How to load raw disk image in u-boot?
Hello,
I am working on the secure boot for raspberry pi topic as described here https://github.com/raspberrypi/usbboot/tree/master?tab=readme-ov-file#secure... The boot.img file contains u-boot.bin, config.txt, boot.scr, Image, DTB and other raspberry pi necessary files. But when I try to integrate this with u-boot, the boot.img is not being parsed and I see below errors
libfdt fdt_check_header(): FDT_ERR_BADMAGIC No EFI system partition BootOrder not defined EFI boot manager: Cannot load any image
I tried to manually load it using: fatload mmc 0:1 ${kernel_addr_r} boot.img
this works but, booty is not able to run it booti ${kernel_addr_r} - ${fdt_addr}
Bad Linux ARM64 Image magic!
I believe first we need to uncompress the raw disk image and then load it. However with unzip it is not possible to do it. unzip ${kernel_addr_r} 0x83000000 Error: Bad gzipped data
So, how can we load the raw disk image in U-boot?
Sourabh Hegde
