[U-Boot] Pull request v2: u-boot-blackfin
Hi Tom,
Please pull the following patches from u-boot-blackfin into your tree. In this second pull request: - CONFIG_CMD_SOFTSWITCH document is added to the README file. - The tools/patman folder is synced with upstream master. - 3 missing patches were sent to the mailing list.
Thanks
The following changes since commit bbd0f7e3ba66d288a2f146f1c7797801e04598ae:
Move FDT_RAMDISK_OVERHEAD from fdt.h to libfdt_env.h (2013-05-10 19:04:50 -0400)
git://git.denx.de/u-boot-blackfin.git master
for you to fetch changes up to da34aae5fba36c1f1989fdd41fffa723f300eaad:
bfin: Move gpio support for bf54x and bf60x into the generic driver folder. (2013-05-13 16:30:27 +0800)
---------------------------------------------------------------- Bob Liu (3): blackfin: reduce size of u-boot.ldr in bf548-ezkit default config. blackfin: add baudrate to bdinfo blackfin: bf609: add softswitch config command
Marek Vasut (1): blackfin: The buf variable in bfin_mac.c is not used and produces warning,
Mike Frysinger (1): Blackfin: adjust asm constraints with NMI workaround
Scott Jiang (3): bfin: Remove spi dma function in bf5xx. bfin: discard invalid data and clear RXS in bf5xx spi driver bf609: add SPI register base address
Sonic Zhang (14): blackfin: Change the member's type in dma structures. blackfin: limit the max memory dma peripheral transfer size to 4 bytes. blackfin: run core1 from L1 code sram start address in uboot init code on core 0 blackfin: Set correct early debug serial baudrate. blackfin: Correct early serial mess output in BYPASS boot mode. blackfin: bf609: implement soft switch blackfin: Fit u-boot image size into limited nor flash on blackfin. blackfin: Enable early print via the generic serial API. blackfin: Add memory virtual console to blackfin serial driver. blackfin: Uart divisor should be set after their values are generated. blackfin: Move blackfin watchdog driver out of the blackfin arch folder. blackfin: Move blackfin serial driver out of blackfin arch folder. blackfin: Add comments for watchdog event initialization. bfin: Move gpio support for bf54x and bf60x into the generic driver folder.
README | 1 + arch/blackfin/cpu/Makefile | 4 +- arch/blackfin/cpu/cpu.c | 32 +- arch/blackfin/cpu/gpio.c | 145 +------ arch/blackfin/cpu/initcode.c | 71 ++-- arch/blackfin/cpu/start.S | 29 +- arch/blackfin/include/asm/clock.h | 78 ++++ arch/blackfin/include/asm/dma.h | 24 +- arch/blackfin/include/asm/gpio.h | 62 +-- arch/blackfin/include/asm/mach-bf561/BF561_def.h | 2 + arch/blackfin/include/asm/mach-bf609/BF609_def.h | 5 + arch/blackfin/include/asm/portmux.h | 5 - arch/blackfin/{cpu => include/asm}/serial.h | 23 +- arch/blackfin/{cpu => include/asm}/serial1.h | 48 +-- arch/blackfin/{cpu => include/asm}/serial4.h | 27 +- arch/blackfin/include/asm/soft_switch.h | 18 + arch/blackfin/lib/board.c | 6 +- arch/blackfin/lib/clocks.c | 12 +- arch/blackfin/lib/string.c | 9 +- board/bf609-ezkit/soft_switch.c | 171 ++++++++ board/bf609-ezkit/soft_switch.h | 80 ++++ common/Makefile | 1 + common/cmd_softswitch.c | 41 ++ doc/README.watchdog | 3 + drivers/gpio/Makefile | 1 + drivers/gpio/adi_gpio2.c | 440 +++++++++++++++++++++ drivers/net/bfin_mac.c | 2 - drivers/serial/Makefile | 1 + .../cpu/serial.c => drivers/serial/serial_bfin.c | 110 ++++-- drivers/spi/bfin_spi.c | 105 +---- drivers/watchdog/Makefile | 1 + .../cpu/watchdog.c => drivers/watchdog/bfin_wdt.c | 7 +- include/configs/bf527-ezkit.h | 12 +- include/configs/bf537-stamp.h | 10 +- include/configs/bf548-ezkit.h | 25 +- include/configs/bf561-ezkit.h | 5 + include/configs/bf609-ezkit.h | 10 + include/configs/bfin_adi_common.h | 14 +- include/watchdog.h | 3 +- 39 files changed, 1164 insertions(+), 479 deletions(-) create mode 100644 arch/blackfin/include/asm/clock.h rename arch/blackfin/{cpu => include/asm}/serial.h (82%) rename arch/blackfin/{cpu => include/asm}/serial1.h (94%) rename arch/blackfin/{cpu => include/asm}/serial4.h (86%) create mode 100644 arch/blackfin/include/asm/soft_switch.h create mode 100644 board/bf609-ezkit/soft_switch.c create mode 100644 board/bf609-ezkit/soft_switch.h create mode 100644 common/cmd_softswitch.c create mode 100644 drivers/gpio/adi_gpio2.c rename arch/blackfin/cpu/serial.c => drivers/serial/serial_bfin.c (79%) rename arch/blackfin/cpu/watchdog.c => drivers/watchdog/bfin_wdt.c (64%)
On Tue, May 14, 2013 at 02:20:46PM +0800, Sonic Zhang wrote:
Hi Tom,
Thanks
Sonic Zhang
