[RFC PATCH 0/3] Minimal platform configuration
When someone attempts to bring up a custom board using TI SoCs (am62x in this case), it often takes several days for someone to reduce the current configuration from the TI EVM/SK boards to a configuration that works for their board.
The goal of these changes is to allow for a minimal boot configuration to exist within UBoot that someone can access directly in order to test their boards for a sign of life before beginning development. This is all done with the hope to increase ease of use and reduce the upbringing process from several days to a few hours.
With the use of fragments, the base defconfigs reside in configs/ and the config fragments reside in board/../
There is still quite a lot of board specific code inside board_init_f() that will need attention later, however this series begins the process of splitting the am62x's configs into a separate generic defconfig everyone can use for new board wakeups with individual board/ti/*.config fragments for each board varient.
Jason Kacines (3): scripts: kconfig: Add config fragment support in board/../ configs: Add am62x wakeup defconfigs board: ti: am62x: Add am62x_evm defconfig fragments
board/ti/am62x/am62x_evm_a53.config | 38 +++++++++++++ board/ti/am62x/am62x_evm_r5.config | 51 ++++++++++++++++++ ..._evm_a53_defconfig => am62x_a53_defconfig} | 34 ++---------- ...2x_evm_r5_defconfig => am62x_r5_defconfig} | 53 ++++--------------- scripts/kconfig/Makefile | 4 +- 5 files changed, 106 insertions(+), 74 deletions(-) create mode 100644 board/ti/am62x/am62x_evm_a53.config create mode 100644 board/ti/am62x/am62x_evm_r5.config rename configs/{am62x_evm_a53_defconfig => am62x_a53_defconfig} (72%) rename configs/{am62x_evm_r5_defconfig => am62x_r5_defconfig} (66%)
Add support to config fragments (.config) located in the /board directory. This will allow only base defconfigs to live in /configs and all fragments to live in their respective device directory in /board/..
Signed-off-by: Jason Kacines j-kacines@ti.com --- scripts/kconfig/Makefile | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/scripts/kconfig/Makefile b/scripts/kconfig/Makefile index 12e525ee31..2d97aab8d2 100644 --- a/scripts/kconfig/Makefile +++ b/scripts/kconfig/Makefile @@ -99,7 +99,9 @@ endif %_config: %_defconfig @:
-configfiles=$(wildcard $(srctree)/kernel/configs/$@ $(srctree)/arch/$(SRCARCH)/configs/$@) +configfiles=$(wildcard $(srctree)/kernel/configs/$@ \ + $(srctree)/arch/$(SRCARCH)/configs/$@ \ + $(shell find $(srctree)/board -name "$@"))
%.config: $(obj)/conf $(if $(call configfiles),, $(error No configuration exists for this target on this architecture))
Hi Jason,
Does this mean defconfigs?
Why do we want this? The patch should have a motivation.
%.config: $(obj)/conf $(if $(call configfiles),, $(error No configuration exists for this target on this architecture)) -- 2.34.1
Regards, SImon
On Wed, Jul 12, 2023 at 08:00:28AM -0600, Simon Glass wrote:
Hi Jason,
This looks like it would cover defconfig files too, but the initial motivation is config fragments. See https://patchwork.ozlabs.org/project/uboot/patch/20230606071850.270001-5-cla... for another example.
I've asked a few people to look in to this because we have a lot of cases today of N _defconfig files where we could really instead have 1 _defconfig file and N config fragment files. But I do not want them living in the top level configs directory as that will get even more unmanageable.
What's not in this patch (and not an ask at this point) is figuring out how buildman could handle "foo_defconfig bar.config" as the required config target.
Hi Tom,
Hi Jason,
OK I see, thank you. The patch still needs this motivation though.
Indeed. Also, should they appear in the boards.cfg list?
On Sat, Jul 15, 2023 at 05:40:35PM -0600, Simon Glass wrote:
Hi Tom,
Hi Jason,
So you're saying you want the message re-worded?
I doubt it? I'm not sure yet how we address getting buildman to know about valid additional combinations. Take the example of something like: som_vendor_carrier_defconfig + som_vendor_imx7_som.config + emmc_boot_instead.config + customer_production_tweaks.config
How would you want buildman to know about that? Does it even really need to, on the other hand? And that's not I think an uncommon example, it's just splitting colibri_imx7_emmc_defconfig in to how it would be used by someone taking that carrier+som to production, with their own touchscreen and a few other tweaks in the dtb that needs to be passed to linux. Or the mnt reform with whatever SOM/COM you happen to have for it.
Hi Tom,
Hi Jason,
Yes, to explain why.
Could we also get some docs in doc/build/gcc.rst or similar?
Well firstly we should only worry about things that are in-tree.
The thing is, if we don't validate that the configs at least build, then someone could change a config (anywhere in Kconfig or in a 'base' defconfig) and break the build for these 'add-on' configs. Also if there is no record of what fragments can be built with what, it could get awfully confusing.
I would suggest an interface where you can query which fragments are available for a board, and that buildman support building them. For that to work, we need some sort of structure. For example the config fragment could have a line listing the defconfig / .config filename it is intended to augment.
Hi Tom,
Hi Jason,
I think the message is fine as it clearly says what it does.
No, I don't think that makes sense yet. And looking at that doc, we should split that up in to compiler specifics and then a general build doc. Using fragments belongs in the board docs which use fragments (as is done in the series which have boards using fragments) and as a general "do this to make developing your board easier" that should come later once there's more agreement and understanding of what we can and should do with fragments, rather than meta-options in Kconfig.
Well, since I'm not letting people bring in fragments until it won't make the configs directory even more unmanageable, we have a problem. The problem which this patch solves. And the example I gave above is in-tree, except for the final step of "now make this my product", which when it's a matter of a new device tree and config, is fine for most cases.
I'm not worried about this at the start. If people start trying to enable unique drivers only in fragments, we have a problem. But based on all of the proposed uses so far, we shouldn't see unique settings there that we need to have compile tested all the time.
Exactly why I want these fragments to be able to live in the board directory rather than the top level configs directory. Honestly, this also opens up the possibility of moving the defconfig files from configs/ to the board directory and I think that would be really good.
I'm not sure how buildman will handle fragments, if at all, but that's a secondary consideration. Buildman isn't used by most people and in most cases, "make" is, and that supports (and has supported for I don't know how many years, off-hand) config fragments.
Hi Tom,
Hi Tom,
Hi Jason,
On Tue, 11 Jul 2023 at 16:29, Jason Kacines j-kacines@ti.com wrote: > > Add support to config fragments (.config) located in the /board > directory. This will allow only base defconfigs to live in /configs and
Indeed.
+Heinrich Schuchardt perhaps?
Yes it is that understanding that I am missing.
My objection is really that this changes / adds behaviour for which there is no mention in the docs. I didn't even know about this stuff.
OK
Yes it would be easier, since we can presumably still enumerate them using MAINTAINERS
OK, well if it becomes a problem we can worry about it then.
To help guide developers down the right path, begin a document that lists some best practices to follow when creating a new board port.
Signed-off-by: Tom Rini trini@konsulko.com --- doc/develop/board_best_practices.rst | 26 ++++++++++++++++++++++++++ doc/develop/index.rst | 1 + 2 files changed, 27 insertions(+) create mode 100644 doc/develop/board_best_practices.rst
diff --git a/doc/develop/board_best_practices.rst b/doc/develop/board_best_practices.rst new file mode 100644 index 000000000000..835ea86dedb2 --- /dev/null +++ b/doc/develop/board_best_practices.rst @@ -0,0 +1,26 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +Best Practices for Board Ports +============================== + +In addition to the regular best practices such as using :doc:`checkpatch` and +following :doc:`docstyle` and :doc:`codingstyle` there are some things which +are specific to creating a new board port. + +* Implement :doc:`bootstd` to ensure that the most number of operating systems + will be available for the platform. + +* The platform defconfig file must be generated via `make savedefconfig`. + +* The Kconfig and Kbuild infrastructure supports using "fragments" tha can be + used to make changes on top of a defconfig file. These can be useful for + many things such as: + + * Supporting different firmware locations (e.g. eMMC, SD, QSPI). + + * Multiple board variants when runtime detection is not desired. + + * Supporting different build types such as production and development. + + And when used should reside in the board directory itself rather than the + top-level `configs/` directory. diff --git a/doc/develop/index.rst b/doc/develop/index.rst index 263d404b4ca8..5b230d0321f2 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -9,6 +9,7 @@ General .. toctree:: :maxdepth: 1
+ board_best_practices codingstyle designprinciples docstyle
This looks helpful. Just a few suggestions:
"to ensure that most operating systems will be supported by the platform."
- will be available for the platform.
%s/tha/that/
- used to make changes on top of a defconfig file. These can be useful for
Maybe: %s/to make/to apply/
- many things such as:
- Supporting different firmware locations (e.g. eMMC, SD, QSPI).
- Multiple board variants when runtime detection is not desired.
- Supporting different build types such as production and development.
- And when used should reside in the board directory itself rather than the
%s/And when used should/Kconfig fragments should/
%s/rather than the/rather than in the/
Best regards
Heinrich
- top-level `configs/` directory.
- board_best_practices codingstyle designprinciples docstyle
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Heinrich Schuchardt heinrich.schuchardt@canonical.com Changes in v2: - Apply feedback from Heinrich --- doc/develop/board_best_practices.rst | 26 ++++++++++++++++++++++++++ doc/develop/index.rst | 1 + 2 files changed, 27 insertions(+) create mode 100644 doc/develop/board_best_practices.rst
diff --git a/doc/develop/board_best_practices.rst b/doc/develop/board_best_practices.rst new file mode 100644 index 000000000000..b012ac59e232 --- /dev/null +++ b/doc/develop/board_best_practices.rst @@ -0,0 +1,26 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +Best Practices for Board Ports +============================== + +In addition to the regular best practices such as using :doc:`checkpatch` and +following :doc:`docstyle` and :doc:`codingstyle` there are some things which +are specific to creating a new board port. + +* Implement :doc:`bootstd` to ensure that most operating systems will be + supported by the platform. + +* The platform defconfig file must be generated via `make savedefconfig`. + +* The Kconfig and Kbuild infrastructure supports using "fragments" that can be + used to apply changes on top of a defconfig file. These can be useful for + many things such as: + + * Supporting different firmware locations (e.g. eMMC, SD, QSPI). + + * Multiple board variants when runtime detection is not desired. + + * Supporting different build types such as production and development. + + Kconfig fragments should reside in the board directory itself rather than in + the top-level `configs/` directory. diff --git a/doc/develop/index.rst b/doc/develop/index.rst index 263d404b4ca8..5b230d0321f2 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -9,6 +9,7 @@ General .. toctree:: :maxdepth: 1
Introduce a minimal platform wakeup configuration for am62x devices. These defconfigs are meant to serve as a foundation for custom boards to build upon by only including necessary components to boot the device.
Defconfig fragments will be used to expand upon these base files.
Signed-off-by: Jason Kacines j-kacines@ti.com --- configs/am62x_a53_defconfig | 78 ++++++++++++++++++++++++++++++ configs/am62x_r5_defconfig | 94 +++++++++++++++++++++++++++++++++++++ 2 files changed, 172 insertions(+) create mode 100644 configs/am62x_a53_defconfig create mode 100644 configs/am62x_r5_defconfig
diff --git a/configs/am62x_a53_defconfig b/configs/am62x_a53_defconfig new file mode 100644 index 0000000000..baaa229b34 --- /dev/null +++ b/configs/am62x_a53_defconfig @@ -0,0 +1,78 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SOC_K3_AM625=y +CONFIG_K3_ATF_LOAD_ADDR=0x9e780000 +CONFIG_TARGET_AM625_A53_EVM=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80b80000 +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-sk" +CONFIG_SPL_TEXT_BASE=0x80080000 +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_SIZE_LIMIT=0x40000 +CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x800 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +# CONFIG_CMD_PXE is not set +# CONFIG_CMD_DHCP is not set +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; setenv fdtfile ti/${name_fdt}; run distro_bootcmd" +CONFIG_SPL_MAX_SIZE=0x58000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x80c80000 +CONFIG_SPL_BSS_MAX_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_CMD_MMC=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +# CONFIG_NET is not set +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_TI_SCI=y +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_AM654=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +# CONFIG_SPL_YMODEM_SUPPORT is not set +CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_RESET_TI_SCI=y +CONFIG_DM_SERIAL=y +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_TI_K3=y +CONFIG_SOC_TI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_TI_SCI=y +CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 diff --git a/configs/am62x_r5_defconfig b/configs/am62x_r5_defconfig new file mode 100644 index 0000000000..64ae24bc90 --- /dev/null +++ b/configs/am62x_r5_defconfig @@ -0,0 +1,94 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SOC_K3_AM625=y +CONFIG_TARGET_AM625_R5_EVM=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x43c3a7f0 +CONFIG_ENV_IS_NOWHERE=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-r5-sk" +CONFIG_SPL_TEXT_BASE=0x43c00000 +CONFIG_DM_RESET=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x7000 +CONFIG_SPL_SIZE_LIMIT=0x3A7F0 +CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x3500 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 +CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y +# CONFIG_LEGACY_IMAGE_FORMAT is not set +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y +CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y +CONFIG_SPL_MAX_SIZE=0x3B000 +CONFIG_SPL_PAD_TO=0x0 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x43c3b000 +CONFIG_SPL_BSS_MAX_SIZE=0x3000 +CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_EARLY_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_REMOTEPROC=y +# CONFIG_SPL_YMODEM_SUPPORT is not set +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_REMOTEPROC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent interrupts" +# CONFIG_NET is not set +# CONFIG_BOOTDEV_ETH is not set +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_SPL_CLK_CCF=y +CONFIG_SPL_CLK_K3_PLL=y +CONFIG_SPL_CLK_K3=y +CONFIG_TI_SCI_PROTOCOL=y +# CONFIG_GPIO is not set +# CONFIG_I2C is not set +# CONFIG_INPUT is not set +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_AM654=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_RESET_TI_SCI=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_TI_K3=y +CONFIG_SOC_TI=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_LIB_RATIONAL=y +CONFIG_SPL_LIB_RATIONAL=y
Introduce am62x_evm defconfig fragments that will be used on top of the base wakeup defconfigs. The usage will be as follows:
make <...> am62x_r5_defconfig am62x_evm_r5.config make <...> am62x_a53_defconfig am62x_evm_a53.config
This will use the Makefile changes previously mentioned to access the .config fragments from /board/../
Also remove the original am62x_evm defconfigs now that fragments will be used to support to the board.
Signed-off-by: Jason Kacines j-kacines@ti.com --- board/ti/am62x/am62x_evm_a53.config | 38 +++++++++ board/ti/am62x/am62x_evm_r5.config | 51 +++++++++++ configs/am62x_evm_a53_defconfig | 104 ----------------------- configs/am62x_evm_r5_defconfig | 127 ---------------------------- 4 files changed, 89 insertions(+), 231 deletions(-) create mode 100644 board/ti/am62x/am62x_evm_a53.config create mode 100644 board/ti/am62x/am62x_evm_r5.config delete mode 100644 configs/am62x_evm_a53_defconfig delete mode 100644 configs/am62x_evm_r5_defconfig
diff --git a/board/ti/am62x/am62x_evm_a53.config b/board/ti/am62x/am62x_evm_a53.config new file mode 100644 index 0000000000..383bb4597a --- /dev/null +++ b/board/ti/am62x/am62x_evm_a53.config @@ -0,0 +1,38 @@ +# CONFIG_TI_SECURE_DEVICE is not set +CONFIG_SF_DEFAULT_SPEED=25000000 +CONFIG_SPL_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-sk" +CONFIG_SPL_OF_LIST="k3-am625-sk" +CONFIG_OF_LIST="k3-am625-sk" +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y +CONFIG_SPL_DM_SPI_FLASH=y +# CONFIG_SPL_SPI_FLASH_TINY is not set +CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_SYS_BOOTM_LEN=0x800000 +CONFIG_CMD_PXE=y +CONFIG_CMD_DHCP=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DMA_CHANNELS=y +CONFIG_TI_K3_NAVSS_UDMA=y +CONFIG_MMC_SDHCI_ADMA=y +CONFIG_SPL_MMC_SDHCI_ADMA=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_SOFT_RESET=y +CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_S28HX_T=y +CONFIG_NET=y +CONFIG_PHY_TI_DP83867=y +CONFIG_PHY_FIXED=y +CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_PHY=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_CADENCE_QSPI=y diff --git a/board/ti/am62x/am62x_evm_r5.config b/board/ti/am62x/am62x_evm_r5.config new file mode 100644 index 0000000000..5dffab74f6 --- /dev/null +++ b/board/ti/am62x/am62x_evm_r5.config @@ -0,0 +1,51 @@ +# CONFIG_TI_SECURE_DEVICE is not set +CONFIG_SYS_MALLOC_LEN=0x08000000 +CONFIG_SYS_MALLOC_F_LEN=0x9000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SF_DEFAULT_SPEED=25000000 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_ENV_SIZE=0x20000 +CONFIG_GPIO=y +CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-r5-sk" +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_I2C=y +CONFIG_INPUT=y +CONFIG_NET=y +CONFIG_BOOTDEV_ETH=y +CONFIG_SPL_DM_SPI_FLASH=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +# CONFIG_SPL_SPI_FLASH_TINY is not set +CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_DFU=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DA8XX_GPIO=y +CONFIG_SPL_MISC=y +CONFIG_ESM_K3=y +CONFIG_MMC_SDHCI_ADMA=y +CONFIG_SPL_MMC_SDHCI_ADMA=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_SOFT_RESET=y +CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_S28HX_T=y +CONFIG_CADENCE_QSPI=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_GENERIC is not set +CONFIG_PINCTRL_SINGLE=y diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig deleted file mode 100644 index 7c3bc184cf..0000000000 --- a/configs/am62x_evm_a53_defconfig +++ /dev/null @@ -1,104 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_F_LEN=0x8000 -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SOC_K3_AM625=y -CONFIG_K3_ATF_LOAD_ADDR=0x9e780000 -CONFIG_TARGET_AM625_A53_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80b80000 -CONFIG_SF_DEFAULT_SPEED=25000000 -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-am625-sk" -CONFIG_SPL_TEXT_BASE=0x80080000 -CONFIG_OF_LIBFDT_OVERLAY=y -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_SIZE_LIMIT=0x40000 -CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x800 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; setenv fdtfile ti/${name_fdt}; run distro_bootcmd" -CONFIG_SPL_MAX_SIZE=0x58000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x80c80000 -CONFIG_SPL_BSS_MAX_SIZE=0x80000 -CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 -CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_POWER_DOMAIN=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_SYS_BOOTM_LEN=0x800000 -CONFIG_CMD_MMC=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_CLK_TI_SCI=y -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ADMA=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_SOFT_RESET=y -CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_S28HX_T=y -CONFIG_PHY_TI_DP83867=y -CONFIG_PHY_FIXED=y -CONFIG_TI_AM65_CPSW_NUSS=y -CONFIG_PHY=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_K3_SYSTEM_CONTROLLER=y -CONFIG_REMOTEPROC_TI_K3_ARM64=y -CONFIG_RESET_TI_SCI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 diff --git a/configs/am62x_evm_r5_defconfig b/configs/am62x_evm_r5_defconfig deleted file mode 100644 index 3c5f367298..0000000000 --- a/configs/am62x_evm_r5_defconfig +++ /dev/null @@ -1,127 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x08000000 -CONFIG_SYS_MALLOC_F_LEN=0x9000 -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SOC_K3_AM625=y -CONFIG_TARGET_AM625_R5_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x43c3a7f0 -CONFIG_SF_DEFAULT_SPEED=25000000 -CONFIG_SF_DEFAULT_MODE=0 -CONFIG_ENV_SIZE=0x20000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-am625-r5-sk" -CONFIG_SPL_TEXT_BASE=0x43c00000 -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_SYS_MALLOC_F_LEN=0x7000 -CONFIG_SPL_SIZE_LIMIT=0x3A7F0 -CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x3500 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y -CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y -CONFIG_SPL_MAX_SIZE=0x3B000 -CONFIG_SPL_PAD_TO=0x0 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x43c3b000 -CONFIG_SPL_BSS_MAX_SIZE=0x3000 -CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 -CONFIG_SPL_EARLY_BSS=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -CONFIG_SPL_REMOTEPROC=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_ASKENV=y -CONFIG_CMD_DFU=y -CONFIG_CMD_GPT=y -CONFIG_CMD_MMC=y -CONFIG_CMD_REMOTEPROC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_SPL_CLK_CCF=y -CONFIG_SPL_CLK_K3_PLL=y -CONFIG_SPL_CLK_K3=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_SPL_MISC=y -CONFIG_ESM_K3=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ADMA=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_SOFT_RESET=y -CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_S28HX_T=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_POWER_DOMAIN=y -CONFIG_K3_SYSTEM_CONTROLLER=y -CONFIG_REMOTEPROC_TI_K3_ARM64=y -CONFIG_RESET_TI_SCI=y -CONFIG_SPECIFY_CONSOLE_INDEX=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_TIMER=y -CONFIG_SPL_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_LIB_RATIONAL=y -CONFIG_SPL_LIB_RATIONAL=y
Hi Jason,
How about setting up some common defaults for your arch using Kconfig, so that the board defconfigs are much smaller?
In general, boards in U-Boot have far too many individual settings. Most of them should use a sensible default.
Going in the direction you have here just continues that tradition, inventing what I feel is an unnecessary solution.
On 08:00-20230712, Simon Glass wrote:
Hi Jason,
Challenge here is SRAM. When we enable OSPI for example or USB DFU for a group of our devices -> they follow a specific pattern of CONFIG options, which over and over again, we mess up by having individual config options being updated. This is similar in nature to the kernel config fragment motivation as well - in fact just worse with SRAM limitations with which SPL or early stages of bootloaders need to function with.
Look at today's list: am65x_evm_a53_defconfig am65x_evm_r5_defconfig am65x_evm_r5_usbdfu_defconfig am65x_evm_r5_usbmsc_defconfig am65x_hs_evm_a53_defconfig am65x_hs_evm_r5_defconfig
The usbdfu or msc stuff just replicates it self over and over as people enable that for next TI SoC and so and so forth.
Other patterns are stuff like Android configurations or distro boot configurations - or uefi - instead of each vendor re-discovering the right options, the opens up the possibility of standardized fragments that any platform that chooses can pick.
I am with you that there are too many individual settings at times, and there is a need to keep the defconfigs small as well. One thing we have to fight against constantly is boot time memory availability and speed of boot requirements. but those are details of the exact Kconfig options enabled etc.. for us at least, config fragments opens up a sustainable and low-fail option of consistently enabling features across SoCs and platforms. I think many folks who struggle with the same will concur as well. We are definitely open to following a structured set of rules when and how it should be used.. but hopefully, this helps explains?
Hi Nishanth,
Hi Jason,
Yes, thank you.
participants (5)
Jason Kacines
Nishanth Menon
