[U-Boot] [PATCH] OMAP3: igep00x0: Enable required clocks for GPIO that are used.
Enable required clocks for GPIO to fix a boot issue introduced by commit f33b9bd3984fb11e1d8566a866adc5957b1e1c9d (arm: omap3: Enable clocks for peripherals only if they are used).
Without this patch the u-boot freezes after the following messages
OMAP36XX/37XX-GP ES1.2, CPU-OPP2, L3-200MHz, Max CPU Clock 1 Ghz IGEPv2 + LPDDR/NAND I2C: ready DRAM: 512 MiB NAND: 512 MiB MMC: OMAP SD/MMC: 0
Diving into the issue, the sequence that produces the u-boot freezes is
setup_net_chip |--> gpio_direction_out |--> _set_gpio_dataout |--> __raw_writel
To avoid this we just need enable the clocks for GPIOs that are used, but it would be interesting implement a mechanism to protect these situations and make sure that the clock is enabled when we request a GPIO.
Signed-off-by: Enric Balletbo i Serra eballetbo@gmail.com --- include/configs/omap3_igep00x0.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 20fbbec..8cc23c1 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -37,6 +37,11 @@ #define CONFIG_SHOW_BOOT_PROGRESS #endif
+/* GPIO banks */ +#define CONFIG_OMAP3_GPIO_3 /* GPIO64 .. 95 is in GPIO bank 3 */ +#define CONFIG_OMAP3_GPIO_5 /* GPIO128..159 is in GPIO bank 5 */ +#define CONFIG_OMAP3_GPIO_6 /* GPIO160..191 is in GPIO bank 6 */ + /* USB */ #define CONFIG_MUSB_UDC 1 #define CONFIG_USB_OMAP3 1
Hi Tom,
2014-01-25 22:52 GMT+01:00 Enric Balletbo i Serra eballetbo@gmail.com:
1.8.3.2
Any plan or inconvenient to include this ? It's important as current support for IGEP boards is broken ...
Thanks, Enric
On Sat, Jan 25, 2014 at 4:52 PM, Enric Balletbo i Serra eballetbo@gmail.com wrote:
Applied to u-boot-ti/master, thanks!
Enric Balletbo Serra
