[U-Boot] [PATCH] env_mmc: Allow SPL to use any MMC device to load/save the environment
SPL has been restricted to use only dev 0 based on the assumption that only one MMC device is registered. This is not always the case and many platforms now register several devices as expected by the spl mmc boot code For those platform SPL_ENV_SUPPORT is broken if dev is forced to 0.
A word of warning: this commit may break SPL_ENV_SUPPORT on platforms that do not register the same MMC controllers in SPL and in u-boot (mostly iMX6 based platforms). Fortunately none of those activate SPL_ENV_SUPPORT in their default configuration.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com --- common/env_mmc.c | 15 --------------- 1 file changed, 15 deletions(-)
diff --git a/common/env_mmc.c b/common/env_mmc.c index 16f6a17..a5d14d4 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -82,10 +82,6 @@ static int mmc_set_env_part(struct mmc *mmc) int dev = mmc_get_env_dev(); int ret = 0;
-#ifdef CONFIG_SPL_BUILD - dev = 0; -#endif - env_mmc_orig_hwpart = mmc_get_blk_desc(mmc)->hwpart; ret = blk_select_hwpart_devnum(IF_TYPE_MMC, dev, part); if (ret) @@ -116,9 +112,6 @@ static void fini_mmc_for_env(struct mmc *mmc) #ifdef CONFIG_SYS_MMC_ENV_PART int dev = mmc_get_env_dev();
-#ifdef CONFIG_SPL_BUILD - dev = 0; -#endif blk_select_hwpart_devnum(IF_TYPE_MMC, dev, env_mmc_orig_hwpart); #endif } @@ -223,10 +216,6 @@ void env_relocate_spec(void) ALLOC_CACHE_ALIGN_BUFFER(env_t, tmp_env1, 1); ALLOC_CACHE_ALIGN_BUFFER(env_t, tmp_env2, 1);
-#ifdef CONFIG_SPL_BUILD - dev = 0; -#endif - mmc = find_mmc_device(dev);
errmsg = init_mmc_for_env(mmc); @@ -306,10 +295,6 @@ void env_relocate_spec(void) int dev = mmc_get_env_dev(); const char *errmsg;
Hi Tom,
Have you had a chance to look at the patch below?
Jean-Jacques
- dev = 0;
-#endif
- dev = 0;
- dev = 0;
-#endif
- dev = 0;
-#endif
On Tue, Feb 14, 2017 at 02:16:13PM +0100, Jean-Jacques Hiblot wrote:
Hi Tom,
It looks fine but was too close to the release window (given the potential impact) to merge. Thanks!
Jean-Jacques
diff --git a/common/env_mmc.c b/common/env_mmc.c index 16f6a17..a5d14d4 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -82,10 +82,6 @@ static int mmc_set_env_part(struct mmc *mmc) int dev = mmc_get_env_dev(); int ret = 0; -#ifdef CONFIG_SPL_BUILD
- dev = 0;
-#endif
@@ -116,9 +112,6 @@ static void fini_mmc_for_env(struct mmc *mmc) #ifdef CONFIG_SYS_MMC_ENV_PART int dev = mmc_get_env_dev(); -#ifdef CONFIG_SPL_BUILD
- dev = 0;
-#endif blk_select_hwpart_devnum(IF_TYPE_MMC, dev, env_mmc_orig_hwpart); #endif } @@ -223,10 +216,6 @@ void env_relocate_spec(void) ALLOC_CACHE_ALIGN_BUFFER(env_t, tmp_env1, 1); ALLOC_CACHE_ALIGN_BUFFER(env_t, tmp_env2, 1); -#ifdef CONFIG_SPL_BUILD
- dev = 0;
-#endif
- mmc = find_mmc_device(dev); errmsg = init_mmc_for_env(mmc);
@@ -306,10 +295,6 @@ void env_relocate_spec(void) int dev = mmc_get_env_dev(); const char *errmsg; -#ifdef CONFIG_SPL_BUILD
- dev = 0;
-#endif
Hi Tom,
Ok Thank you for the feedback.
Jean-Jacques
- dev = 0;
-#endif
- dev = 0;
- dev = 0;
-#endif
- dev = 0;
-#endif
Hi Tom,
Hi Tom,
Don't want to pester you. I'm just checking on the status regarding this patch. Without it the environment is not accessible in the SPL for the omap platforms and we rely on the environment for the falcon boot.
Jean-Jacques
Jean-Jacques
- dev = 0;
-#endif
- dev = 0;
- dev = 0;
-#endif
- dev = 0;
-#endif
Jean-Jacques Hiblot
