[U-Boot] [PATCH v2] mmc: uniphier-sd: Fix a compile error relevant to unused-function
During disabled MMC_HS200_SUPPORT, some functions don't use anywhere.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- Chnagelog on V2 - Remove functions in uniphier-sd.h
drivers/mmc/uniphier-sd-rcar.c | 4 ++++ drivers/mmc/uniphier-sd.h | 9 --------- 2 files changed, 4 insertions(+), 9 deletions(-)
diff --git a/drivers/mmc/uniphier-sd-rcar.c b/drivers/mmc/uniphier-sd-rcar.c index 8baa2a9b46..894decd04d 100644 --- a/drivers/mmc/uniphier-sd-rcar.c +++ b/drivers/mmc/uniphier-sd-rcar.c @@ -80,6 +80,7 @@ static unsigned int uniphier_sd_init_tuning(struct uniphier_sd_priv *priv) SH_MOBILE_SDHI_SCC_DTCNTL_TAPNUM_MASK; }
+#if CONFIG_IS_ENABLED(MMC_HS200_SUPPORT) void rcar_gen3_sd_reset_tuning(struct uniphier_sd_priv *priv) { u32 reg; @@ -105,6 +106,7 @@ void rcar_gen3_sd_reset_tuning(struct uniphier_sd_priv *priv) reg &= ~SH_MOBILE_SDHI_SCC_RVSCNTL_RVSEN; uniphier_sd_writel(priv, reg, SH_MOBILE_SDHI_SCC_RVSCNTL); } +#endif
static void uniphier_sd_prepare_tuning(struct uniphier_sd_priv *priv, unsigned long tap) @@ -223,6 +225,7 @@ static int uniphier_sd_select_tuning(struct uniphier_sd_priv *priv, return 0; }
+#if CONFIG_IS_ENABLED(MMC_HS200_SUPPORT) int rcar_gen3_sd_execute_tuning(struct udevice *dev, uint opcode) { struct uniphier_sd_priv *priv = dev_get_priv(dev); @@ -286,3 +289,4 @@ out:
return ret; } +#endif diff --git a/drivers/mmc/uniphier-sd.h b/drivers/mmc/uniphier-sd.h index 38d104296f..6192e5973c 100644 --- a/drivers/mmc/uniphier-sd.h +++ b/drivers/mmc/uniphier-sd.h @@ -141,15 +141,6 @@ void uniphier_sd_writel(struct uniphier_sd_priv *priv, #if CONFIG_IS_ENABLED(MMC_RENESAS_TUNING) void rcar_gen3_sd_reset_tuning(struct uniphier_sd_priv *priv); int rcar_gen3_sd_execute_tuning(struct udevice *dev, uint opcode); -#else -static void rcar_gen3_sd_reset_tuning(struct uniphier_sd_priv *priv) -{ -} - -static int rcar_gen3_sd_execute_tuning(struct udevice *dev, uint opcode) -{ - return -EINVAL; -} #endif
#endif /* __MMC_UNIPHIER_SD_H__ */
Jaehoon Chung
