Re: [U-Boot] [PATCH 3/5] scsi/ahci: ata id little endian fix
On Tue, Sep 6, 2011 at 12:07 PM, vb@vsbe.com wrote:
---------- Forwarded message ---------- From: Rob Herring robherring2@gmail.com Date: Tue, Jun 21, 2011 at 2:33 PM Subject: [U-Boot] [PATCH 3/5] scsi/ahci: ata id little endian fix To: u-boot@lists.denx.de Cc: Rob Herring rob.herring@calxeda.com
The ata id string always needs swapping, not just on BE machines.
Signed-off-by: Rob Herring rob.herring@calxeda.com Cc: Wolfgang Denk wd@denx.de
drivers/block/ahci.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index a3ca2dc..d431c5a 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -468,7 +468,7 @@ static char *ata_id_strcpy(u16 *target, u16 *src, int len) { int i; for (i = 0; i < len / 2; i++)
target[i] = le16_to_cpu(src[i]);
target[i] = swab16(src[i]); return (char *)target;
-- 1.7.4.1
guys, I am looking into enabling the AHCI driver on the x86 platforms (working off an older version of drivers/block/ahci.c, but planning to reconcile).
One of my internal reviewers brought this up (and it seems quite a reasonable question): why does one need to swap bytes always, no matter the CPU endianness?
Also, can you please comment on what is going on in ata_scsiop_inquiry(), in particular, what are the contents of the hdr[] array? Any hints would be highly appreciated,
cheers, /vb
Vadim Bendebury (вб)
