[U-Boot] [PATCH 1/2] net: fec_mxc: Fix setting of RCR for xMII
At least on i.MX25, the RMII mode did not work, which is fixed by this patch.
The MII_MODE bit of the FEC RCR register means xMII, i.e. 'not 7-wire', so set it accordingly.
According to the xMII and 7-wire (aka GPSI) standards, full duplex should be available on xMII, but not on 7-wire, so set FCE accordingly. The FEC may support full duplex for 7-wire too, but the reference manual does not say that, so avoid an invalid assumption. Actually, the choice between half and full duplex also depends on the endpoint/switch/repeater configuration, so a config option could be added for that, but there has been no need for it so far.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Stefano Babic sbabic@denx.de --- .../drivers/net/fec_mxc.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git u-boot-66714b1.orig/drivers/net/fec_mxc.c u-boot-66714b1/drivers/net/fec_mxc.c index eee41d7..c64a223 100644 --- u-boot-66714b1.orig/drivers/net/fec_mxc.c +++ u-boot-66714b1/drivers/net/fec_mxc.c @@ -424,14 +424,12 @@ static void fec_reg_setup(struct fec_priv *fec)
/* Start with frame length = 1518, common for all modes. */ rcntrl = PKTSIZE << FEC_RCNTRL_MAX_FL_SHIFT; - if (fec->xcv_type == SEVENWIRE) - rcntrl |= FEC_RCNTRL_FCE; - else if (fec->xcv_type == RGMII) + if (fec->xcv_type != SEVENWIRE) /* xMII modes */ + rcntrl |= FEC_RCNTRL_FCE | FEC_RCNTRL_MII_MODE; + if (fec->xcv_type == RGMII) rcntrl |= FEC_RCNTRL_RGMII; else if (fec->xcv_type == RMII) rcntrl |= FEC_RCNTRL_RMII; - else /* MII mode */ - rcntrl |= FEC_RCNTRL_FCE | FEC_RCNTRL_MII_MODE;
writel(rcntrl, &fec->eth->r_cntrl); }
Benoît Thébaudeau
