[PATCH v2 00/10] cache operation cleanups for Andes AE350 platform
This patchset is intended to enable L2-cache in U-boot SPL, along with cache operations cleanup for AE350 platforms.
Changes v1 -> v2: - Drop plicsw related patch - Include RB tags from Rick and Leo
The patchset is based on commit: a209c3e6b48cf042d0220245a2d1636f74389c17
Leo Yu-Chi Liang (1): riscv: Remove redundant Kconfig "RISCV_NDS_CACHE"
Yu Chien Peter Lin (9): board: AndesTech: ax25-ae350.c: Enable v5l2-cache in spl_board_init() driver: cache: cache-v5l2: Update memory-mapped scheme to support Gen2 platform riscv: cpu: ax25: Simplify cache enabling logic in harts_early_init() riscv: ae350: dts: Update L2 cache compatible string riscv: ax25: cache.c: Cleanups to L1/L2 cache function used in SPL configs: ae350: Enable v5l2 cache for AE350 platforms in SPL configs: ae350: Increase maximum retry count for AE350 platforms configs: ae350: Display CPU and board info for AE350 platforms driver: cache-v5l2: Fix type casting warning on RV32
arch/riscv/cpu/ax25/Kconfig | 11 +-- arch/riscv/cpu/ax25/cache.c | 118 ++++++++---------------- arch/riscv/cpu/ax25/cpu.c | 49 +++------- arch/riscv/dts/ae350_32.dts | 2 +- arch/riscv/dts/ae350_64.dts | 2 +- arch/riscv/include/asm/arch-andes/csr.h | 29 ++++++ board/AndesTech/ax25-ae350/ax25-ae350.c | 17 ++-- configs/ae350_rv32_defconfig | 3 + configs/ae350_rv32_spl_defconfig | 5 + configs/ae350_rv32_spl_xip_defconfig | 5 + configs/ae350_rv32_xip_defconfig | 3 + configs/ae350_rv64_defconfig | 3 + configs/ae350_rv64_spl_defconfig | 5 + configs/ae350_rv64_spl_xip_defconfig | 5 + configs/ae350_rv64_xip_defconfig | 3 + drivers/cache/Kconfig | 1 - drivers/cache/cache-v5l2.c | 36 ++++++-- 17 files changed, 149 insertions(+), 148 deletions(-) create mode 100644 arch/riscv/include/asm/arch-andes/csr.h
There is no need for RISCV_NDS_CACHE config to control cache switches.
Signed-off-by: Leo Yu-Chi Liang ycliang@andestech.com Reviewed-by: Yu Chien Peter Lin peterlin@andestech.com Reviewed-by: Rick Chen rick@andestech.com --- arch/riscv/cpu/ax25/Kconfig | 10 ----- arch/riscv/cpu/ax25/cache.c | 84 +------------------------------------ drivers/cache/Kconfig | 1 - 3 files changed, 2 insertions(+), 93 deletions(-)
diff --git a/arch/riscv/cpu/ax25/Kconfig b/arch/riscv/cpu/ax25/Kconfig index 4a7295d30c..eca68ea2a7 100644 --- a/arch/riscv/cpu/ax25/Kconfig +++ b/arch/riscv/cpu/ax25/Kconfig @@ -12,13 +12,3 @@ config RISCV_NDS help Run U-Boot on AndeStar V5 platforms and use some specific features which are provided by Andes Technology AndeStar V5 families. - -if RISCV_NDS - -config RISCV_NDS_CACHE - bool "AndeStar V5 families specific cache support" - depends on RISCV_MMODE || SPL_RISCV_MMODE - help - Provide Andes Technology AndeStar V5 families specific cache support. - -endif diff --git a/arch/riscv/cpu/ax25/cache.c b/arch/riscv/cpu/ax25/cache.c index 35f23c748d..1c0c3772a1 100644 --- a/arch/riscv/cpu/ax25/cache.c +++ b/arch/riscv/cpu/ax25/cache.c @@ -67,106 +67,26 @@ void invalidate_dcache_range(unsigned long start, unsigned long end)
void icache_enable(void) { -#if !CONFIG_IS_ENABLED(SYS_ICACHE_OFF) -#ifdef CONFIG_RISCV_NDS_CACHE -#if CONFIG_IS_ENABLED(RISCV_MMODE) - asm volatile ( - "csrr t1, mcache_ctl\n\t" - "ori t0, t1, 0x1\n\t" - "csrw mcache_ctl, t0\n\t" - ); -#endif -#endif -#endif }
void icache_disable(void) { -#if !CONFIG_IS_ENABLED(SYS_ICACHE_OFF) -#ifdef CONFIG_RISCV_NDS_CACHE -#if CONFIG_IS_ENABLED(RISCV_MMODE) - asm volatile ( - "fence.i\n\t" - "csrr t1, mcache_ctl\n\t" - "andi t0, t1, ~0x1\n\t" - "csrw mcache_ctl, t0\n\t" - ); -#endif -#endif -#endif }
void dcache_enable(void) { -#if !CONFIG_IS_ENABLED(SYS_DCACHE_OFF) -#ifdef CONFIG_RISCV_NDS_CACHE -#if CONFIG_IS_ENABLED(RISCV_MMODE) - asm volatile ( - "csrr t1, mcache_ctl\n\t" - "ori t0, t1, 0x2\n\t" - "csrw mcache_ctl, t0\n\t" - ); -#endif -#ifdef CONFIG_V5L2_CACHE - _cache_enable(); -#endif -#endif -#endif }
void dcache_disable(void) { -#if !CONFIG_IS_ENABLED(SYS_DCACHE_OFF) -#ifdef CONFIG_RISCV_NDS_CACHE -#if CONFIG_IS_ENABLED(RISCV_MMODE) - csr_write(CCTL_REG_MCCTLCOMMAND_NUM, CCTL_L1D_WBINVAL_ALL); - asm volatile ( - "csrr t1, mcache_ctl\n\t" - "andi t0, t1, ~0x2\n\t" - "csrw mcache_ctl, t0\n\t" - ); -#endif -#ifdef CONFIG_V5L2_CACHE - _cache_disable(); -#endif -#endif -#endif }
int icache_status(void) { - int ret = 0; - -#ifdef CONFIG_RISCV_NDS_CACHE -#if CONFIG_IS_ENABLED(RISCV_MMODE) - asm volatile ( - "csrr t1, mcache_ctl\n\t" - "andi %0, t1, 0x01\n\t" - : "=r" (ret) - : - : "memory" - ); -#endif -#endif - - return ret; + return 0; }
int dcache_status(void) { - int ret = 0; - -#ifdef CONFIG_RISCV_NDS_CACHE -#if CONFIG_IS_ENABLED(RISCV_MMODE) - asm volatile ( - "csrr t1, mcache_ctl\n\t" - "andi %0, t1, 0x02\n\t" - : "=r" (ret) - : - : "memory" - ); -#endif -#endif - - return ret; + return 0; } diff --git a/drivers/cache/Kconfig b/drivers/cache/Kconfig index 40f41a817c..6cb8c3e980 100644 --- a/drivers/cache/Kconfig +++ b/drivers/cache/Kconfig @@ -25,7 +25,6 @@ config L2X0_CACHE config V5L2_CACHE bool "Andes V5L2 cache driver" select CACHE - depends on RISCV_NDS_CACHE help Support Andes V5L2 cache controller in AE350 platform. It will configure tag and data ram timing control from the
The L2-cache is not enabled currently, the enbale_caches() will call the v5l2_enable() callback to enable it in SPL.
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com Reviewed-by: Rick Chen rick@andestech.com --- board/AndesTech/ax25-ae350/ax25-ae350.c | 17 +++++++++-------- 1 file changed, 9 insertions(+), 8 deletions(-)
diff --git a/board/AndesTech/ax25-ae350/ax25-ae350.c b/board/AndesTech/ax25-ae350/ax25-ae350.c index 63a966e092..1c2288b6ce 100644 --- a/board/AndesTech/ax25-ae350/ax25-ae350.c +++ b/board/AndesTech/ax25-ae350/ax25-ae350.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <cpu_func.h> #include <flash.h> #include <image.h> #include <init.h> @@ -72,6 +73,14 @@ void *board_fdt_blob_setup(int *err) return NULL; }
+#ifdef CONFIG_SPL_BOARD_INIT +void spl_board_init() +{ + /* enable v5l2 cache */ + enable_caches(); +} +#endif + int smc_init(void) { int node = -1; @@ -96,18 +105,10 @@ int smc_init(void) return 0; }
-static void v5l2_init(void) -{ - struct udevice *dev; - - uclass_get_device(UCLASS_CACHE, 0, &dev); -} - #ifdef CONFIG_BOARD_EARLY_INIT_F int board_early_init_f(void) { smc_init(); - v5l2_init();
return 0; }
The L2C configuration register has MAP field to indicate its version is v0 (Gen1) or v1 (Gen2) L2-cache. This patch makes the driver compatible with both memory-mapped scheme.
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- drivers/cache/cache-v5l2.c | 32 ++++++++++++++++++++++++-------- 1 file changed, 24 insertions(+), 8 deletions(-)
diff --git a/drivers/cache/cache-v5l2.c b/drivers/cache/cache-v5l2.c index bbdb76bd57..e782430c57 100644 --- a/drivers/cache/cache-v5l2.c +++ b/drivers/cache/cache-v5l2.c @@ -34,6 +34,14 @@ struct l2cache { volatile u64 cctl_status; };
+/* Configuration register */ +#define MEM_MAP_OFF 20 +#define MEM_MAP_MSK BIT(MEM_MAP_OFF) +/* offset of v0 memory map (Gen1) */ +static u32 cmd_stride = 0x10; +static u32 status_stride = 0x0; +static u32 status_bit_offset = 0x4; + /* Control Register */ #define L2_ENABLE 0x1 /* prefetch */ @@ -53,14 +61,15 @@ struct l2cache { #define DRAMICTL_MSK BIT(DRAMICTL_OFF)
/* CCTL Command Register */ -#define CCTL_CMD_REG(base, hart) ((ulong)(base) + 0x40 + (hart) * 0x10) +#define CCTL_CMD_REG(base, hart) ((ulong)(base) + 0x40 + (hart) * (cmd_stride)) #define L2_WBINVAL_ALL 0x12
/* CCTL Status Register */ -#define CCTL_STATUS_MSK(hart) (0xf << ((hart) * 4)) -#define CCTL_STATUS_IDLE(hart) (0 << ((hart) * 4)) -#define CCTL_STATUS_PROCESS(hart) (1 << ((hart) * 4)) -#define CCTL_STATUS_ILLEGAL(hart) (2 << ((hart) * 4)) +#define CCTL_STATUS_REG(base, hart) ((ulong)(base) + 0x80 + (hart) * (status_stride)) +#define CCTL_STATUS_MSK(hart) (0xf << ((hart) * (status_bit_offset))) +#define CCTL_STATUS_IDLE(hart) (0 << ((hart) * (status_bit_offset))) +#define CCTL_STATUS_PROCESS(hart) (1 << ((hart) * (status_bit_offset))) +#define CCTL_STATUS_ILLEGAL(hart) (2 << ((hart) * (status_bit_offset)))
DECLARE_GLOBAL_DATA_PTR;
@@ -133,12 +142,19 @@ static int v5l2_probe(struct udevice *dev) { struct v5l2_plat *plat = dev_get_plat(dev); struct l2cache *regs = plat->regs; - u32 ctl_val; + u32 cfg_val, ctl_val;
+ cfg_val = readl(®s->configure); ctl_val = readl(®s->control);
- if (!(ctl_val & L2_ENABLE)) - ctl_val |= L2_ENABLE; + /* If true, v1 memory map (Gen2) */ + if (cfg_val & MEM_MAP_MSK) { + cmd_stride = 0x1000; + status_stride = 0x1000; + status_bit_offset = 0x0; + } + + ctl_val |= L2_ENABLE;
if (plat->iprefetch != -EINVAL) { ctl_val &= ~(IPREPETCH_MSK);
As the OpenSBI v1.2 does not enable the cache [0], we enable the i/d-cache in harts_early_init() and do not disable in cleanup_before_linux(). This patch also simplifies the logic and moves the CSR encoding to include/asm/arch-andes/csr.h.
[0] https://github.com/riscv-software-src/opensbi/commit/bd7ef4139829da5c30fa980...
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/cpu/ax25/cpu.c | 49 ++++++------------------- arch/riscv/include/asm/arch-andes/csr.h | 29 +++++++++++++++ 2 files changed, 41 insertions(+), 37 deletions(-) create mode 100644 arch/riscv/include/asm/arch-andes/csr.h
diff --git a/arch/riscv/cpu/ax25/cpu.c b/arch/riscv/cpu/ax25/cpu.c index a46674f7c2..2c7565ad49 100644 --- a/arch/riscv/cpu/ax25/cpu.c +++ b/arch/riscv/cpu/ax25/cpu.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2017 Andes Technology Corporation + * Copyright (C) 2023 Andes Technology Corporation * Rick Chen, Andes Technology Corporation rick@andestech.com */
@@ -10,23 +10,7 @@ #include <irq_func.h> #include <asm/cache.h> #include <asm/csr.h> - -#define CSR_MCACHE_CTL 0x7ca -#define CSR_MMISC_CTL 0x7d0 -#define CSR_MARCHID 0xf12 - -#define V5_MCACHE_CTL_IC_EN_OFFSET 0 -#define V5_MCACHE_CTL_DC_EN_OFFSET 1 -#define V5_MCACHE_CTL_CCTL_SUEN_OFFSET 8 -#define V5_MCACHE_CTL_DC_COHEN_OFFSET 19 -#define V5_MCACHE_CTL_DC_COHSTA_OFFSET 20 - -#define V5_MCACHE_CTL_IC_EN BIT(V5_MCACHE_CTL_IC_EN_OFFSET) -#define V5_MCACHE_CTL_DC_EN BIT(V5_MCACHE_CTL_DC_EN_OFFSET) -#define V5_MCACHE_CTL_CCTL_SUEN BIT(V5_MCACHE_CTL_CCTL_SUEN_OFFSET) -#define V5_MCACHE_CTL_DC_COHEN_EN BIT(V5_MCACHE_CTL_DC_COHEN_OFFSET) -#define V5_MCACHE_CTL_DC_COHSTA_EN BIT(V5_MCACHE_CTL_DC_COHSTA_OFFSET) - +#include <asm/arch-andes/csr.h>
/* * cleanup_before_linux() is called just before we call linux @@ -38,38 +22,29 @@ int cleanup_before_linux(void) { disable_interrupts();
- /* turn off I/D-cache */ cache_flush(); - icache_disable(); - dcache_disable();
return 0; }
void harts_early_init(void) { + /* Enable I/D-cache in SPL */ if (CONFIG_IS_ENABLED(RISCV_MMODE)) { - unsigned long long mcache_ctl_val = csr_read(CSR_MCACHE_CTL); + unsigned long mcache_ctl_val = csr_read(CSR_MCACHE_CTL); + + mcache_ctl_val |= (MCACHE_CTL_DC_COHEN | MCACHE_CTL_IC_EN | + MCACHE_CTL_DC_EN);
- if (!(mcache_ctl_val & V5_MCACHE_CTL_DC_COHEN_EN)) - mcache_ctl_val |= V5_MCACHE_CTL_DC_COHEN_EN; - if (!(mcache_ctl_val & V5_MCACHE_CTL_IC_EN)) - mcache_ctl_val |= V5_MCACHE_CTL_IC_EN; - if (!(mcache_ctl_val & V5_MCACHE_CTL_DC_EN)) - mcache_ctl_val |= V5_MCACHE_CTL_DC_EN; - if (!(mcache_ctl_val & V5_MCACHE_CTL_CCTL_SUEN)) - mcache_ctl_val |= V5_MCACHE_CTL_CCTL_SUEN; csr_write(CSR_MCACHE_CTL, mcache_ctl_val);
/* - * Check DC_COHEN_EN, if cannot write to mcache_ctl, - * we assume this bitmap not support L2 CM + * Check mcache_ctl.DC_COHEN, we assume this platform does + * not support CM if the bit is hard-wired to 0. */ - mcache_ctl_val = csr_read(CSR_MCACHE_CTL); - if ((mcache_ctl_val & V5_MCACHE_CTL_DC_COHEN_EN)) { - /* Wait for DC_COHSTA bit be set */ - while (!(mcache_ctl_val & V5_MCACHE_CTL_DC_COHSTA_EN)) - mcache_ctl_val = csr_read(CSR_MCACHE_CTL); + if (csr_read(CSR_MCACHE_CTL) & MCACHE_CTL_DC_COHEN) { + /* Wait for DC_COHSTA bit to be set */ + while (!(csr_read(CSR_MCACHE_CTL)& MCACHE_CTL_DC_COHSTA)); } } } diff --git a/arch/riscv/include/asm/arch-andes/csr.h b/arch/riscv/include/asm/arch-andes/csr.h new file mode 100644 index 0000000000..a03ccd5b3e --- /dev/null +++ b/arch/riscv/include/asm/arch-andes/csr.h @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Andes Technology Corporation + */ + +#ifndef _ASM_ANDES_CSR_H +#define _ASM_ANDES_CSR_H + +#include <asm/asm.h> +#include <linux/const.h> + +#define CSR_MCACHE_CTL 0x7ca +#define CSR_MMISC_CTL 0x7d0 +#define CSR_MARCHID 0xf12 +#define CSR_MCCTLCOMMAND 0x7cc + +#define MCACHE_CTL_IC_EN_OFFSET 0 +#define MCACHE_CTL_DC_EN_OFFSET 1 +#define MCACHE_CTL_DC_COHEN_OFFSET 19 +#define MCACHE_CTL_DC_COHSTA_OFFSET 20 + +#define MCACHE_CTL_IC_EN BIT(MCACHE_CTL_IC_EN_OFFSET) +#define MCACHE_CTL_DC_EN BIT(MCACHE_CTL_DC_EN_OFFSET) +#define MCACHE_CTL_DC_COHEN BIT(MCACHE_CTL_DC_COHEN_OFFSET) +#define MCACHE_CTL_DC_COHSTA BIT(MCACHE_CTL_DC_COHSTA_OFFSET) + +#define CCTL_L1D_WBINVAL_ALL 6 + +#endif /* _ASM_ANDES_CSR_H */
Update the compatible string of L2 cache.
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/dts/ae350_32.dts | 2 +- arch/riscv/dts/ae350_64.dts | 2 +- drivers/cache/cache-v5l2.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/riscv/dts/ae350_32.dts b/arch/riscv/dts/ae350_32.dts index 96ef8bd8dd..61af6d5465 100644 --- a/arch/riscv/dts/ae350_32.dts +++ b/arch/riscv/dts/ae350_32.dts @@ -112,7 +112,7 @@ };
L2: l2-cache@e0500000 { - compatible = "v5l2cache"; + compatible = "cache"; cache-level = <2>; cache-size = <0x40000>; reg = <0xe0500000 0x40000>; diff --git a/arch/riscv/dts/ae350_64.dts b/arch/riscv/dts/ae350_64.dts index cddbaec98a..8c7db29b4f 100644 --- a/arch/riscv/dts/ae350_64.dts +++ b/arch/riscv/dts/ae350_64.dts @@ -112,7 +112,7 @@ };
L2: l2-cache@e0500000 { - compatible = "v5l2cache"; + compatible = "cache"; cache-level = <2>; cache-size = <0x40000>; reg = <0x0 0xe0500000 0x0 0x40000>; diff --git a/drivers/cache/cache-v5l2.c b/drivers/cache/cache-v5l2.c index e782430c57..c6d3a8f893 100644 --- a/drivers/cache/cache-v5l2.c +++ b/drivers/cache/cache-v5l2.c @@ -184,7 +184,7 @@ static int v5l2_probe(struct udevice *dev) }
static const struct udevice_id v5l2_cache_ids[] = { - { .compatible = "v5l2cache" }, + { .compatible = "cache" }, {} };
This patch refines L1 cache enable/disable and v5l2-cache enable functions.
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/cpu/ax25/cache.c | 98 +++++++++++++++++++++++++------------ 1 file changed, 68 insertions(+), 30 deletions(-)
diff --git a/arch/riscv/cpu/ax25/cache.c b/arch/riscv/cpu/ax25/cache.c index 1c0c3772a1..40d77f671c 100644 --- a/arch/riscv/cpu/ax25/cache.c +++ b/arch/riscv/cpu/ax25/cache.c @@ -1,57 +1,51 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2017 Andes Technology Corporation + * Copyright (C) 2023 Andes Technology Corporation * Rick Chen, Andes Technology Corporation rick@andestech.com */
+#include <asm/csr.h> +#include <asm/asm.h> #include <common.h> +#include <cache.h> #include <cpu_func.h> #include <dm.h> -#include <asm/cache.h> #include <dm/uclass-internal.h> -#include <cache.h> -#include <asm/csr.h> - -#ifdef CONFIG_RISCV_NDS_CACHE -#if CONFIG_IS_ENABLED(RISCV_MMODE) -/* mcctlcommand */ -#define CCTL_REG_MCCTLCOMMAND_NUM 0x7cc - -/* D-cache operation */ -#define CCTL_L1D_WBINVAL_ALL 6 -#endif -#endif +#include <asm/arch-andes/csr.h>
#ifdef CONFIG_V5L2_CACHE -static void _cache_enable(void) +void enable_caches(void) { - struct udevice *dev = NULL; - - uclass_find_first_device(UCLASS_CACHE, &dev); - - if (dev) - cache_enable(dev); + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_CACHE, + DM_DRIVER_GET(v5l2_cache), + &dev); + if (ret) { + log_debug("Cannot enable v5l2 cache\n"); + } else { + ret = cache_enable(dev); + if (ret) + log_debug("v5l2 cache enable failed\n"); + } }
-static void _cache_disable(void) +static void cache_ops(int (*ops)(struct udevice *dev)) { struct udevice *dev = NULL;
if (dev) - cache_disable(dev); + ops(dev); } #endif
void flush_dcache_all(void) { -#if !CONFIG_IS_ENABLED(SYS_ICACHE_OFF) -#ifdef CONFIG_RISCV_NDS_CACHE #if CONFIG_IS_ENABLED(RISCV_MMODE) - csr_write(CCTL_REG_MCCTLCOMMAND_NUM, CCTL_L1D_WBINVAL_ALL); -#endif -#endif + csr_write(CSR_MCCTLCOMMAND, CCTL_L1D_WBINVAL_ALL); #endif }
@@ -67,26 +61,70 @@ void invalidate_dcache_range(unsigned long start, unsigned long end)
void icache_enable(void) { +#if CONFIG_IS_ENABLED(RISCV_MMODE) + asm volatile("csrsi %0, 0x1" :: "i"(CSR_MCACHE_CTL)); +#endif }
void icache_disable(void) { +#if CONFIG_IS_ENABLED(RISCV_MMODE) + asm volatile("csrci %0, 0x1" :: "i"(CSR_MCACHE_CTL)); +#endif }
void dcache_enable(void) { +#if CONFIG_IS_ENABLED(RISCV_MMODE) + asm volatile("csrsi %0, 0x2" :: "i"(CSR_MCACHE_CTL)); +#endif + +#ifdef CONFIG_V5L2_CACHE + cache_ops(cache_enable); +#endif }
void dcache_disable(void) { +#if CONFIG_IS_ENABLED(RISCV_MMODE) + asm volatile("csrci %0, 0x2" :: "i"(CSR_MCACHE_CTL)); +#endif + +#ifdef CONFIG_V5L2_CACHE + cache_ops(cache_disable); +#endif }
int icache_status(void) { - return 0; + int ret = 0; + +#if CONFIG_IS_ENABLED(RISCV_MMODE) + asm volatile ( + "csrr t1, %1\n\t" + "andi %0, t1, 0x01\n\t" + : "=r" (ret) + : "i"(CSR_MCACHE_CTL) + : "memory" + ); +#endif + + return !!ret; }
int dcache_status(void) { - return 0; + int ret = 0; + +#if CONFIG_IS_ENABLED(RISCV_MMODE) + asm volatile ( + "csrr t1, %1\n\t" + "andi %0, t1, 0x02\n\t" + : "=r" (ret) + : "i" (CSR_MCACHE_CTL) + : "memory" + ); +#endif + + return !!ret; }
To reduce the code size, CONFIG_V5L2_CACHE was disabled since commit: ca06444aac2c643db3a3f2eb37afc60fae15177e
Turing on does not significantly increase the size of u-boot-spl.bin, so we enable it by default to improve performance.
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/cpu/ax25/Kconfig | 1 + configs/ae350_rv32_spl_defconfig | 2 ++ configs/ae350_rv32_spl_xip_defconfig | 2 ++ configs/ae350_rv64_spl_defconfig | 2 ++ configs/ae350_rv64_spl_xip_defconfig | 2 ++ 5 files changed, 9 insertions(+)
diff --git a/arch/riscv/cpu/ax25/Kconfig b/arch/riscv/cpu/ax25/Kconfig index eca68ea2a7..82bb5a2a53 100644 --- a/arch/riscv/cpu/ax25/Kconfig +++ b/arch/riscv/cpu/ax25/Kconfig @@ -6,6 +6,7 @@ config RISCV_NDS imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE) imply ANDES_PLICSW if (RISCV_MMODE || SPL_RISCV_MMODE) imply ANDES_PLMT_TIMER if (RISCV_MMODE || SPL_RISCV_MMODE) + imply V5L2_CACHE imply SPL_CPU imply SPL_OPENSBI imply SPL_LOAD_FIT diff --git a/configs/ae350_rv32_spl_defconfig b/configs/ae350_rv32_spl_defconfig index a66db65621..f5bd7a9a7e 100644 --- a/configs/ae350_rv32_spl_defconfig +++ b/configs/ae350_rv32_spl_defconfig @@ -22,6 +22,8 @@ CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_CACHE=y CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y diff --git a/configs/ae350_rv32_spl_xip_defconfig b/configs/ae350_rv32_spl_xip_defconfig index 606962c0a7..014dcbedf6 100644 --- a/configs/ae350_rv32_spl_xip_defconfig +++ b/configs/ae350_rv32_spl_xip_defconfig @@ -23,6 +23,8 @@ CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_CACHE=y CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y diff --git a/configs/ae350_rv64_spl_defconfig b/configs/ae350_rv64_spl_defconfig index f235db7990..51d23d050d 100644 --- a/configs/ae350_rv64_spl_defconfig +++ b/configs/ae350_rv64_spl_defconfig @@ -22,6 +22,8 @@ CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_CACHE=y CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y diff --git a/configs/ae350_rv64_spl_xip_defconfig b/configs/ae350_rv64_spl_xip_defconfig index 4cbfd52fb1..c44df4b561 100644 --- a/configs/ae350_rv64_spl_xip_defconfig +++ b/configs/ae350_rv64_spl_xip_defconfig @@ -23,6 +23,8 @@ CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_CACHE=y CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y
Loading an image via TFTP is often interrupted when retrying more than 10 times, increase the number of retries so that it does not simply stop the transfer.
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- configs/ae350_rv32_defconfig | 1 + configs/ae350_rv32_spl_defconfig | 1 + configs/ae350_rv32_spl_xip_defconfig | 1 + configs/ae350_rv32_xip_defconfig | 1 + configs/ae350_rv64_defconfig | 1 + configs/ae350_rv64_spl_defconfig | 1 + configs/ae350_rv64_spl_xip_defconfig | 1 + configs/ae350_rv64_xip_defconfig | 1 + 8 files changed, 8 insertions(+)
diff --git a/configs/ae350_rv32_defconfig b/configs/ae350_rv32_defconfig index e5c8358e54..a9d158dc8d 100644 --- a/configs/ae350_rv32_defconfig +++ b/configs/ae350_rv32_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y diff --git a/configs/ae350_rv32_spl_defconfig b/configs/ae350_rv32_spl_defconfig index f5bd7a9a7e..54587018d5 100644 --- a/configs/ae350_rv32_spl_defconfig +++ b/configs/ae350_rv32_spl_defconfig @@ -34,6 +34,7 @@ CONFIG_BOOTP_PREFER_SERVERIP=y CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y diff --git a/configs/ae350_rv32_spl_xip_defconfig b/configs/ae350_rv32_spl_xip_defconfig index 014dcbedf6..b626153723 100644 --- a/configs/ae350_rv32_spl_xip_defconfig +++ b/configs/ae350_rv32_spl_xip_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTP_PREFER_SERVERIP=y CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y diff --git a/configs/ae350_rv32_xip_defconfig b/configs/ae350_rv32_xip_defconfig index 069a9d3982..628522cd4d 100644 --- a/configs/ae350_rv32_xip_defconfig +++ b/configs/ae350_rv32_xip_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y diff --git a/configs/ae350_rv64_defconfig b/configs/ae350_rv64_defconfig index c373b99b95..c058f76780 100644 --- a/configs/ae350_rv64_defconfig +++ b/configs/ae350_rv64_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y diff --git a/configs/ae350_rv64_spl_defconfig b/configs/ae350_rv64_spl_defconfig index 51d23d050d..9664baf705 100644 --- a/configs/ae350_rv64_spl_defconfig +++ b/configs/ae350_rv64_spl_defconfig @@ -34,6 +34,7 @@ CONFIG_BOOTP_PREFER_SERVERIP=y CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y diff --git a/configs/ae350_rv64_spl_xip_defconfig b/configs/ae350_rv64_spl_xip_defconfig index c44df4b561..b754888409 100644 --- a/configs/ae350_rv64_spl_xip_defconfig +++ b/configs/ae350_rv64_spl_xip_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTP_PREFER_SERVERIP=y CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y diff --git a/configs/ae350_rv64_xip_defconfig b/configs/ae350_rv64_xip_defconfig index 4fed2ead1d..380ae096ee 100644 --- a/configs/ae350_rv64_xip_defconfig +++ b/configs/ae350_rv64_xip_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y
Display information about CPU and board during start up.
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- configs/ae350_rv32_defconfig | 2 ++ configs/ae350_rv32_spl_defconfig | 2 ++ configs/ae350_rv32_spl_xip_defconfig | 2 ++ configs/ae350_rv32_xip_defconfig | 2 ++ configs/ae350_rv64_defconfig | 2 ++ configs/ae350_rv64_spl_defconfig | 2 ++ configs/ae350_rv64_spl_xip_defconfig | 2 ++ configs/ae350_rv64_xip_defconfig | 2 ++ 8 files changed, 16 insertions(+)
diff --git a/configs/ae350_rv32_defconfig b/configs/ae350_rv32_defconfig index a9d158dc8d..fd1bf5fa4f 100644 --- a/configs/ae350_rv32_defconfig +++ b/configs/ae350_rv32_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 diff --git a/configs/ae350_rv32_spl_defconfig b/configs/ae350_rv32_spl_defconfig index 54587018d5..4d3623a894 100644 --- a/configs/ae350_rv32_spl_defconfig +++ b/configs/ae350_rv32_spl_defconfig @@ -19,6 +19,8 @@ CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x00200000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x4000000 diff --git a/configs/ae350_rv32_spl_xip_defconfig b/configs/ae350_rv32_spl_xip_defconfig index b626153723..a076b77834 100644 --- a/configs/ae350_rv32_spl_xip_defconfig +++ b/configs/ae350_rv32_spl_xip_defconfig @@ -20,6 +20,8 @@ CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x4000000 diff --git a/configs/ae350_rv32_xip_defconfig b/configs/ae350_rv32_xip_defconfig index 628522cd4d..da1bd2b10b 100644 --- a/configs/ae350_rv32_xip_defconfig +++ b/configs/ae350_rv32_xip_defconfig @@ -15,6 +15,8 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 diff --git a/configs/ae350_rv64_defconfig b/configs/ae350_rv64_defconfig index c058f76780..959258176a 100644 --- a/configs/ae350_rv64_defconfig +++ b/configs/ae350_rv64_defconfig @@ -14,6 +14,8 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xfffd70 CONFIG_FIT=y CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 diff --git a/configs/ae350_rv64_spl_defconfig b/configs/ae350_rv64_spl_defconfig index 9664baf705..0217027e6d 100644 --- a/configs/ae350_rv64_spl_defconfig +++ b/configs/ae350_rv64_spl_defconfig @@ -19,6 +19,8 @@ CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x00200000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x4000000 diff --git a/configs/ae350_rv64_spl_xip_defconfig b/configs/ae350_rv64_spl_xip_defconfig index b754888409..5a1fa8b6a1 100644 --- a/configs/ae350_rv64_spl_xip_defconfig +++ b/configs/ae350_rv64_spl_xip_defconfig @@ -20,6 +20,8 @@ CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x4000000 diff --git a/configs/ae350_rv64_xip_defconfig b/configs/ae350_rv64_xip_defconfig index 380ae096ee..c3fcbf3d28 100644 --- a/configs/ae350_rv64_xip_defconfig +++ b/configs/ae350_rv64_xip_defconfig @@ -15,6 +15,8 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xfffd70 CONFIG_FIT=y CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000
This patch fixes following warning for the riscv32 toolchain.
drivers/cache/cache-v5l2.c:122:16: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] 122 | regs = (struct l2cache *)dev_read_addr(dev); | ^
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- drivers/cache/cache-v5l2.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/cache/cache-v5l2.c b/drivers/cache/cache-v5l2.c index c6d3a8f893..eda07d3f29 100644 --- a/drivers/cache/cache-v5l2.c +++ b/drivers/cache/cache-v5l2.c @@ -119,7 +119,7 @@ static int v5l2_of_to_plat(struct udevice *dev) struct v5l2_plat *plat = dev_get_plat(dev); struct l2cache *regs;
- regs = (struct l2cache *)dev_read_addr(dev); + regs = (struct l2cache *)(uintptr_t)dev_read_addr(dev); plat->regs = regs;
plat->iprefetch = -EINVAL;
Yu Chien Peter Lin
