[U-Boot] [PATCH v2 3/4] arm: exynos: clock: Remove exynos4x12_set_mmc_clk function
exynos4x12_set_mmc_clk function have been removed. Because exynos4x12_clock and exynos4_clock return same div_fsys* value.
Signed-off-by: Beomho Seo beomho.seo@samsung.com Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - None.
arch/arm/cpu/armv7/exynos/clock.c | 29 +---------------------------- 1 file changed, 1 insertion(+), 28 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 1fea4d6..2c2029a 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -893,30 +893,6 @@ static void exynos4_set_mmc_clk(int dev_index, unsigned int div) (div & 0xff) << ((dev_index << 4) + 8)); }
-/* exynos4x12: set the mmc clock */ -static void exynos4x12_set_mmc_clk(int dev_index, unsigned int div) -{ - struct exynos4x12_clock *clk = - (struct exynos4x12_clock *)samsung_get_base_clock(); - unsigned int addr; - - /* - * CLK_DIV_FSYS1 - * MMC0_PRE_RATIO [15:8], MMC1_PRE_RATIO [31:24] - * CLK_DIV_FSYS2 - * MMC2_PRE_RATIO [15:8], MMC3_PRE_RATIO [31:24] - */ - if (dev_index < 2) { - addr = (unsigned int)&clk->div_fsys1; - } else { - addr = (unsigned int)&clk->div_fsys2; - dev_index -= 2; - } - - clrsetbits_le32(addr, 0xff << ((dev_index << 4) + 8), - (div & 0xff) << ((dev_index << 4) + 8)); -} - /* exynos5: set the mmc clock */ static void exynos5_set_mmc_clk(int dev_index, unsigned int div) { @@ -1612,10 +1588,7 @@ void set_mmc_clk(int dev_index, unsigned int div) else exynos5_set_mmc_clk(dev_index, div); } else { - if (proid_is_exynos4412()) - exynos4x12_set_mmc_clk(dev_index, div); - else - exynos4_set_mmc_clk(dev_index, div); + exynos4_set_mmc_clk(dev_index, div); } }
Beomho Seo
