[U-Boot] [PATCH v3] net: Add MT76xx ethernet driver
This patch adds ethernet support for the Mediatek MT76xx SoC, including a minimum setup of the integrated switch. This driver is loosly based on the driver version included in this MediaTek github repository:
https://github.com/MediaTek-Labs/linkit-smart-uboot.git
Tested on the MT7688 LinkIt smart-gateway and on the Gardena-smart-gateway.
Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- v3: - Add Reviewed-by from Daniel - Address review comments from Joe: - Use more macros / defines instead of magic values, especially in the MDIO functions - Use FIELD_xxx from include/linux/bitfield.h whereever possible - Remove some unreferenced defines - Remove some unnecessary casts - Spelling fixes - Add documentation in doc/device-tree-bindings/net/
v2: - Use wait_for_bit_le32() in more places - Use syscon / regmap to access the system-controller registers needed in this driver instead of finding and mapping this area
.../net/mediatek,mt76xx-eth.txt | 17 + drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/mt76xx-eth.c | 635 ++++++++++++++++++ 4 files changed, 660 insertions(+) create mode 100644 doc/device-tree-bindings/net/mediatek,mt76xx-eth.txt create mode 100644 drivers/net/mt76xx-eth.c
diff --git a/doc/device-tree-bindings/net/mediatek,mt76xx-eth.txt b/doc/device-tree-bindings/net/mediatek,mt76xx-eth.txt new file mode 100644 index 0000000000..db035c99d4 --- /dev/null +++ b/doc/device-tree-bindings/net/mediatek,mt76xx-eth.txt @@ -0,0 +1,17 @@ +* MediaTek Frame Engine Ethernet controller + +Required properties: +- compatible: should be "mediatek,mt7622-eth" +- reg: address and length of the register set for the frame + engine ethernet controller and the internal switch. +- syscon: phandle to the system controller + +Example: + +eth@10100000 { + compatible = "mediatek,mt7622-eth"; + reg = <0x10100000 0x10000 + 0x10110000 0x8000>; + + syscon = <&sysc>; +}; diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index f1f0e2d94e..d3ed1c2857 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -227,6 +227,13 @@ config MACB_ZYNQ The Cadence MACB ethernet interface was used on Zynq platform. Say Y to enable support for the MACB/GEM in Zynq chip.
+config MT76XX_ETH + bool "MediaTek MT76xx Ethernet Interface" + depends on ARCH_MT7620 + help + The MediaTek MT76xx ethernet interface is used on MT7688 + based boards. + config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver" depends on DM_ETH && DM_PCI diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 48a2878071..05189514b7 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -37,6 +37,7 @@ obj-$(CONFIG_LPC32XX_ETH) += lpc32xx_eth.o obj-$(CONFIG_MACB) += macb.o obj-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o obj-$(CONFIG_MPC8XX_FEC) += mpc8xx_fec.o +obj-$(CONFIG_MT76XX_ETH) += mt76xx-eth.o obj-$(CONFIG_MVGBE) += mvgbe.o obj-$(CONFIG_MVNETA) += mvneta.o obj-$(CONFIG_MVPP2) += mvpp2.o diff --git a/drivers/net/mt76xx-eth.c b/drivers/net/mt76xx-eth.c new file mode 100644 index 0000000000..e6fa803d97 --- /dev/null +++ b/drivers/net/mt76xx-eth.c @@ -0,0 +1,635 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * MediaTek ethernet IP driver for U-Boot + * + * Copyright (C) 2018 Stefan Roese sr@denx.de + * + * This code is mostly based on the code extracted from this MediaTek + * github repository: + * + * https://github.com/MediaTek-Labs/linkit-smart-uboot.git + * + * I was not able to find a specific license or other developers + * copyrights here, so I can't add them here. + */ + +#include <common.h> +#include <dm.h> +#include <malloc.h> +#include <miiphy.h> +#include <net.h> +#include <regmap.h> +#include <syscon.h> +#include <wait_bit.h> +#include <asm/io.h> +#include <linux/bitfield.h> +#include <linux/err.h> + +/* System controller register */ +#define MT76XX_RSTCTRL_REG 0x34 +#define RSTCTRL_EPHY_RST BIT(24) + +#define MT76XX_AGPIO_CFG_REG 0x3c +#define MT7628_EPHY_GPIO_AIO_EN GENMASK(20, 17) +#define MT7628_EPHY_P0_DIS BIT(16) + +#define MT76XX_GPIO2_MODE_REG 0x64 + +/* Ethernet frame engine register */ +#define PDMA_RELATED 0x0800 + +#define TX_BASE_PTR0 (PDMA_RELATED + 0x000) +#define TX_MAX_CNT0 (PDMA_RELATED + 0x004) +#define TX_CTX_IDX0 (PDMA_RELATED + 0x008) +#define TX_DTX_IDX0 (PDMA_RELATED + 0x00c) + +#define RX_BASE_PTR0 (PDMA_RELATED + 0x100) +#define RX_MAX_CNT0 (PDMA_RELATED + 0x104) +#define RX_CALC_IDX0 (PDMA_RELATED + 0x108) + +#define PDMA_GLO_CFG (PDMA_RELATED + 0x204) +#define PDMA_RST_IDX (PDMA_RELATED + 0x208) +#define DLY_INT_CFG (PDMA_RELATED + 0x20c) + +#define SDM_RELATED 0x0c00 + +#define SDM_MAC_ADRL (SDM_RELATED + 0x0c) /* MAC address LSB */ +#define SDM_MAC_ADRH (SDM_RELATED + 0x10) /* MAC Address MSB */ + +#define RST_DTX_IDX0 BIT(0) +#define RST_DRX_IDX0 BIT(16) + +#define TX_DMA_EN BIT(0) +#define TX_DMA_BUSY BIT(1) +#define RX_DMA_EN BIT(2) +#define RX_DMA_BUSY BIT(3) +#define TX_WB_DDONE BIT(6) + +/* Ethernet switch register */ +#define MT76XX_SWITCH_FCT0 0x0008 +#define MT76XX_SWITCH_PFC1 0x0014 +#define MT76XX_SWITCH_FPA 0x0084 +#define MT76XX_SWITCH_SOCPC 0x008c +#define MT76XX_SWITCH_POC0 0x0090 +#define MT76XX_SWITCH_POC2 0x0098 +#define MT76XX_SWITCH_SGC 0x009c +#define MT76XX_SWITCH_PCR0 0x00c0 +#define PCR0_PHY_ADDR GENMASK(4, 0) +#define PCR0_PHY_REG GENMASK(12, 8) +#define PCR0_WT_PHY_CMD BIT(13) +#define PCR0_RD_PHY_CMD BIT(14) +#define PCR0_WT_DATA GENMASK(31, 16) + +#define MT76XX_SWITCH_PCR1 0x00c4 +#define PCR1_WT_DONE BIT(0) +#define PCR1_RD_RDY BIT(1) +#define PCR1_RD_DATA GENMASK(31, 16) + +#define MT76XX_SWITCH_FPA1 0x00c8 +#define MT76XX_SWITCH_FCT2 0x00cc +#define MT76XX_SWITCH_SGC2 0x00e4 +#define MT76XX_SWITCH_BMU_CTRL 0x0110 + +/* rxd2 */ +#define RX_DMA_DONE BIT(31) +#define RX_DMA_LSO BIT(30) +#define RX_DMA_PLEN0 GENMASK(29, 16) +#define RX_DMA_TAG BIT(15) + +struct fe_rx_dma { + unsigned int rxd1; + unsigned int rxd2; + unsigned int rxd3; + unsigned int rxd4; +} __packed __aligned(4); + +#define TX_DMA_PLEN0 GENMASK(29, 16) +#define TX_DMA_LS1 BIT(14) +#define TX_DMA_LS0 BIT(30) +#define TX_DMA_DONE BIT(31) + +#define TX_DMA_INS_VLAN_MT7621 BIT(16) +#define TX_DMA_INS_VLAN BIT(7) +#define TX_DMA_INS_PPPOE BIT(12) +#define TX_DMA_PN GENMASK(26, 24) + +struct fe_tx_dma { + unsigned int txd1; + unsigned int txd2; + unsigned int txd3; + unsigned int txd4; +} __packed __aligned(4); + +#define NUM_RX_DESC 256 +#define NUM_TX_DESC 4 + +#define PADDING_LENGTH 60 + +#define MTK_QDMA_PAGE_SIZE 2048 + +#define CONFIG_MDIO_TIMEOUT 100 +#define CONFIG_DMA_STOP_TIMEOUT 100 +#define CONFIG_TX_DMA_TIMEOUT 100 + +#define LINK_DELAY_TIME 500 /* 500 ms */ +#define LINK_TIMEOUT 10000 /* 10 seconds */ + +struct mt76xx_eth_dev { + void __iomem *base; /* frame engine base address */ + void __iomem *eth_sw_base; /* switch base address */ + struct regmap *sysctrl_regmap; /* system-controller reg-map */ + + struct mii_dev *bus; + + struct fe_tx_dma *tx_ring; + struct fe_rx_dma *rx_ring; + + u8 *rx_buf[NUM_RX_DESC]; + + /* Point to the next RXD DMA wants to use in RXD Ring0 */ + int rx_dma_idx; + /* Point to the next TXD in TXD Ring0 CPU wants to use */ + int tx_dma_idx; +}; + +static int mdio_wait_read(struct mt76xx_eth_dev *priv, u32 mask, bool mask_set) +{ + void __iomem *base = priv->eth_sw_base; + int ret; + + ret = wait_for_bit_le32(base + MT76XX_SWITCH_PCR1, mask, mask_set, + CONFIG_MDIO_TIMEOUT, false); + if (ret) { + printf("MDIO operation timeout!\n"); + return -ETIMEDOUT; + } + + return 0; +} + +static int mii_mgr_read(struct mt76xx_eth_dev *priv, + u32 phy_addr, u32 phy_register, u32 *read_data) +{ + void __iomem *base = priv->eth_sw_base; + u32 status = 0; + u32 ret; + + *read_data = 0xffff; + /* Make sure previous read operation is complete */ + ret = mdio_wait_read(priv, PCR1_RD_RDY, false); + if (ret) + return ret; + + writel(PCR0_RD_PHY_CMD | + FIELD_PREP(PCR0_PHY_REG, phy_register) | + FIELD_PREP(PCR0_PHY_ADDR, phy_addr), + base + MT76XX_SWITCH_PCR0); + + /* Make sure previous read operation is complete */ + ret = mdio_wait_read(priv, PCR1_RD_RDY, true); + if (ret) + return ret; + + status = readl(base + MT76XX_SWITCH_PCR1); + *read_data = FIELD_GET(PCR1_RD_DATA, status); + + return 0; +} + +static int mii_mgr_write(struct mt76xx_eth_dev *priv, + u32 phy_addr, u32 phy_register, u32 write_data) +{ + void __iomem *base = priv->eth_sw_base; + u32 data; + int ret; + + /* Make sure previous write operation is complete */ + ret = mdio_wait_read(priv, PCR1_WT_DONE, false); + if (ret) + return ret; + + data = FIELD_PREP(PCR0_WT_DATA, write_data) | + FIELD_PREP(PCR0_PHY_REG, phy_register) | + FIELD_PREP(PCR0_PHY_ADDR, phy_addr) | + PCR0_WT_PHY_CMD; + writel(data, base + MT76XX_SWITCH_PCR0); + + return mdio_wait_read(priv, PCR1_WT_DONE, true); +} + +static int mt76xx_mdio_read(struct mii_dev *bus, int addr, int devad, int reg) +{ + u32 val; + int ret; + + ret = mii_mgr_read(bus->priv, addr, reg, &val); + if (ret) + return ret; + + return val; +} + +static int mt76xx_mdio_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value) +{ + return mii_mgr_write(bus->priv, addr, reg, value); +} + +static void mt7628_ephy_init(struct mt76xx_eth_dev *priv) +{ + int i; + + mii_mgr_write(priv, 0, 31, 0x2000); /* change G2 page */ + mii_mgr_write(priv, 0, 26, 0x0000); + + for (i = 0; i < 5; i++) { + mii_mgr_write(priv, i, 31, 0x8000); /* change L0 page */ + mii_mgr_write(priv, i, 0, 0x3100); + + /* EEE disable */ + mii_mgr_write(priv, i, 30, 0xa000); + mii_mgr_write(priv, i, 31, 0xa000); /* change L2 page */ + mii_mgr_write(priv, i, 16, 0x0606); + mii_mgr_write(priv, i, 23, 0x0f0e); + mii_mgr_write(priv, i, 24, 0x1610); + mii_mgr_write(priv, i, 30, 0x1f15); + mii_mgr_write(priv, i, 28, 0x6111); + } + + /* 100Base AOI setting */ + mii_mgr_write(priv, 0, 31, 0x5000); /* change G5 page */ + mii_mgr_write(priv, 0, 19, 0x004a); + mii_mgr_write(priv, 0, 20, 0x015a); + mii_mgr_write(priv, 0, 21, 0x00ee); + mii_mgr_write(priv, 0, 22, 0x0033); + mii_mgr_write(priv, 0, 23, 0x020a); + mii_mgr_write(priv, 0, 24, 0x0000); + mii_mgr_write(priv, 0, 25, 0x024a); + mii_mgr_write(priv, 0, 26, 0x035a); + mii_mgr_write(priv, 0, 27, 0x02ee); + mii_mgr_write(priv, 0, 28, 0x0233); + mii_mgr_write(priv, 0, 29, 0x000a); + mii_mgr_write(priv, 0, 30, 0x0000); + + /* Fix EPHY idle state abnormal behavior */ + mii_mgr_write(priv, 0, 31, 0x4000); /* change G4 page */ + mii_mgr_write(priv, 0, 29, 0x000d); + mii_mgr_write(priv, 0, 30, 0x0500); +} + +static void rt305x_esw_init(struct mt76xx_eth_dev *priv) +{ + void __iomem *base = priv->eth_sw_base; + + /* + * FC_RLS_TH=200, FC_SET_TH=160 + * DROP_RLS=120, DROP_SET_TH=80 + */ + writel(0xc8a07850, base + MT76XX_SWITCH_FCT0); + writel(0x00000000, base + MT76XX_SWITCH_SGC2); + writel(0x00405555, base + MT76XX_SWITCH_PFC1); + writel(0x00007f7f, base + MT76XX_SWITCH_POC0); + writel(0x00007f7f, base + MT76XX_SWITCH_POC2); /* disable VLAN */ + writel(0x0002500c, base + MT76XX_SWITCH_FCT2); + /* hashing algorithm=XOR48, aging interval=300sec */ + writel(0x0008a301, base + MT76XX_SWITCH_SGC); + writel(0x02404040, base + MT76XX_SWITCH_SOCPC); + + /* Ext PHY Addr=0x1f */ + writel(0x3f502b28, base + MT76XX_SWITCH_FPA1); + writel(0x00000000, base + MT76XX_SWITCH_FPA); + /* 1us cycle number=125 (FE's clock=125Mhz) */ + writel(0x7d000000, base + MT76XX_SWITCH_BMU_CTRL); + + /* Configure analog GPIO setup */ + regmap_update_bits(priv->sysctrl_regmap, MT76XX_AGPIO_CFG_REG, + MT7628_EPHY_P0_DIS, MT7628_EPHY_GPIO_AIO_EN); + + /* Reset PHY */ + regmap_update_bits(priv->sysctrl_regmap, MT76XX_RSTCTRL_REG, + 0, RSTCTRL_EPHY_RST); + regmap_update_bits(priv->sysctrl_regmap, MT76XX_RSTCTRL_REG, + RSTCTRL_EPHY_RST, 0); + mdelay(10); + + /* Set P0 EPHY LED mode */ + regmap_update_bits(priv->sysctrl_regmap, MT76XX_GPIO2_MODE_REG, + 0x0ffc0ffc, 0x05540554); + mdelay(10); + + mt7628_ephy_init(priv); +} + +static void eth_dma_start(struct mt76xx_eth_dev *priv) +{ + void __iomem *base = priv->base; + + setbits_le32(base + PDMA_GLO_CFG, TX_WB_DDONE | RX_DMA_EN | TX_DMA_EN); +} + +static void eth_dma_stop(struct mt76xx_eth_dev *priv) +{ + void __iomem *base = priv->base; + int ret; + + clrbits_le32(base + PDMA_GLO_CFG, TX_WB_DDONE | RX_DMA_EN | TX_DMA_EN); + + /* Wait for DMA to stop */ + ret = wait_for_bit_le32(base + PDMA_GLO_CFG, + RX_DMA_BUSY | TX_DMA_BUSY, false, + CONFIG_DMA_STOP_TIMEOUT, false); + if (ret) + printf("DMA stop timeout error!\n"); +} + +static int mt76xx_eth_write_hwaddr(struct udevice *dev) +{ + struct mt76xx_eth_dev *priv = dev_get_priv(dev); + void __iomem *base = priv->base; + u8 *addr = ((struct eth_pdata *)dev_get_platdata(dev))->enetaddr; + u32 val; + u16 tmp; + + /* Set MAC address. */ + tmp = addr[0]; + val = (tmp << 8) | addr[1]; + writel(val, base + SDM_MAC_ADRH); + + tmp = addr[2]; + val = (tmp << 8) | addr[3]; + val = val << 16; + tmp = addr[4]; + val |= (tmp << 8) | addr[5]; + writel(val, base + SDM_MAC_ADRL); + + return 0; +} + +static int mt76xx_eth_send(struct udevice *dev, void *packet, int length) +{ + struct mt76xx_eth_dev *priv = dev_get_priv(dev); + void __iomem *base = priv->base; + int ret; + int idx; + int i; + + idx = priv->tx_dma_idx; + + /* Pad message to a minimum length */ + if (length < PADDING_LENGTH) { + char *p = (char *)packet; + + for (i = 0; i < PADDING_LENGTH - length; i++) + p[length + i] = 0; + length = PADDING_LENGTH; + } + + /* Check if buffer is ready for next TX DMA */ + ret = wait_for_bit_le32(&priv->tx_ring[idx].txd2, TX_DMA_DONE, true, + CONFIG_TX_DMA_TIMEOUT, false); + if (ret) { + printf("TX: DMA still busy on buffer %d\n", idx); + return ret; + } + + flush_dcache_range((u32)packet, (u32)packet + length); + + priv->tx_ring[idx].txd1 = CPHYSADDR(packet); + priv->tx_ring[idx].txd2 &= ~TX_DMA_PLEN0; + priv->tx_ring[idx].txd2 |= FIELD_PREP(TX_DMA_PLEN0, length); + priv->tx_ring[idx].txd2 &= ~TX_DMA_DONE; + + idx = (idx + 1) % NUM_TX_DESC; + + /* Make sure the writes executed at this place */ + wmb(); + writel(idx, base + TX_CTX_IDX0); + + priv->tx_dma_idx = idx; + + return 0; +} + +static int mt76xx_eth_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct mt76xx_eth_dev *priv = dev_get_priv(dev); + void __iomem *base = priv->base; + u32 rxd_info; + int length; + int idx; + + idx = priv->rx_dma_idx; + + rxd_info = priv->rx_ring[idx].rxd2; + if ((rxd_info & RX_DMA_DONE) == 0) + return -EAGAIN; + + length = FIELD_GET(RX_DMA_PLEN0, priv->rx_ring[idx].rxd2); + if (length == 0 || length > MTK_QDMA_PAGE_SIZE) { + printf("%s: invalid length (%d bytes)\n", __func__, length); + return -EIO; + } + + *packetp = priv->rx_buf[idx]; + invalidate_dcache_range((u32)*packetp, (u32)*packetp + length); + + priv->rx_ring[idx].rxd4 = 0; + priv->rx_ring[idx].rxd2 = RX_DMA_LSO; + + /* Make sure the writes executed at this place */ + wmb(); + + /* Move point to next RXD which wants to alloc */ + writel(idx, base + RX_CALC_IDX0); + + /* Update to Next packet point that was received */ + idx = (idx + 1) % NUM_RX_DESC; + + priv->rx_dma_idx = idx; + + return length; +} + +static int phy_link_up(struct mt76xx_eth_dev *priv) +{ + u32 val; + + mii_mgr_read(priv, 0x00, MII_BMSR, &val); + return !!(val & BMSR_LSTATUS); +} + +static int mt76xx_eth_start(struct udevice *dev) +{ + struct mt76xx_eth_dev *priv = dev_get_priv(dev); + void __iomem *base = priv->base; + uchar packet[MTK_QDMA_PAGE_SIZE]; + uchar *packetp; + int i; + + for (i = 0; i < NUM_RX_DESC; i++) { + memset((void *)&priv->rx_ring[i], 0, sizeof(priv->rx_ring[0])); + priv->rx_ring[i].rxd2 |= RX_DMA_LSO; + priv->rx_ring[i].rxd1 = CPHYSADDR(priv->rx_buf[i]); + } + + for (i = 0; i < NUM_TX_DESC; i++) { + memset((void *)&priv->tx_ring[i], 0, sizeof(priv->tx_ring[0])); + priv->tx_ring[i].txd2 = TX_DMA_LS0 | TX_DMA_DONE; + priv->tx_ring[i].txd4 = FIELD_PREP(TX_DMA_PN, 1); + } + + priv->rx_dma_idx = 0; + priv->tx_dma_idx = 0; + + /* Make sure the writes executed at this place */ + wmb(); + + /* disable delay interrupt */ + writel(0, base + DLY_INT_CFG); + + clrbits_le32(base + PDMA_GLO_CFG, 0xffff0000); + + /* Tell the adapter where the TX/RX rings are located. */ + writel(CPHYSADDR(&priv->rx_ring[0]), base + RX_BASE_PTR0); + writel(CPHYSADDR((u32)&priv->tx_ring[0]), base + TX_BASE_PTR0); + + writel(NUM_RX_DESC, base + RX_MAX_CNT0); + writel(NUM_TX_DESC, base + TX_MAX_CNT0); + + writel(priv->tx_dma_idx, base + TX_CTX_IDX0); + writel(RST_DTX_IDX0, base + PDMA_RST_IDX); + + writel(NUM_RX_DESC - 1, base + RX_CALC_IDX0); + writel(RST_DRX_IDX0, base + PDMA_RST_IDX); + + /* Make sure the writes executed at this place */ + wmb(); + eth_dma_start(priv); + + /* Check if link is not up yet */ + if (!phy_link_up(priv)) { + /* Wait for link to come up */ + + printf("Waiting for link to come up ."); + for (i = 0; i < (LINK_TIMEOUT / LINK_DELAY_TIME); i++) { + mdelay(LINK_DELAY_TIME); + if (phy_link_up(priv)) { + mdelay(100); /* Ensure all is ready */ + break; + } + + printf("."); + } + + if (phy_link_up(priv)) + printf(" done\n"); + else + printf(" timeout! Trying anyways\n"); + } + + /* + * The integrated switch seems to queue some received ethernet + * packets in some FIFO. Lets read the already queued packets + * out by using the receive routine, so that these old messages + * are dropped before the new xfer starts. + */ + packetp = &packet[0]; + while (mt76xx_eth_recv(dev, 0, &packetp) != -EAGAIN) + ; + + return 0; +} + +static void mt76xx_eth_stop(struct udevice *dev) +{ + struct mt76xx_eth_dev *priv = dev_get_priv(dev); + + eth_dma_stop(priv); +} + +static int mt76xx_eth_probe(struct udevice *dev) +{ + struct mt76xx_eth_dev *priv = dev_get_priv(dev); + struct udevice *syscon; + struct mii_dev *bus; + int ret; + int i; + + /* Save frame-engine base address for later use */ + priv->base = dev_remap_addr_index(dev, 0); + if (IS_ERR(priv->base)) + return PTR_ERR(priv->base); + + /* Save switch base address for later use */ + priv->eth_sw_base = dev_remap_addr_index(dev, 1); + if (IS_ERR(priv->eth_sw_base)) + return PTR_ERR(priv->eth_sw_base); + + /* Get system controller regmap */ + ret = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, + "syscon", &syscon); + if (ret) { + pr_err("unable to find syscon device\n"); + return ret; + } + + priv->sysctrl_regmap = syscon_get_regmap(syscon); + if (!priv->sysctrl_regmap) { + pr_err("unable to find regmap\n"); + return -ENODEV; + } + + /* Put rx and tx rings into KSEG1 area (uncached) */ + priv->tx_ring = (struct fe_tx_dma *) + KSEG1ADDR(memalign(ARCH_DMA_MINALIGN, + sizeof(*priv->tx_ring) * NUM_TX_DESC)); + priv->rx_ring = (struct fe_rx_dma *) + KSEG1ADDR(memalign(ARCH_DMA_MINALIGN, + sizeof(*priv->rx_ring) * NUM_RX_DESC)); + + for (i = 0; i < NUM_RX_DESC; i++) + priv->rx_buf[i] = memalign(PKTALIGN, MTK_QDMA_PAGE_SIZE); + + bus = mdio_alloc(); + if (!bus) { + printf("Failed to allocate MDIO bus\n"); + return -ENOMEM; + } + + bus->read = mt76xx_mdio_read; + bus->write = mt76xx_mdio_write; + snprintf(bus->name, sizeof(bus->name), dev->name); + bus->priv = (void *)priv; + + ret = mdio_register(bus); + if (ret) + return ret; + + /* Switch configuration */ + rt305x_esw_init(priv); + + return 0; +} + +static const struct eth_ops mt76xx_eth_ops = { + .start = mt76xx_eth_start, + .send = mt76xx_eth_send, + .recv = mt76xx_eth_recv, + .stop = mt76xx_eth_stop, + .write_hwaddr = mt76xx_eth_write_hwaddr, +}; + +static const struct udevice_id mt76xx_eth_ids[] = { + { .compatible = "mediatek,mt7622-eth" }, + { } +}; + +U_BOOT_DRIVER(mt76xx_eth) = { + .name = "mt76xx_eth", + .id = UCLASS_ETH, + .of_match = mt76xx_eth_ids, + .probe = mt76xx_eth_probe, + .ops = &mt76xx_eth_ops, + .priv_auto_alloc_size = sizeof(struct mt76xx_eth_dev), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +};
Stefan Roese
