[U-Boot] [PATCH v2] usb: host: xhci-omap: Remove redundant board_usb_init and board_usb_cleanup functions
board_usb_init()/_cleanup() should be in board files and don't have a place in the xhci-omap driver. Weak versions for board_usb_init()/_cleanup() already exist in common/usb.c (for host mode) and drivers/usb/gadget/g_dnl.c (for gadget mode).
Therefore, remove init and cleanup functions from xhci-omap and implement them in the board files.
Signed-off-by: Faiz Abbas faiz_abbas@ti.com Reviewed-by: Marek Vasut marex@denx.de Reviewed-by: Bin Meng bmeng.cn@gmail.com --- v2: Added init and cleanup implementations for boards which were relying on the weak implementation.
Uri please test the compulab boards.
board/compulab/cl-som-am57x/cl-som-am57x.c | 13 +++++++++++++ board/compulab/cm_t43/cm_t43.c | 14 ++++++++++++++ board/ti/am43xx/board.c | 4 ++-- board/ti/am57xx/board.c | 4 ++-- board/ti/dra7xx/evm.c | 4 ++-- drivers/usb/host/xhci-omap.c | 22 ---------------------- 6 files changed, 33 insertions(+), 28 deletions(-)
diff --git a/board/compulab/cl-som-am57x/cl-som-am57x.c b/board/compulab/cl-som-am57x/cl-som-am57x.c index 389eebb..d7dc8a4 100644 --- a/board/compulab/cl-som-am57x/cl-som-am57x.c +++ b/board/compulab/cl-som-am57x/cl-som-am57x.c @@ -16,6 +16,7 @@ #include <asm/arch/sys_proto.h> #include "../common/common.h" #include "../common/eeprom.h" +#include <asm/omap_common.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -64,3 +65,15 @@ u32 get_board_rev(void) { return cl_eeprom_get_board_rev(CONFIG_SYS_I2C_EEPROM_BUS); } + +int board_usb_init(int index, enum usb_init_type init) +{ + enable_usb_clocks(index); + return 0; +} + +int board_usb_cleanup(int index, enum usb_init_type init) +{ + disable_usb_clocks(index); + return 0; +} diff --git a/board/compulab/cm_t43/cm_t43.c b/board/compulab/cm_t43/cm_t43.c index 0d5da6f..bdbea4f 100644 --- a/board/compulab/cm_t43/cm_t43.c +++ b/board/compulab/cm_t43/cm_t43.c @@ -14,6 +14,8 @@ #include <power/pmic.h> #include <power/tps65218.h> #include "board.h" +#include <usb.h> +#include <asm/omap_common.h>
@@ -50,6 +52,18 @@ int board_init(void) return 0; }
+int board_usb_init(int index, enum usb_init_type init) +{ + enable_usb_clocks(index); + return 0; +} + +int board_usb_cleanup(int index, enum usb_init_type init) +{ + disable_usb_clocks(index); + return 0; +} + #ifdef CONFIG_DRIVER_TI_CPSW
static void cpsw_control(int enabled) diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 16150ad..715960a 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -687,7 +687,7 @@ int usb_gadget_handle_interrupts(int index) #endif /* CONFIG_USB_DWC3 */
#if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_OMAP) -int omap_xhci_board_usb_init(int index, enum usb_init_type init) +int board_usb_init(int index, enum usb_init_type init) { enable_usb_clocks(index); #ifdef CONFIG_USB_DWC3 @@ -718,7 +718,7 @@ int omap_xhci_board_usb_init(int index, enum usb_init_type init) return 0; }
-int omap_xhci_board_usb_cleanup(int index, enum usb_init_type init) +int board_usb_cleanup(int index, enum usb_init_type init) { #ifdef CONFIG_USB_DWC3 switch (index) { diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 1128784..c3f60f6 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -867,7 +867,7 @@ int usb_gadget_handle_interrupts(int index) #endif /* CONFIG_USB_DWC3 */
#if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_OMAP) -int omap_xhci_board_usb_init(int index, enum usb_init_type init) +int board_usb_init(int index, enum usb_init_type init) { enable_usb_clocks(index); switch (index) { @@ -901,7 +901,7 @@ int omap_xhci_board_usb_init(int index, enum usb_init_type init) return 0; }
-int omap_xhci_board_usb_cleanup(int index, enum usb_init_type init) +int board_usb_cleanup(int index, enum usb_init_type init) { #ifdef CONFIG_USB_DWC3 switch (index) { diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 6ecf971..519475e 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -907,7 +907,7 @@ static struct ti_usb_phy_device usb_phy2_device = { .index = 1, };
-int omap_xhci_board_usb_init(int index, enum usb_init_type init) +int board_usb_init(int index, enum usb_init_type init) { enable_usb_clocks(index); switch (index) { @@ -944,7 +944,7 @@ int omap_xhci_board_usb_init(int index, enum usb_init_type init) return 0; }
-int omap_xhci_board_usb_cleanup(int index, enum usb_init_type init) +int board_usb_cleanup(int index, enum usb_init_type init) { switch (index) { case 0: diff --git a/drivers/usb/host/xhci-omap.c b/drivers/usb/host/xhci-omap.c index d6c5744..b814500 100644 --- a/drivers/usb/host/xhci-omap.c +++ b/drivers/usb/host/xhci-omap.c @@ -27,28 +27,6 @@ DECLARE_GLOBAL_DATA_PTR;
static struct omap_xhci omap;
-__weak int omap_xhci_board_usb_init(int index, enum usb_init_type init) -{ - enable_usb_clocks(index); - return 0; -} - -int board_usb_init(int index, enum usb_init_type init) -{ - return omap_xhci_board_usb_init(index, init); -} - -__weak int omap_xhci_board_usb_cleanup(int index, enum usb_init_type init) -{ - disable_usb_clocks(index); - return 0; -} - -int board_usb_cleanup(int index, enum usb_init_type init) -{ - return omap_xhci_board_usb_cleanup(index, init); -} - static int omap_xhci_core_init(struct omap_xhci *omap) { int ret = 0;
Tested-by: Uri Mashiach uri.mashiach@compulab.co.il
Faiz Abbas
Uri Mashiach
