[PATCH v2] arm: dts: kirkwood: Enable upstream DT on Kirkwood boards
Enable OF_UPSTREAM to use upstream DT and add marvell/ prefix to the DEFAULT_DEVICE_TREE for Kirkwood boards. And so we can directly build DTBs from dts/upstream/src/arm/marvell, and including *-u-boot.dtsi files from arch/arm/dts/ directory.
Background:
Hi Stefan, Hi Michael,
I did a survey and we currently have 28 Kirkwood boards. Using some commands and filters, here are the finding.
git grep -li arch_kirkwood configs | xargs grep DEVICE_TREE | cut -d '"' -f2 | xargs -n1 sh -c 'diff -qs arch/arm/dts/$1.dts dts/upstream/src/arm/marvell/$1.dts' sh | grep differ
diff: dts/upstream/src/arm/marvell/kirkwood-atl-sbx81lifkw.dts: No such file or directory diff: dts/upstream/src/arm/marvell/kirkwood-atl-sbx81lifxcat.dts: No such file or directory
Files arch/arm/dts/kirkwood-dockstar.dts and dts/upstream/src/arm/marvell/kirkwood-dockstar.dts differ Files arch/arm/dts/kirkwood-dreamplug.dts and dts/upstream/src/arm/marvell/kirkwood-dreamplug.dts differ Files arch/arm/dts/kirkwood-goflexnet.dts and dts/upstream/src/arm/marvell/kirkwood-goflexnet.dts differ Files arch/arm/dts/kirkwood-guruplug-server-plus.dts and dts/upstream/src/arm/marvell/kirkwood-guruplug-server-plus.dts differ Files arch/arm/dts/kirkwood-iconnect.dts and dts/upstream/src/arm/marvell/kirkwood-iconnect.dts differ Files arch/arm/dts/kirkwood-net2big.dts and dts/upstream/src/arm/marvell/kirkwood-net2big.dts differ Files arch/arm/dts/kirkwood-ns2max.dts and dts/upstream/src/arm/marvell/kirkwood-ns2max.dts differ Files arch/arm/dts/kirkwood-ns2mini.dts and dts/upstream/src/arm/marvell/kirkwood-ns2mini.dts differ Files arch/arm/dts/kirkwood-nsa310s.dts and dts/upstream/src/arm/marvell/kirkwood-nsa310s.dts differ Files arch/arm/dts/kirkwood-nsa325.dts and dts/upstream/src/arm/marvell/kirkwood-nsa325.dts differ Files arch/arm/dts/kirkwood-openrd-client.dts and dts/upstream/src/arm/marvell/kirkwood-openrd-client.dts differ
diff -qrbu arch/arm/dts/ dts/upstream/src/arm/marvell/ | grep kirkwood | grep ".dtsi "
Files arch/arm/dts/kirkwood-6192.dtsi and dts/upstream/src/arm/marvell/kirkwood-6192.dtsi differ Files arch/arm/dts/kirkwood-6281.dtsi and dts/upstream/src/arm/marvell/kirkwood-6281.dtsi differ Files arch/arm/dts/kirkwood-98dx4122.dtsi and dts/upstream/src/arm/marvell/kirkwood-98dx4122.dtsi differ Files arch/arm/dts/kirkwood-dnskw.dtsi and dts/upstream/src/arm/marvell/kirkwood-dnskw.dtsi differ Files arch/arm/dts/kirkwood.dtsi and dts/upstream/src/arm/marvell/kirkwood.dtsi differ Files arch/arm/dts/kirkwood-lsxl.dtsi and dts/upstream/src/arm/marvell/kirkwood-lsxl.dtsi differ Files arch/arm/dts/kirkwood-nsa3x0-common.dtsi and dts/upstream/src/arm/marvell/kirkwood-nsa3x0-common.dtsi differ Files arch/arm/dts/kirkwood-synology.dtsi and dts/upstream/src/arm/marvell/kirkwood-synology.dtsi differ
And after reviewing these differences, the following are my observation.
OF_LIST is not used in these Kirkwood boards.
1. Boards that have only u-boot DTS that should be opt-out for now with "#CONFIG_OF_UPSTREAM is not set"
2. DTS and DTSI files that have only cosmetic, style, or binding changes (safe to take)
Files arch/arm/dts/kirkwood-dockstar.dts and dts/upstream/src/arm/marvell/kirkwood-dockstar.dts differ Files arch/arm/dts/kirkwood-goflexnet.dts and dts/upstream/src/arm/marvell/kirkwood-goflexnet.dts differ Files arch/arm/dts/kirkwood-guruplug-server-plus.dts and dts/upstream/src/arm/marvell/kirkwood-guruplug-server-plus.dts differ Files arch/arm/dts/kirkwood-iconnect.dts and dts/upstream/src/arm/marvell/kirkwood-iconnect.dts differ Files arch/arm/dts/kirkwood-net2big.dts and dts/upstream/src/arm/marvell/kirkwood-net2big.dts differ Files arch/arm/dts/kirkwood-ns2max.dts and dts/upstream/src/arm/marvell/kirkwood-ns2max.dts differ Files arch/arm/dts/kirkwood-ns2mini.dts and dts/upstream/src/arm/marvell/kirkwood-ns2mini.dts differ Files arch/arm/dts/kirkwood-nsa325.dts and dts/upstream/src/arm/marvell/kirkwood-nsa325.dts differ Files arch/arm/dts/kirkwood-openrd-client.dts and dts/upstream/src/arm/marvell/kirkwood-openrd-client.dts differ
Files arch/arm/dts/kirkwood-dnskw.dtsi and dts/upstream/src/arm/marvell/kirkwood-dnskw.dtsi differ Files arch/arm/dts/kirkwood.dtsi and dts/upstream/src/arm/marvell/kirkwood.dtsi differ Files arch/arm/dts/kirkwood-synology.dtsi and dts/upstream/src/arm/marvell/kirkwood-synology.dtsi differ
3. DTS files that are newer in upstream (safe to take with regression test)
4. DTSI files that have additional PCI-related bindings in upstream (safe to take with regression test)
5. DTSI files that will need new or modified -u-boot.dtsi
Files arch/arm/dts/kirkwood-dreamplug.dts and dts/upstream/src/arm/marvell/kirkwood-dreamplug.dts differ Files arch/arm/dts/kirkwood-lsxl.dtsi and dts/upstream/src/arm/marvell/kirkwood-lsxl.dtsi differ Files arch/arm/dts/kirkwood-nsa3x0-common.dtsi and dts/upstream/src/arm/marvell/kirkwood-nsa3x0-common.dtsi differ
So these u-boot.dtsi files need to be created/modified so we can use upstream DTS/DTSI:
modified: arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi modified: arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi
new file: arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi new file: arch/arm/dts/kirkwood-nsa325-u-boot.dtsi
I've regression tested this patch with the Zyxel NSA325 (Kirkwood 88F6282) and Zyxel NSA310S (Kirkwood 88F6281). The Zyxel NSA325 board has a USB 3.0 controller attached to the PCIe bus. And the Zyxel NSA310S has an extensive overhaul in bindings and styles in upstream DTS version.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
Changes in v2: Remove unnecessary redefined OF_UPSTREAM and use "imply OF_UPSTREAM" for KW88F6281 and KW88F6192 SoCs.
arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi | 7 +++++++ arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi | 6 ++++-- arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi | 6 ++++-- arch/arm/dts/kirkwood-nsa325-u-boot.dtsi | 7 +++++++ arch/arm/mach-kirkwood/Kconfig | 2 ++ configs/SBx81LIFKW_defconfig | 1 + configs/SBx81LIFXCAT_defconfig | 1 + configs/d2net_v2_defconfig | 2 +- configs/dns325_defconfig | 2 +- configs/dockstar_defconfig | 2 +- configs/dreamplug_defconfig | 2 +- configs/ds109_defconfig | 2 +- configs/goflexhome_defconfig | 2 +- configs/guruplug_defconfig | 2 +- configs/ib62x0_defconfig | 2 +- configs/iconnect_defconfig | 2 +- configs/inetspace_v2_defconfig | 2 +- configs/lschlv2_defconfig | 2 +- configs/lsxhl_defconfig | 2 +- configs/nas220_defconfig | 2 +- configs/net2big_v2_defconfig | 2 +- configs/netspace_lite_v2_defconfig | 2 +- configs/netspace_max_v2_defconfig | 2 +- configs/netspace_mini_v2_defconfig | 2 +- configs/netspace_v2_defconfig | 2 +- configs/nsa310s_defconfig | 2 +- configs/nsa325_defconfig | 2 +- configs/openrd_base_defconfig | 2 +- configs/openrd_client_defconfig | 2 +- configs/openrd_ultimate_defconfig | 2 +- configs/pogo_e02_defconfig | 2 +- configs/pogo_v4_defconfig | 2 +- configs/sheevaplug_defconfig | 2 +- 33 files changed, 52 insertions(+), 30 deletions(-) create mode 100644 arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi create mode 100644 arch/arm/dts/kirkwood-nsa325-u-boot.dtsi
diff --git a/arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi b/arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi new file mode 100644 index 0000000000..59f19a211f --- /dev/null +++ b/arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/ { + aliases { + spi0 = &spi0; + }; +}; diff --git a/arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi b/arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi index 7fc2d7d3b4..cf33ff822e 100644 --- a/arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi +++ b/arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi @@ -1,7 +1,9 @@ // SPDX-License-Identifier: GPL-2.0+
-ð0 { - status = "disabled"; +/ { + aliases { + spi0 = &spi0; + }; };
&hdd_power { diff --git a/arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi b/arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi index 7fc2d7d3b4..cf33ff822e 100644 --- a/arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi +++ b/arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi @@ -1,7 +1,9 @@ // SPDX-License-Identifier: GPL-2.0+
&hdd_power { diff --git a/arch/arm/dts/kirkwood-nsa325-u-boot.dtsi b/arch/arm/dts/kirkwood-nsa325-u-boot.dtsi new file mode 100644 index 0000000000..dec27b2a87 --- /dev/null +++ b/arch/arm/dts/kirkwood-nsa325-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ + +&nand { + partition@0 { + /delete-property/ read-only; + }; +}; diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index c2fff84a68..031d4e5ecd 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -6,10 +6,12 @@ config FEROCEON_88FR131 config KW88F6192 bool select ARCH_VERY_EARLY_INIT + imply OF_UPSTREAM
config KW88F6281 bool select ARCH_VERY_EARLY_INIT + imply OF_UPSTREAM
config SHEEVA_88SV131 bool diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index cc17a8b114..977daf9f09 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_KWD_CONFIG="board/alliedtelesis/SBx81LIFKW/kwbimage.cfg" CONFIG_TEXT_BASE=0x00600000 CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 +# CONFIG_OF_UPSTREAM is not set CONFIG_TARGET_SBx81LIFKW=y CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xC0000 diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index 0612723298..9bc8614030 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_KWD_CONFIG="board/alliedtelesis/SBx81LIFXCAT/kwbimage.cfg" CONFIG_TEXT_BASE=0x00600000 CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 +# CONFIG_OF_UPSTREAM is not set CONFIG_TARGET_SBx81LIFXCAT=y CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xC0000 diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index bb1bcb0aa3..69658a2ba7 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_NET2BIG_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-d2net" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-d2net" CONFIG_IDENT_STRING=" D2 v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index edfe92c5f3..b85f7cac8e 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_DNS325=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dns325" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-dns325" CONFIG_IDENT_STRING="\nD-Link DNS-325" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 719fa3979e..7b5f19433a 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_DOCKSTAR=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dockstar" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-dockstar" CONFIG_IDENT_STRING="\nSeagate FreeAgent DockStar" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_BOOTDELAY=3 diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index 02a2635af8..8518eabcb2 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -13,7 +13,7 @@ CONFIG_TARGET_DREAMPLUG=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x100000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dreamplug" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-dreamplug" CONFIG_IDENT_STRING="\nMarvell-DreamPlug" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x100000 diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 304c098c99..ef805eca56 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -14,7 +14,7 @@ CONFIG_TARGET_DS109=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x3D0000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ds109" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ds109" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x3D0000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index d577d5807b..53b2ce97e8 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_GOFLEXHOME=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-goflexnet" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-goflexnet" CONFIG_IDENT_STRING="\nSeagate GoFlex Home" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_BOOTDELAY=3 diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 7cb649e29c..5371ee403b 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_GURUPLUG=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-guruplug-server-plus" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-guruplug-server-plus" CONFIG_IDENT_STRING="\nMarvell-GuruPlug" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 074384e387..32b0e1c395 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_IB62X0=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ib62x0" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ib62x0" CONFIG_IDENT_STRING=" RaidSonic ICY BOX IB-NAS62x0" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index f7b74c4662..45ffbd92db 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_ICONNECT=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-iconnect" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-iconnect" CONFIG_IDENT_STRING=" Iomega iConnect" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_PCI=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 2e8e3f3928..3fa7790d77 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-is2" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-is2" CONFIG_IDENT_STRING=" IS v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 99bdbc1483..ad060079a7 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -15,7 +15,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lschlv2" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-lschlv2" CONFIG_IDENT_STRING=" LS-CHLv2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index bb0a5ddf50..b2d9f0c9d8 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -16,7 +16,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lsxhl" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-lsxhl" CONFIG_IDENT_STRING=" LS-XHL" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index f01b26f2df..4ea342a043 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_NAS220=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0xA0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-blackarmor-nas220" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-blackarmor-nas220" CONFIG_IDENT_STRING="\nNAS 220" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index dda627aac6..39cbc3384f 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NET2BIG_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-net2big" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-net2big" CONFIG_IDENT_STRING=" 2Big v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 742e6205d8..cd416cb150 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_LITE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2lite" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2lite" CONFIG_IDENT_STRING=" NS v2 Lite" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 7779e6815e..6a3d9296ac 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_MAX_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2max" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2max" CONFIG_IDENT_STRING=" NS Max v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 9e3614bb44..e25631b09f 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_MINI_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2mini" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2mini" CONFIG_IDENT_STRING=" NS v2 Mini" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 1583a0adb3..b6ac2a8b19 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2" CONFIG_IDENT_STRING=" NS v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 89d8b18b16..e859a43ffa 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NSA310S=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-nsa310s" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-nsa310s" CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=166666667 CONFIG_IDENT_STRING="\nZyXEL NSA310S/320S 1/2-Bay Power Media Server" diff --git a/configs/nsa325_defconfig b/configs/nsa325_defconfig index 5da4a002b4..88a890002e 100644 --- a/configs/nsa325_defconfig +++ b/configs/nsa325_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NSA325=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-nsa325" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-nsa325" CONFIG_IDENT_STRING="\nZyXEL NSA325 2-Bay Power Media Server" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_PCI=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 29a14e0927..057dd28dff 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -11,7 +11,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_OPENRD=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-base" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-openrd-base" CONFIG_IDENT_STRING="\nOpenRD-Base" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index a95a435bdf..05e4292764 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -12,7 +12,7 @@ CONFIG_TARGET_OPENRD=y CONFIG_BOARD_IS_OPENRD_CLIENT=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-client" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-openrd-client" CONFIG_IDENT_STRING="\nOpenRD-Client" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index e3f5294ff1..6e13c6eabd 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -12,7 +12,7 @@ CONFIG_TARGET_OPENRD=y CONFIG_BOARD_IS_OPENRD_ULTIMATE=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-ultimate" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-openrd-ultimate" CONFIG_IDENT_STRING="\nOpenRD-Ultimate" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index e53ccf34c7..880cb20b22 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_POGO_E02=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogo_e02" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-pogo_e02" CONFIG_IDENT_STRING="\nPogo E02" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_BOOTDELAY=3 diff --git a/configs/pogo_v4_defconfig b/configs/pogo_v4_defconfig index 95e22b3fef..50046e83b7 100644 --- a/configs/pogo_v4_defconfig +++ b/configs/pogo_v4_defconfig @@ -12,7 +12,7 @@ CONFIG_TEXT_BASE=0x600000 CONFIG_TARGET_POGO_V4=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogoplug-series-4" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-pogoplug-series-4" CONFIG_IDENT_STRING="\nPogoplug V4" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_PCI=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 0af87dc4fb..b673b3f6da 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_SHEEVAPLUG=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-sheevaplug" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-sheevaplug" CONFIG_IDENT_STRING="\nMarvell-Sheevaplug" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y
Background:
- Boards that have only u-boot DTS that should be opt-out for now with "#CONFIG_OF_UPSTREAM is not set"
- DTS and DTSI files that have only cosmetic, style, or binding changes (safe to take)
- DTS files that are newer in upstream (safe to take with regression test)
- DTSI files that have additional PCI-related bindings in upstream (safe to take with regression test)
- DTSI files that will need new or modified -u-boot.dtsi
modified: arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi modified: arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi new file: arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi new file: arch/arm/dts/kirkwood-nsa325-u-boot.dtsi
Acked-by: Sumit Garg sumit.garg@linaro.org
-Sumit
aliases {
spi0 = &spi0;
-ð0 {
aliases {
spi0 = &spi0;
-ð0 {
aliases {
spi0 = &spi0;
+&nand {
partition@0 {
imply OF_UPSTREAM
imply OF_UPSTREAM
config SHEEVA_88SV131 bool diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index cc17a8b114..977daf9f09 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_KWD_CONFIG="board/alliedtelesis/SBx81LIFKW/kwbimage.cfg" CONFIG_TEXT_BASE=0x00600000 CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 +# CONFIG_OF_UPSTREAM is not set CONFIG_TARGET_SBx81LIFKW=y CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xC0000 diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index 0612723298..9bc8614030 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_KWD_CONFIG="board/alliedtelesis/SBx81LIFXCAT/kwbimage.cfg" CONFIG_TEXT_BASE=0x00600000 CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 +# CONFIG_OF_UPSTREAM is not set CONFIG_TARGET_SBx81LIFXCAT=y CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xC0000 diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index bb1bcb0aa3..69658a2ba7 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_NET2BIG_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-d2net" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-d2net" CONFIG_IDENT_STRING=" D2 v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index edfe92c5f3..b85f7cac8e 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_DNS325=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dns325" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-dns325" CONFIG_IDENT_STRING="\nD-Link DNS-325" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 719fa3979e..7b5f19433a 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_DOCKSTAR=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dockstar" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-dockstar" CONFIG_IDENT_STRING="\nSeagate FreeAgent DockStar" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_BOOTDELAY=3 diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index 02a2635af8..8518eabcb2 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -13,7 +13,7 @@ CONFIG_TARGET_DREAMPLUG=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x100000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dreamplug" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-dreamplug" CONFIG_IDENT_STRING="\nMarvell-DreamPlug" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x100000 diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 304c098c99..ef805eca56 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -14,7 +14,7 @@ CONFIG_TARGET_DS109=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x3D0000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ds109" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ds109" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x3D0000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index d577d5807b..53b2ce97e8 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_GOFLEXHOME=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-goflexnet" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-goflexnet" CONFIG_IDENT_STRING="\nSeagate GoFlex Home" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_BOOTDELAY=3 diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 7cb649e29c..5371ee403b 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_GURUPLUG=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-guruplug-server-plus" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-guruplug-server-plus" CONFIG_IDENT_STRING="\nMarvell-GuruPlug" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 074384e387..32b0e1c395 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_IB62X0=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ib62x0" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ib62x0" CONFIG_IDENT_STRING=" RaidSonic ICY BOX IB-NAS62x0" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index f7b74c4662..45ffbd92db 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_ICONNECT=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-iconnect" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-iconnect" CONFIG_IDENT_STRING=" Iomega iConnect" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_PCI=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 2e8e3f3928..3fa7790d77 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-is2" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-is2" CONFIG_IDENT_STRING=" IS v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 99bdbc1483..ad060079a7 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -15,7 +15,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lschlv2" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-lschlv2" CONFIG_IDENT_STRING=" LS-CHLv2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index bb0a5ddf50..b2d9f0c9d8 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -16,7 +16,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lsxhl" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-lsxhl" CONFIG_IDENT_STRING=" LS-XHL" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index f01b26f2df..4ea342a043 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_NAS220=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0xA0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-blackarmor-nas220" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-blackarmor-nas220" CONFIG_IDENT_STRING="\nNAS 220" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index dda627aac6..39cbc3384f 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NET2BIG_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-net2big" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-net2big" CONFIG_IDENT_STRING=" 2Big v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 742e6205d8..cd416cb150 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_LITE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2lite" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2lite" CONFIG_IDENT_STRING=" NS v2 Lite" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 7779e6815e..6a3d9296ac 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_MAX_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2max" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2max" CONFIG_IDENT_STRING=" NS Max v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 9e3614bb44..e25631b09f 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_MINI_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2mini" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2mini" CONFIG_IDENT_STRING=" NS v2 Mini" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 1583a0adb3..b6ac2a8b19 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2" CONFIG_IDENT_STRING=" NS v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 89d8b18b16..e859a43ffa 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NSA310S=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-nsa310s" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-nsa310s" CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=166666667 CONFIG_IDENT_STRING="\nZyXEL NSA310S/320S 1/2-Bay Power Media Server" diff --git a/configs/nsa325_defconfig b/configs/nsa325_defconfig index 5da4a002b4..88a890002e 100644 --- a/configs/nsa325_defconfig +++ b/configs/nsa325_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NSA325=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-nsa325" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-nsa325" CONFIG_IDENT_STRING="\nZyXEL NSA325 2-Bay Power Media Server" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_PCI=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 29a14e0927..057dd28dff 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -11,7 +11,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_OPENRD=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-base" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-openrd-base" CONFIG_IDENT_STRING="\nOpenRD-Base" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index a95a435bdf..05e4292764 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -12,7 +12,7 @@ CONFIG_TARGET_OPENRD=y CONFIG_BOARD_IS_OPENRD_CLIENT=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-client" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-openrd-client" CONFIG_IDENT_STRING="\nOpenRD-Client" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index e3f5294ff1..6e13c6eabd 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -12,7 +12,7 @@ CONFIG_TARGET_OPENRD=y CONFIG_BOARD_IS_OPENRD_ULTIMATE=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-ultimate" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-openrd-ultimate" CONFIG_IDENT_STRING="\nOpenRD-Ultimate" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index e53ccf34c7..880cb20b22 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_POGO_E02=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogo_e02" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-pogo_e02" CONFIG_IDENT_STRING="\nPogo E02" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_BOOTDELAY=3 diff --git a/configs/pogo_v4_defconfig b/configs/pogo_v4_defconfig index 95e22b3fef..50046e83b7 100644 --- a/configs/pogo_v4_defconfig +++ b/configs/pogo_v4_defconfig @@ -12,7 +12,7 @@ CONFIG_TEXT_BASE=0x600000 CONFIG_TARGET_POGO_V4=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogoplug-series-4" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-pogoplug-series-4" CONFIG_IDENT_STRING="\nPogoplug V4" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_PCI=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 0af87dc4fb..b673b3f6da 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_SHEEVAPLUG=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-sheevaplug" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-sheevaplug" CONFIG_IDENT_STRING="\nMarvell-Sheevaplug" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y -- 2.39.2
Background:
Are you sure you want to have all this text in the commit log?
You seem to have forgotten my tag: Tested-by: Michael Walle michael@walle.cc # on lschv2
Hi Tony,
Background:
This is also my concern. Even though I love descriptive commit messages, this seems to be a bit too much IMHO. Not sure if and how to get these findings of yours archived otherwise.
Tony, many thanks to work on this consolidation. Very impressive results. I can't test anything of this though, but my plan would be to pull this in the upcoming merge window, if nobody complains.
Thanks, Stefan
Hi Michael, Hi Stefan,
It seems either the Denx server or Gmail has failed to send/deliver Stefan's response to my Inbox. Luckily, I also monitored lore.kernel.org and I saw the response. So I'd like to answer that below.
Background:
Please see my response to you and Stefan below.
My bad!
Stefan's comment (about the large commit text): "This is also my concern. Even though I love descriptive commit messages, this seems to be a bit too much IMHO. Not sure if and how to get these findings of yours archived otherwise."
I can send a V3 patch. I will cut out the Background stuff and point it to: https://lore.kernel.org/u-boot/55229181-3aff-4bff-afb5-df778f5f1849@denx.de/... And also I will collect Michael's Test-by tag and your Review-by tag in the commit description.
Does that sound OK?
Stefan's comment: "Tony, many thanks to work on this consolidation. Very impressive results. I can't test anything of this though, but my plan would be to pull this in the upcoming merge window, if nobody complains." Reviewed-by: Stefan Roese sr@denx.de"
I think between Michael and I, we've tested 3 representative Kirkwood boards. Time permitted, I will update u-boot for a few of my other Kirkwood boards, and will send patches if I see any regression.
All the best, Tony
Michael Walle
Stefan Roese
Sumit Garg
Tony Dinh
