[U-Boot] [PATCH] serial: drop redundant depends on
SANDBOX_SERIAL depends on SANDBOX, and SANDBOX selects DM. So, "SANDBOX_SERIAL depends on DM" is redundant.
Likewise, UNIPHIER_SERIAL depends on ARCH_UNIPHIER, and ARCH_UNIPHIER selects DM_SERIAL. So, "UNIPHIER_SERIAL depends on DM_SERIAL" is redundant.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/serial/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 4f6a3b8..002f1da 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -111,7 +111,7 @@ config DEBUG_UART_SHIFT
config SANDBOX_SERIAL bool "Sandbox UART support" - depends on SANDBOX && DM + depends on SANDBOX help Select this to enable a seral UART for sandbox. This is required to operate correctly, otherwise you will see no serial output from @@ -131,7 +131,7 @@ config SANDBOX_SERIAL
config UNIPHIER_SERIAL bool "Support for UniPhier on-chip UART" - depends on ARCH_UNIPHIER && DM_SERIAL + depends on ARCH_UNIPHIER help If you have a UniPhier based board and want to use the on-chip serial ports, say Y to this option. If unsure, say N.
On 28 August 2015 at 05:14, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Acked-by: Simon Glass sjg@chromium.org
Masahiro Yamada
