[U-Boot-Users] [PATCH] ARM: Board voiceblue update
Signed-off-by: Ladislav Michl ladis@linux-mips.org
diff --git a/Makefile b/Makefile index 1ff80b5..7f66bc5 100644 --- a/Makefile +++ b/Makefile @@ -2294,20 +2294,8 @@ versatileab_config \ versatilepb_config : unconfig @board/versatile/split_by_variant.sh $@
-voiceblue_smallflash_config \ voiceblue_config: unconfig - @mkdir -p $(obj)include - @mkdir -p $(obj)board/voiceblue - @if [ "$(findstring _smallflash_,$@)" ] ; then \ - echo "... boot from lower flash bank" ; \ - echo "#define VOICEBLUE_SMALL_FLASH" >>$(obj)include/config.h ; \ - echo "VOICEBLUE_SMALL_FLASH=y" >$(obj)board/voiceblue/config.tmp ; \ - else \ - echo "... boot from upper flash bank" ; \ - >$(obj)include/config.h ; \ - echo "VOICEBLUE_SMALL_FLASH=n" >$(obj)board/voiceblue/config.tmp ; \ - fi - @$(MKCONFIG) -a voiceblue arm arm925t voiceblue + @$(MKCONFIG) $(@:_config=) arm arm925t voiceblue
cm4008_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t cm4008 NULL ks8695 diff --git a/board/voiceblue/Makefile b/board/voiceblue/Makefile index 5f340b4..9386bb0 100644 --- a/board/voiceblue/Makefile +++ b/board/voiceblue/Makefile @@ -62,7 +62,7 @@ clean:
distclean: clean - rm -f $(LIB) core config.tmp *.bak .depend + rm -f $(LIB) core *.bak .depend
diff --git a/board/voiceblue/config.mk b/board/voiceblue/config.mk index d55daa4..2cfc56a 100644 --- a/board/voiceblue/config.mk +++ b/board/voiceblue/config.mk @@ -1,16 +1 @@ -# -# Linux-Kernel is expected to be at 1000'8000, -# entry 1000'8000 (mem base + reserved) -# - -sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp - -ifeq ($(VOICEBLUE_SMALL_FLASH),y) -# We load ourself to internal SRAM at 2001'2000 -# Check map file when changing TEXT_BASE. -# Everything has fit into 192kB internal SRAM! -TEXT_BASE = 0x20012000 -else -# Running in SDRAM... TEXT_BASE = 0x13FD0000 -endif diff --git a/board/voiceblue/setup.S b/board/voiceblue/setup.S index dcf37b5..78cd2b6 100644 --- a/board/voiceblue/setup.S +++ b/board/voiceblue/setup.S @@ -77,7 +77,7 @@ MUX_CONFIG_VALUES: .word 0x00000000 @ FUNC_MUX_CTRL_3 .word 0x00000000 @ FUNC_MUX_CTRL_4 .word 0x12082480 @ FUNC_MUX_CTRL_5 - .word 0x00000004 @ FUNC_MUX_CTRL_6 + .word 0x0000001c @ FUNC_MUX_CTRL_6 .word 0x00000003 @ FUNC_MUX_CTRL_7 .word 0x10001200 @ FUNC_MUX_CTRL_8 .word 0x01201012 @ FUNC_MUX_CTRL_9 diff --git a/include/configs/voiceblue.h b/include/configs/voiceblue.h index 7cab31d..8c827af 100644 --- a/include/configs/voiceblue.h +++ b/include/configs/voiceblue.h @@ -26,10 +26,6 @@
#include <configs/omap1510.h>
-/* - * High Level Configuration Options - * (easy to change) - */ #define CONFIG_ARM925T 1 /* This is an arm925t CPU */ #define CONFIG_OMAP 1 /* in a TI OMAP core */ #define CONFIG_OMAP1510 1 /* which is in a 5910 */ @@ -54,10 +50,9 @@ */ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ #define PHYS_SDRAM_1 0x10000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE SZ_64M +#define PHYS_SDRAM_1_SIZE (64 * 1024 * 1024)
#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ -#define PHYS_FLASH_2 0x0c000000
#define CFG_LOAD_ADDR PHYS_SDRAM_1 + 0x400000 /* default load address */
@@ -67,50 +62,34 @@ #define CFG_FLASH_CFI /* Flash is CFI conformant */ #define CFG_FLASH_CFI_DRIVER /* Use the common driver */ #define CFG_MAX_FLASH_BANKS 1 -#ifdef VOICEBLUE_SMALL_FLASH -#define CFG_FLASH_BANKS_LIST { PHYS_FLASH_2 } -#else -#define CFG_FLASH_BANKS_LIST { PHYS_FLASH_1 } -#endif +#define CFG_FLASH_BASE PHYS_FLASH_1
/* FIXME: Does not work on AMD flash */ /* #define CFG_FLASH_USE_BUFFER_WRITE 1 */ /* use buffered writes (20x faster) */ #define CFG_MAX_FLASH_SECT 512 /* max # of sectors on one chip */
#define CFG_MONITOR_BASE PHYS_FLASH_1 -#define CFG_MONITOR_LEN SZ_128K +#define CFG_MONITOR_LEN (256 * 1024)
/* * Environment settings */ -#ifdef VOICEBLUE_SMALL_FLASH -#define CFG_ENV_IS_NOWHERE -#define CFG_ENV_SIZE SZ_1K -#else #define CFG_ENV_IS_IN_FLASH #define CFG_ENV_ADDR (PHYS_FLASH_1 + CFG_MONITOR_LEN) -#define CFG_ENV_SIZE SZ_8K -#define CFG_ENV_SECT_SIZE SZ_64K +#define CFG_ENV_SIZE (8 * 1024) +#define CFG_ENV_SECT_SIZE (64 * 1024) #define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR + CFG_ENV_SECT_SIZE) #define CFG_ENV_SIZE_REDUND CFG_ENV_SIZE
#define CONFIG_ENV_OVERWRITE
-#endif - /* * Size of malloc() pool and stack */ #define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#ifdef VOICEBLUE_SMALL_FLASH -#define CFG_MALLOC_LEN (SZ_64K - CFG_GBL_DATA_SIZE) -#define CONFIG_STACKSIZE SZ_8K -#define PHYS_SDRAM_1_RESERVED 0 -#else -#define CFG_MALLOC_LEN SZ_4M -#define CONFIG_STACKSIZE SZ_1M +#define CFG_MALLOC_LEN (4 * 1024 * 1024) +#define CONFIG_STACKSIZE (1 * 1024 * 1024) #define PHYS_SDRAM_1_RESERVED (CFG_MONITOR_LEN + CFG_MALLOC_LEN + CONFIG_STACKSIZE) -#endif
/* * Hardware drivers @@ -118,6 +97,14 @@ #define CONFIG_DRIVER_SMC91111 #define CONFIG_SMC91111_BASE 0x08000300
+#define CONFIG_HARD_I2C +#define CFG_I2C_SPEED 100000 +#define CFG_I2C_SLAVE 1 +#define CONFIG_DRIVER_OMAP1510_I2C + +#define CONFIG_RTC_DS1307 +#define CFG_I2C_RTC_ADDR 0x68 + /* * NS16550 Configuration */ @@ -138,21 +125,18 @@ #include <config_cmd_default.h>
#define CONFIG_CMD_BDI -#define CONFIG_CMD_LOADB -#define CONFIG_CMD_IMI +#define CONFIG_CMD_BOOTD +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ENV #define CONFIG_CMD_FLASH +#define CONFIG_CMD_IMI +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_LOADB #define CONFIG_CMD_MEMORY #define CONFIG_CMD_NET -#define CONFIG_CMD_BOOTD -#define CONFIG_CMD_DHCP #define CONFIG_CMD_PING #define CONFIG_CMD_RUN
-#if !defined(VOICEBLUE_SMALL_FLASH) - #define CONFIG_CMD_ENV - #define CONFIG_CMD_JFFS2 -#endif -
/* * BOOTP options @@ -165,32 +149,20 @@
#define CONFIG_LOOPW
-#ifdef VOICEBLUE_SMALL_FLASH -#define CONFIG_BOOTDELAY 0 -#undef CONFIG_BOOTARGS /* the preboot command will set bootargs*/ -#define CFG_AUTOLOAD "n" /* no autoload */ -#define CONFIG_PREBOOT "run setup" -#define CONFIG_EXTRA_ENV_SETTINGS \ - "setup=setenv bootargs console=ttyS0,${baudrate} " \ - "root=/dev/nfs ip=dhcp\0" \ - "update=erase c000000 c03ffff; " \ - "cp.b 10400000 c000000 ${filesize}\0" -#else #define CONFIG_BOOTDELAY 3 -#undef CONFIG_BOOTARGS /* boot command will set bootargs */ -#define CFG_AUTOLOAD "n" /* no autoload */ +#define CONFIG_ZERO_BOOTDELAY_CHECK /* allow to break in always */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs*/ +#define CFG_AUTOLOAD "n" /* No autoload */ #define CONFIG_BOOTCOMMAND "run nboot" #define CONFIG_PREBOOT "run setup" #define CONFIG_EXTRA_ENV_SETTINGS \ "silent=1\0" \ "ospart=0\0" \ - "swapos=no\0" \ + "bootfile=/boot/uImage\0" \ "setpart=" \ - "if test $swapos = yes; then " \ - "if test $ospart -eq 0; then chpart 4; else chpart 3; fi; "\ - "setenv swapos no; saveenv; " \ - "else " \ - "if test $ospart -eq 0; then chpart 3; else chpart 4; fi; "\ + "if test -n $swapos; then " \ + "setenv swapos; saveenv; " \ + "if test $ospart -eq 0; then setenv ospart 1; else setenv ospart 0; fi; "\ "fi\0" \ "setup=setenv bootargs console=ttyS0,$baudrate " \ "mtdparts=$mtdparts\0" \ @@ -198,16 +170,14 @@ "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname::off " \ "nfsroot=$rootpath root=/dev/nfs\0" \ "flashargs=run setpart; setenv bootargs $bootargs " \ - "root=/dev/mtdblock$partition ro " \ + "root=mtd:data$ospart ro " \ "rootfstype=jffs2\0" \ "initrdargs=setenv bootargs $bootargs " \ "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname::off\0" \ - "fboot=run flashargs; fsload /boot/uImage; bootm\0" \ - "iboot=bootp; run initrdargs; tftp; bootm\0" \ + "fboot=run flashargs; chpart data$ospart; fsload; bootm\0" \ + "mboot=bootp; run initrdargs; tftp; bootm\0" \ "nboot=bootp; run nfsargs; tftp; bootm\0" -#endif
-#ifndef VOICEBLUE_SMALL_FLASH #define CONFIG_SILENT_CONSOLE 1 /* enable silent startup */
#if 1 /* feel free to disable for development */ @@ -221,19 +191,15 @@ */ #define CONFIG_JFFS2_CMDLINE #define MTDIDS_DEFAULT "nor0=omapflash.0" -#define MTDPARTS_DEFAULT "mtdparts=omapflash.0:128k(uboot),64k(env),64k(r_env),16256k(data1),-(data2)" - -#endif /* VOICEBLUE_SMALL_FLASH */ +#define MTDPARTS_DEFAULT "mtdparts=omapflash.0:256k(u-boot),64k(env),64k(r_env),16192k(data0),-(data1)"
/* * Miscellaneous configurable options */ -#ifndef VOICEBLUE_SMALL_FLASH #define CFG_HUSH_PARSER #define CFG_PROMPT_HUSH_PS2 "> " #define CONFIG_AUTO_COMPLETE -#endif #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "# " /* Monitor Command Prompt */ #define CFG_CBSIZE 256 /* Console I/O Buffer Size */
Applied, thanks.
Ladislav Michl
