[U-Boot] [PATCH] ARM: mvebu: handle unused DRAM banks with ECC enabled
dram_ecc_scrubbing() had code to skip unused DRAM banks but it would not work because mvebu_sdram_bs() returns 0 and the code was subtracting 1 before checking the size. Remove the -1 from the bank size and the +1 from the total which will skip unused banks and still calculate the correct size. Put the -1 where it is needed for scrubbing via the xor engine.
Reported-by: Joshua Scott joshua.scott@alliedtelesis.co.nz Signed-off-by: Chris Packham judge.packham@gmail.com ---
arch/arm/mach-mvebu/dram.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-mvebu/dram.c b/arch/arm/mach-mvebu/dram.c index e3f304c366..f946c0cffe 100644 --- a/arch/arm/mach-mvebu/dram.c +++ b/arch/arm/mach-mvebu/dram.c @@ -179,11 +179,11 @@ static void dram_ecc_scrubbing(void) reg_write(REG_SDRAM_CONFIG_ADDR, temp);
for (cs = 0; cs < CONFIG_NR_DRAM_BANKS; cs++) { - size = mvebu_sdram_bs(cs) - 1; + size = mvebu_sdram_bs(cs); if (size == 0) continue;
- total = (u64)size + 1; + total = (u64)size; total_mem += (u32)(total / (1 << 30)); start_addr = 0; mv_xor_init2(cs); @@ -194,7 +194,7 @@ static void dram_ecc_scrubbing(void) size -= start_addr; }
- mv_xor_mem_init(SCRB_XOR_CHAN, start_addr, size, + mv_xor_mem_init(SCRB_XOR_CHAN, start_addr, size - 1, SCRUB_MAGIC, SCRUB_MAGIC);
/* Wait for previous transfer completion */
I can confirm that this patch fixes the issue I was seeing (data_abort, single and dual-bit ecc errors during dram_ecc_scrubbing).
Tested on a board with the Marvell AlleyCat3 switch/SoC.
Cheers, Joshua Scott
________________________________________ From: Chris Packham judge.packham@gmail.com Sent: Saturday, 23 September 2017 4:50 a.m. To: u-boot@lists.denx.de Cc: Joshua Scott; Chris Packham; Prafulla Wadaskar; Albert Aribaud; Luka Perkov; Stefan Roese Subject: [PATCH] ARM: mvebu: handle unused DRAM banks with ECC enabled
/* Wait for previous transfer completion */ -- 2.14.1
Applied to u-boot-marvell/master.
Thanks, Stefan
Chris Packham
Joshua Scott
Stefan Roese
