[PATCH u-boot] ata: Fix dependency for CONFIG_SATA_SIL
sata_sil.c is PCI driver and without CONFIG_PCI is building of U-Boot failing:
LD u-boot ld.bfd: drivers/ata/sata_sil.o: in function `sil_exec_cmd': drivers/ata/sata_sil.c:148: undefined reference to `dm_pci_phys_to_bus' ld.bfd: drivers/ata/sata_sil.o: in function `sil_pci_probe': drivers/ata/sata_sil.c:687: undefined reference to `dm_pci_get_bdf' ld.bfd: drivers/ata/sata_sil.c:691: undefined reference to `dm_pci_read_config16' ld.bfd: drivers/ata/sata_sil.c:701: undefined reference to `dm_pci_map_bar' ld.bfd: drivers/ata/sata_sil.c:704: undefined reference to `dm_pci_map_bar' ld.bfd: drivers/ata/sata_sil.c:713: undefined reference to `dm_pci_write_config16' ld.bfd: drivers/ata/sata_sil.c:717: undefined reference to `dm_pci_read_config16' ld.bfd: drivers/ata/sata_sil.o: in function `sil_cmd_identify_device': drivers/ata/sata_sil.c:256: undefined reference to `dm_pci_phys_to_bus' ld.bfd: drivers/ata/sata_sil.o: in function `sil_sata_rw_cmd': drivers/ata/sata_sil.c:330: undefined reference to `dm_pci_phys_to_bus' ld.bfd: drivers/ata/sata_sil.o: in function `sil_sata_rw_cmd_ext': drivers/ata/sata_sil.c:377: undefined reference to `dm_pci_phys_to_bus' make: *** [Makefile:1778: u-boot] Error 1
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/ata/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index a063b221cd1f..3fe53d6d4f3a 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -135,6 +135,7 @@ config SATA_MV
config SATA_SIL bool "Enable Silicon Image SIL3131 / SIL3132 / SIL3124 SATA driver support" + depends on PCI select AHCI select LIBATA help
Thanks, Stefan
- depends on PCI select AHCI select LIBATA help
Viele Grüße, Stefan Roese
Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de
Pali Rohár
Stefan Roese
