Pull request for u-boot-nand-20230422
Hi Tom,
The following changes since commit 5db4972a5bbdbf9e3af48ffc9bc4fec73b7b6a79:
Merge tag 'u-boot-nand-20230417' of https://source.denx.de/u-boot/custodians/u-boot-nand-flash (2023-04-17 10:47:33 -0400)
https://source.denx.de/u-boot/custodians/u-boot-nand-flash.git tags/u-boot-nand-20230422
for you to fetch changes up to 770e77051ec50b46c2aed4c4a355bd79054cf274:
mtd: rawnand: nand_base: Handle algorithm selection (2023-04-22 23:07:57 +0200)
Gitlab CI showed no issues: https://source.denx.de/u-boot/custodians/u-boot-nand-flash/-/pipelines/16082
---------------------------------------------------------------- Pull request for u-boot-nand-20230422
Replaces a patch by Linus Walleij merged with pull request u-boot-nand-20230417, with a newer version that contains fixes for tests run by Tom Rini.
---------------------------------------------------------------- Dario Binacchi (1): Revert "mtd: rawnand: nand_base: Handle algorithm selection"
Linus Walleij (1): mtd: rawnand: nand_base: Handle algorithm selection
drivers/mtd/nand/raw/nand_base.c | 29 ++++++++++++++++++++++------- 1 file changed, 22 insertions(+), 7 deletions(-)
On Sun, Apr 23, 2023 at 12:03:28AM +0200, Dario Binacchi wrote:
Hi Tom,
Dario Binacchi
