[BUG] network is broken on Orange Pi PC
Dear all,
network is broken in U-Boot on orangepi_pc_defconfig:
U-Boot 2021.07-rc3-00059-gd8729a114e (May 31 2021 - 21:26:56 +0000) Allwinner Technology eth0: ethernet@1c30000 => dhcp sun8i_emac_eth_start: Timeout
Best regards
Heinrich
On Tue, Jun 1, 2021 at 12:35 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Dear all,
Best regards
Heinrich
Hi Heinrich, I don't have OrangePi. can you bisect and tell me when it broke ? Thanks. Ramon.
Dear all,
Best regards
Heinrich
Git bisect points to:
commit 4f0278dac56a658ef1e0967fec0bb95372a875bd Author: Andre Przywara andre.przywara@arm.com Date: Mon Jul 6 01:40:45 2020 +0100
net: sun8i-emac: Lower MDIO frequency
Reverting the patch solves the problem for the OrangePi PC.
According to the commit message the change was only needed for needed for external PHYs. Can't we let the change depend on priv->use_internal_phy?
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 5a1b38bf80..d7553fe163 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -211,7 +211,9 @@ static int sun8i_mdio_read(struct mii_dev *bus, int addr, int devad, int reg) * The EMAC clock is either 200 or 300 MHz, so we need a divider * of 128 to get the MDIO frequency below the required 2.5 MHz. */ - mii_cmd |= MDIO_CMD_MII_CLK_CSR_DIV_128 << MDIO_CMD_MII_CLK_CSR_SHIFT; + if (!priv->use_internal_phy) + mii_cmd |= MDIO_CMD_MII_CLK_CSR_DIV_128 << + MDIO_CMD_MII_CLK_CSR_SHIFT;
mii_cmd |= MDIO_CMD_MII_BUSY;
@@ -242,7 +244,9 @@ static int sun8i_mdio_write(struct mii_dev *bus, int addr, int devad, int reg, * The EMAC clock is either 200 or 300 MHz, so we need a divider * of 128 to get the MDIO frequency below the required 2.5 MHz. */ - mii_cmd |= MDIO_CMD_MII_CLK_CSR_DIV_128 << MDIO_CMD_MII_CLK_CSR_SHIFT; + if (!priv->use_internal_phy) + mii_cmd |= MDIO_CMD_MII_CLK_CSR_DIV_128 << + MDIO_CMD_MII_CLK_CSR_SHIFT;
mii_cmd |= MDIO_CMD_MII_WRITE; mii_cmd |= MDIO_CMD_MII_BUSY;
Best regards
Heinrich
I would assume the problem hits all H3 boards.
Best regards
Heinrich
On Thu, 3 Jun 2021 09:46:48 +0200 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hi Heinrich,
Dear all,
Thanks for the report!
Best regards
Heinrich
The external PHY on the Pine64 (non-plus) was the trigger, however both the manual and the Linux driver point to that we definitely need a higher divider. From what I can see, AHB2 (the EMAC clock) runs at 200 MHz (AHB2=AHB1/1=PLL6/3=200 MHz). So just having "/ 16" results in 12.5 MHz MDIO frequency. Can you check whether any other divider values fix this for you as well?
MDIO_CMD_MII_CLK_CSR_SHIFT; mii_cmd |= MDIO_CMD_MII_BUSY;
MDIO_CMD_MII_CLK_CSR_SHIFT; mii_cmd |= MDIO_CMD_MII_WRITE; mii_cmd |= MDIO_CMD_MII_BUSY;
Best regards
Heinrich
And that's the confusing part: it does not. I tested this on my OrangePi Zero (H2+ with internal PHY), both back then with the original MDIO frequency patch and also now after your report. It always worked reliably for me. Also: I am still puzzled how one influences the other: The error you get is from the *MAC* soft reset: I would think this is an independent operation from any communication attempts with the PHY.
There is this thread here about the same symptom on a V3s: https://lists.denx.de/pipermail/u-boot/2021-May/450315.html v2 of this original patch (in the same thread) proposes some other solution, which I am also not very happy with. But just to get some more data points: can you check whether skipping the soft reset fixes this for you? I will have a closer look tonight to check the order of soft reset and PHY communication. Maybe we should only do the soft reset *once* when the MAC probes, and not on every .start call?
Thanks, Andre
Hi Heinrich,
Dear all,
Best regards
Heinrich
MDIO_CMD_MII_CLK_CSR_DIV_16 = 0 and this is the value that was used before your patch.
MDIO_CMD_MII_CLK_CSR_DIV_16 = 0 => Waiting for PHY auto negotiation to complete. done MDIO_CMD_MII_CLK_CSR_DIV_32 = 1 => sun8i_emac_eth_start: Timeout MDIO_CMD_MII_CLK_CSR_DIV_64 = 2 => sun8i_emac_eth_start: Timeout MDIO_CMD_MII_CLK_CSR_DIV_128 = 3 => sun8i_emac_eth_start: Timeout
What is wrong about the approach in
[PATCH 1/1] net: sun8i-emac: fix MDIO frequency https://lists.denx.de/pipermail/u-boot/2021-June/451305.html ?
The Linux 5.10 driver runs fine no matter what value we choose for the divider in U-Boot. But I see a message:
dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
@default_syscon_value: The default value of the EMAC register in syscon This value is used for disabling properly EMAC and used as a good starting value in case of the boot process(uboot) leave some stuff.
Best regards
Heinrich
Best regards
Heinrich
Thanks, Andre
On Thu, 3 Jun 2021 12:20:34 +0200 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hi Heinrich,
Dear all,
Best regards
Heinrich
The MDIO spec says that the maximum frequency on the MDIO bus should be 2.5 MHz. On the H3 with 200 MHz AHB and with a divider of 16 it's 12.5 MHz. Apparently the internal H3 PHY can tolerate those high frequencies, but it's beyond the spec. And certainly it should not fail with lower frequencies. And indeed it works for me on the H2+ (which I understand is just a binned version of the H3).
Because it programs the divider correctly: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv... I take it you have no problems with Linux, so the divider being too high cannot be the root cause of the problem.
So I'd rather fix this problem properly and correctly, especially as it seems to be more related to the EMAC soft reset (where your error message comes from).
Yeah, I never got the reason for this message. If Linux wants a certain value, it should program that. Whatever was left by someone else (be it U-Boot or some other software/OS) should not matter.
Cheers, Andre
Best regards
Heinrich
Best regards
Heinrich
Thanks, Andre
Hi Heinrich,
Dear all,
Best regards
Heinrich
The dts says for the MDIO:
int_mii_phy: ethernet-phy@1 { clocks = <&ccu CLK_BUS_EPHY>;
"ahb" refers to CLK_BUS_SPI1:
spi1: spi@1c69000 { clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_SPI1>; clock-names = "ahb", "mod";
Why are you mentioning AHB?
Function stmmac_clk_csr_set() depends on the rate of the clock named "stmmaceth":
ethernet@1c30000 { clocks = <&ccu CLK_BUS_EMAC>; clock-names = "stmmaceth";
How do we get the frequency of this clock?
Best regards
Heinrich
Cheers, Andre
Best regards
Heinrich
Best regards
Heinrich
Thanks, Andre
On Thu, 3 Jun 2021 18:09:25 +0200 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hi Heinrich,
On Tue, Jun 1, 2021 at 12:35 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > Dear all, > > network is broken in U-Boot on orangepi_pc_defconfig:
> > U-Boot 2021.07-rc3-00059-gd8729a114e (May 31 2021 - 21:26:56 +0000) > Allwinner Technology > eth0: ethernet@1c30000 > => dhcp > sun8i_emac_eth_start: Timeout > > Best regards > > Heinrich > Hi Heinrich, I don't have OrangePi. can you bisect and tell me when it broke ? Thanks. Ramon.
I think that is the clock to drive the PHY logic, not the MDIO bus. It's a gate for AHB1, in this case, which seems to be 200 MHz as well (because rate(AHB2)=rate(AHB1)/1).
AHB stands for "Advanced High-performance Bus", which is a traditional term for a (faster, data centric) bus interface in the ARM bus world. I am not sure the exact term is actually correct anymore with recent bus implementations, but the H3 manual refers to AHB everywhere, in particular as the bus name for the EMAC IP (figure 4-1 System Bus Tree). Apparently the bus clock is used as the clock source for the MDIO bus as well - after dividing it.
Have you checked /sys/kernel/debug/clk/clk_summary? You could also insert some printk to be sure. Otherwise the definition of bus_emac_clk and CLK_BUS_EMAC in drivers/clk/sunxi-ng/ccu-sun8i-h3.c tell you that it's a gate for ahb2. All of those point to 200 MHz on my OPi Zero.
Hope that helps!
Cheers, Andre
Best regards
Heinrich
Cheers, Andre
Best regards
Heinrich
Best regards
Heinrich
Thanks, Andre
Am Do., 3. Juni 2021 um 18:58 Uhr schrieb Andre Przywara < andre.przywara@arm.com>:
Hi Heinrich,
On 6/2/21 3:08 PM, Ramon Fried wrote: > On Tue, Jun 1, 2021 at 12:35 AM Heinrich Schuchardt <
xypron.glpk@gmx.de> wrote:
>> >> Dear all, >> >> network is broken in U-Boot on orangepi_pc_defconfig:
+0000)
>> Allwinner Technology >> eth0: ethernet@1c30000 >> => dhcp >> sun8i_emac_eth_start: Timeout >> >> Best regards >> >> Heinrich >> > Hi Heinrich, I don't have OrangePi. can you bisect and tell me
when it broke ?
> Thanks. > Ramon. >
needed
for external PHYs.
need a
200
12.5
fix
12.5
Hope that helps!
Cheers, Andre
Best regards
Heinrich
Cheers, Andre
Best regards
Heinrich
int
divider
2.5 MHz.
*bus, int
divider
2.5 MHz.
I tried this with my v3s which has only an internal phy. u-boot wasn't able to establish a connection with any speed and duplex mode combination. All i get is `ethernet@1c30000 Waiting for PHY auto negotiation to complete......... TIMEOUT !`
Do you work with the internal or external phy @Heinrich? Did you try the default u-boot with a different speed and duplex mode combination and have the same behavior? Greetings andreas
Best regards
Heinrich
original
independent
more
Thanks, Andre
On 6/3/21 8:00 PM, Andreas Rehn wrote:
Am Do., 3. Juni 2021 um 18:58 Uhr schrieb Andre Przywara <andre.przywara@arm.com mailto:andre.przywara@arm.com>:
On Thu, 3 Jun 2021 18:09:25 +0200 Heinrich Schuchardt <xypron.glpk@gmx.de <mailto:xypron.glpk@gmx.de>> wrote: Hi, > On 6/3/21 1:04 PM, Andre Przywara wrote: > > On Thu, 3 Jun 2021 12:20:34 +0200 > > Heinrich Schuchardt <xypron.glpk@gmx.de <mailto:xypron.glpk@gmx.de>> wrote: > > > > Hi, > > > >> On 6/3/21 11:04 AM, Andre Przywara wrote: > >>> On Thu, 3 Jun 2021 09:46:48 +0200 > >>> Heinrich Schuchardt <xypron.glpk@gmx.de <mailto:xypron.glpk@gmx.de>> wrote: > >>> > >>> Hi Heinrich, > >>> > >>>> On 6/2/21 3:08 PM, Ramon Fried wrote: > >>>>> On Tue, Jun 1, 2021 at 12:35 AM Heinrich Schuchardt <xypron.glpk@gmx.de <mailto:xypron.glpk@gmx.de>> wrote: > >>>>>> > >>>>>> Dear all, > >>>>>> > >>>>>> network is broken in U-Boot on orangepi_pc_defconfig: > >>> > >>> Thanks for the report! > >>> > >>>>>> > >>>>>> U-Boot 2021.07-rc3-00059-gd8729a114e (May 31 2021 - 21:26:56 +0000) > >>>>>> Allwinner Technology > >>>>>> eth0: ethernet@1c30000 > >>>>>> => dhcp > >>>>>> sun8i_emac_eth_start: Timeout > >>>>>> > >>>>>> Best regards > >>>>>> > >>>>>> Heinrich > >>>>>> > >>>>> Hi Heinrich, I don't have OrangePi. can you bisect and tell me when it broke ? > >>>>> Thanks. > >>>>> Ramon. > >>>>> > >>>> > >>>> Git bisect points to: > >>>> > >>>> commit 4f0278dac56a658ef1e0967fec0bb95372a875bd > >>>> Author: Andre Przywara <andre.przywara@arm.com <mailto:andre.przywara@arm.com>> > >>>> Date: Mon Jul 6 01:40:45 2020 +0100 > >>>> > >>>> net: sun8i-emac: Lower MDIO frequency > >>>> > >>>> Reverting the patch solves the problem for the OrangePi PC. > >>>> > >>>> According to the commit message the change was only needed for needed > >>>> for external PHYs. > >>> > >>> The external PHY on the Pine64 (non-plus) was the trigger, however > >>> both the manual and the Linux driver point to that we definitely need a > >>> higher divider. From what I can see, AHB2 (the EMAC clock) runs at 200 > >>> MHz (AHB2=AHB1/1=PLL6/3=200 MHz). So just having "/ 16" results in 12.5 > >>> MHz MDIO frequency. Can you check whether any other divider values fix > >>> this for you as well? > >> > >> MDIO_CMD_MII_CLK_CSR_DIV_16 = 0 and this is the value that was used > >> before your patch. > >> > >> MDIO_CMD_MII_CLK_CSR_DIV_16 = 0 => > >> Waiting for PHY auto negotiation to complete. done > >> MDIO_CMD_MII_CLK_CSR_DIV_32 = 1 => sun8i_emac_eth_start: Timeout > >> MDIO_CMD_MII_CLK_CSR_DIV_64 = 2 => sun8i_emac_eth_start: Timeout > >> MDIO_CMD_MII_CLK_CSR_DIV_128 = 3 => sun8i_emac_eth_start: Timeout > >> > >> What is wrong about the approach in > >> > >> [PATCH 1/1] net: sun8i-emac: fix MDIO frequency > >> https://lists.denx.de/pipermail/u-boot/2021-June/451305.html <https://lists.denx.de/pipermail/u-boot/2021-June/451305.html> ? > > > > The MDIO spec says that the maximum frequency on the MDIO bus should be > > 2.5 MHz. On the H3 with 200 MHz AHB and with a divider of 16 it's 12.5 > > The dts says for the MDIO: > > int_mii_phy: ethernet-phy@1 { > clocks = <&ccu CLK_BUS_EPHY>; I think that is the clock to drive the PHY logic, not the MDIO bus. It's a gate for AHB1, in this case, which seems to be 200 MHz as well (because rate(AHB2)=rate(AHB1)/1). > "ahb" refers to CLK_BUS_SPI1: > > spi1: spi@1c69000 { > clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_SPI1>; > clock-names = "ahb", "mod"; > > Why are you mentioning AHB? AHB stands for "Advanced High-performance Bus", which is a traditional term for a (faster, data centric) bus interface in the ARM bus world. I am not sure the exact term is actually correct anymore with recent bus implementations, but the H3 manual refers to AHB everywhere, in particular as the bus name for the EMAC IP (figure 4-1 System Bus Tree). Apparently the bus clock is used as the clock source for the MDIO bus as well - after dividing it. > > MHz. Apparently the internal H3 PHY can tolerate those high > > frequencies, but it's beyond the spec. And certainly it should not fail > > with lower frequencies. And indeed it works for me on the H2+ (which I > > understand is just a binned version of the H3). > > > >> The Linux 5.10 driver runs fine no matter what value we choose for the > >> divider in U-Boot. > > > > Because it programs the divider correctly: > > https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/net/ethernet/stmicro/stmmac/stmmac_main.c#n316 <https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/net/ethernet/stmicro/stmmac/stmmac_main.c#n316> > > I take it you have no problems with Linux, so the divider being too > > high cannot be the root cause of the problem. > > Function stmmac_clk_csr_set() depends on the rate of the clock named > "stmmaceth": > > ethernet@1c30000 { > clocks = <&ccu CLK_BUS_EMAC>; > clock-names = "stmmaceth"; > > How do we get the frequency of this clock? Have you checked /sys/kernel/debug/clk/clk_summary? You could also insert some printk to be sure. Otherwise the definition of bus_emac_clk and CLK_BUS_EMAC in drivers/clk/sunxi-ng/ccu-sun8i-h3.c tell you that it's a gate for ahb2. All of those point to 200 MHz on my OPi Zero. Hope that helps! Cheers, Andre > > Best regards > > Heinrich > > > > > So I'd rather fix this problem properly and correctly, especially as it > > seems to be more related to the EMAC soft reset (where your error > > message comes from). > > > >> But I see a message: > >> > >> dwmac-sun8i 1c30000.ethernet: > >> Current syscon value is not the default 148000 (expect 58000) > >> > >> @default_syscon_value: > >> The default value of the EMAC register in syscon > >> This value is used for disabling properly EMAC > >> and used as a good starting value in case of the > >> boot process(uboot) leave some stuff. > > > > Yeah, I never got the reason for this message. If Linux wants a > > certain value, it should program that. Whatever was left by someone > > else (be it U-Boot or some other software/OS) should not matter. > > > > Cheers, > > Andre > > > >> > >> Best regards > >> > >> Heinrich > >> > >>> > >>>> Can't we let the change depend on priv->use_internal_phy? > >>>> > >>>> diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c > >>>> index 5a1b38bf80..d7553fe163 100644 > >>>> --- a/drivers/net/sun8i_emac.c > >>>> +++ b/drivers/net/sun8i_emac.c > >>>> @@ -211,7 +211,9 @@ static int sun8i_mdio_read(struct mii_dev *bus, int > >>>> addr, int devad, int reg) > >>>> * The EMAC clock is either 200 or 300 MHz, so we need a divider > >>>> * of 128 to get the MDIO frequency below the required 2.5 MHz. > >>>> */ > >>>> - mii_cmd |= MDIO_CMD_MII_CLK_CSR_DIV_128 << > >>>> MDIO_CMD_MII_CLK_CSR_SHIFT; > >>>> + if (!priv->use_internal_phy) > >>>> + mii_cmd |= MDIO_CMD_MII_CLK_CSR_DIV_128 << > >>>> + MDIO_CMD_MII_CLK_CSR_SHIFT; > >>>> > >>>> mii_cmd |= MDIO_CMD_MII_BUSY; > >>>> > >>>> @@ -242,7 +244,9 @@ static int sun8i_mdio_write(struct mii_dev *bus, int > >>>> addr, int devad, int reg, > >>>> * The EMAC clock is either 200 or 300 MHz, so we need a divider > >>>> * of 128 to get the MDIO frequency below the required 2.5 MHz. > >>>> */ > >>>> - mii_cmd |= MDIO_CMD_MII_CLK_CSR_DIV_128 << > >>>> MDIO_CMD_MII_CLK_CSR_SHIFT; > >>>> + if (!priv->use_internal_phy) > >>>> + mii_cmd |= MDIO_CMD_MII_CLK_CSR_DIV_128 << > >>>> + MDIO_CMD_MII_CLK_CSR_SHIFT; > >>>> > >>>> mii_cmd |= MDIO_CMD_MII_WRITE; > >>>> mii_cmd |= MDIO_CMD_MII_BUSY;
I simply use orangepi_pc_defconfig. It worked out of the box in the previous release. Communication speed and duplex mode should be auto-negotiated.
Best regards
Heinrich
> >>>> > >>>> Best regards > >>>> > >>>> Heinrich > >>>> > >>>> I would assume the problem hits all H3 boards. > >>> > >>> And that's the confusing part: it does not. I tested this on my > >>> OrangePi Zero (H2+ with internal PHY), both back then with the original > >>> MDIO frequency patch and also now after your report. It always worked > >>> reliably for me. > >>> Also: I am still puzzled how one influences the other: The error you > >>> get is from the *MAC* soft reset: I would think this is an independent > >>> operation from any communication attempts with the PHY. > >>> > >>> There is this thread here about the same symptom on a V3s: > >>> https://lists.denx.de/pipermail/u-boot/2021-May/450315.html <https://lists.denx.de/pipermail/u-boot/2021-May/450315.html> > >>> v2 of this original patch (in the same thread) proposes some other > >>> solution, which I am also not very happy with. But just to get some more > >>> data points: can you check whether skipping the soft reset fixes this > >>> for you? I will have a closer look tonight to check the order of soft > >>> reset and PHY communication. Maybe we should only do the soft reset > >>> *once* when the MAC probes, and not on every .start call? > >>> > >>> Thanks, > >>> Andre > >>> > >> > > >
-- Mit freundlichen Grüßen / kind regards Andreas Rehn | Master of Engineering (M.Eng)
Hi Heinrich,
On 6/2/21 3:08 PM, Ramon Fried wrote: > On Tue, Jun 1, 2021 at 12:35 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote: >> >> Dear all, >> >> network is broken in U-Boot on orangepi_pc_defconfig:
>> >> U-Boot 2021.07-rc3-00059-gd8729a114e (May 31 2021 - 21:26:56 +0000) >> Allwinner Technology >> eth0: ethernet@1c30000 >> => dhcp >> sun8i_emac_eth_start: Timeout >> >> Best regards >> >> Heinrich >> > Hi Heinrich, I don't have OrangePi. can you bisect and tell me when it broke ? > Thanks. > Ramon. >
I have appended clk_summary.
stmmac_clk_csr_set(): dwmac-sun8i 1c30000.ethernet: priv->plat->has_sun8i 1 dwmac-sun8i 1c30000.ethernet: clk_rate 200000000 dwmac-sun8i 1c30000.ethernet: priv->clk_csr 3
Best regards
Heinrich
Hope that helps!
Cheers, Andre
Best regards
Heinrich
Cheers, Andre
Best regards
Heinrich
Best regards
Heinrich
Thanks, Andre
Andre Przywara
Andreas Rehn
Ramon Fried
