[PATCH v2 1/3] mx23-evk: Import devicetree file from Linux
Import the imx23-evk devicetree files from Linux kernel version 5.11.
This is in preparation for converting the mx23evk_defconfig target to driver model.
Signed-off-by: Fabio Estevam festevam@gmail.com --- Changes since v1: - Fix subject mx28->mx23
arch/arm/dts/imx23-evk.dts | 145 ++++++++ arch/arm/dts/imx23-pinfunc.h | 333 ++++++++++++++++++ arch/arm/dts/imx23.dtsi | 636 +++++++++++++++++++++++++++++++++++ 3 files changed, 1114 insertions(+) create mode 100644 arch/arm/dts/imx23-evk.dts create mode 100644 arch/arm/dts/imx23-pinfunc.h create mode 100644 arch/arm/dts/imx23.dtsi
diff --git a/arch/arm/dts/imx23-evk.dts b/arch/arm/dts/imx23-evk.dts new file mode 100644 index 000000000000..8cbaf1c81174 --- /dev/null +++ b/arch/arm/dts/imx23-evk.dts @@ -0,0 +1,145 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright 2012 Freescale Semiconductor, Inc. + +/dts-v1/; +#include "imx23.dtsi" + +/ { + model = "Freescale i.MX23 Evaluation Kit"; + compatible = "fsl,imx23-evk", "fsl,imx23"; + + memory@40000000 { + device_type = "memory"; + reg = <0x40000000 0x08000000>; + }; + + reg_vddio_sd0: regulator-vddio-sd0 { + compatible = "regulator-fixed"; + regulator-name = "vddio-sd0"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio1 29 0>; + }; + + reg_lcd_3v3: regulator-lcd-3v3 { + compatible = "regulator-fixed"; + regulator-name = "lcd-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio1 18 0>; + enable-active-high; + }; + + reg_lcd_5v: regulator-lcd-5v { + compatible = "regulator-fixed"; + regulator-name = "lcd-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + panel { + compatible = "sii,43wvf1g"; + backlight = <&backlight_display>; + dvdd-supply = <®_lcd_3v3>; + avdd-supply = <®_lcd_5v>; + + port { + panel_in: endpoint { + remote-endpoint = <&display_out>; + }; + }; + }; + + apb@80000000 { + apbh@80000000 { + nand-controller@8000c000 { + pinctrl-names = "default"; + pinctrl-0 = <&gpmi_pins_a &gpmi_pins_fixup>; + status = "okay"; + }; + + ssp0: spi@80010000 { + compatible = "fsl,imx23-mmc"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_4bit_pins_a &mmc0_pins_fixup>; + bus-width = <4>; + wp-gpios = <&gpio1 30 0>; + vmmc-supply = <®_vddio_sd0>; + status = "okay"; + }; + + pinctrl@80018000 { + pinctrl-names = "default"; + pinctrl-0 = <&hog_pins_a>; + + hog_pins_a: hog@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_LCD_RESET__GPIO_1_18 + MX23_PAD_PWM3__GPIO_1_29 + MX23_PAD_PWM4__GPIO_1_30 + MX23_PAD_SSP1_DETECT__SSP1_DETECT + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + }; + + lcdif@80030000 { + pinctrl-names = "default"; + pinctrl-0 = <&lcdif_24bit_pins_a>; + status = "okay"; + + port { + display_out: endpoint { + remote-endpoint = <&panel_in>; + }; + }; + }; + }; + + apbx@80040000 { + lradc@80050000 { + status = "okay"; + fsl,lradc-touchscreen-wires = <4>; + }; + + pwm: pwm@80064000 { + pinctrl-names = "default"; + pinctrl-0 = <&pwm2_pins_a>; + status = "okay"; + }; + + auart0: serial@8006c000 { + pinctrl-names = "default"; + pinctrl-0 = <&auart0_pins_a>; + status = "okay"; + }; + + duart: serial@80070000 { + pinctrl-names = "default"; + pinctrl-0 = <&duart_pins_a>; + status = "okay"; + }; + + usbphy0: usbphy@8007c000 { + status = "okay"; + }; + }; + }; + + ahb@80080000 { + usb0: usb@80080000 { + status = "okay"; + }; + }; + + backlight_display: backlight { + compatible = "pwm-backlight"; + pwms = <&pwm 2 5000000>; + brightness-levels = <0 4 8 16 32 64 128 255>; + default-brightness-level = <6>; + }; +}; diff --git a/arch/arm/dts/imx23-pinfunc.h b/arch/arm/dts/imx23-pinfunc.h new file mode 100644 index 000000000000..5c0f32ca3a93 --- /dev/null +++ b/arch/arm/dts/imx23-pinfunc.h @@ -0,0 +1,333 @@ +/* + * Header providing constants for i.MX23 pinctrl bindings. + * + * Copyright (C) 2013 Lothar Waßmann LW@KARO-electronics.de + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +#ifndef __DT_BINDINGS_MX23_PINCTRL_H__ +#define __DT_BINDINGS_MX23_PINCTRL_H__ + +#include "mxs-pinfunc.h" + +#define MX23_PAD_GPMI_D00__GPMI_D00 0x0000 +#define MX23_PAD_GPMI_D01__GPMI_D01 0x0010 +#define MX23_PAD_GPMI_D02__GPMI_D02 0x0020 +#define MX23_PAD_GPMI_D03__GPMI_D03 0x0030 +#define MX23_PAD_GPMI_D04__GPMI_D04 0x0040 +#define MX23_PAD_GPMI_D05__GPMI_D05 0x0050 +#define MX23_PAD_GPMI_D06__GPMI_D06 0x0060 +#define MX23_PAD_GPMI_D07__GPMI_D07 0x0070 +#define MX23_PAD_GPMI_D08__GPMI_D08 0x0080 +#define MX23_PAD_GPMI_D09__GPMI_D09 0x0090 +#define MX23_PAD_GPMI_D10__GPMI_D10 0x00a0 +#define MX23_PAD_GPMI_D11__GPMI_D11 0x00b0 +#define MX23_PAD_GPMI_D12__GPMI_D12 0x00c0 +#define MX23_PAD_GPMI_D13__GPMI_D13 0x00d0 +#define MX23_PAD_GPMI_D14__GPMI_D14 0x00e0 +#define MX23_PAD_GPMI_D15__GPMI_D15 0x00f0 +#define MX23_PAD_GPMI_CLE__GPMI_CLE 0x0100 +#define MX23_PAD_GPMI_ALE__GPMI_ALE 0x0110 +#define MX23_PAD_GPMI_CE2N__GPMI_CE2N 0x0120 +#define MX23_PAD_GPMI_RDY0__GPMI_RDY0 0x0130 +#define MX23_PAD_GPMI_RDY1__GPMI_RDY1 0x0140 +#define MX23_PAD_GPMI_RDY2__GPMI_RDY2 0x0150 +#define MX23_PAD_GPMI_RDY3__GPMI_RDY3 0x0160 +#define MX23_PAD_GPMI_WPN__GPMI_WPN 0x0170 +#define MX23_PAD_GPMI_WRN__GPMI_WRN 0x0180 +#define MX23_PAD_GPMI_RDN__GPMI_RDN 0x0190 +#define MX23_PAD_AUART1_CTS__AUART1_CTS 0x01a0 +#define MX23_PAD_AUART1_RTS__AUART1_RTS 0x01b0 +#define MX23_PAD_AUART1_RX__AUART1_RX 0x01c0 +#define MX23_PAD_AUART1_TX__AUART1_TX 0x01d0 +#define MX23_PAD_I2C_SCL__I2C_SCL 0x01e0 +#define MX23_PAD_I2C_SDA__I2C_SDA 0x01f0 +#define MX23_PAD_LCD_D00__LCD_D00 0x1000 +#define MX23_PAD_LCD_D01__LCD_D01 0x1010 +#define MX23_PAD_LCD_D02__LCD_D02 0x1020 +#define MX23_PAD_LCD_D03__LCD_D03 0x1030 +#define MX23_PAD_LCD_D04__LCD_D04 0x1040 +#define MX23_PAD_LCD_D05__LCD_D05 0x1050 +#define MX23_PAD_LCD_D06__LCD_D06 0x1060 +#define MX23_PAD_LCD_D07__LCD_D07 0x1070 +#define MX23_PAD_LCD_D08__LCD_D08 0x1080 +#define MX23_PAD_LCD_D09__LCD_D09 0x1090 +#define MX23_PAD_LCD_D10__LCD_D10 0x10a0 +#define MX23_PAD_LCD_D11__LCD_D11 0x10b0 +#define MX23_PAD_LCD_D12__LCD_D12 0x10c0 +#define MX23_PAD_LCD_D13__LCD_D13 0x10d0 +#define MX23_PAD_LCD_D14__LCD_D14 0x10e0 +#define MX23_PAD_LCD_D15__LCD_D15 0x10f0 +#define MX23_PAD_LCD_D16__LCD_D16 0x1100 +#define MX23_PAD_LCD_D17__LCD_D17 0x1110 +#define MX23_PAD_LCD_RESET__LCD_RESET 0x1120 +#define MX23_PAD_LCD_RS__LCD_RS 0x1130 +#define MX23_PAD_LCD_WR__LCD_WR 0x1140 +#define MX23_PAD_LCD_CS__LCD_CS 0x1150 +#define MX23_PAD_LCD_DOTCK__LCD_DOTCK 0x1160 +#define MX23_PAD_LCD_ENABLE__LCD_ENABLE 0x1170 +#define MX23_PAD_LCD_HSYNC__LCD_HSYNC 0x1180 +#define MX23_PAD_LCD_VSYNC__LCD_VSYNC 0x1190 +#define MX23_PAD_PWM0__PWM0 0x11a0 +#define MX23_PAD_PWM1__PWM1 0x11b0 +#define MX23_PAD_PWM2__PWM2 0x11c0 +#define MX23_PAD_PWM3__PWM3 0x11d0 +#define MX23_PAD_PWM4__PWM4 0x11e0 +#define MX23_PAD_SSP1_CMD__SSP1_CMD 0x2000 +#define MX23_PAD_SSP1_DETECT__SSP1_DETECT 0x2010 +#define MX23_PAD_SSP1_DATA0__SSP1_DATA0 0x2020 +#define MX23_PAD_SSP1_DATA1__SSP1_DATA1 0x2030 +#define MX23_PAD_SSP1_DATA2__SSP1_DATA2 0x2040 +#define MX23_PAD_SSP1_DATA3__SSP1_DATA3 0x2050 +#define MX23_PAD_SSP1_SCK__SSP1_SCK 0x2060 +#define MX23_PAD_ROTARYA__ROTARYA 0x2070 +#define MX23_PAD_ROTARYB__ROTARYB 0x2080 +#define MX23_PAD_EMI_A00__EMI_A00 0x2090 +#define MX23_PAD_EMI_A01__EMI_A01 0x20a0 +#define MX23_PAD_EMI_A02__EMI_A02 0x20b0 +#define MX23_PAD_EMI_A03__EMI_A03 0x20c0 +#define MX23_PAD_EMI_A04__EMI_A04 0x20d0 +#define MX23_PAD_EMI_A05__EMI_A05 0x20e0 +#define MX23_PAD_EMI_A06__EMI_A06 0x20f0 +#define MX23_PAD_EMI_A07__EMI_A07 0x2100 +#define MX23_PAD_EMI_A08__EMI_A08 0x2110 +#define MX23_PAD_EMI_A09__EMI_A09 0x2120 +#define MX23_PAD_EMI_A10__EMI_A10 0x2130 +#define MX23_PAD_EMI_A11__EMI_A11 0x2140 +#define MX23_PAD_EMI_A12__EMI_A12 0x2150 +#define MX23_PAD_EMI_BA0__EMI_BA0 0x2160 +#define MX23_PAD_EMI_BA1__EMI_BA1 0x2170 +#define MX23_PAD_EMI_CASN__EMI_CASN 0x2180 +#define MX23_PAD_EMI_CE0N__EMI_CE0N 0x2190 +#define MX23_PAD_EMI_CE1N__EMI_CE1N 0x21a0 +#define MX23_PAD_GPMI_CE1N__GPMI_CE1N 0x21b0 +#define MX23_PAD_GPMI_CE0N__GPMI_CE0N 0x21c0 +#define MX23_PAD_EMI_CKE__EMI_CKE 0x21d0 +#define MX23_PAD_EMI_RASN__EMI_RASN 0x21e0 +#define MX23_PAD_EMI_WEN__EMI_WEN 0x21f0 +#define MX23_PAD_EMI_D00__EMI_D00 0x3000 +#define MX23_PAD_EMI_D01__EMI_D01 0x3010 +#define MX23_PAD_EMI_D02__EMI_D02 0x3020 +#define MX23_PAD_EMI_D03__EMI_D03 0x3030 +#define MX23_PAD_EMI_D04__EMI_D04 0x3040 +#define MX23_PAD_EMI_D05__EMI_D05 0x3050 +#define MX23_PAD_EMI_D06__EMI_D06 0x3060 +#define MX23_PAD_EMI_D07__EMI_D07 0x3070 +#define MX23_PAD_EMI_D08__EMI_D08 0x3080 +#define MX23_PAD_EMI_D09__EMI_D09 0x3090 +#define MX23_PAD_EMI_D10__EMI_D10 0x30a0 +#define MX23_PAD_EMI_D11__EMI_D11 0x30b0 +#define MX23_PAD_EMI_D12__EMI_D12 0x30c0 +#define MX23_PAD_EMI_D13__EMI_D13 0x30d0 +#define MX23_PAD_EMI_D14__EMI_D14 0x30e0 +#define MX23_PAD_EMI_D15__EMI_D15 0x30f0 +#define MX23_PAD_EMI_DQM0__EMI_DQM0 0x3100 +#define MX23_PAD_EMI_DQM1__EMI_DQM1 0x3110 +#define MX23_PAD_EMI_DQS0__EMI_DQS0 0x3120 +#define MX23_PAD_EMI_DQS1__EMI_DQS1 0x3130 +#define MX23_PAD_EMI_CLK__EMI_CLK 0x3140 +#define MX23_PAD_EMI_CLKN__EMI_CLKN 0x3150 +#define MX23_PAD_GPMI_D00__LCD_D8 0x0001 +#define MX23_PAD_GPMI_D01__LCD_D9 0x0011 +#define MX23_PAD_GPMI_D02__LCD_D10 0x0021 +#define MX23_PAD_GPMI_D03__LCD_D11 0x0031 +#define MX23_PAD_GPMI_D04__LCD_D12 0x0041 +#define MX23_PAD_GPMI_D05__LCD_D13 0x0051 +#define MX23_PAD_GPMI_D06__LCD_D14 0x0061 +#define MX23_PAD_GPMI_D07__LCD_D15 0x0071 +#define MX23_PAD_GPMI_D08__LCD_D18 0x0081 +#define MX23_PAD_GPMI_D09__LCD_D19 0x0091 +#define MX23_PAD_GPMI_D10__LCD_D20 0x00a1 +#define MX23_PAD_GPMI_D11__LCD_D21 0x00b1 +#define MX23_PAD_GPMI_D12__LCD_D22 0x00c1 +#define MX23_PAD_GPMI_D13__LCD_D23 0x00d1 +#define MX23_PAD_GPMI_D14__AUART2_RX 0x00e1 +#define MX23_PAD_GPMI_D15__AUART2_TX 0x00f1 +#define MX23_PAD_GPMI_CLE__LCD_D16 0x0101 +#define MX23_PAD_GPMI_ALE__LCD_D17 0x0111 +#define MX23_PAD_GPMI_CE2N__ATA_A2 0x0121 +#define MX23_PAD_AUART1_RTS__IR_CLK 0x01b1 +#define MX23_PAD_AUART1_RX__IR_RX 0x01c1 +#define MX23_PAD_AUART1_TX__IR_TX 0x01d1 +#define MX23_PAD_I2C_SCL__GPMI_RDY2 0x01e1 +#define MX23_PAD_I2C_SDA__GPMI_CE2N 0x01f1 +#define MX23_PAD_LCD_D00__ETM_DA8 0x1001 +#define MX23_PAD_LCD_D01__ETM_DA9 0x1011 +#define MX23_PAD_LCD_D02__ETM_DA10 0x1021 +#define MX23_PAD_LCD_D03__ETM_DA11 0x1031 +#define MX23_PAD_LCD_D04__ETM_DA12 0x1041 +#define MX23_PAD_LCD_D05__ETM_DA13 0x1051 +#define MX23_PAD_LCD_D06__ETM_DA14 0x1061 +#define MX23_PAD_LCD_D07__ETM_DA15 0x1071 +#define MX23_PAD_LCD_D08__ETM_DA0 0x1081 +#define MX23_PAD_LCD_D09__ETM_DA1 0x1091 +#define MX23_PAD_LCD_D10__ETM_DA2 0x10a1 +#define MX23_PAD_LCD_D11__ETM_DA3 0x10b1 +#define MX23_PAD_LCD_D12__ETM_DA4 0x10c1 +#define MX23_PAD_LCD_D13__ETM_DA5 0x10d1 +#define MX23_PAD_LCD_D14__ETM_DA6 0x10e1 +#define MX23_PAD_LCD_D15__ETM_DA7 0x10f1 +#define MX23_PAD_LCD_RESET__ETM_TCTL 0x1121 +#define MX23_PAD_LCD_RS__ETM_TCLK 0x1131 +#define MX23_PAD_LCD_DOTCK__GPMI_RDY3 0x1161 +#define MX23_PAD_LCD_ENABLE__I2C_SCL 0x1171 +#define MX23_PAD_LCD_HSYNC__I2C_SDA 0x1181 +#define MX23_PAD_LCD_VSYNC__LCD_BUSY 0x1191 +#define MX23_PAD_PWM0__ROTARYA 0x11a1 +#define MX23_PAD_PWM1__ROTARYB 0x11b1 +#define MX23_PAD_PWM2__GPMI_RDY3 0x11c1 +#define MX23_PAD_PWM3__ETM_TCTL 0x11d1 +#define MX23_PAD_PWM4__ETM_TCLK 0x11e1 +#define MX23_PAD_SSP1_DETECT__GPMI_CE3N 0x2011 +#define MX23_PAD_SSP1_DATA1__I2C_SCL 0x2031 +#define MX23_PAD_SSP1_DATA2__I2C_SDA 0x2041 +#define MX23_PAD_ROTARYA__AUART2_RTS 0x2071 +#define MX23_PAD_ROTARYB__AUART2_CTS 0x2081 +#define MX23_PAD_GPMI_D00__SSP2_DATA0 0x0002 +#define MX23_PAD_GPMI_D01__SSP2_DATA1 0x0012 +#define MX23_PAD_GPMI_D02__SSP2_DATA2 0x0022 +#define MX23_PAD_GPMI_D03__SSP2_DATA3 0x0032 +#define MX23_PAD_GPMI_D04__SSP2_DATA4 0x0042 +#define MX23_PAD_GPMI_D05__SSP2_DATA5 0x0052 +#define MX23_PAD_GPMI_D06__SSP2_DATA6 0x0062 +#define MX23_PAD_GPMI_D07__SSP2_DATA7 0x0072 +#define MX23_PAD_GPMI_D08__SSP1_DATA4 0x0082 +#define MX23_PAD_GPMI_D09__SSP1_DATA5 0x0092 +#define MX23_PAD_GPMI_D10__SSP1_DATA6 0x00a2 +#define MX23_PAD_GPMI_D11__SSP1_DATA7 0x00b2 +#define MX23_PAD_GPMI_D15__GPMI_CE3N 0x00f2 +#define MX23_PAD_GPMI_RDY0__SSP2_DETECT 0x0132 +#define MX23_PAD_GPMI_RDY1__SSP2_CMD 0x0142 +#define MX23_PAD_GPMI_WRN__SSP2_SCK 0x0182 +#define MX23_PAD_AUART1_CTS__SSP1_DATA4 0x01a2 +#define MX23_PAD_AUART1_RTS__SSP1_DATA5 0x01b2 +#define MX23_PAD_AUART1_RX__SSP1_DATA6 0x01c2 +#define MX23_PAD_AUART1_TX__SSP1_DATA7 0x01d2 +#define MX23_PAD_I2C_SCL__AUART1_TX 0x01e2 +#define MX23_PAD_I2C_SDA__AUART1_RX 0x01f2 +#define MX23_PAD_LCD_D08__SAIF2_SDATA0 0x1082 +#define MX23_PAD_LCD_D09__SAIF1_SDATA0 0x1092 +#define MX23_PAD_LCD_D10__SAIF_MCLK_BITCLK 0x10a2 +#define MX23_PAD_LCD_D11__SAIF_LRCLK 0x10b2 +#define MX23_PAD_LCD_D12__SAIF2_SDATA1 0x10c2 +#define MX23_PAD_LCD_D13__SAIF2_SDATA2 0x10d2 +#define MX23_PAD_LCD_D14__SAIF1_SDATA2 0x10e2 +#define MX23_PAD_LCD_D15__SAIF1_SDATA1 0x10f2 +#define MX23_PAD_LCD_D16__SAIF_ALT_BITCLK 0x1102 +#define MX23_PAD_LCD_RESET__GPMI_CE3N 0x1122 +#define MX23_PAD_PWM0__DUART_RX 0x11a2 +#define MX23_PAD_PWM1__DUART_TX 0x11b2 +#define MX23_PAD_PWM3__AUART1_CTS 0x11d2 +#define MX23_PAD_PWM4__AUART1_RTS 0x11e2 +#define MX23_PAD_SSP1_CMD__JTAG_TDO 0x2002 +#define MX23_PAD_SSP1_DETECT__USB_OTG_ID 0x2012 +#define MX23_PAD_SSP1_DATA0__JTAG_TDI 0x2022 +#define MX23_PAD_SSP1_DATA1__JTAG_TCLK 0x2032 +#define MX23_PAD_SSP1_DATA2__JTAG_RTCK 0x2042 +#define MX23_PAD_SSP1_DATA3__JTAG_TMS 0x2052 +#define MX23_PAD_SSP1_SCK__JTAG_TRST 0x2062 +#define MX23_PAD_ROTARYA__SPDIF 0x2072 +#define MX23_PAD_ROTARYB__GPMI_CE3N 0x2082 +#define MX23_PAD_GPMI_D00__GPIO_0_0 0x0003 +#define MX23_PAD_GPMI_D01__GPIO_0_1 0x0013 +#define MX23_PAD_GPMI_D02__GPIO_0_2 0x0023 +#define MX23_PAD_GPMI_D03__GPIO_0_3 0x0033 +#define MX23_PAD_GPMI_D04__GPIO_0_4 0x0043 +#define MX23_PAD_GPMI_D05__GPIO_0_5 0x0053 +#define MX23_PAD_GPMI_D06__GPIO_0_6 0x0063 +#define MX23_PAD_GPMI_D07__GPIO_0_7 0x0073 +#define MX23_PAD_GPMI_D08__GPIO_0_8 0x0083 +#define MX23_PAD_GPMI_D09__GPIO_0_9 0x0093 +#define MX23_PAD_GPMI_D10__GPIO_0_10 0x00a3 +#define MX23_PAD_GPMI_D11__GPIO_0_11 0x00b3 +#define MX23_PAD_GPMI_D12__GPIO_0_12 0x00c3 +#define MX23_PAD_GPMI_D13__GPIO_0_13 0x00d3 +#define MX23_PAD_GPMI_D14__GPIO_0_14 0x00e3 +#define MX23_PAD_GPMI_D15__GPIO_0_15 0x00f3 +#define MX23_PAD_GPMI_CLE__GPIO_0_16 0x0103 +#define MX23_PAD_GPMI_ALE__GPIO_0_17 0x0113 +#define MX23_PAD_GPMI_CE2N__GPIO_0_18 0x0123 +#define MX23_PAD_GPMI_RDY0__GPIO_0_19 0x0133 +#define MX23_PAD_GPMI_RDY1__GPIO_0_20 0x0143 +#define MX23_PAD_GPMI_RDY2__GPIO_0_21 0x0153 +#define MX23_PAD_GPMI_RDY3__GPIO_0_22 0x0163 +#define MX23_PAD_GPMI_WPN__GPIO_0_23 0x0173 +#define MX23_PAD_GPMI_WRN__GPIO_0_24 0x0183 +#define MX23_PAD_GPMI_RDN__GPIO_0_25 0x0193 +#define MX23_PAD_AUART1_CTS__GPIO_0_26 0x01a3 +#define MX23_PAD_AUART1_RTS__GPIO_0_27 0x01b3 +#define MX23_PAD_AUART1_RX__GPIO_0_28 0x01c3 +#define MX23_PAD_AUART1_TX__GPIO_0_29 0x01d3 +#define MX23_PAD_I2C_SCL__GPIO_0_30 0x01e3 +#define MX23_PAD_I2C_SDA__GPIO_0_31 0x01f3 +#define MX23_PAD_LCD_D00__GPIO_1_0 0x1003 +#define MX23_PAD_LCD_D01__GPIO_1_1 0x1013 +#define MX23_PAD_LCD_D02__GPIO_1_2 0x1023 +#define MX23_PAD_LCD_D03__GPIO_1_3 0x1033 +#define MX23_PAD_LCD_D04__GPIO_1_4 0x1043 +#define MX23_PAD_LCD_D05__GPIO_1_5 0x1053 +#define MX23_PAD_LCD_D06__GPIO_1_6 0x1063 +#define MX23_PAD_LCD_D07__GPIO_1_7 0x1073 +#define MX23_PAD_LCD_D08__GPIO_1_8 0x1083 +#define MX23_PAD_LCD_D09__GPIO_1_9 0x1093 +#define MX23_PAD_LCD_D10__GPIO_1_10 0x10a3 +#define MX23_PAD_LCD_D11__GPIO_1_11 0x10b3 +#define MX23_PAD_LCD_D12__GPIO_1_12 0x10c3 +#define MX23_PAD_LCD_D13__GPIO_1_13 0x10d3 +#define MX23_PAD_LCD_D14__GPIO_1_14 0x10e3 +#define MX23_PAD_LCD_D15__GPIO_1_15 0x10f3 +#define MX23_PAD_LCD_D16__GPIO_1_16 0x1103 +#define MX23_PAD_LCD_D17__GPIO_1_17 0x1113 +#define MX23_PAD_LCD_RESET__GPIO_1_18 0x1123 +#define MX23_PAD_LCD_RS__GPIO_1_19 0x1133 +#define MX23_PAD_LCD_WR__GPIO_1_20 0x1143 +#define MX23_PAD_LCD_CS__GPIO_1_21 0x1153 +#define MX23_PAD_LCD_DOTCK__GPIO_1_22 0x1163 +#define MX23_PAD_LCD_ENABLE__GPIO_1_23 0x1173 +#define MX23_PAD_LCD_HSYNC__GPIO_1_24 0x1183 +#define MX23_PAD_LCD_VSYNC__GPIO_1_25 0x1193 +#define MX23_PAD_PWM0__GPIO_1_26 0x11a3 +#define MX23_PAD_PWM1__GPIO_1_27 0x11b3 +#define MX23_PAD_PWM2__GPIO_1_28 0x11c3 +#define MX23_PAD_PWM3__GPIO_1_29 0x11d3 +#define MX23_PAD_PWM4__GPIO_1_30 0x11e3 +#define MX23_PAD_SSP1_CMD__GPIO_2_0 0x2003 +#define MX23_PAD_SSP1_DETECT__GPIO_2_1 0x2013 +#define MX23_PAD_SSP1_DATA0__GPIO_2_2 0x2023 +#define MX23_PAD_SSP1_DATA1__GPIO_2_3 0x2033 +#define MX23_PAD_SSP1_DATA2__GPIO_2_4 0x2043 +#define MX23_PAD_SSP1_DATA3__GPIO_2_5 0x2053 +#define MX23_PAD_SSP1_SCK__GPIO_2_6 0x2063 +#define MX23_PAD_ROTARYA__GPIO_2_7 0x2073 +#define MX23_PAD_ROTARYB__GPIO_2_8 0x2083 +#define MX23_PAD_EMI_A00__GPIO_2_9 0x2093 +#define MX23_PAD_EMI_A01__GPIO_2_10 0x20a3 +#define MX23_PAD_EMI_A02__GPIO_2_11 0x20b3 +#define MX23_PAD_EMI_A03__GPIO_2_12 0x20c3 +#define MX23_PAD_EMI_A04__GPIO_2_13 0x20d3 +#define MX23_PAD_EMI_A05__GPIO_2_14 0x20e3 +#define MX23_PAD_EMI_A06__GPIO_2_15 0x20f3 +#define MX23_PAD_EMI_A07__GPIO_2_16 0x2103 +#define MX23_PAD_EMI_A08__GPIO_2_17 0x2113 +#define MX23_PAD_EMI_A09__GPIO_2_18 0x2123 +#define MX23_PAD_EMI_A10__GPIO_2_19 0x2133 +#define MX23_PAD_EMI_A11__GPIO_2_20 0x2143 +#define MX23_PAD_EMI_A12__GPIO_2_21 0x2153 +#define MX23_PAD_EMI_BA0__GPIO_2_22 0x2163 +#define MX23_PAD_EMI_BA1__GPIO_2_23 0x2173 +#define MX23_PAD_EMI_CASN__GPIO_2_24 0x2183 +#define MX23_PAD_EMI_CE0N__GPIO_2_25 0x2193 +#define MX23_PAD_EMI_CE1N__GPIO_2_26 0x21a3 +#define MX23_PAD_GPMI_CE1N__GPIO_2_27 0x21b3 +#define MX23_PAD_GPMI_CE0N__GPIO_2_28 0x21c3 +#define MX23_PAD_EMI_CKE__GPIO_2_29 0x21d3 +#define MX23_PAD_EMI_RASN__GPIO_2_30 0x21e3 +#define MX23_PAD_EMI_WEN__GPIO_2_31 0x21f3 + +#endif /* __DT_BINDINGS_MX23_PINCTRL_H__ */ diff --git a/arch/arm/dts/imx23.dtsi b/arch/arm/dts/imx23.dtsi new file mode 100644 index 000000000000..7f4c602454a5 --- /dev/null +++ b/arch/arm/dts/imx23.dtsi @@ -0,0 +1,636 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright 2012 Freescale Semiconductor, Inc. + +#include "imx23-pinfunc.h" + +/ { + #address-cells = <1>; + #size-cells = <1>; + + interrupt-parent = <&icoll>; + /* + * The decompressor and also some bootloaders rely on a + * pre-existing /chosen node to be available to insert the + * command line and merge other ATAGS info. + */ + chosen {}; + + aliases { + gpio0 = &gpio0; + gpio1 = &gpio1; + gpio2 = &gpio2; + serial0 = &auart0; + serial1 = &auart1; + spi0 = &ssp0; + spi1 = &ssp1; + usbphy0 = &usbphy0; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,arm926ej-s"; + device_type = "cpu"; + reg = <0>; + }; + }; + + apb@80000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x80000000 0x80000>; + ranges; + + apbh@80000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x80000000 0x40000>; + ranges; + + icoll: interrupt-controller@80000000 { + compatible = "fsl,imx23-icoll", "fsl,icoll"; + interrupt-controller; + #interrupt-cells = <1>; + reg = <0x80000000 0x2000>; + }; + + dma_apbh: dma-apbh@80004000 { + compatible = "fsl,imx23-dma-apbh"; + reg = <0x80004000 0x2000>; + interrupts = <0 14 20 0 + 13 13 13 13>; + interrupt-names = "empty", "ssp0", "ssp1", "empty", + "gpmi0", "gpmi1", "gpmi2", "gpmi3"; + #dma-cells = <1>; + dma-channels = <8>; + clocks = <&clks 15>; + }; + + ecc@80008000 { + reg = <0x80008000 0x2000>; + status = "disabled"; + }; + + nand-controller@8000c000 { + compatible = "fsl,imx23-gpmi-nand"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x8000c000 0x2000>, <0x8000a000 0x2000>; + reg-names = "gpmi-nand", "bch"; + interrupts = <56>; + interrupt-names = "bch"; + clocks = <&clks 34>; + clock-names = "gpmi_io"; + dmas = <&dma_apbh 4>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + ssp0: spi@80010000 { + reg = <0x80010000 0x2000>; + interrupts = <15>; + clocks = <&clks 33>; + dmas = <&dma_apbh 1>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + etm@80014000 { + reg = <0x80014000 0x2000>; + status = "disabled"; + }; + + pinctrl@80018000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx23-pinctrl", "simple-bus"; + reg = <0x80018000 0x2000>; + + gpio0: gpio@0 { + compatible = "fsl,imx23-gpio", "fsl,mxs-gpio"; + reg = <0>; + interrupts = <16>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio@1 { + compatible = "fsl,imx23-gpio", "fsl,mxs-gpio"; + reg = <1>; + interrupts = <17>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@2 { + compatible = "fsl,imx23-gpio", "fsl,mxs-gpio"; + reg = <2>; + interrupts = <18>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + duart_pins_a: duart@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_PWM0__DUART_RX + MX23_PAD_PWM1__DUART_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart0_pins_a: auart0@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_AUART1_RX__AUART1_RX + MX23_PAD_AUART1_TX__AUART1_TX + MX23_PAD_AUART1_CTS__AUART1_CTS + MX23_PAD_AUART1_RTS__AUART1_RTS + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart0_2pins_a: auart0-2pins@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_I2C_SCL__AUART1_TX + MX23_PAD_I2C_SDA__AUART1_RX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart1_2pins_a: auart1-2pins@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_GPMI_D14__AUART2_RX + MX23_PAD_GPMI_D15__AUART2_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + gpmi_pins_a: gpmi-nand@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_GPMI_D00__GPMI_D00 + MX23_PAD_GPMI_D01__GPMI_D01 + MX23_PAD_GPMI_D02__GPMI_D02 + MX23_PAD_GPMI_D03__GPMI_D03 + MX23_PAD_GPMI_D04__GPMI_D04 + MX23_PAD_GPMI_D05__GPMI_D05 + MX23_PAD_GPMI_D06__GPMI_D06 + MX23_PAD_GPMI_D07__GPMI_D07 + MX23_PAD_GPMI_CLE__GPMI_CLE + MX23_PAD_GPMI_ALE__GPMI_ALE + MX23_PAD_GPMI_RDY0__GPMI_RDY0 + MX23_PAD_GPMI_RDY1__GPMI_RDY1 + MX23_PAD_GPMI_WPN__GPMI_WPN + MX23_PAD_GPMI_WRN__GPMI_WRN + MX23_PAD_GPMI_RDN__GPMI_RDN + MX23_PAD_GPMI_CE1N__GPMI_CE1N + MX23_PAD_GPMI_CE0N__GPMI_CE0N + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + gpmi_pins_fixup: gpmi-pins-fixup@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_GPMI_WPN__GPMI_WPN + MX23_PAD_GPMI_WRN__GPMI_WRN + MX23_PAD_GPMI_RDN__GPMI_RDN + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + }; + + mmc0_4bit_pins_a: mmc0-4bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_SSP1_DATA0__SSP1_DATA0 + MX23_PAD_SSP1_DATA1__SSP1_DATA1 + MX23_PAD_SSP1_DATA2__SSP1_DATA2 + MX23_PAD_SSP1_DATA3__SSP1_DATA3 + MX23_PAD_SSP1_CMD__SSP1_CMD + MX23_PAD_SSP1_SCK__SSP1_SCK + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mmc0_8bit_pins_a: mmc0-8bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_SSP1_DATA0__SSP1_DATA0 + MX23_PAD_SSP1_DATA1__SSP1_DATA1 + MX23_PAD_SSP1_DATA2__SSP1_DATA2 + MX23_PAD_SSP1_DATA3__SSP1_DATA3 + MX23_PAD_GPMI_D08__SSP1_DATA4 + MX23_PAD_GPMI_D09__SSP1_DATA5 + MX23_PAD_GPMI_D10__SSP1_DATA6 + MX23_PAD_GPMI_D11__SSP1_DATA7 + MX23_PAD_SSP1_CMD__SSP1_CMD + MX23_PAD_SSP1_DETECT__SSP1_DETECT + MX23_PAD_SSP1_SCK__SSP1_SCK + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mmc0_pins_fixup: mmc0-pins-fixup@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_SSP1_DETECT__SSP1_DETECT + MX23_PAD_SSP1_SCK__SSP1_SCK + >; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + mmc0_sck_cfg: mmc0-sck-cfg@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_SSP1_SCK__SSP1_SCK + >; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + mmc1_4bit_pins_a: mmc1-4bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_GPMI_D00__SSP2_DATA0 + MX23_PAD_GPMI_D01__SSP2_DATA1 + MX23_PAD_GPMI_D02__SSP2_DATA2 + MX23_PAD_GPMI_D03__SSP2_DATA3 + MX23_PAD_GPMI_RDY1__SSP2_CMD + MX23_PAD_GPMI_WRN__SSP2_SCK + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mmc1_8bit_pins_a: mmc1-8bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_GPMI_D00__SSP2_DATA0 + MX23_PAD_GPMI_D01__SSP2_DATA1 + MX23_PAD_GPMI_D02__SSP2_DATA2 + MX23_PAD_GPMI_D03__SSP2_DATA3 + MX23_PAD_GPMI_D04__SSP2_DATA4 + MX23_PAD_GPMI_D05__SSP2_DATA5 + MX23_PAD_GPMI_D06__SSP2_DATA6 + MX23_PAD_GPMI_D07__SSP2_DATA7 + MX23_PAD_GPMI_RDY1__SSP2_CMD + MX23_PAD_GPMI_WRN__SSP2_SCK + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + pwm2_pins_a: pwm2@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_PWM2__PWM2 + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + lcdif_24bit_pins_a: lcdif-24bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_LCD_D00__LCD_D00 + MX23_PAD_LCD_D01__LCD_D01 + MX23_PAD_LCD_D02__LCD_D02 + MX23_PAD_LCD_D03__LCD_D03 + MX23_PAD_LCD_D04__LCD_D04 + MX23_PAD_LCD_D05__LCD_D05 + MX23_PAD_LCD_D06__LCD_D06 + MX23_PAD_LCD_D07__LCD_D07 + MX23_PAD_LCD_D08__LCD_D08 + MX23_PAD_LCD_D09__LCD_D09 + MX23_PAD_LCD_D10__LCD_D10 + MX23_PAD_LCD_D11__LCD_D11 + MX23_PAD_LCD_D12__LCD_D12 + MX23_PAD_LCD_D13__LCD_D13 + MX23_PAD_LCD_D14__LCD_D14 + MX23_PAD_LCD_D15__LCD_D15 + MX23_PAD_LCD_D16__LCD_D16 + MX23_PAD_LCD_D17__LCD_D17 + MX23_PAD_GPMI_D08__LCD_D18 + MX23_PAD_GPMI_D09__LCD_D19 + MX23_PAD_GPMI_D10__LCD_D20 + MX23_PAD_GPMI_D11__LCD_D21 + MX23_PAD_GPMI_D12__LCD_D22 + MX23_PAD_GPMI_D13__LCD_D23 + MX23_PAD_LCD_DOTCK__LCD_DOTCK + MX23_PAD_LCD_ENABLE__LCD_ENABLE + MX23_PAD_LCD_HSYNC__LCD_HSYNC + MX23_PAD_LCD_VSYNC__LCD_VSYNC + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + spi2_pins_a: spi2@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_GPMI_WRN__SSP2_SCK + MX23_PAD_GPMI_RDY1__SSP2_CMD + MX23_PAD_GPMI_D00__SSP2_DATA0 + MX23_PAD_GPMI_D03__SSP2_DATA3 + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + i2c_pins_a: i2c@0 { + reg = <0>; + fsl,pinmux-ids = < + MX23_PAD_I2C_SCL__I2C_SCL + MX23_PAD_I2C_SDA__I2C_SDA + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + i2c_pins_b: i2c@1 { + reg = <1>; + fsl,pinmux-ids = < + MX23_PAD_LCD_ENABLE__I2C_SCL + MX23_PAD_LCD_HSYNC__I2C_SDA + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + i2c_pins_c: i2c@2 { + reg = <2>; + fsl,pinmux-ids = < + MX23_PAD_SSP1_DATA1__I2C_SCL + MX23_PAD_SSP1_DATA2__I2C_SDA + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + }; + + digctl@8001c000 { + compatible = "fsl,imx23-digctl"; + reg = <0x8001c000 2000>; + status = "disabled"; + }; + + emi@80020000 { + reg = <0x80020000 0x2000>; + status = "disabled"; + }; + + dma_apbx: dma-apbx@80024000 { + compatible = "fsl,imx23-dma-apbx"; + reg = <0x80024000 0x2000>; + interrupts = <7 5 9 26 + 19 0 25 23 + 60 58 9 0 + 0 0 0 0>; + interrupt-names = "audio-adc", "audio-dac", "spdif-tx", "i2c", + "saif0", "empty", "auart0-rx", "auart0-tx", + "auart1-rx", "auart1-tx", "saif1", "empty", + "empty", "empty", "empty", "empty"; + #dma-cells = <1>; + dma-channels = <16>; + clocks = <&clks 16>; + }; + + dcp: crypto@80028000 { + compatible = "fsl,imx23-dcp"; + reg = <0x80028000 0x2000>; + interrupts = <53 54>; + status = "okay"; + }; + + pxp@8002a000 { + reg = <0x8002a000 0x2000>; + status = "disabled"; + }; + + efuse@8002c000 { + compatible = "fsl,imx23-ocotp", "fsl,ocotp"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x8002c000 0x2000>; + clocks = <&clks 15>; + }; + + axi-ahb@8002e000 { + reg = <0x8002e000 0x2000>; + status = "disabled"; + }; + + lcdif@80030000 { + compatible = "fsl,imx23-lcdif"; + reg = <0x80030000 2000>; + interrupts = <46 45>; + clocks = <&clks 38>; + status = "disabled"; + }; + + ssp1: spi@80034000 { + reg = <0x80034000 0x2000>; + interrupts = <2>; + clocks = <&clks 33>; + dmas = <&dma_apbh 2>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + tvenc@80038000 { + reg = <0x80038000 0x2000>; + status = "disabled"; + }; + }; + + apbx@80040000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x80040000 0x40000>; + ranges; + + clks: clkctrl@80040000 { + compatible = "fsl,imx23-clkctrl", "fsl,clkctrl"; + reg = <0x80040000 0x2000>; + #clock-cells = <1>; + }; + + saif0: saif@80042000 { + reg = <0x80042000 0x2000>; + dmas = <&dma_apbx 4>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + power@80044000 { + reg = <0x80044000 0x2000>; + status = "disabled"; + }; + + saif1: saif@80046000 { + reg = <0x80046000 0x2000>; + dmas = <&dma_apbx 10>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + audio-out@80048000 { + reg = <0x80048000 0x2000>; + dmas = <&dma_apbx 1>; + dma-names = "tx"; + status = "disabled"; + }; + + audio-in@8004c000 { + reg = <0x8004c000 0x2000>; + dmas = <&dma_apbx 0>; + dma-names = "rx"; + status = "disabled"; + }; + + lradc: lradc@80050000 { + compatible = "fsl,imx23-lradc"; + reg = <0x80050000 0x2000>; + interrupts = <36 37 38 39 40 41 42 43 44>; + status = "disabled"; + clocks = <&clks 26>; + #io-channel-cells = <1>; + }; + + spdif@80054000 { + reg = <0x80054000 2000>; + dmas = <&dma_apbx 2>; + dma-names = "tx"; + status = "disabled"; + }; + + i2c: i2c@80058000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx23-i2c"; + reg = <0x80058000 0x2000>; + interrupts = <27>; + clock-frequency = <100000>; + dmas = <&dma_apbx 3>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + rtc@8005c000 { + compatible = "fsl,imx23-rtc", "fsl,stmp3xxx-rtc"; + reg = <0x8005c000 0x2000>; + interrupts = <22>; + }; + + pwm: pwm@80064000 { + compatible = "fsl,imx23-pwm"; + reg = <0x80064000 0x2000>; + clocks = <&clks 30>; + #pwm-cells = <2>; + fsl,pwm-number = <5>; + status = "disabled"; + }; + + timrot@80068000 { + compatible = "fsl,imx23-timrot", "fsl,timrot"; + reg = <0x80068000 0x2000>; + interrupts = <28 29 30 31>; + clocks = <&clks 28>; + }; + + auart0: serial@8006c000 { + compatible = "fsl,imx23-auart"; + reg = <0x8006c000 0x2000>; + interrupts = <24>; + clocks = <&clks 32>; + dmas = <&dma_apbx 6>, <&dma_apbx 7>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + auart1: serial@8006e000 { + compatible = "fsl,imx23-auart"; + reg = <0x8006e000 0x2000>; + interrupts = <59>; + clocks = <&clks 32>; + dmas = <&dma_apbx 8>, <&dma_apbx 9>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + duart: serial@80070000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x80070000 0x2000>; + interrupts = <0>; + clocks = <&clks 32>, <&clks 16>; + clock-names = "uart", "apb_pclk"; + status = "disabled"; + }; + + usbphy0: usbphy@8007c000 { + compatible = "fsl,imx23-usbphy"; + reg = <0x8007c000 0x2000>; + clocks = <&clks 41>; + status = "disabled"; + }; + }; + }; + + ahb@80080000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x80080000 0x80000>; + ranges; + + usb0: usb@80080000 { + compatible = "fsl,imx23-usb", "fsl,imx27-usb"; + reg = <0x80080000 0x40000>; + interrupts = <11>; + fsl,usbphy = <&usbphy0>; + clocks = <&clks 40>; + status = "disabled"; + }; + }; + + iio-hwmon { + compatible = "iio-hwmon"; + io-channels = <&lradc 8>; + }; +};
Make the conversion to driver model as it is mandatory.
Successfully tested booting Linux from the SD card.
Dropped splash screen support as this needs to be properly converted to DM and tested.
arch/arm/dts/Makefile | 3 +++ arch/arm/dts/imx23-evk-u-boot.dtsi | 4 ++++ arch/arm/dts/imx23-u-boot.dtsi | 14 ++++++++++++++ arch/arm/dts/imx23.dtsi | 2 +- board/freescale/mx23evk/mx23evk.c | 23 ----------------------- configs/mx23evk_defconfig | 14 +++++++++++--- 6 files changed, 33 insertions(+), 27 deletions(-) create mode 100644 arch/arm/dts/imx23-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imx23-u-boot.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fefac899fb90..7d742b482098 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -650,6 +650,9 @@ dtb-$(CONFIG_VF610) += vf500-colibri.dtb \ vf610-pcm052.dtb \ vf610-bk4r1.dtb
+dtb-$(CONFIG_MX23) += \ + imx23-evk.dtb + dtb-$(CONFIG_MX28) += \ imx28-evk.dtb \ imx28-xea.dtb diff --git a/arch/arm/dts/imx23-evk-u-boot.dtsi b/arch/arm/dts/imx23-evk-u-boot.dtsi new file mode 100644 index 000000000000..165e220e314f --- /dev/null +++ b/arch/arm/dts/imx23-evk-u-boot.dtsi @@ -0,0 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "imx23-u-boot.dtsi" + diff --git a/arch/arm/dts/imx23-u-boot.dtsi b/arch/arm/dts/imx23-u-boot.dtsi new file mode 100644 index 000000000000..5e87aca61b79 --- /dev/null +++ b/arch/arm/dts/imx23-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ + +&gpio0 { + gpio-ranges = <&pinctrl 0 0 32>; +}; + +&gpio1 { + gpio-ranges = <&pinctrl 0 32 31>; +}; + +&gpio2 { + gpio-ranges = <&pinctrl 0 63 32>; +}; + diff --git a/arch/arm/dts/imx23.dtsi b/arch/arm/dts/imx23.dtsi index 7f4c602454a5..4cfec7784925 100644 --- a/arch/arm/dts/imx23.dtsi +++ b/arch/arm/dts/imx23.dtsi @@ -105,7 +105,7 @@ status = "disabled"; };
- pinctrl@80018000 { + pinctrl: pinctrl@80018000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx23-pinctrl", "simple-bus"; diff --git a/board/freescale/mx23evk/mx23evk.c b/board/freescale/mx23evk/mx23evk.c index 3fbac6b5cc31..fc0f9acd38e8 100644 --- a/board/freescale/mx23evk/mx23evk.c +++ b/board/freescale/mx23evk/mx23evk.c @@ -53,26 +53,3 @@ int board_init(void)
return 0; } - -#ifdef CONFIG_CMD_MMC -static int mx23evk_mmc_wp(int id) -{ - if (id != 0) { - printf("MXS MMC: Invalid card selected (card id = %d)\n", id); - return 1; - } - - return gpio_get_value(MX23_PAD_PWM4__GPIO_1_30); -} - -int board_mmc_init(struct bd_info *bis) -{ - /* Configure WP as input */ - gpio_direction_input(MX23_PAD_PWM4__GPIO_1_30); - - /* Configure MMC0 Power Enable */ - gpio_direction_output(MX23_PAD_PWM3__GPIO_1_29, 0); - - return mxsmmc_initialize(bis, 0, mx23evk_mmc_wp, NULL); -} -#endif diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 0e3d9774c591..99881f358c16 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -7,16 +7,19 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x40000 +CONFIG_DM_GPIO=y CONFIG_SPL_TEXT_BASE=0x00001000 CONFIG_TARGET_MX23EVK=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="imx23-evk" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DM=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -24,17 +27,22 @@ CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y # CONFIG_NET is not set +CONFIG_DM=y CONFIG_MXS_GPIO=y +CONFIG_DM_MMC=y CONFIG_MMC_MXS=y +CONFIG_PINCTRL=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y CONFIG_CONS_INDEX=0 CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_SPLASH_SCREEN=y -CONFIG_VIDEO_BMP_GZIP=y -CONFIG_OF_LIBFDT=y
Make the conversion to driver model as it is mandatory. Successfully tested booting Linux from the SD card. Dropped splash screen support as this needs to be properly converted to DM and tested. Signed-off-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
I would like to help supporting this board, so add myself as a maintainer.
Now that the board has been converted to DM, also add its devicetree in the MAINTAINERS files entry.
Signed-off-by: Fabio Estevam festevam@gmail.com --- Changes since v1: - None
board/freescale/mx23evk/MAINTAINERS | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/mx23evk/MAINTAINERS b/board/freescale/mx23evk/MAINTAINERS index b03ad6ae0af6..122b70cd7196 100644 --- a/board/freescale/mx23evk/MAINTAINERS +++ b/board/freescale/mx23evk/MAINTAINERS @@ -1,6 +1,8 @@ MX23EVK BOARD +M: Fabio Estevam festevam@gmail.com M: Otavio Salvador otavio@ossystems.com.br S: Maintained F: board/freescale/mx23evk/ +F: arch/arm/dts/imx23-evk.dts F: include/configs/mx23evk.h F: configs/mx23evk_defconfig
I would like to help supporting this board, so add myself as a maintainer. Now that the board has been converted to DM, also add its devicetree in the MAINTAINERS files entry. Signed-off-by: Fabio Estevam festevam@gmail.com
Import the imx23-evk devicetree files from Linux kernel version 5.11. This is in preparation for converting the mx23evk_defconfig target to driver model. Signed-off-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
sbabic@denx.de
