[PATCH v2 00/10] tpm: rng: Move TPM RNG functionality to driver model
The TPM device provides the random number generator(RNG) functionality, whereby sending a command to the TPM device results in the TPM device responding with random bytes.
There was a discussion on the mailing list earlier[1], where it was explained that platforms with a TPM device can install the EFI_RNG_PROTOCOL for getting the random bytes instead of populating the dtb with the kaslr-seed property. That would make it possible to measure the dtb.
This patchset moves the already existing functions for getting random bytes from the TPM device to drivers complying with the RNG uclass. This is done since the EFI_RNG_PROTOCOL's get_rng routine uses the RNG uclass's dm_rng_read api to get the random bytes.
The TPM uclass driver adds the RNG child device as part of it's post_probe function. The TPM uclass driver's child_pre_probe function initialises the TPM parent device for use -- this enables the RNG child device to be used subsequently.
Some additional changes have also been made to facilitate the use of the RNG devices, including extending the 'rng' command to take the RNG device as one of the command-line parameters.
Changes since V1: * Added existing copyrights for the rng functions taken from the tpm library routines * Return -EIO for TPM command returning an error * Simplify the logic in tpm_get_random based on the review comments from Ilias * Changed the help text to show order of the parameters passed to the rng command, based on review comment from Heinrich
[1] - https://lore.kernel.org/u-boot/20220103120738.47835-1-ilias.apalodimas@linar...
Sughosh Ganu (10): tpm: Move tpm-utils header under the include directory tpm: rng: Change tpm_get_random to return an int tpm: Fix the return type of tpm_startup tpm: Move the TPM version detection functions to the uclass driver configs: gazerbeam: Build TPMV2 library routines configs: chromebook_coral: Build TPMV1 library routines tpm: rng: Move the TPM RNG functionality to driver model tpm: Add the RNG child device qemu: arm: Remove platform specific function to get RNG device cmd: rng: Add support for selecting RNG device
board/emulation/qemu-arm/qemu-arm.c | 42 -------------- cmd/rng.c | 31 +++++++--- configs/chromebook_coral_defconfig | 1 - configs/gazerbeam_defconfig | 1 - drivers/rng/Makefile | 1 + drivers/rng/tpm1_rng.c | 87 +++++++++++++++++++++++++++++ drivers/rng/tpm2_rng.c | 86 ++++++++++++++++++++++++++++ drivers/tpm/tpm-uclass.c | 69 +++++++++++++++++++++-- {lib => include}/tpm-utils.h | 0 include/tpm_api.h | 26 ++++++++- lib/tpm-common.c | 2 +- lib/tpm-v1.c | 46 +-------------- lib/tpm-v2.c | 46 +-------------- lib/tpm_api.c | 37 ++++++------ 14 files changed, 309 insertions(+), 166 deletions(-) create mode 100644 drivers/rng/tpm1_rng.c create mode 100644 drivers/rng/tpm2_rng.c rename {lib => include}/tpm-utils.h (100%)
The random number generation functions of TPM will be moved under a dedicated driver. With this, the function declarations along with some other relevant macro definitions need to be moved under a common header file directory. Move the tpm-utils.h header file under the common include directory.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de ---
Changes since V1: None
{lib => include}/tpm-utils.h | 0 lib/tpm-common.c | 2 +- lib/tpm-v1.c | 2 +- lib/tpm-v2.c | 2 +- 4 files changed, 3 insertions(+), 3 deletions(-) rename {lib => include}/tpm-utils.h (100%)
diff --git a/lib/tpm-utils.h b/include/tpm-utils.h similarity index 100% rename from lib/tpm-utils.h rename to include/tpm-utils.h diff --git a/lib/tpm-common.c b/lib/tpm-common.c index 82ffdc5341..26506f0b99 100644 --- a/lib/tpm-common.c +++ b/lib/tpm-common.c @@ -11,7 +11,7 @@ #include <log.h> #include <asm/unaligned.h> #include <tpm-common.h> -#include "tpm-utils.h" +#include <tpm-utils.h>
enum tpm_version tpm_get_version(struct udevice *dev) { diff --git a/lib/tpm-v1.c b/lib/tpm-v1.c index 22a769c587..467992e04e 100644 --- a/lib/tpm-v1.c +++ b/lib/tpm-v1.c @@ -13,7 +13,7 @@ #include <u-boot/sha1.h> #include <tpm-common.h> #include <tpm-v1.h> -#include "tpm-utils.h" +#include <tpm-utils.h>
#ifdef CONFIG_TPM_AUTH_SESSIONS
diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 1bf627853a..2f16b0007b 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -9,7 +9,7 @@ #include <tpm-common.h> #include <tpm-v2.h> #include <linux/bitops.h> -#include "tpm-utils.h" +#include <tpm-utils.h>
u32 tpm2_startup(struct udevice *dev, enum tpm2_startup_types mode) {
Hi Sughosh,
Having looked at this a few days ago I don't think it is a good idea. These functions and methods should sit within lib/tpm, which is where messages are packed and unpacked.
The tpm random number generation functionality will be moved to the driver model. With that, the tpm_get_random function will call the common driver model api instead of separate functions for tpmv1 and tpmv2. Return an int instead of a u32 to comply with the return value of the driver model function.
include/tpm_api.h | 4 ++-- lib/tpm_api.c | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/tpm_api.h b/include/tpm_api.h index ef45b43a8f..b9e3e8b5e6 100644 --- a/include/tpm_api.h +++ b/include/tpm_api.h @@ -274,9 +274,9 @@ u32 tpm_find_key_sha1(struct udevice *dev, const u8 auth[20], * @param dev TPM device * @param data output buffer for the random bytes * @param count size of output buffer - * Return: return code of the operation + * Return: 0 if OK, -ve on error */ -u32 tpm_get_random(struct udevice *dev, void *data, u32 count); +int tpm_get_random(struct udevice *dev, void *data, u32 count);
/** * tpm_finalise_physical_presence() - Finalise physical presence diff --git a/lib/tpm_api.c b/lib/tpm_api.c index 4c662640a9..1bbe33a3fc 100644 --- a/lib/tpm_api.c +++ b/lib/tpm_api.c @@ -274,7 +274,7 @@ u32 tpm_get_permissions(struct udevice *dev, u32 index, u32 *perm) return -ENOSYS; }
-u32 tpm_get_random(struct udevice *dev, void *data, u32 count) +int tpm_get_random(struct udevice *dev, void *data, u32 count) { if (is_tpm1(dev)) return tpm1_get_random(dev, data, count);
The tpm_startup function returns negative values for error conditions. Fix the return type of the function to a signed int instead of a u32.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org ---
include/tpm_api.h | 2 +- lib/tpm_api.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/tpm_api.h b/include/tpm_api.h index b9e3e8b5e6..fb6ee14e23 100644 --- a/include/tpm_api.h +++ b/include/tpm_api.h @@ -18,7 +18,7 @@ * @param mode TPM startup mode * Return: return code of the operation */ -u32 tpm_startup(struct udevice *dev, enum tpm_startup_type mode); +int tpm_startup(struct udevice *dev, enum tpm_startup_type mode);
/** * Issue a TPM_SelfTestFull command. diff --git a/lib/tpm_api.c b/lib/tpm_api.c index 1bbe33a3fc..b762202866 100644 --- a/lib/tpm_api.c +++ b/lib/tpm_api.c @@ -21,7 +21,7 @@ static bool is_tpm2(struct udevice *dev) return IS_ENABLED(CONFIG_TPM_V2) && tpm_get_version(dev) == TPM_V2; }
-u32 tpm_startup(struct udevice *dev, enum tpm_startup_type mode) +int tpm_startup(struct udevice *dev, enum tpm_startup_type mode) { if (is_tpm1(dev)) { return tpm1_startup(dev, mode);
Make the TPM version detection functions as external symbols and move them to the TPM uclass driver. These are useful functions to check the TPM device version and should not be static functions.
drivers/tpm/tpm-uclass.c | 11 +++++++++++ include/tpm_api.h | 20 ++++++++++++++++++++ lib/tpm_api.c | 10 ---------- 3 files changed, 31 insertions(+), 10 deletions(-)
diff --git a/drivers/tpm/tpm-uclass.c b/drivers/tpm/tpm-uclass.c index f67fe1019b..8619da89d8 100644 --- a/drivers/tpm/tpm-uclass.c +++ b/drivers/tpm/tpm-uclass.c @@ -11,10 +11,21 @@ #include <log.h> #include <linux/delay.h> #include <linux/unaligned/be_byteshift.h> +#include <tpm_api.h> #include <tpm-v1.h> #include <tpm-v2.h> #include "tpm_internal.h"
+bool is_tpm1(struct udevice *dev) +{ + return IS_ENABLED(CONFIG_TPM_V1) && tpm_get_version(dev) == TPM_V1; +} + +bool is_tpm2(struct udevice *dev) +{ + return IS_ENABLED(CONFIG_TPM_V2) && tpm_get_version(dev) == TPM_V2; +} + int tpm_open(struct udevice *dev) { struct tpm_ops *ops = tpm_get_ops(dev); diff --git a/include/tpm_api.h b/include/tpm_api.h index fb6ee14e23..c19639a688 100644 --- a/include/tpm_api.h +++ b/include/tpm_api.h @@ -11,6 +11,26 @@ #include <tpm-v1.h> #include <tpm-v2.h>
+/** + * is_tpm1() - Check if it is a tpmv1 device + * @param dev TPM device + * + * Check if the TPM device is a TPMv1 device + * + * Return: 1 if TPMv1, 0 otherwise + */ +bool is_tpm1(struct udevice *dev); + +/** + * is_tpm2() - Check if it is a tpmv2 device + * @param dev TPM device + * + * Check if the TPM device is a TPMv2 device + * + * Return: 1 if TPMv2, 0 otherwise + */ +bool is_tpm2(struct udevice *dev); + /** * Issue a TPM_Startup command. * diff --git a/lib/tpm_api.c b/lib/tpm_api.c index b762202866..9dd9606fa8 100644 --- a/lib/tpm_api.c +++ b/lib/tpm_api.c @@ -11,16 +11,6 @@ #include <tpm-v2.h> #include <tpm_api.h>
-static bool is_tpm1(struct udevice *dev) -{ - return IS_ENABLED(CONFIG_TPM_V1) && tpm_get_version(dev) == TPM_V1; -} - -static bool is_tpm2(struct udevice *dev) -{ - return IS_ENABLED(CONFIG_TPM_V2) && tpm_get_version(dev) == TPM_V2; -} - int tpm_startup(struct udevice *dev, enum tpm_startup_type mode) { if (is_tpm1(dev)) {
I just sent a similar patch a few days ago.
I think a better name is tpm_is_v1() since this is in the tpm uclass. It should have a tpm_ prefix.
hi Simon,
Okay, but do we keep this patch, or use the approach which you have taken to define these as inline functions in tpm_api.h. If we are to keep these definitions in the uclass driver, I will rename them as you suggest. Thanks.
-sughosh
Hi Sughosh,
On Tue, 1 Mar 2022 at 21:40, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Well if you put them in the .c file then they don't work property and you have to enable by TPMv1 and TPMv2 code. The idea of the inline functions is that they work even if you don't enable both APIs.
The TPM code currently does a runtime detection of the TPM version and calls appropriate functions. Gazerbeam is one of the platforms where the TPMV2 code is disabled at build time. With this, calling TPM api's from the TPM uclass driver results in link errors. Enable TPMV2 library routines and determine the TPM version at runtime like other platforms.
configs/gazerbeam_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index 199afb4d16..b18194aa0f 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -213,7 +213,6 @@ CONFIG_TIMER=y CONFIG_MPC83XX_TIMER=y CONFIG_TPM_ATMEL_TWI=y CONFIG_TPM_AUTH_SESSIONS=y -# CONFIG_TPM_V2 is not set CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_LOGICORE_DP_TX=y
The TPM code currently does a runtime detection of the TPM version and calls appropriate functions. Chromebook Coral is one of the platforms where the TPMV1 code is disabled at build time. With this, calling TPM api's from the TPM uclass driver results in link errors. Enable TPMV1 library routines and determine the TPM version at runtime like other platforms.
configs/chromebook_coral_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index 0cd8f39aa3..4704ce25c8 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -104,7 +104,6 @@ CONFIG_SPI=y CONFIG_ICH_SPI=y # CONFIG_SYSINFO_SMBIOS is not set CONFIG_TPL_SYSRESET=y -# CONFIG_TPM_V1 is not set CONFIG_TPM2_CR50_I2C=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y
Hi Sughosh,
diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index 0cd8f39aa3..4704ce25c8 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -104,7 +104,6 @@ CONFIG_SPI=y CONFIG_ICH_SPI=y # CONFIG_SYSINFO_SMBIOS is not set CONFIG_TPL_SYSRESET=y -# CONFIG_TPM_V1 is not set CONFIG_TPM2_CR50_I2C=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y -- 2.25.1
This board does not have a v1 TPM so we don't want to waste code space adding it.
The current code works fine and supports both a build-time and run-time check. What has gone wrong?
hi Simon,
Hi Sughosh,
Yes, but because the version detection is happening at runtime, we need both the files to be compiled if we call any of the tpm api from outside lib/tpm. When I call the tpm_startup function from the child_pre_probe callback in tpm-uclass.c, I get link errors for the TPM v2 functions. Similarly for Gazerbeam board.
Does not work when an api is called from the tpm uclass driver.
-sughosh
Hi Sughosh,
On Tue, 1 Mar 2022 at 21:50, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
OK, I see, then the tpm_is_v1() functions need to stay in the header file, to fix that.
hi Simon,
On Wed, 2 Mar 2022 at 21:02, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
hi Simon,
Hi Sughosh,
The link errors are not for the tpm_is_v{1,2} functions -- I had already moved them to the tpm uclass driver in a previous patch of my patchset. The link errors are for the tpm{1,2}_startup functions being undefined for the chromebook_coral and gazerboam platforms. I think when the tpm_startup function is getting called from within the same module(lib/tpm) the compiler optimises out the calls to the non-existing functions. But when called from a different directory, like the tpm uclass driver in my case, we get link errors.
-sughosh
Hi Sughosh,
On Wed, 2 Mar 2022 at 11:12, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
hi Simon,
Hi Sughosh,
I don't think that is right, sorry.
Currently, the TPM random number generator(RNG) functions are defined as part of the library functions under the corresponding tpm files for tpmv1 and tpmv2. Move the RNG functionality under TPM RNG drivers complying with the driver model.
Also make changes to the tpm_get_random function to have it call the TPM RNG driver functions instead of the library functions.
drivers/rng/Makefile | 1 + drivers/rng/tpm1_rng.c | 87 ++++++++++++++++++++++++++++++++++++++++++ drivers/rng/tpm2_rng.c | 86 +++++++++++++++++++++++++++++++++++++++++ lib/tpm-v1.c | 44 --------------------- lib/tpm-v2.c | 44 --------------------- lib/tpm_api.c | 23 +++++++++-- 6 files changed, 193 insertions(+), 92 deletions(-) create mode 100644 drivers/rng/tpm1_rng.c create mode 100644 drivers/rng/tpm2_rng.c
diff --git a/drivers/rng/Makefile b/drivers/rng/Makefile index 39f7ee3f03..129cfbd006 100644 --- a/drivers/rng/Makefile +++ b/drivers/rng/Makefile @@ -10,3 +10,4 @@ obj-$(CONFIG_RNG_MSM) += msm_rng.o obj-$(CONFIG_RNG_STM32MP1) += stm32mp1_rng.o obj-$(CONFIG_RNG_ROCKCHIP) += rockchip_rng.o obj-$(CONFIG_RNG_IPROC200) += iproc_rng200.o +obj-$(CONFIG_TPM) += tpm1_rng.o tpm2_rng.o diff --git a/drivers/rng/tpm1_rng.c b/drivers/rng/tpm1_rng.c new file mode 100644 index 0000000000..7e629756b3 --- /dev/null +++ b/drivers/rng/tpm1_rng.c @@ -0,0 +1,87 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2013 The Chromium OS Authors. + * Coypright (c) 2013 Guntermann & Drunck GmbH + * Copyright (c) 2022, Linaro Limited + */ + +#include <common.h> +#include <dm.h> +#include <rng.h> +#include <tpm-utils.h> +#include <tpm-v1.h> + +#include <linux/errno.h> + +#define TPM_HEADER_SIZE 10 + +#define TPMV1_DATA_OFFSET 14 + +/** + * tpm1_rng_read() - Read the random bytes from TPMv1 device + * @param dev TPMv1 RNG device + * @param data data buffer to write random bytes + * @param count number of random bytes to read from + * the device + * + * Function to read the random bytes from the RNG pseudo device + * built into the TPMv1 device. Reads 'count' number of bytes + * from the random number generator and copies them into the + * 'data' buffer. + * + * Return: 0 if OK, -ve on error. + * + */ +static int tpm1_rng_read(struct udevice *dev, void *data, size_t count) +{ + const u8 command[14] = { + 0x0, 0xc1, /* TPM_TAG */ + 0x0, 0x0, 0x0, 0xe, /* parameter size */ + 0x0, 0x0, 0x0, 0x46, /* TPM_COMMAND_CODE */ + }; + const size_t length_offset = TPM_HEADER_SIZE; + const size_t data_size_offset = TPM_HEADER_SIZE; + const size_t data_offset = TPMV1_DATA_OFFSET; + u8 buf[COMMAND_BUFFER_SIZE], response[COMMAND_BUFFER_SIZE]; + size_t response_length = sizeof(response); + u32 data_size; + u8 *out = data; + + while (count > 0) { + u32 this_bytes = min(count, + sizeof(response) - data_offset); + u32 err; + + if (pack_byte_string(buf, sizeof(buf), "sd", + 0, command, sizeof(command), + length_offset, this_bytes)) + return -EIO; + err = tpm_sendrecv_command(dev->parent, buf, response, + &response_length); + if (err) + return err; + if (unpack_byte_string(response, response_length, "d", + data_size_offset, &data_size)) + return -EIO; + if (data_size > count) + return TPM_LIB_ERROR; + if (unpack_byte_string(response, response_length, "s", + data_offset, out, data_size)) + return -EIO; + + count -= data_size; + out += data_size; + } + + return 0; +} + +static const struct dm_rng_ops tpm1_rng_ops = { + .read = tpm1_rng_read, +}; + +U_BOOT_DRIVER(tpm1_rng) = { + .name = "tpm1-rng", + .id = UCLASS_RNG, + .ops = &tpm1_rng_ops, +}; diff --git a/drivers/rng/tpm2_rng.c b/drivers/rng/tpm2_rng.c new file mode 100644 index 0000000000..e7f6be46e4 --- /dev/null +++ b/drivers/rng/tpm2_rng.c @@ -0,0 +1,86 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2018 Bootlin + * Copyright (c) 2022, Linaro Limited + */ + +#include <common.h> +#include <dm.h> +#include <rng.h> +#include <tpm-utils.h> +#include <tpm-v2.h> + +#include <linux/errno.h> + +#define TPM_HEADER_SIZE 10 + +#define TPMV2_DATA_OFFSET 12 + +/** + * tpm2_rng_read() - Read the random bytes from TPMv2 device + * @param dev TPMv2 RNG device + * @param data data buffer to write random bytes + * @param count number of random bytes to read from + * the device + * + * Function to read the random bytes from the RNG pseudo device + * built into the TPMv2 device. Reads 'count' number of bytes + * from the random number generator and copies them into the + * 'data' buffer. + * + * Return: 0 if OK, -ve on error. + * + */ +static int tpm2_rng_read(struct udevice *dev, void *data, size_t count) +{ + const u8 command_v2[10] = { + tpm_u16(TPM2_ST_NO_SESSIONS), + tpm_u32(12), + tpm_u32(TPM2_CC_GET_RANDOM), + }; + u8 buf[COMMAND_BUFFER_SIZE], response[COMMAND_BUFFER_SIZE]; + + const size_t data_size_offset = TPM_HEADER_SIZE; + const size_t data_offset = TPMV2_DATA_OFFSET; + size_t response_length = sizeof(response); + u32 data_size; + u8 *out = data; + + while (count > 0) { + u32 this_bytes = min((size_t)count, + sizeof(response) - data_offset); + u32 err; + + if (pack_byte_string(buf, sizeof(buf), "sw", + 0, command_v2, sizeof(command_v2), + sizeof(command_v2), this_bytes)) + return -EIO; + err = tpm_sendrecv_command(dev->parent, buf, response, + &response_length); + if (err) + return err; + if (unpack_byte_string(response, response_length, "w", + data_size_offset, &data_size)) + return -EIO; + if (data_size > this_bytes) + return TPM_LIB_ERROR; + if (unpack_byte_string(response, response_length, "s", + data_offset, out, data_size)) + return -EIO; + + count -= data_size; + out += data_size; + } + + return 0; +} + +static const struct dm_rng_ops tpm2_rng_ops = { + .read = tpm2_rng_read, +}; + +U_BOOT_DRIVER(tpm2_rng) = { + .name = "tpm2-rng", + .id = UCLASS_RNG, + .ops = &tpm2_rng_ops, +}; diff --git a/lib/tpm-v1.c b/lib/tpm-v1.c index 467992e04e..71cc90a2ab 100644 --- a/lib/tpm-v1.c +++ b/lib/tpm-v1.c @@ -868,47 +868,3 @@ u32 tpm1_find_key_sha1(struct udevice *dev, const u8 auth[20], #endif /* CONFIG_TPM_LOAD_KEY_BY_SHA1 */
#endif /* CONFIG_TPM_AUTH_SESSIONS */ - -u32 tpm1_get_random(struct udevice *dev, void *data, u32 count) -{ - const u8 command[14] = { - 0x0, 0xc1, /* TPM_TAG */ - 0x0, 0x0, 0x0, 0xe, /* parameter size */ - 0x0, 0x0, 0x0, 0x46, /* TPM_COMMAND_CODE */ - }; - const size_t length_offset = 10; - const size_t data_size_offset = 10; - const size_t data_offset = 14; - u8 buf[COMMAND_BUFFER_SIZE], response[COMMAND_BUFFER_SIZE]; - size_t response_length = sizeof(response); - u32 data_size; - u8 *out = data; - - while (count > 0) { - u32 this_bytes = min((size_t)count, - sizeof(response) - data_offset); - u32 err; - - if (pack_byte_string(buf, sizeof(buf), "sd", - 0, command, sizeof(command), - length_offset, this_bytes)) - return TPM_LIB_ERROR; - err = tpm_sendrecv_command(dev, buf, response, - &response_length); - if (err) - return err; - if (unpack_byte_string(response, response_length, "d", - data_size_offset, &data_size)) - return TPM_LIB_ERROR; - if (data_size > count) - return TPM_LIB_ERROR; - if (unpack_byte_string(response, response_length, "s", - data_offset, out, data_size)) - return TPM_LIB_ERROR; - - count -= data_size; - out += data_size; - } - - return 0; -} diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 2f16b0007b..c1456c1974 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -562,50 +562,6 @@ u32 tpm2_pcr_setauthvalue(struct udevice *dev, const char *pw, return tpm_sendrecv_command(dev, command_v2, NULL, NULL); }
-u32 tpm2_get_random(struct udevice *dev, void *data, u32 count) -{ - const u8 command_v2[10] = { - tpm_u16(TPM2_ST_NO_SESSIONS), - tpm_u32(12), - tpm_u32(TPM2_CC_GET_RANDOM), - }; - u8 buf[COMMAND_BUFFER_SIZE], response[COMMAND_BUFFER_SIZE]; - - const size_t data_size_offset = 10; - const size_t data_offset = 12; - size_t response_length = sizeof(response); - u32 data_size; - u8 *out = data; - - while (count > 0) { - u32 this_bytes = min((size_t)count, - sizeof(response) - data_offset); - u32 err; - - if (pack_byte_string(buf, sizeof(buf), "sw", - 0, command_v2, sizeof(command_v2), - sizeof(command_v2), this_bytes)) - return TPM_LIB_ERROR; - err = tpm_sendrecv_command(dev, buf, response, - &response_length); - if (err) - return err; - if (unpack_byte_string(response, response_length, "w", - data_size_offset, &data_size)) - return TPM_LIB_ERROR; - if (data_size > this_bytes) - return TPM_LIB_ERROR; - if (unpack_byte_string(response, response_length, "s", - data_offset, out, data_size)) - return TPM_LIB_ERROR; - - count -= data_size; - out += data_size; - } - - return 0; -} - u32 tpm2_write_lock(struct udevice *dev, u32 index) { u8 command_v2[COMMAND_BUFFER_SIZE] = { diff --git a/lib/tpm_api.c b/lib/tpm_api.c index 9dd9606fa8..5492f89959 100644 --- a/lib/tpm_api.c +++ b/lib/tpm_api.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <rng.h> #include <tpm_api.h> #include <tpm-v1.h> #include <tpm-v2.h> @@ -264,12 +265,26 @@ u32 tpm_get_permissions(struct udevice *dev, u32 index, u32 *perm) return -ENOSYS; }
+#if CONFIG_IS_ENABLED(DM_RNG) int tpm_get_random(struct udevice *dev, void *data, u32 count) { + int ret = -ENOSYS; + struct udevice *rng_dev; + if (is_tpm1(dev)) - return tpm1_get_random(dev, data, count); + ret = uclass_get_device_by_driver(UCLASS_RNG, + DM_DRIVER_GET(tpm1_rng), + &rng_dev); else if (is_tpm2(dev)) - return -ENOSYS; /* not implemented yet */ - else - return -ENOSYS; + ret = uclass_get_device_by_driver(UCLASS_RNG, + DM_DRIVER_GET(tpm2_rng), + &rng_dev); + + if (ret) { + log_err("Getting tpm rng device failed\n"); + return ret; + } + + return dm_rng_read(rng_dev, data, (size_t)count); } +#endif /* DM_RNG */
Hi Sughosh,
Changes since V1:
- Added existing copyrights for the rng functions taken from the tpm library routines
- Return -EIO for TPM command returning an error
- Simplify the logic in tpm_get_random based on the review comments from Ilias
- Copyright (c) 2013 The Chromium OS Authors.
- Coypright (c) 2013 Guntermann & Drunck GmbH
- Copyright (c) 2022, Linaro Limited
- tpm1_rng_read() - Read the random bytes from TPMv1 device
- @param dev TPMv1 RNG device
- @param data data buffer to write random bytes
- @param count number of random bytes to read from
the device
- Function to read the random bytes from the RNG pseudo device
- built into the TPMv1 device. Reads 'count' number of bytes
- from the random number generator and copies them into the
- 'data' buffer.
- Return: 0 if OK, -ve on error.
u32 data_size;
u8 *out = data;
The current model is that all TPM calls are set up in lib/tpm and I don't think we should change it. You should be able to move these functions into lib/tpm and add your random_read function to tpm_api.h
hi Simon,
On Tue, 1 Mar 2022 at 20:28, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
Changes since V1:
the device
- 'data' buffer.
u32 data_size;
u8 *out = data;
I moved these functions under separate drivers as I thought that looked cleaner as against exporting the driver interface in tpm-v{1,2}.c. If you strongly feel that these should remain under lib/tpm, I will make the change. But I believe you do not have a problem with exporting these rng functions as part of the driver model. We do need that so that the EFI_RNG_PROTOCOL can use these for getting the random bytes.
-sughosh
Hi Sughosh,
On Tue, 1 Mar 2022 at 21:36, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
Changes since V1:
the device
- 'data' buffer.
u32 data_size;
u8 *out = data;
But you are now creating TPM messages in a different file so I don't think it is cleaner. The message pack/unpack should happen in the tpm_... functions.
I think you might misunderstand me. I mean that the code that calls pack_byte_string() should be in lib/ like the other code. I agree that the driver should be were you have put it, I just don't like having the tpm message creation in that driver. It should call a tpm_... function to create and send the message, like elsewhere.
hi Simon,
On Thu, 3 Mar 2022 at 09:17, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
hi Simon,
Hi Sughosh,
Changes since V1:
the device
- 'data' buffer.
u32 data_size;
u8 *out = data;
I tried putting a wrapper around the pack/unpack functions like you suggest, but it is getting more complicated than required. Even after putting the wrapper, there still is an issue of tpm_sendrecv being declared in tpm-utils.h, along with some other necessary macros like COMMAND_BUFFER_SIZE. You have mentioned in another review that you don't want tpm-utils.h to be moved to the include/ directory. If we are not to move tpm-utils.h and also not call functions like pack_byte_string directly from the driver, I feel it will be easier to simply export the rng functions to the driver model from within lib/tpm/ instead of moving them under drivers/rng/. Will you be okay with this.
-sughosh
Hi Sughosh,
On Thu, 3 Mar 2022 at 05:07, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
hi Simon,
Hi Sughosh,
Changes since V1:
the device
- 'data' buffer.
u32 data_size;
u8 *out = data;
See tpm1_get_random() ... can you write a function that works like that, i.e. implements the tpm API? You are bypassing the API, which is what I don't like.
I'm just a bit lost as to what the problem is. See above. Perhaps you can send a patch or add a bit more detail so I can understand it.
Regards, SImon
hi Simon,
On Fri, 4 Mar 2022 at 08:08, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
hi Simon,
Hi Sughosh,
hi Simon,
Hi Sughosh,
Changes since V1:
the device
- 'data' buffer.
u32 data_size;
u8 *out = data;
I have sent a v3 patch series which takes the approach I was trying to explain above. Please check. Thanks.
-sughosh
Regards, SImon
The TPM device comes with the random number generator(RNG) functionality which is built into the TPM device. Add logic to add the RNG child device in the TPM uclass post probe callback.
The RNG device can then be used to pass a set of random bytes to the linux kernel, need for address space randomisation through the EFI_RNG_PROTOCOL interface.
drivers/tpm/tpm-uclass.c | 58 +++++++++++++++++++++++++++++++++++++--- 1 file changed, 54 insertions(+), 4 deletions(-)
diff --git a/drivers/tpm/tpm-uclass.c b/drivers/tpm/tpm-uclass.c index 8619da89d8..383cc7bc48 100644 --- a/drivers/tpm/tpm-uclass.c +++ b/drivers/tpm/tpm-uclass.c @@ -16,6 +16,11 @@ #include <tpm-v2.h> #include "tpm_internal.h"
+#include <dm/lists.h> + +#define TPM_RNG1_DRV_NAME "tpm1-rng" +#define TPM_RNG2_DRV_NAME "tpm2-rng" + bool is_tpm1(struct udevice *dev) { return IS_ENABLED(CONFIG_TPM_V1) && tpm_get_version(dev) == TPM_V1; @@ -147,12 +152,57 @@ int tpm_xfer(struct udevice *dev, const uint8_t *sendbuf, size_t send_size, return 0; }
+#if IS_ENABLED(CONFIG_TPM) +static int tpm_uclass_post_probe(struct udevice *dev) +{ + int ret; + const char *drv = is_tpm1(dev) ? TPM_RNG1_DRV_NAME : TPM_RNG2_DRV_NAME; + struct udevice *child; + + ret = device_bind_driver(dev, drv, "tpm-rng0", &child); + if (ret == -ENOENT) { + log_err("No driver configured for tpm-rng device\n"); + return 0; + } + + if (ret) { + log_err("Unable to bind rng driver with the tpm-rng device\n"); + return ret; + } + + return 0; +} + +static int tpm_uclass_child_pre_probe(struct udevice *dev) +{ + int ret; + + ret = tpm_open(dev->parent); + if (ret == -EBUSY) { + log_info("TPM device already opened\n"); + } else if (ret) { + log_err("Unable to open TPM device\n"); + return ret; + } + + ret = tpm_startup(dev->parent, TPM_ST_CLEAR); + if (ret) + log_err("Unable to start TPM device\n"); + + return ret; +} +#endif /* CONFIG_TPM */ + UCLASS_DRIVER(tpm) = { - .id = UCLASS_TPM, - .name = "tpm", - .flags = DM_UC_FLAG_SEQ_ALIAS, + .id = UCLASS_TPM, + .name = "tpm", + .flags = DM_UC_FLAG_SEQ_ALIAS, #if CONFIG_IS_ENABLED(OF_REAL) - .post_bind = dm_scan_fdt_dev, + .post_bind = dm_scan_fdt_dev, +#endif +#if IS_ENABLED(CONFIG_TPM) + .post_probe = tpm_uclass_post_probe, + .child_pre_probe = tpm_uclass_child_pre_probe, #endif .per_device_auto = sizeof(struct tpm_chip_priv), };
Hi Sughosh,
This should be in the Makefile so that we only build this file if TPM is enabled.
int ret;
if (ret) {
return ret;
int ret;
} else if (ret) {
return ret;
if (ret)
return ret;
.id = UCLASS_TPM,
.name = "tpm",
.id = UCLASS_TPM,
.name = "tpm",
#endif .per_device_auto = sizeof(struct tpm_chip_priv), }; -- 2.25.1
hi Simon,
Hi Sughosh,
The Makefile allows for the tpm uclass driver to be built for SPL and TPL stages as well. The addition of the RNG device is to be done only in the u-boot proper stage, since we enable RNG support only in u-boot proper. Thanks.
-sughosh
int ret;
if (ret) {
return ret;
int ret;
} else if (ret) {
return ret;
if (ret)
return ret;
.id = UCLASS_TPM,
.name = "tpm",
.id = UCLASS_TPM,
.name = "tpm",
Hi Sughosh,
On Tue, 1 Mar 2022 at 21:53, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
Well in that case, create a new SPL_TPM_RAND or similar to control enabling it in SPL. It should be explicit.
hi Simon,
On Thu, 3 Mar 2022 at 09:18, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
hi Simon,
Hi Sughosh,
I think it is easier to just protect the child addition functions under CONFIG_TPM rather than create SPL_RNG and TPL_RNG symbols. We don't have any requirement for generating random numbers in the SPL and TPL stages. I feel that creating new symbols just for the sake of not putting a check for CONFIG_TPM is a bit of an overkill, especially since we do not have any requirement for RNG devices in the SPL/TPL stages.
-sughosh
Hi Sughosh,
On Thu, 3 Mar 2022 at 05:11, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
hi Simon,
Hi Sughosh,
What does checking for CONFIG_TPM have to do with SPL and TPL? If that option is enabled, the feature will be active in SPL and TPL too.
Also I see another problem, on further examination. You cannot start up the TPM in the pre_probe() function. That needs to be done under board control. E.g. for coral it happens in the TPL (or soon VPL) phase so cannot be done again in U-Boot proper.
So perhaps we need to remember the state of the TPM (using SPL handoff perhaps). Also you probably need to move the startup stuff to the RNG itself.
Perhaps we could add a new function to handle this, which can be called from your rand driver.
int tpm_ensure_started(struct udevice *dev, enum tpm_startup_type mode)
hi Simon,
On Fri, 4 Mar 2022 at 08:07, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
hi Simon,
Hi Sughosh,
hi Simon,
Hi Sughosh,
Maybe I am not explaining it properly. We need the addition of the RNG child device only in the u-boot proper stage, not in the SPL and TPL stages. The TPM uclass driver can indeed be built for the SPL and TPL stages, while the RNG uclass is needed only for u-boot proper. So, the addition of the RNG child device done in the TPM uclass driver should only happen in u-boot proper, and not in SPL/TPL stages. Which is the reason for the CONFIG_TPM check.
I tested running the RNG command after the TPM device has already been probed and tpm_startup has been called. Even if I call the tpm_startup again, I do not see any issues. Does the TPM spec prohibit calling the initialisation function multiple times. I believe that the TPM device should be able to handle this scenario right?
I can move the call to tpm_startup to the RNG driver's probe function. But I thought it is better that the parent device(TPM) is initialised before calling the probe of the child device.
Okay, I can add this, but the question is, does calling the tpm_startup function cause issues? If not, maybe this is not needed?
-sughosh
We've already discussed this in [1]. Issuing multiple startup commands will just make the TPM respond with TPM2_RC_INITIALIZE. At least that's my reading of [2]
[1] https://lore.kernel.org/all/CAC_iWjLQmsGLLYfnDFq17-SD3RC7-Da-M41Qc5DjWp3XX9Z... [2] https://trustedcomputinggroup.org/wp-content/uploads/TPM-Rev-2.0-Part-3-Comm... section 9.3.1
Regards /Ilias
Hi Sughosh,
On Fri, 4 Mar 2022 at 06:44, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
hi Simon,
Hi Sughosh,
hi Simon,
Hi Sughosh,
On Mon, 28 Feb 2022 at 05:07, Sughosh Ganu sughosh.ganu@linaro.org wrote: > > The TPM device comes with the random number generator(RNG) > functionality which is built into the TPM device. Add logic to add the > RNG child device in the TPM uclass post probe callback. > > The RNG device can then be used to pass a set of random bytes to the > linux kernel, need for address space randomisation through the > EFI_RNG_PROTOCOL interface. > > Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org > --- > > Changes since V1: None > > drivers/tpm/tpm-uclass.c | 58 +++++++++++++++++++++++++++++++++++++--- > 1 file changed, 54 insertions(+), 4 deletions(-) > > diff --git a/drivers/tpm/tpm-uclass.c b/drivers/tpm/tpm-uclass.c > index 8619da89d8..383cc7bc48 100644 > --- a/drivers/tpm/tpm-uclass.c > +++ b/drivers/tpm/tpm-uclass.c > @@ -16,6 +16,11 @@ > #include <tpm-v2.h> > #include "tpm_internal.h" > > +#include <dm/lists.h> > + > +#define TPM_RNG1_DRV_NAME "tpm1-rng" > +#define TPM_RNG2_DRV_NAME "tpm2-rng" > + > bool is_tpm1(struct udevice *dev) > { > return IS_ENABLED(CONFIG_TPM_V1) && tpm_get_version(dev) == TPM_V1; > @@ -147,12 +152,57 @@ int tpm_xfer(struct udevice *dev, const uint8_t *sendbuf, size_t send_size, > return 0; > } > > +#if IS_ENABLED(CONFIG_TPM)
Let me try one more time. If this doesn't work, please chat with a colleague.
The way we do that is with Kconfig options. We don't use ad-hoc methods to enable things in U-Boot proper but not SPL. Boards that have CONFIG_TPM set have it set everywhere, including in SPL. So checking for CONFIG_TPM is going to return true in both U-Boot proper and SPL. If you want different behaviour in SPL, you need CONFIG_SPL_TPM. But even that is indirect, as I have explained. To enable your driver in SPL, you need a CONFIG_SPL_...
Also, you should use devicetree to provide the random number generator, just a device_bind(). Add the node as a subnode of the TPM. Otherwise it cannot work with OF_PLATDATA.
I hangs on coral, for example.
We use lazy init in U-Boot, so it should be possible to probe the TPM without automatically starting it. Otherwise you are going to break some of the tpm commands.
It does on coral. I don't know whether other TPMs are tolerant of it, but in any case it is not a good idea.
hi Simon,
On Sun, 6 Mar 2022 at 08:37, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
hi Simon,
Hi Sughosh,
hi Simon,
Hi Sughosh,
hi Simon,
On Tue, 1 Mar 2022 at 20:29, Simon Glass sjg@chromium.org wrote: > > Hi Sughosh, > > On Mon, 28 Feb 2022 at 05:07, Sughosh Ganu sughosh.ganu@linaro.org wrote: > > > > The TPM device comes with the random number generator(RNG) > > functionality which is built into the TPM device. Add logic to add the > > RNG child device in the TPM uclass post probe callback. > > > > The RNG device can then be used to pass a set of random bytes to the > > linux kernel, need for address space randomisation through the > > EFI_RNG_PROTOCOL interface. > > > > Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org > > --- > > > > Changes since V1: None > > > > drivers/tpm/tpm-uclass.c | 58 +++++++++++++++++++++++++++++++++++++--- > > 1 file changed, 54 insertions(+), 4 deletions(-) > > > > diff --git a/drivers/tpm/tpm-uclass.c b/drivers/tpm/tpm-uclass.c > > index 8619da89d8..383cc7bc48 100644 > > --- a/drivers/tpm/tpm-uclass.c > > +++ b/drivers/tpm/tpm-uclass.c > > @@ -16,6 +16,11 @@ > > #include <tpm-v2.h> > > #include "tpm_internal.h" > > > > +#include <dm/lists.h> > > + > > +#define TPM_RNG1_DRV_NAME "tpm1-rng" > > +#define TPM_RNG2_DRV_NAME "tpm2-rng" > > + > > bool is_tpm1(struct udevice *dev) > > { > > return IS_ENABLED(CONFIG_TPM_V1) && tpm_get_version(dev) == TPM_V1; > > @@ -147,12 +152,57 @@ int tpm_xfer(struct udevice *dev, const uint8_t *sendbuf, size_t send_size, > > return 0; > > } > > > > +#if IS_ENABLED(CONFIG_TPM) > > This should be in the Makefile so that we only build this file if TPM > is enabled.
Okay. I now get your point. So this is because these config symbols are getting included in all the stages, so I cannot use the symbol name to identify the spl/tpl/u-boot stages. I believe earlier, the identification used to be done based on whether a symbol is CONFIG_xxx as against CONFIG_SPL_xxx. Now it is being done with CONFIG_{SPL,TPL}_BUILD symbols for differentiating between stages. I will use these instead to have the code enabled only for the u-boot proper stage. Thing is, I don't want to define these functions for the spl and tpl stages since they are adding to the size with no benefits. I do understand that currently no platform is enabling tpm drivers in the spl/tpl stage, but the driver can be enabled in those stages.
As per the documentation in of-plat.rst, the OF_PLATDATA method is to be used only for the SPL/TPL stages where there might be a size constraint. And the tpm rng drivers are to be enabled only in the u-boot proper stage. So I think we would not need to put a subnode in the devicetree. Basically, the presence of the rng functionality in the TPM device is not optional as per my understanding, so the rng child node can just be added in the tpm uclass driver.
Yes I understand. With the patch, the tpm device is being started only when a child device is being probed. But I can remove the startup of the tpm device from the child_pre_probe function. It will have to be done explicitly before the rng device is to be used.
Btw, can you please comment on patch 3 of this series[1].
-sughosh
[1] - https://lists.denx.de/pipermail/u-boot/2022-March/476830.html
Hi Sughosh,
On Sun, 6 Mar 2022 at 00:03, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
hi Simon,
Hi Sughosh,
hi Simon,
Hi Sughosh,
On Tue, 1 Mar 2022 at 21:53, Sughosh Ganu sughosh.ganu@linaro.org wrote: > > hi Simon, > > On Tue, 1 Mar 2022 at 20:29, Simon Glass sjg@chromium.org wrote: > > > > Hi Sughosh, > > > > On Mon, 28 Feb 2022 at 05:07, Sughosh Ganu sughosh.ganu@linaro.org wrote: > > > > > > The TPM device comes with the random number generator(RNG) > > > functionality which is built into the TPM device. Add logic to add the > > > RNG child device in the TPM uclass post probe callback. > > > > > > The RNG device can then be used to pass a set of random bytes to the > > > linux kernel, need for address space randomisation through the > > > EFI_RNG_PROTOCOL interface. > > > > > > Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org > > > --- > > > > > > Changes since V1: None > > > > > > drivers/tpm/tpm-uclass.c | 58 +++++++++++++++++++++++++++++++++++++--- > > > 1 file changed, 54 insertions(+), 4 deletions(-) > > > > > > diff --git a/drivers/tpm/tpm-uclass.c b/drivers/tpm/tpm-uclass.c > > > index 8619da89d8..383cc7bc48 100644 > > > --- a/drivers/tpm/tpm-uclass.c > > > +++ b/drivers/tpm/tpm-uclass.c > > > @@ -16,6 +16,11 @@ > > > #include <tpm-v2.h> > > > #include "tpm_internal.h" > > > > > > +#include <dm/lists.h> > > > + > > > +#define TPM_RNG1_DRV_NAME "tpm1-rng" > > > +#define TPM_RNG2_DRV_NAME "tpm2-rng" > > > + > > > bool is_tpm1(struct udevice *dev) > > > { > > > return IS_ENABLED(CONFIG_TPM_V1) && tpm_get_version(dev) == TPM_V1; > > > @@ -147,12 +152,57 @@ int tpm_xfer(struct udevice *dev, const uint8_t *sendbuf, size_t send_size, > > > return 0; > > > } > > > > > > +#if IS_ENABLED(CONFIG_TPM) > > > > This should be in the Makefile so that we only build this file if TPM > > is enabled. > > The Makefile allows for the tpm uclass driver to be built for SPL and > TPL stages as well. The addition of the RNG device is to be done only > in the u-boot proper stage, since we enable RNG support only in u-boot > proper. Thanks.
coral uses TPM in the VPL stage. In general, the TPM needs to be used earlier than U-Boot proper, since verified boot has to be complete by then.
We don't need the subnode but it is normal practice to have one. If you want to use a manual bind, that is OK, at least for U-Boot proper.
Yes, that's how it should work, for now.
I suspect it is in my queue but I have not had time yet.
-sughosh
The Qemu platform has a function defined to get the random number generator(RNG) device. However, the RNG device can be obtained simply by searching for a device belonging to the RNG uclass. Remove the superfluous platform function defined for the Qemu platform for getting the RNG device.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Tested-by: Heinrich Schuchardt xypron.glpk@gmx.de ---
board/emulation/qemu-arm/qemu-arm.c | 42 ----------------------------- 1 file changed, 42 deletions(-)
diff --git a/board/emulation/qemu-arm/qemu-arm.c b/board/emulation/qemu-arm/qemu-arm.c index 16d5a97167..c9e886e44a 100644 --- a/board/emulation/qemu-arm/qemu-arm.c +++ b/board/emulation/qemu-arm/qemu-arm.c @@ -107,48 +107,6 @@ void enable_caches(void) dcache_enable(); }
-#if defined(CONFIG_EFI_RNG_PROTOCOL) -#include <efi_loader.h> -#include <efi_rng.h> - -#include <dm/device-internal.h> - -efi_status_t platform_get_rng_device(struct udevice **dev) -{ - int ret; - efi_status_t status = EFI_DEVICE_ERROR; - struct udevice *bus, *devp; - - for (uclass_first_device(UCLASS_VIRTIO, &bus); bus; - uclass_next_device(&bus)) { - for (device_find_first_child(bus, &devp); devp; - device_find_next_child(&devp)) { - if (device_get_uclass_id(devp) == UCLASS_RNG) { - *dev = devp; - status = EFI_SUCCESS; - break; - } - } - } - - if (status != EFI_SUCCESS) { - debug("No rng device found\n"); - return EFI_DEVICE_ERROR; - } - - if (*dev) { - ret = device_probe(*dev); - if (ret) - return EFI_DEVICE_ERROR; - } else { - debug("Couldn't get child device\n"); - return EFI_DEVICE_ERROR; - } - - return EFI_SUCCESS; -} -#endif /* CONFIG_EFI_RNG_PROTOCOL */ - #ifdef CONFIG_ARM64 #define __W "w" #else
The 'rng' u-boot command is used for printing a select number of random bytes on the console. Currently, the RNG device from which the random bytes are read is fixed. However, a platform can have multiple RNG devices, one example being qemu, which has a virtio RNG device and the RNG pseudo device through the TPM chip.
Extend the 'rng' command so that the user can provide the RNG device number from which the random bytes are to be read. This will be the device index under the RNG uclass.
Changes since V1: * Changed the help text to show order of the parameters passed to the rng command, based on review comment from Heinrich
cmd/rng.c | 31 +++++++++++++++++++++++-------- 1 file changed, 23 insertions(+), 8 deletions(-)
diff --git a/cmd/rng.c b/cmd/rng.c index 1ad5a096c0..bb89cfa784 100644 --- a/cmd/rng.c +++ b/cmd/rng.c @@ -13,19 +13,34 @@
static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - size_t n = 0x40; + size_t n; struct udevice *dev; void *buf; + int devnum; int ret = CMD_RET_SUCCESS;
- if (uclass_get_device(UCLASS_RNG, 0, &dev) || !dev) { + switch (argc) { + case 1: + devnum = 0; + n = 0x40; + break; + case 2: + devnum = hextoul(argv[1], NULL); + n = 0x40; + break; + case 3: + devnum = hextoul(argv[1], NULL); + n = hextoul(argv[2], NULL); + break; + default: + return CMD_RET_USAGE; + } + + if (uclass_get_device(UCLASS_RNG, devnum, &dev) || !dev) { printf("No RNG device\n"); return CMD_RET_FAILURE; }
- if (argc >= 2) - n = hextoul(argv[1], NULL); - buf = malloc(n); if (!buf) { printf("Out of memory\n"); @@ -46,12 +61,12 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[])
#ifdef CONFIG_SYS_LONGHELP static char rng_help_text[] = - "[n]\n" - " - print n random bytes\n"; + "[dev [n]]\n" + " - print n random bytes read from dev\n"; #endif
U_BOOT_CMD( - rng, 2, 0, do_rng, + rng, 3, 0, do_rng, "print bytes from the hardware random number generator", rng_help_text );
Hi Sughosh,
Changes since V1:
- Changed the help text to show order of the parameters passed to the rng command, based on review comment from Heinrich
Please add a test for the command and also add doc/usage
hi Simon,
Hi Sughosh,
Changes since V1:
We already have a test for the RNG uclass, which is basically doing the exact same thing. Do we still need one for the command? Or is it for testing the command parameters?
-sughosh
Hi Sughosh,
On Tue, 1 Mar 2022 at 21:56, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
Changes since V1:
Yes and it provides test coverage. See acpi.c for an example test. It can be quite simple I suspect.
Ilias Apalodimas
Sughosh Ganu
