[U-Boot] [PATCH 0/2] mkimage: Refactor and clean up 32-bit crcs
As a step towards adding an image signer for socfpga, this set of patches breaks out the common crc code that is used in both pblimage and mxsimage.
Not that this is NOT the same algorithm as the crc generated by zlib.
The new function has been named pbl_crc32.
Charles Manning (2): mkimage : Split out and clean pbl_crc32 for use by other image types mkimage: Refactor mxsimage to use common crc32 code
tools/Makefile | 1 + tools/mxsimage.c | 28 +++------------------------ tools/pbl_crc32.c | 56 +++++++++++++++++++++++++++++++++++++++++++++++++++++ tools/pbl_crc32.h | 13 +++++++++++++ tools/pblimage.c | 47 +------------------------------------------- 5 files changed, 74 insertions(+), 71 deletions(-) create mode 100644 tools/pbl_crc32.c create mode 100644 tools/pbl_crc32.h
The crc32 used by pblimgae is NOT the same as zlib crc32.
The pbl_crc32 is useful for other purposes in mkimage so split it out.
While we are about it, clean up redundant and confusing code.
Signed-off-by: Charles Manning cdhmanning@gmail.com --- tools/Makefile | 1 + tools/pbl_crc32.c | 56 +++++++++++++++++++++++++++++++++++++++++++++++++++++ tools/pbl_crc32.h | 13 +++++++++++++ tools/pblimage.c | 47 +------------------------------------------- 4 files changed, 71 insertions(+), 46 deletions(-) create mode 100644 tools/pbl_crc32.c create mode 100644 tools/pbl_crc32.h
diff --git a/tools/Makefile b/tools/Makefile index c34df4f..2f30749 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -86,6 +86,7 @@ dumpimage-mkimage-objs := aisimage.o \ omapimage.o \ os_support.o \ pblimage.o \ + pbl_crc32.o \ sha1.o \ sha256.o \ ublimage.o \ diff --git a/tools/pbl_crc32.c b/tools/pbl_crc32.c new file mode 100644 index 0000000..6e6735a --- /dev/null +++ b/tools/pbl_crc32.c @@ -0,0 +1,56 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * Cleaned up and refactored by Charles Manning. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include "pblimage.h" + +static uint32_t crc_table[256]; +static int crc_table_valid; + +static void make_crc_table(void) +{ + uint32_t mask; + int i, j; + uint32_t poly; /* polynomial exclusive-or pattern */ + + if (crc_table_valid) + return; + + /* + * the polynomial used by PBL is 1 + x1 + x2 + x4 + x5 + x7 + x8 + x10 + * + x11 + x12 + x16 + x22 + x23 + x26 + x32. + */ + poly = 0x04c11db7; + + for (i = 0; i < 256; i++) { + mask = i << 24; + for (j = 0; j < 8; j++) { + if (mask & 0x80000000) + mask = (mask << 1) ^ poly; + else + mask <<= 1; + } + crc_table[i] = mask; + } + + crc_table_valid = 1; +} + +uint32_t pbl_crc32(uint32_t in_crc, const char *buf, uint32_t len) +{ + uint32_t crc32_val; + int i; + + make_crc_table(); + + crc32_val = ~in_crc; + + for (i = 0; i < len; i++) + crc32_val = (crc32_val << 8) ^ + crc_table[(crc32_val >> 24) ^ (*buf++ & 0xff)]; + + return crc32_val; +} diff --git a/tools/pbl_crc32.h b/tools/pbl_crc32.h new file mode 100644 index 0000000..4ab55ee --- /dev/null +++ b/tools/pbl_crc32.h @@ -0,0 +1,13 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef PBLCRC32_H +#define PBLCRC32_H + +#include <stdint.h> +uint32_t pbl_crc32(uint32_t in_crc, const char *buf, uint32_t len); + +#endif diff --git a/tools/pblimage.c b/tools/pblimage.c index ef3d7f6..6e6e801 100644 --- a/tools/pblimage.c +++ b/tools/pblimage.c @@ -6,6 +6,7 @@ #include "imagetool.h" #include <image.h> #include "pblimage.h" +#include "pbl_crc32.h"
/* * Initialize to an invalid value. @@ -137,52 +138,6 @@ static void pbl_parser(char *name) fclose(fd); }
-static uint32_t crc_table[256]; - -static void make_crc_table(void) -{ - uint32_t mask; - int i, j; - uint32_t poly; /* polynomial exclusive-or pattern */ - - /* - * the polynomial used by PBL is 1 + x1 + x2 + x4 + x5 + x7 + x8 + x10 - * + x11 + x12 + x16 + x22 + x23 + x26 + x32. - */ - poly = 0x04c11db7; - - for (i = 0; i < 256; i++) { - mask = i << 24; - for (j = 0; j < 8; j++) { - if (mask & 0x80000000) - mask = (mask << 1) ^ poly; - else - mask <<= 1; - } - crc_table[i] = mask; - } -} - -unsigned long pbl_crc32(unsigned long crc, const char *buf, uint32_t len) -{ - uint32_t crc32_val = 0xffffffff; - uint32_t xor = 0x0; - int i; - - make_crc_table(); - - for (i = 0; i < len; i++) - crc32_val = (crc32_val << 8) ^ - crc_table[(crc32_val >> 24) ^ (*buf++ & 0xff)]; - - crc32_val = crc32_val ^ xor; - if (crc32_val < 0) { - crc32_val += 0xffffffff; - crc32_val += 1; - } - return crc32_val; -} - static uint32_t reverse_byte(uint32_t val) { uint32_t temp;
Hi Charles,
- Copyright 2012 Freescale Semiconductor, Inc.
- Cleaned up and refactored by Charles Manning.
- uint32_t mask;
- int i, j;
- if (crc_table_valid)
return;
mask = i << 24;
else
mask <<= 1;
- crc_table_valid = 1;
- uint32_t crc32_val;
- int i;
- make_crc_table();
- crc32_val = ~in_crc;
- return crc32_val;
- Initialize to an invalid value.
- uint32_t mask;
- int i, j;
mask = i << 24;
else
mask <<= 1;
- int i;
- make_crc_table();
crc32_val += 1;
- return crc32_val;
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
mxsimage uses the same crc32 function as pblimage.
Signed-off-by: Charles Manning cdhmanning@gmail.com --- tools/mxsimage.c | 28 +++------------------------- 1 file changed, 3 insertions(+), 25 deletions(-)
diff --git a/tools/mxsimage.c b/tools/mxsimage.c index 045b35a..0c4348c 100644 --- a/tools/mxsimage.c +++ b/tools/mxsimage.c @@ -19,6 +19,7 @@
#include "imagetool.h" #include "mxsimage.h" +#include "pbl_crc32.h" #include <image.h>
@@ -231,29 +232,6 @@ static int sb_aes_reinit(struct sb_image_ctx *ictx, int enc) }
/* - * CRC32 - */ -static uint32_t crc32(uint8_t *data, uint32_t len) -{ - const uint32_t poly = 0x04c11db7; - uint32_t crc32 = 0xffffffff; - unsigned int byte, bit; - - for (byte = 0; byte < len; byte++) { - crc32 ^= data[byte] << 24; - - for (bit = 8; bit > 0; bit--) { - if (crc32 & (1UL << 31)) - crc32 = (crc32 << 1) ^ poly; - else - crc32 = (crc32 << 1); - } - } - - return crc32; -} - -/* * Debug */ static void soprintf(struct sb_image_ctx *ictx, const char *fmt, ...) @@ -998,7 +976,7 @@ static int sb_build_command_load(struct sb_image_ctx *ictx,
ccmd->load.address = dest; ccmd->load.count = cctx->length; - ccmd->load.crc32 = crc32(cctx->data, cctx->length); + ccmd->load.crc32 = pbl_crc32(0, cctx->data, cctx->length);
cctx->size = sizeof(*ccmd) + cctx->length;
@@ -1834,7 +1812,7 @@ static int sb_verify_command(struct sb_image_ctx *ictx, EVP_DigestUpdate(&ictx->md_ctx, cctx->data, asize); sb_aes_crypt(ictx, cctx->data, cctx->data, asize);
- if (ccmd->load.crc32 != crc32(cctx->data, asize)) { + if (ccmd->load.crc32 != pbl_crc32(0, cctx->data, asize)) { fprintf(stderr, "ERR: SB LOAD command payload CRC32 invalid!\n"); return -EINVAL;
Hi Charles,
- CRC32
else
- return crc32;
- Debug
Good idea to factorize these functions, thanks !
Signed-off-by: Charles Manning cdhmanning@gmail.com Acked-by: Stefano Babic sbabic@denx.de
This introduces warnings: tools/mxsimage.c: In function ‘sb_build_command_load’: tools/mxsimage.c:979:2: warning: pointer targets in passing argument 2 of ‘pbl_crc32’ differ in signedness [-Wpointer-sign] tools/pbl_crc32.h:11:10: note: expected ‘const char *’ but argument is of type ‘uint8_t *’ u-boot/tools/mxsimage.c: In function ‘sb_verify_command’: tools/mxsimage.c:1815:3: warning: pointer targets in passing argument 2 of ‘pbl_crc32’ differ in signedness [-Wpointer-sign] tools/pbl_crc32.h:11:10: note: expected ‘const char *’ but argument is of type ‘uint8_t *’
Thanks for the feedback.
Will it be acceptable to do the following:
*Change the called function from uint8_t * to const uint8_t *Cast the const char * pointer to const uint8_t *.
Thanks
Charles
Sounds right.
This patch set just changes patch 1/2: casting pointers in mxsimage.c
Charles Manning (2): mkimage : Split out and clean pbl_crc32 for use by other image types tools: Refactor mxsimage to use pbl_crc32
tools/Makefile | 1 + tools/mxsimage.c | 32 +++++++----------------------- tools/pbl_crc32.c | 56 +++++++++++++++++++++++++++++++++++++++++++++++++++++ tools/pbl_crc32.h | 13 +++++++++++++ tools/pblimage.c | 47 +------------------------------------------- 5 files changed, 78 insertions(+), 71 deletions(-) create mode 100644 tools/pbl_crc32.c create mode 100644 tools/pbl_crc32.h
Unchanged from V1.
Both pblimage and mxsimage use the same crc algorithm, so refactor.
Signed-off-by: Charles Manning cdhmanning@gmail.com --- Changes for V2: - Cast buffer pointers when calling pbl_crc32().
tools/mxsimage.c | 32 +++++++------------------------- 1 file changed, 7 insertions(+), 25 deletions(-)
diff --git a/tools/mxsimage.c b/tools/mxsimage.c index 045b35a..81c7f2d 100644 --- a/tools/mxsimage.c +++ b/tools/mxsimage.c @@ -19,6 +19,7 @@
/* - * CRC32 - */ -static uint32_t crc32(uint8_t *data, uint32_t len) -{ - const uint32_t poly = 0x04c11db7; - uint32_t crc32 = 0xffffffff; - unsigned int byte, bit; - - for (byte = 0; byte < len; byte++) { - crc32 ^= data[byte] << 24; - - for (bit = 8; bit > 0; bit--) { - if (crc32 & (1UL << 31)) - crc32 = (crc32 << 1) ^ poly; - else - crc32 = (crc32 << 1); - } - } - - return crc32; -} - -/* * Debug */ static void soprintf(struct sb_image_ctx *ictx, const char *fmt, ...) @@ -998,7 +976,9 @@ static int sb_build_command_load(struct sb_image_ctx *ictx,
ccmd->load.address = dest; ccmd->load.count = cctx->length; - ccmd->load.crc32 = crc32(cctx->data, cctx->length); + ccmd->load.crc32 = pbl_crc32(0, + (const char *)cctx->data, + cctx->length);
@@ -1834,7 +1814,9 @@ static int sb_verify_command(struct sb_image_ctx *ictx, EVP_DigestUpdate(&ictx->md_ctx, cctx->data, asize); sb_aes_crypt(ictx, cctx->data, cctx->data, asize);
- if (ccmd->load.crc32 != crc32(cctx->data, asize)) { + if (ccmd->load.crc32 != pbl_crc32(0, + (const char *)cctx->data, + asize)) { fprintf(stderr, "ERR: SB LOAD command payload CRC32 invalid!\n"); return -EINVAL;
Charles Manning
Stefano Babic
