[U-Boot-Users] [T-Engine] UBoot configuration for T-Engine/SH7727 MS7727CP02 DevKit
Dear All,
I would like to port a Uboot loader on T-Engine/SH7727 MS7727CP02 DevKit. Here is the configuration of this board
Renesas Technology SH7727(SH3-DSP, internal clock 96MHz / external clock 48MHz) Flash Memory: 8MB SDRAM: 32MB
Memory map of overall system is shown as below.
0x00000000 +-------------------------------+-------- | User area (P0)| 0x10000000 +-------------------------------+ | (Unused) (P0)| Enabled as a virtual memory 0x40000000 +-------------------------------+ | System / Common area(1) (P0)| 0x80000000 +-------------------------------+-------- | Physical memory area (P1) | | (Cache On) | 0xa0000000 +-------------------------------+ | Physical memory area (P2) | | (Cache Off) | 0xc0000000 +-------------------------------+-------- | System/Common area(2) (P3) | Enabled as a virtual memory 0xe0000000 +-------------------------------+-------- | I/O area (P4) | 0xffffffff +-------------------------------+
Physical memory area (P1 area) memory map is shown as below.
0x80000000 +-------------------------------+-------- | ROM area(8MB) | Area 0 | (Unused area included) | 0x84000000 +-------------------------------+-------- | I/O area | Area 1-2 | (Not used as a general rule)| 0x8c000000 +-------------------------------+-------- | RAM area(64MB) | Area 3 0x90000000 +-------------------------------+-------- | I/O area | Area 4-7 | (Not used as a general rule)| 0xa0000000 +-------------------------------+--------
Here is configuration of UBoot \board\ms7727se\config.mk : TEXT_BASE = 0x8DFC0000 \board\ms7727se\u-boot.lds
OUTPUT_FORMAT("elf32-sh-tkernel", "elf32-sh-tkernel", "elf32-sh-tkernel") SECTIONS { . = 0x8C000000 + (32*1024*1024) - (256*1024);
\include\configs\ms7727se.h /* MEMORY */ #define MS7720SE_SDRAM_BASE 0x8C000000 #define MS7720SE_FLASH_BASE_1 0x80000000 //0xA0000000 #define MS7720SE_FLASH_BANK_SIZE (8 * 1024 * 1024)
#define CFG_MEMTEST_START MS7720SE_SDRAM_BASE #define CFG_MEMTEST_END (CFG_MEMTEST_START + (60 * 1024 * 1024))
#define CFG_SDRAM_BASE MS7720SE_SDRAM_BASE #define CFG_SDRAM_SIZE (32 * 1024 * 1024)
#define CFG_LOAD_ADDR (CFG_SDRAM_BASE + 32 * 1024 * 1024) #define CFG_MONITOR_BASE MS7720SE_FLASH_BASE_1 #define CFG_MONITOR_LEN (128 * 1024) #define CFG_MALLOC_LEN (256 * 1024) #define CFG_GBL_DATA_SIZE 256 #define CFG_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ #define CFG_FLASH_CFI #define CFG_FLASH_CFI_DRIVER #undef CFG_FLASH_QUIET_TEST #define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
#define CFG_FLASH_BASE MS7720SE_FLASH_BASE_1
Would you please help me have a look this setting? 1. Is this setting correct ? I am confusing about TEXT_BASE with CFG_LOAD_ADDR. Here is definition - CFG_FLASH_BASE: Physical start address of Flash memory.
- CFG_MONITOR_BASE: Physical start address of boot monitor code (set by make config files to be same as the text base address (TEXT_BASE) used when linking) - same as CFG_FLASH_BASE when booting from flash.
If I am wrong, please tell me how to correct these setting.
2. "ld" T-Engine toolchain only supports elf32-sh-tkernel target, but reference implementation (example) tell "elf32-sh-linux" is expected target. Is the setting correct?
\board\ms7727se\u-boot.lds Original : OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -> My changes OUTPUT_FORMAT("elf32-sh-tkernel", "elf32-sh-tkernel", "elf32-sh-tkernel")
I am newbie in embedded system. I am appreciating your helping. Thank you a lot.
Hi, thaoth .
2008/8/7 thaoth thaoth@cybersoft-vn.com:
- Is this setting correct ? I am confusing about TEXT_BASE with
Yes, you are right. If you use *make config_xx ; make* , you can make an u-boot.srec file starting from the memory (May be address is 0x8DFC000).
I think that you know it, T-engine has a monitor program. The T-engine user uses this monitor program and writes in it at a flash bulb. However, as for this program, only a SREC file is usable.
If you want make SREC file to Flash, you need to use objcopy command. shX-linux-objcopy -Ibinary -Osrec u-boot.bin u-boot.flash.srec Please check doc/README.sh.
- "ld" T-Engine toolchain only supports elf32-sh-tkernel target, but
Hmmm, I have not used the tool-chain for t-kernel. However, as for me, there is an acquaintance using t-kernel. I can ask him. And, I will reply about this matter.
I think that I want to support t-kernel and other OS to U-boot-sh. I cooperate with you.
Best regards, Nobuhiro
This is a good instruction, now I could flash the srec image to Flash Memory by this command.
srec file was created by below command cannot flash into board. # sh3-linux-objcopy --gap-fill=0xff -O srec u-boot u-boot.srec # sh3-linux-objcopy --gap-fill=0xff -O binary u-boot u-boot.bin
Here are file sizes u-boot.flash.srec 213040 u-boot.srec 222322 u-boot.bin 74080
I didn't see it. there is only doc/README.sha1
This is a T-Monitor program can work as boot loader application. But I didn't use it for flashing memory ROM. I would like to use UBoot as a boot loader replacing this application (T-Monitor).
I worked with Downloader utility of Debug board (T-Engine/SH7727 DevKit) ====================================================
T-Engine(MS7727CP01) DownLoader Ver1.8L
---------------------------------------------------- SH7727 Flash Memory Change Value! Flash Memory data copy to RAM Please Send A S-format Record
Start Addrs = 00000000 End Addrs = 0001215F
Transfer complete Flash chip erase: complete Program :complete Flash write complete Ready>RESTART
I have questions about uboot below: 1. Reallocating address of u-boot in booting process. At the booting process, the address 0x80000000 is executed. This is memory mapping address of Flash memory. and executable code of T-Monitor will be executed.
(1) ROM area memory map In ROM, 8M byte(0x80000000-0x807FFFFF)of area is implemented. Memory map of ROM area is shown as below.
0x80000000 +-------------------------------+ | T-Monitor code | |- - - - - - - - - - - - - - - -| | | 0x80010000 +-------------------------------+ | ROM Information | 0x80010080 +-------------------------------+ |System configuration info | | (SYSCONF / DEVCONF) | |- - - - - - - - - - - - - - - -| | | 0x80020000 +-------------------------------+ | T-Kernel code | | | +-------------------------------+ | | | User area | | | 0x80800000 +-------------------------------+
UBoot code will reflash into Flash memory at 0x80000000 address. This is Flash Memory just readonly. Will UBoot reallocating (loading) binary code into SDRAM at TEXT_BASE address. In T-Engine/Sh7727, this address will be 0x8DFC0000 (Beginning address of SDRAM is 0x8C000000). Does UBoot automatically reload this code into TEXT_BASE address?
Because Boot starting address will begin at Flash memory (0x80000000) and T-Monitor (current boot loader) worked at this address. I don't know how about UBoot. Does it reload Uboot into SDRAM (TEXT BASE) and run?
2. This is a great site for working SH with Linux. http://www.superh-linux.org/platforms/index.html Based on Reference board board/ms7720se, I changed the UBoot configuration for T-Engine/SH7727 MS7727CP02 Kit.
Many thanks to authors for your efforts # Nobuhiro Iwamatsu iwamatsu@nigauri.org # Yoshihiro Shimoda shimoda.yoshihiro@renesas.com
I got a toolchain at http://www.superh-linux.org/archive/bsp/sh7721_se/toolchain_sh3_gcc4.2.tar.g... It supported "elf32-sh-linux" target. And I also got toolchain from T-Engine forum and it support "elf32-sh-tkernel" target.
I don't know UBoot built with toolchain from http://www.superh-linux.org can work on T-Engine platform or not?
3. Debugging tool for U-Boot development. Please tell me how to debug UBoot can work on board. Could you tell me debugger tool for this purpose? Now I can reflash UBoot into Flash Memory but I don't know how to check UBoot can work on it. Because porting have others issues such as serial library, interrupt....
Could you recommend a tool can check it can work? Sorry for stupid question.
4. Serial driver for UBoot on T-Engine/SH7727 board. After make sure these configuration are correct setting (SDRAM adress, Flash Memory). Next step is serial porting for UBoot.
I think serial is basic peripheral and It can work with a small changes. But Maybe I am wrong. Could you recommend the steps I could work on for serial porting of UBoot?
T-Engine has a serial library. I don't know how can reuse this library or not? :(
Nice for hearing that. I appreciated your help. Many thanks for your effort.
Best regards, Thao
Hello,
2008/8/8 thaoth thaoth@cybersoft-vn.com:
- Reallocating address of u-boot in booting process.
Yes, U-Boot designed working on SDRAM. In cpu/sh3/start.S, code of U-boot is copied from a flash bulb by memory and jump in memory. Because implementation of original U-boot comes to work as for this on memory, I match the SuperH with this implementation.
- This is a great site for working SH with Linux.
Sorry , I dont know it. The tool chain of http://www.superh-linux.org tests only elf32-sh-linux.
- Debugging tool for U-Boot development.
A developer has many cases to debug with ICE. When there is not ICE, We write in it at SDRAM with monitor and debug it on SDRAM.
- Serial driver for UBoot on T-Engine/SH7727 board.
There is two approach. 1. You delete content of Flash, and it is the method that only U-Boot uses. When you use this method, you come to need ICE. But this is very simple.
2. You call U-boot like an application from T-monitor, and to use. When you use this method, you will not need ICE. But you need Implementation serial function used T-monitor's library.
I will ask a specialist in T-engine an opinion. I will send e-mail it if there is some information.
Many Japanese companies become the long vacation from tomorrow. Because I am a holiday, an answer is not possible for approximately 2 weeks.
Hi Nobuhiro Iwamatsu,
1. Clock frequency of board.
#define CONFIG_SYS_CLK_FREQ 33333333 #define TMU_CLK_DIVIDER 4 /* 4 (default), 16, 64, 256 or 1024 */ #define CFG_HZ (CONFIG_SYS_CLK_FREQ / TMU_CLK_DIVIDER)
I don't understand how to set CONFIG_SYS_CLK_FREQ value. From T-Engine support, they said clock frequency of board is 144MHz.
CPU: SH7727 144 MHz Flash ROM: 80000000 - 807FFFFF : 8 MB (64 KB blk x 128) 80000000 - 8000FFFF : Monitor Area (64 KB) 80010000 - 8001007F : RomInfo Area (128 B) SDRAM: 8C000000 - 8DFFFFFF : 32 MB 8C000000 - 8C001FFF : Monitor & System Area (8 KB)
Could I set CFG_HZ to 144? #define CFG_HZ 144
2. Cross compiler tool chain : GCC vs T-Engine toolchain There are two tool chains - http://www.superh-linux.org/archive/bsp/sh7721_se/toolchain_sh3_gcc4.2.tar.g... support elf32-sh-linux target. - Tool chain from T-Engine forum support elf32-sh-tkernel Using both cross compilers, we could turn on LED on debug board by setting correct value LED_A and LED_B value.
3. ICE or JTAG debugger and LED debugging. I don't have these debug tools, and so hard for debugging. T-Engine/SH7727 DevKit has debug board with 8 LEDs. I could turn on/off these LEDs by setting correct value to 0xA1600000 memory. But C function turn on/off LED cannot work. For example
int cpu_init(void) { // Turn off LED 1 to notify cpu_init is called. outw(0x00 & 0xFF, 0xa1600000); return 0; }
I don't know why it isn't called?
Would you please give me your ideas? Thank you a lot. Regards,
2008/8/20 thaoth thaoth@cybersoft-vn.com:
- Clock frequency of board.
Please set outside clock to CONFIG_SYS_CLK_FREQ.
- Cross compiler tool chain : GCC vs T-Engine toolchain
- ICE or JTAG debugger and LED debugging.
I think that cpu_init is not carried out. I think that u-boot stopped on lowlevel_init function.
I will get T-Engine board ...... Please wait.
Sorry I didn't see "outside clock" in T-Engine/SH7727 specification. Regard to clock of board, there are 3 types - Internal clock - Peripheral clock - Bus clock
And have a look initialization values of T-Monitor - a boot loader of T-Engine/SH7727, ICLK_VAL: .long 0x0060 // 96 Mhz PCLK_VAL: .long 0x0018 // 24 Mhz FRQCR_VAL: .long 0x0112 // PLL*2, IFC*1, PFC/4 RTCOR_VAL: .long 0xa50b // 48MHz /64 14.667us
FRQCR: frequency multipliers controller RTCOR: reflash time constant counter
Does "outside clock" mean peripheral clock? It is 24 Mhz.
In lowlevel_init function, I put a LED debugging function which turn on LED on debug board. It works.
mov.l LED_A, r1 mov.l LED_D, r0 mov.b r0, @r1
LED_A: .long 0xA1600000 /* LED_BASE address */ LED_D: .long 0xaa /* mh a1600000, 00 --> ALL LED ON */
But C function in sh_generic_init() cannot work. :(
Thank you and hope hearing good news from you. Best regards,
Here is lowlevel_init.S
.global lowlevel_init
.text .align 2
lowlevel_init: mov.l WTCSR,r1 // WTCSR: 0xFFFFFF86 Watchdog Timer Control / Status Register) mov.l WTCSR_D,r0 // WTCSR_D: 0xA506 mov.w r0,@r1
mov.l WTCNT,r1 // WTCNT: 0xFFFFFF84 Watchdog Timer Counter mov.l WTCNT_D,r0 // WTCNT_D: 0x5A00 mov.w r0,@r1
! mov.l UCLKCR,r1 // UCLKCR: USBH/USBF Clock control register ! mov.l UCLKCR_D,r0 ! mov.w r0,@r1
mov.l FRQCR, r1 // FRQCR_A: 0xFFFFFF80 Frequency control register Address mov.l FRQCR_VAL, r0 mov.w r0, @r1
mov.l BCR1, r1 mov.l BCR1_VAL, r0 mov.w r0, @r1 // base control register 1
mov.l BCR2, r1 mov.l BCR2_VAL, r0 mov.w r0, @r1 // base control register 2
mov.l WCR1, r1 mov.l WCR1_VAL, r0 mov.w r0, @r1 // wait state control register 1
mov.l WCR2, r1 mov.l WCR2_VAL, r0 mov.w r0, @r1 // wait state control register 2
mov.l MCR, r1 mov.l MCR_VAL, r0 mov.w r0, @r1 // memory control register
mov.l PCR, r1 mov.l PCR_VAL, r0 mov.w r0, @r1 // PCMCIA control register
mov.l RTCSR, r1 mov.w RTCSR_DUMMY, r0 mov.w r0, @r1 // reflash timer control / status register
mov.l RTCNT, r1 mov.w RTCNT_VAL, r0 mov.w r0, @r1 // reflash timer counter
mov.l RTCOR, r1 mov.w RTCOR_VAL, r0 mov.w r0, @r1 // reflash time constant counter
mov.l RFCR, r1 mov.w RFCR_VAL, r0 mov.w r0, @r1 // reflash count register
/* SDRAM initalization */ // 100us dummy wait
mov.l SDMR3_ADDR, r1 mov.w SDMR3_VAL, r0 mov.w r0, @r1 // reflash count register
mov.l RTCSR, r1 mov.w RTCSR_VAL, r0 mov.w r0, @r1 // reflash timer control / status register
// dummy reflash /***********************/
// mov.l _PINTER, r1 // init PINTER // mov #0, r0 // mov.w r0, @r1
// mov.l _IPRA, r1 // init IPRA // mov.w IPRA_VAL, r0 // mov.w r0, @r1
// mov.l _IPRD, r1 // init IPRD // mov.w IPRD_VAL, r0 // mov.w r0, @r1
// mov.l _IPRG, r1 // init IPRG // mov.w IPRG_VAL, r0 // mov.w r0, @r1
// mov.l _ICR1, r1 // init ICR1 // mov.w ICR1_VAL, r0 // mov.w r0, @r1
// mov.l _ICR2, r1 // init ICR2 // mov.w ICR2_VAL, r0 // mov.w r0, @r1
// mov.l _PINTER, r1 // init PINTER // mov.w PINTER_VAL, r0 // mov.w r0, @r1
mov.l PCCR, r1 // init PCCR mov.w PCCR_VAL, r0 mov.w r0, @r1
mov.l PDCR, r1 // init PDCR mov.w PDCR_VAL, r0 mov.w r0, @r1
mov.l PECR, r1 // init PECR mov.w PECR_VAL, r0 mov.w r0, @r1
mov.l PHCR, r1 // init PHCR mov.w PHCR_VAL, r0 mov.w r0, @r1
mov.l PJCR, r1 // init PJCR mov.w PJCR_VAL, r0 mov.w r0, @r1
mov.l PKCR, r1 // init PKCR mov.w PKCR_VAL, r0 mov.w r0, @r1
mov.l PLCR, r1 // init PLCR mov.w PLCR_VAL, r0 mov.w r0, @r1
mov.l PMCR, r1 // init PMCR mov.w PMCR_VAL, r0 mov.w r0, @r1
mov.l SCPCR, r1 // init SCPCR mov.w SCPCR_VAL, r0 mov.w r0, @r1
! mov.l ICLK, r1 // init internal clock 96 Mhz ! mov.l ICLK_VAL, r0 ! mov.w r0, @r1
! mov.l PCLK, r1 // init peripheral clock 24 Mhz ! mov.l PCLK_VAL, r0 ! mov.w r0, @r1
rts nop
.align 4
!ICLK: .long 0x8c000274 !PCLK: .long 0x8c000276
WTCSR: .long 0xFFFFFF86 /* WTCSR: 0xFFFFFF86 Watchdog Timer Control / Status Register) */ WTCNT: .long 0xFFFFFF84 /* WTCNT: 0xFFFFFF84 Watchdog Timer Counter */ /*UCLKCR: .long 0xA40A0008*/ /* USBH/USBF: Clock control register ???*/ FRQCR: .long 0xffffff80 BCR1: .long 0xffffff60 /* Bus Control Register 1 */ BCR2: .long 0xffffff62 /* Bus Control Register 2 */ WCR1: .long 0xffffff64 /* Wait State Control Register 1 */ WCR2: .long 0xffffff66 /* Wait State Control Register 2 */ MCR: .long 0xffffff68 /* Individual Memory Control Register */ PCR: .long 0xffffff6c /* PCMCIA control register */ RTCSR: .long 0xffffff6e /* Refresh timer control/status register */ RTCNT: .long 0xffffff70 /* Refresh timer counter */ RTCOR: .long 0xffffff72 /* Refresh time contant register */ RFCR: .long 0xffffff74 /* Refresh count register */ SDMR3_ADDR: .long 0xFFFFE800 + 0x80 /* Synchorounos DRAM Mode register ??? */
/* SH Internal Use - Area 1 */ PCCR: .long 0xa4000104 PDCR: .long 0xa4000106 PECR: .long 0xa4000108 PFCR: .long 0xa400010a PGCR: .long 0xa400010c PHCR: .long 0xa400010e PJCR: .long 0xa4000110 PKCR: .long 0xa4000112 PLCR: .long 0xa4000114 PMCR: .long 0xa4000118 SCPCR: .long 0x04000116
/* Initialize data */ ICLK_VAL: .long 0x0060 // 96 Mhz PCLK_VAL: .long 0x0018 // 24 Mhz
WTCNT_D: .long 0x5A00 /* WTCNT_D: 0x5A00 set the upper byte to 5A and transfer data into lower byte */ WTCSR_D: .long 0xA506 /* WTCSR_D: 0xA506 set the upper byte to A5 and transfer data into lower byte */ /*UCLKCR_D: .long 0xA5C0*/
FRQCR_VAL: .long 0x0112 // PLL*2, IFC*1, PFC/4 BCR1_VAL: .long 0x0008 /* Bus Control Register 1 */ BCR2_VAL: .long 0x2ae0 /* Bus Control Register 2 */ #if USE_R0P7727TH003TRK == 1 WCR1_VAL: .long 0xaaa2 /* Wait State Control Register 1 */ #else // previous type T-Engine WCR1_VAL: .long 0xaa22 #endif WCR2_VAL: .long 0xb6dd /* Wait State Control Register 2 */
#if USE_R0P7727TH003TRK == 1 MCR_VAL: .long 0x966c /* Individual Memory Control Register */ #else // previous type T-Engine MCR_VAL: .long 0x012c #endif PCR_VAL: .long 0x0000 /* PCMCIA control register */ RTCSR_DUMMY: .long 0xa500 // RTCSR_VAL: .long 0xa518 /* Refresh timer control/status register : CKIO 1/64 */ RTCNT_VAL: .long 0xa500 /* Refresh timer counter */
#if USE_R0P7727TH003TRK == 1 RTCOR_VAL: .long 0xa505 /* Refresh time contant register */ #else // previous type T-Engine RTCOR_VAL: .long 0xa50b // 48MHz /64 14.667us #endif RFCR_VAL: .long 0xa400 /* Refresh count register */ SDMR3_VAL: .long 0x00 /* Synchorounos DRAM Mode register ??? */
IPRA_VAL: .long 0x8000 IPRD_VAL: .long 0xc000 IPRG_VAL: .long 0xc000 ICR1_VAL: .long 0x42aa ICR2_VAL: .long 0x000c PINTER_VAL: .long 0x000c PCCR_VAL: .long 0x0000 PDCR_VAL: .long 0x0000 PECR_VAL: .long 0x0500 PFCR_VAL: .long 0x00AA PGCR_VAL: .long 0xA200 PHCR_VAL: .long 0x0800 PJCR_VAL: .long 0x0540 PKCR_VAL: .long 0x0005 PLCR_VAL: .long 0xaaaa PMCR_VAL: .long 0xaa00 SCPCR_VAL: .long 0x0000
SDCR_D1: .long 0x00000011 SDCR_D2: .long 0x00000811
void sh_generic_init (void) { ... outw(0x7e, LED_BASE); }
Now sh_generic_init could be called with LEDs indicated true status. :-) But I don't know what next issue? :-((
I have checked sequence initialization functions in sh_generic_init and the problem is serial library cannot work correctly. The result is output to console cannot display.
Regards.
Hi Nobuhiro Iwamatsu, Now I'm porting USB on board T-Engine(SH7727) - My configure following : #define CONFIG_CMD_USB #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_USB_STORAGE 1 #define CFG_USB_OHCI_REGS_BASE 0x04000400 #define CFG_USB_OHCI_SLOT_NAME "s3c2400" #define CFG_USB_OHCI_MAX_ROOT_PORTS 15 #define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_CLK_FREQ 33333333 #define TMU_CLK_DIVIDER 4 /* 4 (default), 16, 64, 256 or 1024 */ #define CFG_HZ (CONFIG_SYS_CLK_FREQ / TMU_CLK_DIVIDER) - And in lowlevel_init.S, I change USB clock following: UCLKCR_A: .long 0xA40A0008 UCLKCR_D: .long 0xA5C0 mov.l UCLKCR_A,r1 mov.l UCLKCR_D,r0 mov.w r0,@r1 - When I'm starting board with above configue, I see the led of USB device is blinking. Then I run command "usb start", the led turn off and u-boot don't find any USB device, with following logs: DEBUG: OHCI controller usb-s3c2400 state DEBUG: control: 0x0000008f HCFS=operational IE PLE CBSR=3 DEBUG: cmdstatus: 0x00000000 SOC=0 DEBUG: intrstatus: 0x00000004 SF DEBUG: intrenable: 0x00000053 RHSC UE WDH SO DEBUG: hcca frame #0019 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000100 PPS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS scanning bus for devices... New Device 0 usb_control_msg: request: 0x6, requesttype: 0x80 value 0x100 index 0x0 length 0x8 INFO: submit_control_msg DEBUG: SUB URB:[ 42] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000 DEBUG: SUB(rh) URB:[ 45] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000 INFO: Root-Hub: adr: 0 cmd(8): 00000680 0001 0000 0800 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000100 PPS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ 56] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x2 usb_ohci.c: cmd(8): 80 06 01 00 00 00 00 08 usb_ohci.c: data(0/8): USB device not responding, giving up (status=2) 0 USB Device(s) found scanning bus for storage devices... 0 Storage Device (s) found - I don't know what is wrong in my configure, I think the CONFIG_SYS_CLK_FREQ and CFG_HZ is incorrect and I can't start USB device, and clock which I control in lowlevel_init.S following: FRQCR_A: .long 0xA415FF80 /* FRQCR Address(Frequency Control Register) */ FRQCR_D: .long 0x1103 /* I:B:P=8:4:2 */ Can you help me about this problem and tell me about any other wrong things in my configure? why the led turn off when I run command "usb start"?
thanks
Best regards, Nobuhiro _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
I got USB issue and here is an error message:
ERROR: CTL:TIMEOUT USB device not responding, giving up (status=20) 3 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found
For detail, TEngine/SH7727 has one USB host controller, when I plugged USB Flash Memory there were 3 devices. And No unplugged USB device, they said 2 devices.
=> usb info 1: Hub, USB Revision 1.10 - OHCI Root Hub - Class: Hub - PacketSize: 8 Configurations: 1 - Vendor: 0x0000 Product 0x0000 Version 0.0 Configuration: 1 - Interfaces: 1 Self Powered 0mA Interface: 0 - Alternate Setting 0, Endpoints: 1 - Class Hub - Endpoint 1 In Interrupt MaxPacket 2 Interval 255ms
Configuration: 0 - Interfaces: 0 Bus Powered 0mA
The problem sounded USB host controller driver could work well but submit_common_msg couldn't get description of USB flash memory device and it said "No storage device".
Here is configuration of USB on UBoot
/* USB Mass Storage Support*/ #define CONFIG_CMD_USB #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_USB_STORAGE 1
#define CFG_USB_OHCI_REGS_BASE 0xA4000400 #define CFG_USB_OHCI_SLOT_NAME "s3c2400" #define CFG_USB_OHCI_MAX_ROOT_PORTS 15
Could I have help? Please tell me if you have any idea. Thank you for your helping. =)
Here is a log data
U-Boot 1.3.4-00404-gab00e7a-dirty (Sep 10 2008 - 16:30:38)
CPU: SH3 BOARD: Hitachi UL MS7727SE DRAM: 32MB FLASH: 8MB *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial => usb start (Re)start USB... USB: INFO: aligned ghcca 8e01ad00 DEBUG: hc_reset
DEBUG: USB HC reset_hc usb-s3c2400: ctrl = 0x0 ;
DEBUG: OHCI controller usb-s3c2400 state DEBUG: control: 0x0000008f HCFS=operational IE PLE CBSR=3 DEBUG: cmdstatus: 0x00000000 SOC=0 DEBUG: intrstatus: 0x00000004 SF DEBUG: intrenable: 0x00000053 RHSC UE WDH SO DEBUG: hcca frame #000d DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000100 PPS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS scanning bus for devices... New Device 0 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0 x8 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000 INFO: Root-Hub: adr: 0 cmd(8): 00000680 0100 0000 0008 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000100 PPS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x0 usb_ohci.c: cmd(8): 80 06 00 01 00 00 08 00 usb_ohci.c: data(0/8): set address 1 usb_control_msg: request: 0x5, requesttype: 0x0, value 0x1 index 0x0 length 0x0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 0,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 00 05 01 00 00 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 0,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 00 05 01 00 00 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000500 0001 0000 0000 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 0,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 00 05 01 00 00 00 00 00 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0 x12 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/18 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/18 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 00000680 0100 0000 0012 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/18 stat:0x0 usb_ohci.c: cmd(8): 80 06 00 01 00 00 12 00 usb_ohci.c: data(0/18): usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0 x8 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 00000680 0200 0000 0008 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/8 stat:0x0 usb_ohci.c: cmd(8): 80 06 00 02 00 00 08 00 usb_ohci.c: data(0/8): usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0 x19 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/25 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/25 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 00000680 0200 0000 0019 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/25 stat:0x0 usb_ohci.c: cmd(8): 80 06 00 02 00 00 19 00 usb_ohci.c: data(0/25): get_conf_no 0 Result 25, wLength 25 if 0, ep 0 ##EP epmaxpacketin[1] = 2 set configuration 1 usb_control_msg: request: 0x9, requesttype: 0x0, value 0x1 index 0x0 length 0x0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 00 09 01 00 00 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 00 09 01 00 00 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000900 0001 0000 0000 INFO: WR:status 0x10000 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 00 09 01 00 00 00 00 00 new device strings: Mfr=0, Product=1, SerialNumber=0 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x300 index 0x0 length 0 xFF INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/255 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/255 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 00000680 0300 0000 00ff DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/255 stat:0x0 usb_ohci.c: cmd(8): 80 06 00 03 00 00 ff 00 usb_ohci.c: data(0/255): USB device number 1 default language ID 0x409 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x301 index 0x409 length 0xFF INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/255 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/255 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 00000680 0301 0409 00ff DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/255 stat:0x0 usb_ohci.c: cmd(8): 80 06 01 03 09 04 ff 00 usb_ohci.c: data(0/255): Manufacturer Product OHCI Root Hub SerialNumber USB hub found usb_control_msg: request: 0x6, requesttype: 0xA0, value 0x2900 index 0x0 length 0x4 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 000006a0 2900 0000 0004 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x0 usb_ohci.c: cmd(8): a0 06 00 29 00 00 04 00 usb_ohci.c: data(0/4): usb_control_msg: request: 0x6, requesttype: 0xA0, value 0x2900 index 0x0 length 0x9 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/9 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/9 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 000006a0 2900 0000 0009 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/9 stat:0x0 usb_ohci.c: cmd(8): a0 06 00 29 00 00 09 00 usb_ohci.c: data(0/9): 2 ports detected ganged power switching standalone hub no over-current protection power on to power good time: 4ms hub controller current requirement: 0mA port 1 is removable port 2 is removable usb_control_msg: request: 0x0, requesttype: 0xA0, value 0x0 index 0x0 length 0x4 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 000000a0 0000 0000 0004 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x0 usb_ohci.c: cmd(8): a0 00 00 00 00 00 04 00 usb_ohci.c: data(0/4): get_hub_status returned status 0, change 0 local power source is good no over-current condition exists enabling power on all ports usb_control_msg: request: 0x3, requesttype: 0x23, value 0x8 index 0x1 length 0x0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 03 08 00 01 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 03 08 00 01 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000323 0008 0001 0000 INFO: WR:portstatus[0] 0x100 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 23 03 08 00 01 00 00 00 port 1 returns 0 usb_control_msg: request: 0x3, requesttype: 0x23, value 0x8 index 0x2 length 0x0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 03 08 00 02 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 03 08 00 02 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000323 0008 0002 0000 INFO: WR:portstatus[1] 0x100 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 23 03 08 00 02 00 00 00 port 2 returns 0 usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 000000a3 0000 0001 0004 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x0 usb_ohci.c: cmd(8): a3 00 00 00 01 00 04 00 usb_ohci.c: data(0/4): Port 1 Status 101 Change 1 port 1 connection change usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 000000a3 0000 0001 0004 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x0 usb_ohci.c: cmd(8): a3 00 00 00 01 00 04 00 usb_ohci.c: data(0/4): portstatus 101, change 1, High Speed usb_control_msg: request: 0x1, requesttype: 0x23, value 0x10 index 0x1 length 0x 0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 10 00 01 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 10 00 01 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000123 0010 0001 0000 INFO: WR:portstatus[0] 0x10000 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000101 PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 23 01 10 00 01 00 00 00 hub_port_reset: resetting port 0... usb_control_msg: request: 0x3, requesttype: 0x23, value 0x4 index 0x1 length 0x0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 03 04 00 01 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 03 04 00 01 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000323 0004 0001 0000 INFO: WR:portstatus[0] 0x10 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000311 LSDA PPS PRS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 23 03 04 00 01 00 00 00 usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 000000a3 0000 0001 0004 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00100303 PRSC LSDA PPS PES CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x0 usb_ohci.c: cmd(8): a3 00 00 00 01 00 04 00 usb_ohci.c: data(0/4): portstatus 303, change 10, Low Speed STAT_C_CONNECTION = 0 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 1 usb_control_msg: request: 0x1, requesttype: 0x23, value 0x14 index 0x1 length 0x 0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 14 00 01 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 14 00 01 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000123 0014 0001 0000 INFO: WR:portstatus[0] 0x100000 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000303 LSDA PPS PES CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 23 01 14 00 01 00 00 00 New Device 1 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0 x8 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000 DEBUG: SUB URB:[ d] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000 hc_interrupt regs->intrstatus=68;regs->intrenable=83;ints=64 submit_common_msg hc_interrupt():stat = 255 DEBUG: % hc_interrupt regs->intrstatus=6;regs->intrenable=83;ints=2 submit_common_msg hc_interrupt():stat = 0 DEBUG: % DEBUG: hc_interrupt: returning..
submit_common_msg hc_interrupt():stat = 255 DEBUG: % DEBUG: hc_interrupt: returning..
submit_common_msg hc_interrupt():stat = 255 ERROR: CTL:TIMEOUT DEBUG: submit_common_msg: TO status ff
DEBUG: RET(ctlr) URB:[ d] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x20
USB device not responding, giving up (status=20) hub: disabling port 1 usb_control_msg: request: 0x1, requesttype: 0x23, value 0x1 index 0x1 length 0x0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 01 00 01 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 01 00 01 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000123 0001 0001 0000 INFO: WR:portstatus[0] 0x1 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000301 LSDA PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 23 01 01 00 01 00 00 00 usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x2 length 0x4 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 000000a3 0000 0002 0004 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000301 LSDA PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x0 usb_ohci.c: cmd(8): a3 00 00 00 02 00 04 00 usb_ohci.c: data(0/4): Port 2 Status 101 Change 1 port 2 connection change usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x2 length 0x4 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 000000a3 0000 0002 0004 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000301 LSDA PPS CCS DEBUG: roothub.portstatus [1] = 0x00010101 CSC PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x0 usb_ohci.c: cmd(8): a3 00 00 00 02 00 04 00 usb_ohci.c: data(0/4): portstatus 101, change 1, High Speed usb_control_msg: request: 0x1, requesttype: 0x23, value 0x10 index 0x2 length 0x 0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 10 00 02 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 10 00 02 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000123 0010 0002 0000 INFO: WR:portstatus[1] 0x10000 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000301 LSDA PPS CCS DEBUG: roothub.portstatus [1] = 0x00000101 PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 23 01 10 00 02 00 00 00 hub_port_reset: resetting port 1... usb_control_msg: request: 0x3, requesttype: 0x23, value 0x4 index 0x2 length 0x0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 03 04 00 02 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 03 04 00 02 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000323 0004 0002 0000 INFO: WR:portstatus[1] 0x10 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000301 LSDA PPS CCS DEBUG: roothub.portstatus [1] = 0x00000111 PPS PRS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 23 03 04 00 02 00 00 00 usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x2 length 0x4 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000 INFO: Root-Hub: adr: 1 cmd(8): 000000a3 0000 0002 0004 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000301 LSDA PPS CCS DEBUG: roothub.portstatus [1] = 0x00100103 PRSC PPS PES CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x0 usb_ohci.c: cmd(8): a3 00 00 00 02 00 04 00 usb_ohci.c: data(0/4): portstatus 103, change 10, High Speed STAT_C_CONNECTION = 0 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 1 usb_control_msg: request: 0x1, requesttype: 0x23, value 0x14 index 0x2 length 0x 0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 14 00 02 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 14 00 02 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000123 0014 0002 0000 INFO: WR:portstatus[1] 0x100000 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000301 LSDA PPS CCS DEBUG: roothub.portstatus [1] = 0x00000103 PPS PES CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 23 01 14 00 02 00 00 00 New Device 2 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0 x8 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000 DEBUG: SUB URB:[ d] dev: 0,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000 hc_interrupt regs->intrstatus=68;regs->intrenable=83;ints=64 submit_common_msg hc_interrupt():stat = 255 DEBUG: % DEBUG: hc_interrupt: returning..
USB device not responding, giving up (status=20) hub: disabling port 2 usb_control_msg: request: 0x1, requesttype: 0x23, value 0x1 index 0x2 length 0x0 INFO: submit_control_msg DEBUG: SUB URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 01 00 02 00 00 00
DEBUG: SUB(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000 usb_ohci.c: cmd(8): 23 01 01 00 02 00 00 00 INFO: Root-Hub: adr: 1 cmd(8): 00000123 0001 0002 0000 INFO: WR:portstatus[1] 0x1 DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2 DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000 DEBUG: roothub.status: 00000000 DEBUG: roothub.portstatus [0] = 0x00000301 LSDA PPS CCS DEBUG: roothub.portstatus [1] = 0x00000101 PPS CCS DEBUG: RET(rh) URB:[ d] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0 usb_ohci.c: cmd(8): 23 01 01 00 02 00 00 00 3 USB Device(s) found scanning bus for storage devices... Storage Device(s) found
Thank you a lot. Best regards,
Hi, thaoth.
Shimoda-san is USB developper on U-Boot in Renesas.
Shimoda-san, please give us comments this problem.
On Wed, 10 Sep 2008 04:51:40 -0700 (PDT) thaoth thaoth@cybersoft-vn.com wrote:
Hi, thaoth.
I think that your board cannot communicate with USB device at all. SH7727 has EXCPGCR register. Do you set this register? When I used this CPU before, I did the following setting.
STCBR3 = 0x18; SRSTR = 0x18; wait_10msec();
EXCPGCR = 0x28; wait_10msec();
SRSTR = 0x00; STCBR3 = 0x00;
Best regards, Yoshihiro Shimoda
Hi, thaoth.
Yoshihiro Shimoda wrote:
Hi, thaoth.
Thank you very much,
Following your instruction, I did int usb_board_init(void) { printf("usb_board_init\n");
outw(0x18, STBCR3); outw(0x18, SRSTR); udelay(10);
outw(0x28, EXCPGCR); udelay(10); outw(0x00, STBCR3); outw(0x00, SRSTR); return 0; }
STCBR3 = 0x18;
I couldn't see this register "STCBR3 ", I only saw STBCR3. Is it correct?
But UBoot didn't work, Would you please tell me more detail ? Thank you alot :)
Hi, thaoth.
Hi, thaoth.
< snip >
You are welcome :)
outw(0x18, STBCR3); outw(0x18, SRSTR); udelay(10); outw(0x28, EXCPGCR); udelay(10); outw(0x00, STBCR3); outw(0x00, SRSTR); return 0;
These registers are 8-bit width. So please use outb() macro.
STCBR3 = 0x18;
Oh, I am sorry. That's correct.
I am sorry, my explanation was short. This EXCPGCR value was for an another board. In the case of your board, it may be necessary to make it a defferent value. And I used my board, I set 0x1500 in PKCR.
They are the same. It is still problem.
As specification of SH7727, value of EXCPGCR is 0x28 and this means
"" The SH7727 has an on-chip USB interface (USB) which requires a fixed 48-MHz clock source.
The extend clock pulse generator (EXCPG) generates a divided clock from the internal clock (Iφ), the bus clock (Bφ), or the external clock (UCLK).
Because the clock sources, which can be a candidate to be used by EXCPG, vary from CPG setting or external clock source, user of SH7727 must adjust the divided clock, carefully to be 48 MHz. "" * Bits 5 to 3Clock Select (USBCKSEL2 to USBCKSEL0): 000: Peripheral Clock (Pφ) (Initial value) 100: Internal Clock (Iφ) 101: Bus Clock (Bφ) 110: External clock (UCLK) ***: Another value Reserved (setting prohibited)
* Bits 2 to 0: Divider Select (USBDIVSEL2 to USBDIVSEL0): 000: 1/1 -> Dividing Ratio Selection 001: 1/2 010: 1/3 1**: Internal clock (Iφ), bus clock (Bφ), external clock (UCLK) halted
0x28: 00101000 -> 00 101 000 -> * 101: Using bus clock * 000: Dividing Ratio Selection is 1/1
I know * Internal clock: 96Mhz * Peripheral Clock: 24Mhz * CPU Block: 144Mhz
http://www.nabble.com/file/p19449833/a.JPG a.JPG
Please let me know the correct value of EXCPGCR ? Is 0x28 correct initialize value of USB clock?
I don't understand PKCR - Port control register so I don't know correct initialize value of this register.
0x1500 = 0001 0101 0000 0000 -> PK6 is port output -> PK5 is port output -> PK4 is port output I don't know this value could be set for my board - TEngine/SH7727.
I am appreciating your helping :)
Hi, thaoth.
- 101: Using bus clock
- 000: Dividing Ratio Selection is 1/1
I know
- Internal clock: 96Mhz
- Peripheral Clock: 24Mhz
- CPU Block: 144Mhz
I think that 0x21 is correct value of EXCPGCR for your board.
0x21: 00101000 -> 00 100 001 -> * 100: Using Internal Clock * 001: Dividing Ratio Selection is 1/2 (96MHz / 2 = 48MHz)
Oh, I am very sorry. This is PECR. This setting enable USB1_pwr_en and USB2_pwr_en pin.
Hi Yoshihiro Shimoda, * Strategy 1: I add usb_cpu_init following your tutorial: int usb_cpu_init(void) { *STCBR3 = 0x18; *SRSTR = 0x18; cpu_wait_ms(50); *EXCPGCR = 0x21;//0x28; *PECR = 0x1500; cpu_wait_ms(50); *SRSTR = 0x00; *STCBR3 = 0x00; return 0; } now, I plug the USB2.0(mass storage) into board T-Engine(sh7727) and run command "usb start", the u-boot can't get decription of usb device with the errror following:
New Device 1 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0 x8 set address 2 usb_control_msg: request: 0x5, requesttype: 0x0, value 0x2 index 0x0 length 0x0 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0 x12 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0 x8 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0 x20 get_conf_no 0 Result 32, wLength 32 if 0, ep 0 if 0, ep 1 ##EP epmaxpacketin[1] = 64 * Strategy 2: I add usb_cpu_init the same strategy 1, I only add instruction "printf("&ep = %x\n",&ep);" into function usb_set_maxpacket of usb.c int usb_set_maxpacket(struct usb_device *dev) { ................................................. ................................................... ep = &dev->config.if_desc[i].ep_desc[ii]; b=ep->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK; printf("&ep = %x\n",&ep); ..................................................... ...................................................... } in this strategy, when I run command "usb start", now I can get information of USB device: Manufacturer Product USB_DRIVE SerialNumber 000000000000001000006886 2 USB Device(s) found scanning bus for storage devices... usb_control_msg: request: 0xFF, reque sttype: 0x21, value 0x0 index 0x0 length 0x0 usb_control_msg: request: 0x1, requesttype: 0x2, value 0x0 index 0x81 length 0x0 usb_control_msg: request: 0x1, requesttype: 0x2, value 0x0 index 0x2 length 0x0 1 Storage Device(s) found
I don't know what is problem?why when I add instruction "printf("&ep = %x\n",&ep);", u-boot can get description of USB device *Strategy 3: I try replace the insctruction "printf("&ep = %x\n",&ep);" with one of these instructions - instruction 1: wait_ms(10) - instruction 2:void * pointer = &ep; - instruction 3: "printf("ep = %x\n",ep);" But the result when run command "usb start" the same strategy 1, I can't get information of USB2.0(mass storage)
Can you help me to resolve this bug? Thank you very much for your supports!
Hi, thaoth.
I know
- CPU Block: 144Mhz
- 100: Using Internal Clock
- 001: Dividing Ratio Selection is 1/2
(96MHz / 2 = 48MHz)
Best regards, Yoshihiro Shimoda _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi, thaoth
I think that it is a problem of the unalignment access. Please change your compiler or change a source code as follows:
diff --git a/common/usb.c b/common/usb.c index 9502f39..1acf51d 100644 --- a/common/usb.c +++ b/common/usb.c @@ -250,7 +250,10 @@ int usb_set_maxpacket(struct usb_device *dev)
for(i=0; i<dev->config.bNumInterfaces;i++) { for(ii=0; ii<dev->config.if_desc[i].bNumEndpoints; ii++) { - ep = &dev->config.if_desc[i].ep_desc[ii]; + struct usb_endpoint_descriptor tmp; + memcpy(&tmp, &dev->config.if_desc[i].ep_desc[ii], + sizeof(struct usb_endpoint_descriptor)); + ep = &tmp; b=ep->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK;
if((ep->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK)==USB_ENDPOINT_XFER_CONTROL) { /* Control => bidirectional */
You're welcome! :)
ep = &tmp; b=ep->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK; if((ep->bmAttributes &
Thank you a lot, it worked well. :jumping::jumping::jumping::jumping:
Thank you for good instruction. Best regards,
Nobuhiro Iwamatsu
Nobuhiro Iwamatsu
thaoth
Yoshihiro Shimoda
