[PATCH 1/2] mx6cuboxi: Fix the mmc device for the rootfs
After the conversion to DM_MMC, the rootfs becomes mmc 1, so adjust it accordingly.
Signed-off-by: Fabio Estevam festevam@gmail.com --- include/configs/mx6cuboxi.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 55717c77ab38..1a06f29b8c17 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -57,7 +57,7 @@ "console=" CONSOLE_DEV ",115200\0" \ "bootm_size=0x10000000\0" \ "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ - "finduuid=part uuid mmc 0:1 uuid\0" \ + "finduuid=part uuid mmc 1:1 uuid\0" \ "update_sd_firmware=" \ "if test ${ip_dyn} = yes; then " \ "setenv get_cmd dhcp; " \
Do not pass the console baudrate to the 'console' variable to avoid the baudrate being passed twice when extlinux.conf contains the standard: console=${console},${baudrate} format.
cat /proc/cmdline root=PARTUUID=00000000-01 rootwait rw console=ttymxc0,115200,115200
Signed-off-by: Fabio Estevam festevam@gmail.com --- include/configs/mx6cuboxi.h | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 1a06f29b8c17..9e5083b0d876 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -38,7 +38,6 @@ /* Command definition */
#define CONFIG_MXC_UART_BASE UART1_BASE -#define CONSOLE_DEV "ttymxc0"
#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ @@ -54,7 +53,7 @@ "ramdiskaddr=0x13000000\0" \ "initrd_high=0xffffffff\0" \ "ip_dyn=yes\0" \ - "console=" CONSOLE_DEV ",115200\0" \ + "console=ttymxc0\0" \ "bootm_size=0x10000000\0" \ "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ "finduuid=part uuid mmc 1:1 uuid\0" \
Maybe we could deal with this using the stdout-path method in DT?
-- 2.25.1
Should this be fixed with an alias in the dts, what's now on mmc 0?
-- 2.25.1
Fabio Estevam
Peter Robinson
