[U-Boot] [PATCH] MX51: efikamx: fix wrong name in boards.cfg
Wrong name in boards.cfg for the efikamx board makes that some files of the mx51evk instead of efikamx are used.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Marek Vasut marek.vasut@gmail.com --- boards.cfg | 2 +- include/configs/efikamx.h | 2 ++ 2 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 0fe0f0e..7c79034 100644 --- a/boards.cfg +++ b/boards.cfg @@ -140,7 +140,7 @@ omap5912osk arm arm926ejs - ti edminiv2 arm arm926ejs - LaCie orion5x dkb arm arm926ejs - Marvell pantheon ca9x4_ct_vxp arm armv7 vexpress armltd -efikamx arm armv7 efikamx - mx5 mx51evk:IMX_CONFIG=board/efikamx/imximage.cfg +efikamx arm armv7 efikamx - mx5 efikamx:IMX_CONFIG=board/efikamx/imximage.cfg mx51evk arm armv7 mx51evk freescale mx5 mx51evk:IMX_CONFIG=board/freescale/mx51evk/imximage.cfg mx53ard arm armv7 mx53ard freescale mx5 mx53ard:IMX_CONFIG=board/freescale/mx53ard/imximage_dd3.cfg mx53evk arm armv7 mx53evk freescale mx5 mx53evk:IMX_CONFIG=board/freescale/mx53evk/imximage.cfg diff --git a/include/configs/efikamx.h b/include/configs/efikamx.h index a04ac49..9c98cdc 100644 --- a/include/configs/efikamx.h +++ b/include/configs/efikamx.h @@ -38,6 +38,8 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
+#define CONFIG_SYS_TEXT_BASE 0x97800000 + #define CONFIG_SYS_L2CACHE_OFF
Dear Stefano Babic,
Um... the CONFIG_SYS_TEXT_BASE is unrelated and should be submitted in a separate patch.
On 07/13/2011 01:58 PM, Wolfgang Denk wrote:
Dear Stefano Babic,
Agree. Fix in V2
Best regards, Stefano Babic
Dear Stefano Babic,
Agree. Fix in V2
Right, Jana's on vacation till 18th, but I guess I can split it and send pullrq ... whatever.
Jana fixed this some time ago ... I have it in my tree and I send it recently to he ML ...
http://git.denx.de/?p=u-boot/u-boot- pxa.git;a=commit;h=ce52afa30284fb08a3129ed86f053e2b0e9b9a5e
arm926ejs
mx53evk
Dear Marek Vasut,
But this is wrong. This is a iMX system, so all patches must go through the iMX custodian and his repositor.
This has no place in the u-boot-pxa reporistory. Please make sure to remove it there before you send any pull requests to Albert.
On Wednesday, July 13, 2011 02:29:03 PM Wolfgang Denk wrote:
Dear Marek Vasut,
Shall I prepare a branch with the stuff I want up and send pull rq to albert ?
Dear Marek Vasut,
I'm a bit surprised by thi squestion. Yes, if you have any patches in the pxa repository that shall go intoi mainline, then you are supposed to send a pull request to Albert. Otherwise nothing will happen.
On Wednesday, July 13, 2011 03:27:11 PM Wolfgang Denk wrote:
Dear Marek Vasut,
No, I mean branch in u-boot-pxa ... since they are unrelated.
Dear Marek Vasut,
Marek,
I missed Jana's patches (they were sent yesterday, I see now), and I get the same bug today after rebuilding all i.MX boards - this is the reason for my patches on the same issue.
I will take Jana's patches and I will apply them to u-boot-imx. You do not need to apply to u-boot-imx, as they are unrelated to PXA
Stefano
Dear Marek Vasut,
Patches are normally picked up by the respective custodian. If you are anot the responsible custodian, you normally don't have to care about patches - actually this is usually even counter productive.
I find the most efficient way to pick up patches to be from patchwork, because this already takes care about things like automatically adding the respective Acked-by: lines, etc.
Correct - I care about Jana's patches - drop them from u-boot-pxa
Agree. It is a very comfortable way to to things, and saves a lot of time.
Stefano Babic
