, it boots fine after 20s.
Thanks for the suggestion, but it didn't work.
Hi Fabio,
On 6/9/21 6:47 AM, Fabio Estevam wrote:
Hi Jaehoon,
If i find a board to use fs_esdhc_imx driver, I will check more. I hope that Bough will suggest better solution to satisfy both case.
-----Original Message----- From: Jaehoon Chung [mailto:jh80.chung@samsung.com] Sent: 2021年6月9日 7:35 To: Fabio Estevam festevam@gmail.com Cc: Bough Chen haibo.chen@nxp.com; Peng Fan peng.fan@nxp.com; u-boot@lists.denx.de; tharvey@gateworks.com Subject: Re: [PATCH v2] Revert "mmc: fsl_esdhc_imx: use VENDORSPEC_FRC_SDCLK_ON to control card clock output"
Hi Fabio,
Hi Jaehoon,
Give me a few days, I'm busy these days, will do when I have time.
Best Regards Bough
Hi Bough,
We are already in 2021.04-rc4, so I think it is safer to go with the revert for now and then you provide a proper fix later.
imx7s-warp is also affected by this.
Hi Fabio
On 2021/6/8 10:07, Fabio Estevam wrote:
Hi Haibo,
Hi Fabio,
Do you have a chance to see where it consumes so much time?
Thanks, Peng.
Thanks
Hi Peng,
Here is the place it consumes too much time. Here is an example on a warp7 board:
U-Boot 2021.07-rc3 (Jun 17 2021 - 18:30:37 +0000)
CPU: Freescale i.MX7S rev1.2 800 MHz (running at 792 MHz) CPU: Extended Commercial temperature grade (-20C to 105C) at 42C Reset cause: POR Model: Warp i.MX7 Board Board: WARP7 in secure mode OPTEE DRAM 0x9d000000-0xa0000000 DRAM: 464 MiB PMIC: PFUZE3000 DEV_ID=0x30 REV_ID=0x11 MMC: FSL_SDHC: 3, FSL_SDHC: 0 Loading Environment from MMC... (takes 10 seconds to continue) OK
Can we go with the revert to avoid such regression?
Hi Fabio,
On 6/18/21 4:19 AM, Fabio Estevam wrote:
Hi Peng,
I think that this patch can be applied. Because it's too late to boot.
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Hi Fabio,
This commit fixes the issue with the imx7s-warp.
Tested-by: Pierre-Jean Texier texier.pj2@gmail.com
Thanks,
Hi Peng/Tom,
On Sun, Jun 20, 2021 at 1:45 PM Pierre-Jean Texier texier.pj2@gmail.com wrote:
Hi Fabio,
The 2021.07 release is near and I would still like to see this patch applied to fix the regression.
It negatively affects the boot time of several i.MX boards.
Please consider applying it.
Applied to mmc/master, awaiting upstream after CI.
Changes since v1:
- if (ret)
- esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); #else esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); #endif
- esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | VENDORSPEC_CKEN); #else esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); #endif
u32 tmp;
int ret;
if (ret)
} }esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON);
u32 tmp;
if (ret)
#else esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); #endif } else { #ifdef CONFIG_FSL_USDHCesdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN);
#else esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); #endifVENDORSPEC_CKEN);
#endif
participants (5)
Bough Chen
Fabio Estevam
Jaehoon Chung
Peng Fan (OSS)
Pierre-Jean Texier
