[U-Boot] [PATCH v2] at91sam9x5ek: Pass serial and revision tags to Linux
This code is small snippet from patch ftp://ftp.linux4sam.org/pub/uboot/u-boot-v2010.06/u-boot-5series_1.0.patch
Bug:- For board at91sam9x5ek, U-boot doesn't pass serial and revision tags to Linux kernel, hence kernel fails to identify correct revision and assumes as rev-A, resulting in failing to detect NAND device.
This patch enables u-boot to pass serial and revision tags to Linux kernel, which helps Linux to detect NAND device.
Signed-off-by: Julius Hemanth juliushemanth@gmail.com --- Changes for v2: - access GPBR using c structure - removed tailing 1 for #define - s/Miscelaneous/Miscellaneous - s/initialisations/initializations
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 33 ++++++++++++++++++++++++++++++- include/configs/at91sam9x5ek.h | 5 ++++ 2 files changed, 37 insertions(+), 1 deletions(-)
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 8773e6f..c05bdb7 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -27,6 +27,7 @@ #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> +#include <asm/arch/at91_gpbr.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> @@ -48,8 +49,34 @@ DECLARE_GLOBAL_DATA_PTR;
/* ------------------------------------------------------------------------- */ /* - * Miscelaneous platform dependent initialisations + * Miscellaneous platform dependent initializations */ + +#ifdef CONFIG_LOAD_ONE_WIRE_INFO +static u32 system_rev; +static u32 system_serial_low; + +u32 get_board_rev(void) +{ + return system_rev; +} + +void get_board_serial(struct tag_serialnr *serialnr) +{ + serialnr->high = 0; /* Not used */ + serialnr->low = system_serial_low; +} + +void load_1wire_info(void) +{ + at91_gpbr_t *gpbr = (at91_gpbr_t *) ATMEL_BASE_GPBR; + + /* serial is in GPBR #2 and revision is in GPBR #3 */ + system_serial_low = readl(gpbr->reg[2]); + system_rev = readl(gpbr->reg[3]); +} +#endif + #ifdef CONFIG_CMD_NAND static void at91sam9x5ek_nand_hw_init(void) { @@ -282,6 +309,10 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
+#ifdef CONFIG_LOAD_ONE_WIRE_INFO + load_1wire_info(); +#endif + #ifdef CONFIG_CMD_NAND at91sam9x5ek_nand_hw_init(); #endif diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index ee6e3fc..995e43b 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -38,6 +38,11 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG + +#define CONFIG_LOAD_ONE_WIRE_INFO +#define CONFIG_REVISION_TAG +#define CONFIG_SERIAL_TAG + #define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO -- 1.7.0.4
Hi Julius,
Bug:-
I think this should not report bug, it should for compatible with old kernel (only for Linux 2.6.39 released on www.at91.com/linux4sam).
This patch can not be applied based on u-boot master branch or else on u-boot-atmel master branch.
Please re-generate this patch based on u-boot master branch or u-boot-atmel master branch.
- Miscelaneous platform dependent initialisations
- Miscellaneous platform dependent initializations
return system_rev;
This is wrong which will cause u-boot hang up. It should be:
system_serial_low = readl(&gpbr->reg[2]); system_rev = readl(&gpbr->reg[3]);
Best Regards, Bo Shen
Thanks Bo, will send updated patch with all corrections.
Regards, Julius Hemanth P On May 9, 2013 8:49 AM, "Bo Shen" voice.shen@atmel.com wrote:
Hi Julius,
This code is small snippet from patch ftp://ftp.linux4sam.org/pub/**uboot/u-boot-v2010.06/u-boot-** 5series_1.0.patchftp://ftp.linux4sam.org/pub/uboot/u-boot-v2010.06/u-boot-5series_1.0.patch
Bug:-
Changes for v2: - access GPBR using c structure - removed tailing 1 for #define - s/Miscelaneous/Miscellaneous - s/initialisations/**initializations
board/atmel/at91sam9x5ek/**at91sam9x5ek.c | 33 ++++++++++++++++++++++++++++++**- include/configs/at91sam9x5ek.h | 5 ++++ 2 files changed, 37 insertions(+), 1 deletions(-)
diff --git a/board/atmel/at91sam9x5ek/**at91sam9x5ek.c
b/board/atmel/at91sam9x5ek/**at91sam9x5ek.c index 8773e6f..c05bdb7 100644 --- a/board/atmel/at91sam9x5ek/**at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/**at91sam9x5ek.c @@ -27,6 +27,7 @@ #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> +#include <asm/arch/at91_gpbr.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> @@ -48,8 +49,34 @@ DECLARE_GLOBAL_DATA_PTR;
return system_rev;
Bo Shen
Julius Hemanth P
