[U-Boot] [PATCH v2] arm: socfpga: set skew settings for ethernet phy
Set the PHY skew settings for the ethernet phy on the SOCFPGA Cyclone5 hardware.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com Cc: Vince Bridgers vbridger@opensource.altera.com Cc: Pavel Machek pavel@denx.de Cc: Marek Vasut marex@denx.de Cc: Tom Rini trini@ti.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Wolfgang Denk wd@denx.de --- v2: Added comments on why it is necessary for setting the skew values. --- board/altera/socfpga/socfpga_cyclone5.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/board/altera/socfpga/socfpga_cyclone5.c b/board/altera/socfpga/socfpga_cyclone5.c index 0f81d89..543a143 100644 --- a/board/altera/socfpga/socfpga_cyclone5.c +++ b/board/altera/socfpga/socfpga_cyclone5.c @@ -8,7 +8,9 @@ #include <asm/arch/reset_manager.h> #include <asm/io.h>
+#include <micrel.h> #include <netdev.h> +#include <phy.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -39,3 +41,17 @@ int board_init(void)
return 0; } + +int board_phy_config(struct phy_device *phydev) +{ + /* + * These skew settings for the KSZ9021 ethernet phy is required for ethernet + * to work reliably on most flavors of cyclone5 boards. + */ + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, + 0x0); + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, + 0x0); + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, + 0xf0f0); +}
Is it to need similar settings for all ksz9021 phys? Should this go to drivers/ as I suggested with a patch?
Thanks, Pavel
return 0; }
- ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW,
0x0);
- ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW,
0x0);
- ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_CLOCK_SKEW,
0xf0f0);
This is board specific, but with the driver model, this should be moved into the PHY driver and the values should be passed via platform data or DT.
I will apply this now, since it fixes real issue.
Best regards, Marek Vasut
Hmm, could you apply the patch I posted, instead? It has configuration in socfpga_config.h -- "platform data".
Pavel
Hi!
The patch you provided (if we're referring to the same patch, Message-ID: 20141113120956.GB30779@amd) breaks every board which uses the Micrel PHY, doesn't it ? The problem for all other boards would be the new CONFIG_* options which are added into the Micrel driver by that patch. Furthermore, the patch doesn't even apply, it was decided that the patch was an RFC, wasn't it ? Please correct me if I'm wrong.
The way forward here would be for you to prepare a patch for the Micrel PHY driver, submit that one (make sure to CC Joe, the network custodian) and in the next step clean up the writes into PHY configuration from both the SoCFPGA CV and from Nitrogen 6x support (I recall I saw the same thing done for that board).
Oh, and btw., the new CONFIG_* options should be documented somewhere, so please keep that in mind. Otherwise, the amount of various CONFIG_* options become an unmanagable mess.
Thanks!
Hi!
The purpose of that mail was to show that there's better way, so that someone (you) would not apply bandaid when something close to real fix is available.
I overlooked the "breaks compilation" part, but I'm sure it could have been solved with strategicaly placed #ifdef. Notice original patch submission in
From pavel@denx.de Sat Oct 25 13:27:52 2014
Date: Sat, 25 Oct 2014 13:27:52 +0200 From: Pavel Machek pavel@denx.de Subject: [patch] net: micrel: configure skew values for Message-ID: 20141025112752.GA19599@amd
it is cleaner then 20141113120956.GB30779@amd version. I don't think I received any reply there.
But the patch you have just merged would interfere with my approach, and makes it unneccessary, so I'll let you solve it.
Best regards, Pavel
Hi!
I had to pick from two options -- apply a patch which solves a real problem now and which follows approach already implemented for a different board in mainline -- or wait until an RFC patch is done discussing and makes it into mainline.
I decided to solve a real problem now and in case a proper fix/cleanup arrives afterward, I will only be happy about that.
From pavel@denx.de Sat Oct 25 13:27:52 2014 Date: Sat, 25 Oct 2014 13:27:52 +0200 From: Pavel Machek pavel@denx.de Subject: [patch] net: micrel: configure skew values for Message-ID: 20141025112752.GA19599@amd
Sorry, I missed the new version. I'll comment on it separatelly.
In fact, the Micrel PHY patch changes only the Micrel driver. This patch changes only the SoCFPGA CV board. They are two completely orthogonal patches.
The Micrel PHY patch can just be followed by a cleanup patch which removes the explicitly PHY setup function from both the MX6 Nitrogen 6x and SoCFPGA boards. I don't see any problem with such cleanup, do you ?
On Thursday, November 13, 2014 at 06:23:41 PM, dinguyen@opensource.altera.com wrote:
Applied, thanks!
dinguyenï¼ opensource.altera.com
Pavel Machek
