[PATCH 1/3] spi: rockchip_sfc: Impletment set_speed logic
Set clock related processing into set_speed logic. And Optimize printing format.
Signed-off-by: Jon Lin jon.lin@rock-chips.com ---
drivers/spi/rockchip_sfc.c | 83 ++++++++++++++++++-------------------- 1 file changed, 40 insertions(+), 43 deletions(-)
diff --git a/drivers/spi/rockchip_sfc.c b/drivers/spi/rockchip_sfc.c index 4e2b861f22..2028b28e26 100644 --- a/drivers/spi/rockchip_sfc.c +++ b/drivers/spi/rockchip_sfc.c @@ -12,6 +12,7 @@ #include <bouncebuf.h> #include <clk.h> #include <dm.h> +#include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/iopoll.h> @@ -116,6 +117,7 @@
/* Master trigger */ #define SFC_DMA_TRIGGER 0x80 +#define SFC_DMA_TRIGGER_START 1
/* Src or Dst addr for master */ #define SFC_DMA_ADDR 0x84 @@ -163,14 +165,12 @@ #define SFC_DMA_TRANS_THRETHOLD (0x40)
/* Maximum clock values from datasheet suggest keeping clock value under - * 150MHz. No minimum or average value is suggested, but the U-boot BSP driver - * has a minimum of 10MHz and a default of 80MHz which seems reasonable. + * 150MHz. No minimum or average value is suggested. */ -#define SFC_MIN_SPEED_HZ (10 * 1000 * 1000) -#define SFC_DEFAULT_SPEED_HZ (80 * 1000 * 1000) -#define SFC_MAX_SPEED_HZ (150 * 1000 * 1000) +#define SFC_MAX_SPEED (150 * 1000 * 1000)
struct rockchip_sfc { + struct udevice *dev; void __iomem *regbase; struct clk hclk; struct clk clk; @@ -197,8 +197,6 @@ static int rockchip_sfc_reset(struct rockchip_sfc *sfc) /* Still need to clear the masked interrupt from RISR */ writel(0xFFFFFFFF, sfc->regbase + SFC_ICLR);
- debug("reset\n"); - return err; }
@@ -261,15 +259,11 @@ static int rockchip_sfc_probe(struct udevice *bus) #if CONFIG_IS_ENABLED(CLK) ret = clk_enable(&sfc->hclk); if (ret) - debug("Enable ahb clock fail %s: %d\n", bus->name, ret); + dev_dbg(sfc->dev, "sfc Enable ahb clock fail %s: %d\n", bus->name, ret);
ret = clk_enable(&sfc->clk); if (ret) - debug("Enable clock fail for %s: %d\n", bus->name, ret); - - ret = clk_set_rate(&sfc->clk, SFC_DEFAULT_SPEED_HZ); - if (ret) - debug("Could not set sfc clock for %s: %d\n", bus->name, ret); + dev_dbg(sfc->dev, "sfc Enable clock fail for %s: %d\n", bus->name, ret); #endif
ret = rockchip_sfc_init(sfc); @@ -278,7 +272,8 @@ static int rockchip_sfc_probe(struct udevice *bus)
sfc->max_iosize = rockchip_sfc_get_max_iosize(sfc); sfc->version = rockchip_sfc_get_version(sfc); - sfc->speed = SFC_DEFAULT_SPEED_HZ; + sfc->max_freq = SFC_MAX_SPEED; + sfc->dev = bus;
@@ -411,11 +406,11 @@ static int rockchip_sfc_xfer_setup(struct rockchip_sfc *sfc, ctrl |= SFC_CTRL_PHASE_SEL_NEGETIVE; cmd |= plat->cs << SFC_CMD_CS_SHIFT;
- debug("addr.nbytes=%x(x%d) dummy.nbytes=%x(x%d)\n", - op->addr.nbytes, op->addr.buswidth, - op->dummy.nbytes, op->dummy.buswidth); - debug("ctrl=%x cmd=%x addr=%llx len=%x\n", - ctrl, cmd, op->addr.val, len); + dev_dbg(sfc->dev, "sfc addr.nbytes=%x(x%d) dummy.nbytes=%x(x%d)\n", + op->addr.nbytes, op->addr.buswidth, + op->dummy.nbytes, op->dummy.buswidth); + dev_dbg(sfc->dev, "sfc ctrl=%x cmd=%x addr=%llx len=%x\n", + ctrl, cmd, op->addr.val, len);
writel(ctrl, sfc->regbase + SFC_CTRL); writel(cmd, sfc->regbase + SFC_CMD); @@ -492,7 +487,7 @@ static int rockchip_sfc_fifo_transfer_dma(struct rockchip_sfc *sfc, dma_addr_t d { writel(0xFFFFFFFF, sfc->regbase + SFC_ICLR); writel((u32)dma_buf, sfc->regbase + SFC_DMA_ADDR); - writel(0x1, sfc->regbase + SFC_DMA_TRIGGER); + writel(SFC_DMA_TRIGGER_START, sfc->regbase + SFC_DMA_TRIGGER);
return len; } @@ -500,7 +495,7 @@ static int rockchip_sfc_fifo_transfer_dma(struct rockchip_sfc *sfc, dma_addr_t d static int rockchip_sfc_xfer_data_poll(struct rockchip_sfc *sfc, const struct spi_mem_op *op, u32 len) { - debug("xfer_poll len=%x\n", len); + dev_dbg(sfc->dev, "sfc xfer_poll len=%x\n", len);
if (op->data.dir == SPI_MEM_DATA_OUT) return rockchip_sfc_write_fifo(sfc, op->data.buf.out, len); @@ -516,7 +511,7 @@ static int rockchip_sfc_xfer_data_dma(struct rockchip_sfc *sfc, void *dma_buf; int ret;
- debug("xfer_dma len=%x\n", len); + dev_dbg(sfc->dev, "sfc xfer_dma len=%x\n", len);
if (op->data.dir == SPI_MEM_DATA_OUT) { dma_buf = (void *)op->data.buf.out; @@ -564,33 +559,16 @@ static int rockchip_sfc_exec_op(struct spi_slave *mem, u32 len = min_t(u32, op->data.nbytes, sfc->max_iosize); int ret;
-#if CONFIG_IS_ENABLED(CLK) - if (unlikely(mem->max_hz != sfc->speed)) { - ret = clk_set_rate(&sfc->clk, clamp(mem->max_hz, (uint)SFC_MIN_SPEED_HZ, - (uint)SFC_MAX_SPEED_HZ)); - if (ret < 0) { - printf("set_freq=%dHz fail, check if it's the cru support level\n", - mem->max_hz); - return ret; - } - - sfc->max_freq = mem->max_hz; - sfc->speed = mem->max_hz; - debug("set_freq=%dHz real_freq=%dHz\n", sfc->max_freq, sfc->speed); - } -#endif - rockchip_sfc_adjust_op_work((struct spi_mem_op *)op); - rockchip_sfc_xfer_setup(sfc, mem, op, len); if (len) { - if (likely(sfc->use_dma) && !(len & 0x3) && len >= SFC_DMA_TRANS_THRETHOLD) + if (likely(sfc->use_dma) && len >= SFC_DMA_TRANS_THRETHOLD) ret = rockchip_sfc_xfer_data_dma(sfc, op, len); else ret = rockchip_sfc_xfer_data_poll(sfc, op, len);
if (ret != len) { - printf("xfer data failed ret %d dir %d\n", ret, op->data.dir); + dev_err(sfc->dev, "xfer data failed ret %d dir %d\n", ret, op->data.dir);
return -EIO; } @@ -604,13 +582,32 @@ static int rockchip_sfc_adjust_op_size(struct spi_slave *mem, struct spi_mem_op struct rockchip_sfc *sfc = dev_get_plat(mem->dev->parent);
op->data.nbytes = min(op->data.nbytes, sfc->max_iosize); + return 0; }
static int rockchip_sfc_set_speed(struct udevice *bus, uint speed) { - /* We set up speed later for each transmission. - */ + struct rockchip_sfc *sfc = dev_get_plat(bus); + int ret; + + if (speed > sfc->max_freq) + speed = sfc->max_freq; + + if (speed == sfc->speed) + return 0; + +#if CONFIG_IS_ENABLED(CLK) + ret = clk_set_rate(&sfc->clk, speed); + if (ret < 0) { + dev_err(sfc->dev, "set_freq=%dHz fail, check if it's the cru support level\n", + speed); + return ret; + } + sfc->speed = speed; +#else + dev_dbg(sfc->dev, "sfc failed, CLK not support\n"); +#endif return 0; }
Using read_poll logic.
drivers/spi/rockchip_sfc.c | 67 ++++++++++++++++++++------------------ 1 file changed, 35 insertions(+), 32 deletions(-)
diff --git a/drivers/spi/rockchip_sfc.c b/drivers/spi/rockchip_sfc.c index 2028b28e26..33c5344c70 100644 --- a/drivers/spi/rockchip_sfc.c +++ b/drivers/spi/rockchip_sfc.c @@ -286,33 +286,38 @@ err_init: return ret; }
-static inline int rockchip_sfc_get_fifo_level(struct rockchip_sfc *sfc, int wr) +static int rockchip_sfc_wait_txfifo_ready(struct rockchip_sfc *sfc, u32 timeout_us) { - u32 fsr = readl(sfc->regbase + SFC_FSR); - int level; + int ret = 0; + u32 status;
- if (wr) - level = (fsr & SFC_FSR_TXLV_MASK) >> SFC_FSR_TXLV_SHIFT; - else - level = (fsr & SFC_FSR_RXLV_MASK) >> SFC_FSR_RXLV_SHIFT; + ret = readl_poll_timeout(sfc->regbase + SFC_FSR, status, + status & SFC_FSR_TXLV_MASK, + timeout_us); + if (ret) { + dev_dbg(sfc->dev, "sfc wait tx fifo timeout\n"); + + ret = -ETIMEDOUT; + }
- return level; + return (status & SFC_FSR_TXLV_MASK) >> SFC_FSR_TXLV_SHIFT; }
-static int rockchip_sfc_wait_fifo_ready(struct rockchip_sfc *sfc, int wr, u32 timeout) +static int rockchip_sfc_wait_rxfifo_ready(struct rockchip_sfc *sfc, u32 timeout_us) { - unsigned long tbase = get_timer(0); - int level; + int ret = 0; + u32 status;
- while (!(level = rockchip_sfc_get_fifo_level(sfc, wr))) { - if (get_timer(tbase) > timeout) { - debug("%s fifo timeout\n", wr ? "write" : "read"); - return -ETIMEDOUT; - } - udelay(1); + ret = readl_poll_timeout(sfc->regbase + SFC_FSR, status, + status & SFC_FSR_RXLV_MASK, + timeout_us); + if (ret) { + dev_dbg(sfc->dev, "sfc wait rx fifo timeout\n"); + + ret = -ETIMEDOUT; }
- return level; + return (status & SFC_FSR_RXLV_MASK) >> SFC_FSR_RXLV_SHIFT; }
static void rockchip_sfc_adjust_op_work(struct spi_mem_op *op) @@ -430,7 +435,7 @@ static int rockchip_sfc_write_fifo(struct rockchip_sfc *sfc, const u8 *buf, int
dwords = len >> 2; while (dwords) { - tx_level = rockchip_sfc_wait_fifo_ready(sfc, SFC_CMD_DIR_WR, 1000); + tx_level = rockchip_sfc_wait_txfifo_ready(sfc, 1000); if (tx_level < 0) return tx_level; write_words = min_t(u32, tx_level, dwords); @@ -441,7 +446,7 @@ static int rockchip_sfc_write_fifo(struct rockchip_sfc *sfc, const u8 *buf, int
/* write the rest non word aligned bytes */ if (bytes) { - tx_level = rockchip_sfc_wait_fifo_ready(sfc, SFC_CMD_DIR_WR, 1000); + tx_level = rockchip_sfc_wait_txfifo_ready(sfc, 1000); if (tx_level < 0) return tx_level; memcpy(&tmp, buf, bytes); @@ -462,7 +467,7 @@ static int rockchip_sfc_read_fifo(struct rockchip_sfc *sfc, u8 *buf, int len) /* word aligned access only */ dwords = len >> 2; while (dwords) { - rx_level = rockchip_sfc_wait_fifo_ready(sfc, SFC_CMD_DIR_RD, 1000); + rx_level = rockchip_sfc_wait_rxfifo_ready(sfc, 1000); if (rx_level < 0) return rx_level; read_words = min_t(u32, rx_level, dwords); @@ -473,7 +478,7 @@ static int rockchip_sfc_read_fifo(struct rockchip_sfc *sfc, u8 *buf, int len)
/* read the rest non word aligned bytes */ if (bytes) { - rx_level = rockchip_sfc_wait_fifo_ready(sfc, SFC_CMD_DIR_RD, 1000); + rx_level = rockchip_sfc_wait_rxfifo_ready(sfc, 1000); if (rx_level < 0) return rx_level; tmp = readl(sfc->regbase + SFC_DATA); @@ -534,19 +539,17 @@ static int rockchip_sfc_xfer_data_dma(struct rockchip_sfc *sfc,
static int rockchip_sfc_xfer_done(struct rockchip_sfc *sfc, u32 timeout_us) { - unsigned long tbase = get_timer(0); int ret = 0; - u32 timeout = timeout_us; - - while (readl(sfc->regbase + SFC_SR) & SFC_SR_IS_BUSY) { - if (get_timer(tbase) > timeout) { - printf("wait sfc idle timeout\n"); - rockchip_sfc_reset(sfc); + u32 status;
- return -ETIMEDOUT; - } + ret = readl_poll_timeout(sfc->regbase + SFC_SR, status, + !(status & SFC_SR_IS_BUSY), + timeout_us); + if (ret) { + dev_err(sfc->dev, "wait sfc idle timeout\n"); + rockchip_sfc_reset(sfc);
- udelay(1); + ret = -EIO; }
return ret;
TX single line is more compatible for corresponding board
arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi | 2 +- arch/arm/dts/rk3326-odroid-go2.dts | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi b/arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi index 741e8dd935..0990005a15 100644 --- a/arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi +++ b/arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi @@ -70,7 +70,7 @@ u-boot,dm-pre-reloc; };
-&spi_flash { +&{/sfc@ff3a0000/flash@0} { u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/rk3326-odroid-go2.dts b/arch/arm/dts/rk3326-odroid-go2.dts index 6f91f5040b..57e7f409d8 100644 --- a/arch/arm/dts/rk3326-odroid-go2.dts +++ b/arch/arm/dts/rk3326-odroid-go2.dts @@ -629,7 +629,7 @@ reg = <0>; spi-max-frequency = <108000000>; spi-rx-bus-width = <2>; - spi-tx-bus-width = <2>; + spi-tx-bus-width = <1>; }; };
There are still some bugs with this. Note that if you want for now you can just abandon this patch (or fix it, either way is fine). If you abandon it I'll make sure once the Linux driver is upstream the nodes match between it and U-Boot. Otherwise, you'll need to make the changes below to fix this.
This causes the devicetree to fail to compile, since the node is not getting changed from spi_flash in the main dts file.
The node should change here to just "flash@0" instead of "spi_flash: xt25f128b@0" to match upstream (proposed).
Also note that on the upstream (proposed) the pinctrl values are in a different order, and the sfc_cs pinctrl is called the sfc_cs0.
};spi-tx-bus-width = <1>;
-- 2.17.1
I had abandon it because I think it would be more accurate for you to deal with it
}; };spi-tx-bus-width = <1>;
-- 2.17.1
I tested this one and it tests out okay. I figured out the issue that was causing the performance regression. For the value of CONFIG_SF_DEFAULT_SPEED the help text says "Not used for boot with device tree", however I can confirm that after doing an "sf probe" the speed would reset to whatever value I had set in this parameter (which at the time was the default of 1000000). When I changed this parameter to 108000000 the speed regression was fixed. Either the help text needs to be updated or there is a bug where it's using this value instead of the devicetree derived value.
- 150MHz. No minimum or average value is suggested, but the U-boot BSP driver
- has a minimum of 10MHz and a default of 80MHz which seems reasonable.
- 150MHz. No minimum or average value is suggested.
- struct udevice *dev; void __iomem *regbase; struct clk hclk; struct clk clk;
- debug("reset\n");
- return err;
- if (ret)
#endif
sfc->dev = bus;
return len;
if (ret < 0) {
mem->max_hz);
return ret;
-#endif
if (ret != len) {
dev_err(sfc->dev, "xfer data failed ret %d dir %d\n", ret, op->data.dir); return -EIO;
- struct rockchip_sfc *sfc = dev_get_plat(bus);
- int ret;
- if (speed > sfc->max_freq)
- if (speed == sfc->speed)
- ret = clk_set_rate(&sfc->clk, speed);
- if (ret < 0) {
speed);
return ret;
- sfc->speed = speed;
+#else
- dev_dbg(sfc->dev, "sfc failed, CLK not support\n");
+#endif return 0; }
-- 2.17.1
Chris Morgan
Jon Lin
