[U-Boot] USB port detection problem1
Hi All,
In board, we have 2 USB controllers and the first port with USB Mass storage is detected without any problem and 2nd Controller with USB Mass storage is not detected properly. Sometimes it is detecting and sometimes, it is not detecting.
In U-Boot version U-Boot 2011.12, When detect the USB, got the below errors:
U-Boot>> usb start (Re)start USB... USB: Active port: 1 Register 10011 NbrPorts 1 USB EHCI 1.00 *scanning bus for devices... port(0) reset error* *port(0) reset error* *port(0) reset error* *port(0) reset error* *port(0) reset error* *cannot reset port 1!?* 1 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found
When USB works, the output is:
U-Boot>> usb start (Re)start USB... USB: Active port: 1 Register 10011 NbrPorts 1 USB EHCI 1.00 scanning bus for devices... 2 USB Device(s) found scanning bus for storage devices... 1 Storage Device(s) found U-Boot>> usb info 1: Hub, USB Revision 2.0 - u-boot EHCI Host Controller - Class: Hub - PacketSize: 64 Configurations: 1 - Vendor: 0x0000 Product 0x0000 Version 1.0 Configuration: 1 - Interfaces: 1 Self Powered 0mA Interface: 0 - Alternate Setting 0, Endpoints: 1 - Class Hub - Endpoint 1 In Interrupt MaxPacket 8 Interval 255ms
2: Mass Storage, USB Revision 2.0 - JetFlash Mass Storage Device K5Z75Z3O - Class: (from Interface) Mass Storage - PacketSize: 64 Configurations: 1 - Vendor: 0x8564 Product 0x1000 Version 1.0 Configuration: 1 - Interfaces: 1 Bus Powered 200mA Interface: 0 - Alternate Setting 0, Endpoints: 2 - Class Mass Storage, Transp. SCSI, Bulk only - Endpoint 1 Out Bulk MaxPacket 512 - Endpoint 2 In Bulk MaxPacket 512
Please help on this.
When enable the debug printf(), then the error messages is:
U-Boot>> usb start (Re)start USB... USB: Active port: 1 Register 10011 NbrPorts 1 USB EHCI 1.00 scanning bus for devices... New Device 0 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0x40 set address 1 usb_control_msg: request: 0x5, requesttype: 0x0, value 0x1 index 0x0 length 0x0 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0x12 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0x9 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0x19 get_conf_no 0 Result 25, wLength 25 if 0, ep 0 ##EP epmaxpacketin[1] = 8 set configuration 1 usb_control_msg: request: 0x9, requesttype: 0x0, value 0x1 index 0x0 length 0x0 new device strings: Mfr=1, Product=2, SerialNumber=0 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x300 index 0x0 length 0xFF USB device number 1 default language ID 0x1 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x301 index 0x1 length 0xFF usb_control_msg: request: 0x6, requesttype: 0x80, value 0x302 index 0x1 length 0xFF Manufacturer u-boot Product EHCI Host Controller SerialNumber USB hub found usb_control_msg: request: 0x6, requesttype: 0xA0, value 0x2900 index 0x0 length 0x4 usb_control_msg: request: 0x6, requesttype: 0xA0, value 0x2900 index 0x0 length 0x8 1 ports detected individual port power switching standalone hub global over-current protection power on to power good time: 20ms hub controller current requirement: 0mA port 1 is removable usb_control_msg: request: 0x0, requesttype: 0xA0, value 0x0 index 0x0 length 0x4 get_hub_status returned status 1, change 8101 local power source is lost (inactive) no over-current condition exists enabling power on all ports usb_control_msg: request: 0x3, requesttype: 0x23, value 0x8 index 0x1 length 0x0 port 1 returns 0 usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4 Port 1 Status 101 Change 1 port 1 connection change usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4 portstatus 101, change 1, 12 Mb/s usb_control_msg: request: 0x1, requesttype: 0x23, value 0x10 index 0x1 length 0x0 *hub_port_reset: resetting port 0...* *usb_control_msg: request: 0x3, requesttype: 0x23, value 0x4 index 0x1 length 0x0* *port(0) reset error* *usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4* *portstatus 111, change 0, 12 Mb/s* *STAT_C_CONNECTION = 0 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 0* *usb_control_msg: request: 0x3, requesttype: 0x23, value 0x4 index 0x1 length 0x0* *usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4* *portstatus 101, change 13, 12 Mb/s* *STAT_C_CONNECTION = 1 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 0* *cannot reset port 1!?* 1 USB Device(s) found scan end scanning bus for storage devices... 0 Storage Device(s) found
In 2nd Controller, USB Mass storage detection is inconsistent. Need to test this in U-Boot version U-Boot 2011.12.
-Thanks, Balaji N
Balaji N
