[PULL, v2] u-boot-riscv/master
Hi Tom,
The following changes since commit 7755b2200777f72dca87dd169138e95f011bbcb9:
Merge tag 'x86-pull-20230801' of https://source.denx.de/u-boot/custodians/u-boot-x86 (2023-08-01 11:57:55 -0400)
https://source.denx.de/u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to 02be57caf730e2213bc844bf1dbe58bedd2c3734:
riscv: qemu: Enable usb keyboard as an input device (2023-08-02 16:32:44 +0800)
CI result shows no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/17179
+ Fix compilation error for CI when enabling RTL8169 driver + Fix compilation error for pci_mmc.c by adding acpi_table header file + Support video console and usb keyboard on RISC-V QEMU virt machine + Support StarFive JH7110 PCIe driver + Enable PCI on Unmatched board
---------------------------------------------------------------- Bin Meng (8): riscv: qemu: Enable Bochs video support console: kconfig: Drop the redundant VIDEO dependency console: Make stdio_print_current_devices() static console: Refactor stdio_print_current_devices() a little bit console: Print out complete stdio device list riscv: qemu: Enable PRE_CONSOLE_BUFFER riscv: qemu: Remove out-of-date "riscv, kernel-start" handling riscv: qemu: Enable usb keyboard as an input device
Heinrich Schuchardt (2): riscv: sifive: initialize PCI on Unmatched acpi: Add missing RISC-V acpi_table header
Mason Huo (3): starfive: pci: Add StarFive JH7110 pcie driver configs: starfive-jh7110: Add support for PCIe host driver riscv: dts: starfive: Enable PCIe host controller
Minda Chen (5): i2c: designware: Add Kconfig for designware_i2c_pci.c net: rtl8169: Fix compile warning in rtl8169 net: rtl8169: Fix DMA minimal aligned compile warning in RISC-V net: rtl8169: Add one device ID 0x8161 configs: starfive-jh7110: Add CONFIG_RTL8169
arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi | 11 + arch/riscv/dts/jh7110.dtsi | 74 ++++++ arch/riscv/include/asm/acpi_table.h | 11 + board/emulation/qemu-riscv/Kconfig | 13 + board/emulation/qemu-riscv/qemu-riscv.c | 27 +- common/Kconfig | 2 +- common/console.c | 44 ++-- configs/sifive_unmatched_defconfig | 1 + configs/starfive_visionfive2_defconfig | 8 + doc/board/emulation/qemu-riscv.rst | 10 + drivers/i2c/Kconfig | 9 + drivers/i2c/Makefile | 4 +- drivers/net/rtl8169.c | 22 +- drivers/pci/Kconfig | 13 + drivers/pci/Makefile | 2 + drivers/pci/pcie_plda_common.c | 116 +++++++++ drivers/pci/pcie_plda_common.h | 118 +++++++++ drivers/pci/pcie_starfive_jh7110.c | 317 +++++++++++++++++++++++ include/configs/qemu-riscv.h | 15 +- include/stdio_dev.h | 2 - 20 files changed, 755 insertions(+), 64 deletions(-) create mode 100644 arch/riscv/include/asm/acpi_table.h create mode 100644 drivers/pci/pcie_plda_common.c create mode 100644 drivers/pci/pcie_plda_common.h create mode 100644 drivers/pci/pcie_starfive_jh7110.c
Best regards, Leo
On Wed, Aug 02, 2023 at 10:40:05AM +0000, Leo Liang wrote:
Hi Tom,
Leo Liang
