[U-Boot] [PATCH v3] imx: add u-boot-nand.imx target
Add an additional target which prepends the u-boot.imx image with 0x400 padding bytes. On Vybrid and i.MX 7, i.MX6ULL this is required for NAND boot devices. The configuration CONFIG_IMX_NAND enables this image for a board.
Signed-off-by: Stefan Agner stefan.agner@toradex.com Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com ---
v3: - fixed depedency of Ksymbol
v2: - addressed Jagan's comment
Kconfig | 1 + Makefile | 3 +++ arch/arm/mach-imx/Makefile | 7 +++++++ 3 files changed, 11 insertions(+)
diff --git a/Kconfig b/Kconfig index d2eb744e70..c9473e00a9 100644 --- a/Kconfig +++ b/Kconfig @@ -253,6 +253,7 @@ config BUILD_TARGET default "u-boot.itb" if SPL_LOAD_FIT && (ROCKCHIP_RK3399 || ARCH_SUNXI) default "u-boot.kwb" if KIRKWOOD default "u-boot-with-spl.bin" if ARCH_AT91 && SPL_NAND_SUPPORT + default "u-boot-nand.imx" if (ARCH_MX6 || ARCH_MX7) && NAND_BOOT help Some SoCs need special image types (e.g. U-Boot binary with a special header) as build targets. By defining diff --git a/Makefile b/Makefile index 73fdf70cdd..287b74dd50 100644 --- a/Makefile +++ b/Makefile @@ -1106,6 +1106,9 @@ endif %.vyb: %.imx $(Q)$(MAKE) $(build)=arch/arm/cpu/armv7/vf610 $@
+u-boot-nand.imx: u-boot.imx + $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@ + quiet_cmd_copy = COPY $@ cmd_copy = cp $< $@
diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 898478fc4a..365a5951f1 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -112,6 +112,13 @@ u-boot.imx: MKIMAGEOUTPUT = u-boot.imx.log u-boot.imx: u-boot.bin u-boot.cfgout $(PLUGIN).bin FORCE $(call if_changed,mkimage)
+ifeq ($(CONFIG_NAND_BOOT),y) +cmd_u-boot-nand_imx = (dd bs=1024 count=1 if=/dev/zero 2>/dev/null) | \ + cat - $< > $@ +u-boot-nand.imx: u-boot.imx FORCE + $(call if_changed,u-boot-nand_imx) +endif + ifeq ($(CONFIG_MULTI_DTB_FIT),y) MKIMAGEFLAGS_u-boot-dtb.imx = -n $(filter-out $(PLUGIN).bin $< $(PHONY),$^) \ -T $(IMAGE_TYPE) -e $(CONFIG_SYS_TEXT_BASE)
Reviewed-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com
v3:
v2:
cat - $< > $@
+endif
ifeq ($(CONFIG_MULTI_DTB_FIT),y) MKIMAGEFLAGS_u-boot-dtb.imx = -n $(filter-out $(PLUGIN).bin $< $(PHONY),$^) \ -T $(IMAGE_TYPE) -e $(CONFIG_SYS_TEXT_BASE) -- 2.17.1
Igor Opaniuk
Oleksandr Suvorov
