[U-Boot] [PATCH] cgtqmx6eval: fix pad configuration for SPI bus
Use the macro SETUP_IOMUX_PAD(...) rather than imx_iomux_v3_setup_multiple_pads(...) in order to setup the pin configuration for ECSPI1.
ARRAY_SIZE(pads) provides the wrong size for imx_iomux_v3_setup_multiple_pads(pads, ARRAY_SIZE(pads)) in case of MX6QDL. In the particular case, the content of GPR12 is overwritten and the IPG/AHB/ATB/ATP clocks are deactivated. Therefore, the connection to the system via JTAG is not possible anymore. Furthermore, kernel version 3.0.35 hangs during bootprocess in the function etm_init().
Signed-off-by: Michael Schanz michael.schanz@congatec.com ---
board/congatec/cgtqmx6eval/cgtqmx6eval.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/congatec/cgtqmx6eval/cgtqmx6eval.c b/board/congatec/cgtqmx6eval/cgtqmx6eval.c index 5fd526d..225de7c 100644 --- a/board/congatec/cgtqmx6eval/cgtqmx6eval.c +++ b/board/congatec/cgtqmx6eval/cgtqmx6eval.c @@ -404,7 +404,7 @@ static void setup_iomux_uart(void) #ifdef CONFIG_MXC_SPI static void setup_spi(void) { - imx_iomux_v3_setup_multiple_pads(ecspi1_pads, ARRAY_SIZE(ecspi1_pads)); + SETUP_IOMUX_PADS(ecspi1_pads); gpio_direction_output(IMX_GPIO_NR(3, 19), 0); } #endif
On Thu, Dec 10, 2015 at 6:58 AM, Michael Schanz michael.schanz@congatec.com wrote:
Acked-by: Otavio Salvador otavio@ossystems.com.br
Applied to u-boot-imx, thanks!
Best regards, Stefano Babic
Michael Schanz
Otavio Salvador
Stefano Babic
