[PATCH 1/5] mips: octeon: Correct types in cvmx-pko3-queue
When building with gcc-13.1 we see that the prototype for cvmx_pko3_sq_config_children does not match the declaration. Make these match and correct a typo in the function's version of the docs that the prototype did not have, as part of keeping those in-sync.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Aaron Williams awilliams@marvell.com Cc: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-pko3-queue.c | 2 +- .../mips/mach-octeon/include/mach/cvmx-pko3-queue.h | 13 ++++++++----- 2 files changed, 9 insertions(+), 6 deletions(-)
diff --git a/arch/mips/mach-octeon/cvmx-pko3-queue.c b/arch/mips/mach-octeon/cvmx-pko3-queue.c index e28afdf8dd9d..53f2e4dd1861 100644 --- a/arch/mips/mach-octeon/cvmx-pko3-queue.c +++ b/arch/mips/mach-octeon/cvmx-pko3-queue.c @@ -761,7 +761,7 @@ int cvmx_pko3_pq_config(unsigned int node, unsigned int mac_num, * The Scheduler Queues in Levels 3 to 5 and Descriptor Queues are * configured one-to-one or many-to-one to a single parent Scheduler * Queues. The level of the parent SQ is specified in an argument, - * as well as the number of childer to attach to the specific parent. + * as well as the number of children to attach to the specific parent. * The children can have fair round-robin or priority-based scheduling * when multiple children are assigned a single parent. * diff --git a/arch/mips/mach-octeon/include/mach/cvmx-pko3-queue.h b/arch/mips/mach-octeon/include/mach/cvmx-pko3-queue.h index b3f61d75f225..3931191fe20f 100644 --- a/arch/mips/mach-octeon/include/mach/cvmx-pko3-queue.h +++ b/arch/mips/mach-octeon/include/mach/cvmx-pko3-queue.h @@ -6,6 +6,8 @@ #ifndef __CVMX_PKO3_QUEUE_H__ #define __CVMX_PKO3_QUEUE_H__
+enum cvmx_pko3_level_e; + /** * @INTERNAL * @@ -46,11 +48,10 @@ int cvmx_pko3_get_port_queue(int xiface, int index); * The children can have fair round-robin or priority-based scheduling * when multiple children are assigned a single parent. * - * @param node is the OCI node location for the queues to be configured - * @param parent_level is the level of the parent queue, 2 to 5. + * @param node on which to operate + * @param child_level is the level of the child queue * @param parent_queue is the number of the parent Scheduler Queue * @param child_base is the number of the first child SQ or DQ to assign to - * @param parent * @param child_count is the number of consecutive children to assign * @param stat_prio_count is the priority setting for the children L2 SQs * @@ -65,8 +66,10 @@ int cvmx_pko3_get_port_queue(int xiface, int index); * * Note: this function supports the configuration of node-local unit. */ -int cvmx_pko3_sq_config_children(unsigned int node, unsigned int parent_level, - unsigned int parent_queue, unsigned int child_base, +int cvmx_pko3_sq_config_children(unsigned int node, + enum cvmx_pko3_level_e child_level, + unsigned int parent_queue, + unsigned int child_base, unsigned int child_count, int stat_prio_count);
With gcc-13.1 we get a warning about enum vs int here, so correct the declaration to match the implementation.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-mx5/clock.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-mx5/clock.h b/arch/arm/include/asm/arch-mx5/clock.h index 63a51042e1eb..d585b5cf4b22 100644 --- a/arch/arm/include/asm/arch-mx5/clock.h +++ b/arch/arm/include/asm/arch-mx5/clock.h @@ -42,7 +42,7 @@ enum mxc_clock { u32 imx_get_uartclk(void); u32 imx_get_fecclk(void); unsigned int mxc_get_clock(enum mxc_clock clk); -int mxc_set_clock(u32 ref, u32 freq, u32 clk_type); +int mxc_set_clock(u32 ref, u32 freq, enum mxc_clock clk); void set_usb_phy_clk(void); void enable_usb_phy1_clk(bool enable); void enable_usb_phy2_clk(bool enable);
Signed-off-by: Tom Rini trini@konsulko.com --- include/spl.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/spl.h b/include/spl.h index 658d36481dee..92bcaa90a4af 100644 --- a/include/spl.h +++ b/include/spl.h @@ -31,6 +31,7 @@ struct legacy_img_hdr; struct blk_desc; struct legacy_img_hdr; struct spl_boot_device; +enum boot_device;
/* * u_boot_first_phase() - check if this is the first U-Boot phase @@ -525,7 +526,7 @@ void spl_board_prepare_for_linux(void); void spl_board_prepare_for_optee(void *fdt); void spl_board_prepare_for_boot(void); int spl_board_ubi_load_image(u32 boot_device); -int spl_board_boot_device(u32 boot_device); +int spl_board_boot_device(enum boot_device boot_dev_spl);
/** * spl_board_loader_name() - Return a name for the loader
Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org
As this is the current version of the public cross toolchains we use, upgrade to this now.
Suggested-by: Alexey Brodkin Alexey.Brodkin@synopsys.com Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Heinrich Schuchardt xypron.glpk@gmx.de
Heinrich, at this point is there a newer grub we should be testing? There's now 2 changes for RISC-V that we're cherry-picking for newer toolchains. --- .azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- tools/buildman/toolchain.py | 2 +- tools/docker/Dockerfile | 57 +++++++++++++++++++------------------ 4 files changed, 32 insertions(+), 31 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 76982ec3e52e..83cc6176e7b4 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -194,7 +194,7 @@ stages: ln -s /opt/nokia/libc6_2.5.1-1eglibc27+0m5_armel.deb nokia_rx51_tmp/ ln -s /opt/nokia/busybox_1.10.2.legal-1osso30+0m5_armel.deb nokia_rx51_tmp/ ln -s /opt/nokia/qemu-system-arm nokia_rx51_tmp/ - export PATH=/opt/gcc-12.2.0-nolibc/arm-linux-gnueabi/bin:$PATH + export PATH=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin:$PATH test/nokia_rx51_test.sh
- job: pylint diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index f7ffb8f5dfdc..5300813cf511 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -232,7 +232,7 @@ Run tests for Nokia RX-51 (aka N900): ln -s /opt/nokia/libc6_2.5.1-1eglibc27+0m5_armel.deb nokia_rx51_tmp/; ln -s /opt/nokia/busybox_1.10.2.legal-1osso30+0m5_armel.deb nokia_rx51_tmp/; ln -s /opt/nokia/qemu-system-arm nokia_rx51_tmp/; - export PATH=/opt/gcc-12.2.0-nolibc/arm-linux-gnueabi/bin:$PATH; + export PATH=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin:$PATH; test/nokia_rx51_test.sh
# Check for any pylint regressions diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 0ecd8458b912..1001b612086f 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -499,7 +499,7 @@ class Toolchains: if arch == 'aarch64': arch = 'arm64' base = 'https://www.kernel.org/pub/tools/crosstool/files/bin' - versions = ['12.2.0', '11.1.0'] + versions = ['13.1.0', '12.2.0'] links = [] for version in versions: url = '%s/%s/%s/' % (base, arch, version) diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index f72cba0b8cc4..2f2ace2e6554 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -14,18 +14,18 @@ RUN apt-get update && apt-get install -y gnupg2 wget xz-utils && rm -rf /var/lib RUN wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | apt-key add - RUN echo deb http://apt.llvm.org/jammy/ llvm-toolchain-jammy-16 main | tee /etc/apt/sources.list.d/llvm.list
-# Manually install the kernel.org "Crosstool" based toolchains for gcc-12.2.0 -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ +# Manually install the kernel.org "Crosstool" based toolchains for gcc-13.1.0 +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ
# Manually install other toolchains RUN wget -O - https://github.com/foss-xtensa/toolchain/releases/download/2020.07/x86_64-20... | tar -C /opt -xz @@ -129,15 +129,16 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ git config --global user.name "GitLab CI Runner" && \ git config --global user.email trini@konsulko.com && \ git cherry-pick 049efdd72eb7baa7b2bf8884391ee7fe650da5a0 && \ + git cherry-pick 403d6540cd608b2706cfa0cb4713f7e4b490ff45 && \ ./bootstrap && \ mkdir -p /opt/grub && \ ./configure --target=aarch64 --with-platform=efi \ CC=gcc \ - TARGET_CC=/opt/gcc-12.2.0-nolibc/aarch64-linux/bin/aarch64-linux-gcc \ - TARGET_OBJCOPY=/opt/gcc-12.2.0-nolibc/aarch64-linux/bin/aarch64-linux-objcopy \ - TARGET_STRIP=/opt/gcc-12.2.0-nolibc/aarch64-linux/bin/aarch64-linux-strip \ - TARGET_NM=/opt/gcc-12.2.0-nolibc/aarch64-linux/bin/aarch64-linux-nm \ - TARGET_RANLIB=/opt/gcc-12.2.0-nolibc/aarch64-linux/bin/aarch64-linux-ranlib && \ + TARGET_CC=/opt/gcc-13.1.0-nolibc/aarch64-linux/bin/aarch64-linux-gcc \ + TARGET_OBJCOPY=/opt/gcc-13.1.0-nolibc/aarch64-linux/bin/aarch64-linux-objcopy \ + TARGET_STRIP=/opt/gcc-13.1.0-nolibc/aarch64-linux/bin/aarch64-linux-strip \ + TARGET_NM=/opt/gcc-13.1.0-nolibc/aarch64-linux/bin/aarch64-linux-nm \ + TARGET_RANLIB=/opt/gcc-13.1.0-nolibc/aarch64-linux/bin/aarch64-linux-ranlib && \ make && \ ./grub-mkimage -O arm64-efi -o /opt/grub/grubaa64.efi --prefix= -d \ grub-core cat chain configfile echo efinet ext2 fat halt help linux \ @@ -147,11 +148,11 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ make clean && \ ./configure --target=arm --with-platform=efi \ CC=gcc \ - TARGET_CC=/opt/gcc-12.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-gcc \ - TARGET_OBJCOPY=/opt/gcc-12.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-objcopy \ - TARGET_STRIP=/opt/gcc-12.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-strip \ - TARGET_NM=/opt/gcc-12.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-nm \ - TARGET_RANLIB=/opt/gcc-12.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ranlib && \ + TARGET_CC=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-gcc \ + TARGET_OBJCOPY=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-objcopy \ + TARGET_STRIP=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-strip \ + TARGET_NM=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-nm \ + TARGET_RANLIB=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ranlib && \ make && \ ./grub-mkimage -O arm-efi -o /opt/grub/grubarm.efi --prefix= -d \ grub-core cat chain configfile echo efinet ext2 fat halt help linux \ @@ -161,11 +162,11 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ make clean && \ ./configure --target=riscv64 --with-platform=efi \ CC=gcc \ - TARGET_CC=/opt/gcc-12.2.0-nolibc/riscv64-linux/bin/riscv64-linux-gcc \ - TARGET_OBJCOPY=/opt/gcc-12.2.0-nolibc/riscv64-linux/bin/riscv64-linux-objcopy \ - TARGET_STRIP=/opt/gcc-12.2.0-nolibc/riscv64-linux/bin/riscv64-linux-strip \ - TARGET_NM=/opt/gcc-12.2.0-nolibc/riscv64-linux/bin/riscv64-linux-nm \ - TARGET_RANLIB=/opt/gcc-12.2.0-nolibc/riscv64-linux/bin/riscv64-linux-ranlib && \ + TARGET_CC=/opt/gcc-13.1.0-nolibc/riscv64-linux/bin/riscv64-linux-gcc \ + TARGET_OBJCOPY=/opt/gcc-13.1.0-nolibc/riscv64-linux/bin/riscv64-linux-objcopy \ + TARGET_STRIP=/opt/gcc-13.1.0-nolibc/riscv64-linux/bin/riscv64-linux-strip \ + TARGET_NM=/opt/gcc-13.1.0-nolibc/riscv64-linux/bin/riscv64-linux-nm \ + TARGET_RANLIB=/opt/gcc-13.1.0-nolibc/riscv64-linux/bin/riscv64-linux-ranlib && \ make && \ ./grub-mkimage -O riscv64-efi -o /opt/grub/grubriscv64.efi --prefix= -d \ grub-core cat chain configfile echo efinet ext2 fat halt help linux \ @@ -276,7 +277,7 @@ RUN virtualenv -p /usr/bin/python3 /tmp/venv && \
# Create the buildman config file RUN /bin/echo -e "[toolchain]\nroot = /usr" > ~/.buildman -RUN /bin/echo -e "kernelorg = /opt/gcc-12.2.0-nolibc/*" >> ~/.buildman +RUN /bin/echo -e "kernelorg = /opt/gcc-13.1.0-nolibc/*" >> ~/.buildman RUN /bin/echo -e "arc = /opt/arc_gnu_2021.03_prebuilt_uclibc_le_archs_linux_install" >> ~/.buildman RUN /bin/echo -e "\n[toolchain-prefix]\nxtensa = /opt/2020.07/xtensa-dc233c-elf/bin/xtensa-dc233c-elf-" >> ~/.buildman; RUN /bin/echo -e "\n[toolchain-alias]\nsh = sh2" >> ~/.buildman
Hi Tom,
That's what I noticed as well - grub fails to build for RISCV with the following message, I guess you saw that as well: ----------------------->8---------------------- ./grub-mkimage: error: relocation 0x13 is not implemented yet. ----------------------->8----------------------
- job: pylint
Maybe squash my ARC GNU toolchain removal from https://lists.denx.de/pipermail/u-boot/2023-July/521983.html here with use of GCC 13.1.0? I may do it as a follow-up patch as well if it loos more appropriate.
Otherwise, thanks for working on that change and...
Acked-by: Alexey Brodkin abrodkin@synopsys.com
-Alexey
On Fri, Jul 14, 2023 at 01:52:09PM +0000, Alexey Brodkin wrote:
Hi Tom,
Yup, but since it's been solved upstream it's an easy fix, if 2.06 is the right one to keep for now.
- job: pylint
I figured I'd just do the slight rebase of your patch when merging all of these.
Suggested-by: Alexey Brodkin Alexey.Brodkin@synopsys.com Signed-off-by: Tom Rini trini@konsulko.com Acked-by: Alexey Brodkin abrodkin@synopsys.com Reviewed-by: Simon Glass sjg@chromium.org
Move to the latest "Jammy" tag from Ubuntu.
Signed-off-by: Tom Rini trini@konsulko.com --- .azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- tools/docker/Dockerfile | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 83cc6176e7b4..929c8797d5eb 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -2,7 +2,7 @@ variables: windows_vm: windows-2019 ubuntu_vm: ubuntu-22.04 macos_vm: macOS-12 - ci_runner_image: trini/u-boot-gitlab-ci-runner:jammy-20230308-04Apr2023 + ci_runner_image: trini/u-boot-gitlab-ci-runner:jammy-20230624-13Jul2023 # Add '-u 0' options for Azure pipelines, otherwise we get "permission # denied" error when it tries to "useradd -m -u 1001 vsts_azpcontainer", # since our $(ci_runner_image) user is not root. diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 5300813cf511..3017df51ff75 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -10,7 +10,7 @@ default:
# Grab our configured image. The source for this is found # in the u-boot tree at tools/docker/Dockerfile -image: ${MIRROR_DOCKER}/trini/u-boot-gitlab-ci-runner:jammy-20230308-04Apr2023 +image: ${MIRROR_DOCKER}/trini/u-boot-gitlab-ci-runner:jammy-20230624-13Jul2023
# We run some tests in different order, to catch some failures quicker. stages: diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 2f2ace2e6554..7792fb0f3a38 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -2,7 +2,7 @@ # This Dockerfile is used to build an image containing basic stuff to be used # to build U-Boot and run our test suites.
-FROM ubuntu:jammy-20230308 +FROM ubuntu:jammy-20230624 MAINTAINER Tom Rini trini@konsulko.com LABEL Description=" This image is for building U-Boot inside a container"
Alexey Brodkin
