[U-Boot] [PATCH v2] gpio: dwapb_gpio: Add reset ctrl to driver
Add code to reset all reset signals as in gpio DT node. A reset property is an optional feature, so only print out a warning and do not fail if a reset property is not present.
If a reset property is discovered, then use it to deassert, thus bringing the IP out of reset.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com
--- v2: - Move reset to probe() function. --- drivers/gpio/dwapb_gpio.c | 20 +++++++++++++++++++- 1 file changed, 19 insertions(+), 1 deletion(-)
diff --git a/drivers/gpio/dwapb_gpio.c b/drivers/gpio/dwapb_gpio.c index 7cf2d47..dfe1e6d 100644 --- a/drivers/gpio/dwapb_gpio.c +++ b/drivers/gpio/dwapb_gpio.c @@ -15,6 +15,7 @@ #include <dm/lists.h> #include <dm/root.h> #include <errno.h> +#include <reset.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -99,13 +100,30 @@ static const struct dm_gpio_ops gpio_dwapb_ops = { .get_function = dwapb_gpio_get_function, };
+static void gpio_dwapb_reset(struct udevice *dev) +{ + struct reset_ctl_bulk reset_bulk; + int ret; + + ret = reset_get_bulk(dev, &reset_bulk); + if (ret) { + dev_warn(dev, "Can't get reset: %d\n", ret); + return; + } + + reset_deassert_bulk(&reset_bulk); +} + static int gpio_dwapb_probe(struct udevice *dev) { struct gpio_dev_priv *priv = dev_get_uclass_priv(dev); struct gpio_dwapb_platdata *plat = dev->platdata;
- if (!plat) + if (!plat) { + /* Reset on parent device only */ + gpio_dwapb_reset(dev); return 0; + }
priv->gpio_count = plat->pins; priv->bank_name = plat->name;
Enabled get_function support for dwapb where the function will return the state of GPIO port.
Signed-off-by: Chin Liang See chin.liang.see@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com
--- v2: Change to use "if (gpio & BIT(offset))" bit masking. --- drivers/gpio/dwapb_gpio.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/gpio/dwapb_gpio.c b/drivers/gpio/dwapb_gpio.c index 680b11a..7cf2d47 100644 --- a/drivers/gpio/dwapb_gpio.c +++ b/drivers/gpio/dwapb_gpio.c @@ -78,11 +78,25 @@ static int dwapb_gpio_set_value(struct udevice *dev, unsigned pin, int val) return 0; }
+static int dwapb_gpio_get_function(struct udevice *dev, unsigned offset) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + u32 gpio; + + gpio = readl(plat->base + GPIO_SWPORT_DDR(plat->bank)); + + if (gpio & BIT(offset)) + return GPIOF_OUTPUT; + else + return GPIOF_INPUT; +} + static const struct dm_gpio_ops gpio_dwapb_ops = { .direction_input = dwapb_gpio_direction_input, .direction_output = dwapb_gpio_direction_output, .get_value = dwapb_gpio_get_value, .set_value = dwapb_gpio_set_value, + .get_function = dwapb_gpio_get_function, };
v2:
- struct reset_ctl_bulk reset_bulk;
- int ret;
- ret = reset_get_bulk(dev, &reset_bulk);
- if (ret) {
return;
- reset_deassert_bulk(&reset_bulk);
- if (!plat)
if (!plat) {
What about .remove() and reset_release ?
v2:
int ret;
if (ret) {
return;
if (!plat)
if (!plat) {
} priv->gpio_count = plat->pins; priv->bank_name = plat->name;
This driver doesn't implement .remove, should we add this to assert reset?
Regards Ley Foon
v2:
int ret;
if (ret) {
return;
if (!plat)
if (!plat) {
Yes
v2:
int ret;
if (ret) {
return;
if (!plat)
if (!plat) {
Yes
Okay, will try to add it.
BTW, when .remove will be call in Uboot?
Regards Ley Foon
v2:
int ret;
if (ret) {
return;
if (!plat)
if (!plat) {
Yes
When removing the driver and possibly before booting Linux.
Ley Foon Tan
Ley Foon Tan
