[U-Boot] [PATCH v4 0/2] IMX6: Add Gateworks Ventana support
Changes in v4: - fixed FP calculation - fixed invalid return type for read_eeprom() - use enum and defines for GSC HWMON registers/bits - removed unused CONFIG_SPI_FLASH_WINBOND_ERASESIZE - use defines for I2C bus numbers - added PCIE support - moved board-specific gpio iomux to board_init as imx6_pcie_toggle_reset needs it
Changes in v3: - update README fixing typo and removing Freescale document link - use debug() instead of printf() - be more explicit with hwmon error output and use macro for min/max percent - use #defines for GSC slave address and registers - remove extern from function prototype - moved gpio config into structure for better readability - use enum for eeprom bit configs and array to map to fdt property alias - add SATA regardless of cpu type - add FIT support regardless of flash type - display PMIC and device id in misc_init_r() instead of pmic driver
Changes in v2: - rebase on top of u-boot-imx - use switch..case for model specific init instead of strcmps - move checkboard to late init allowing i2c_setup to be moved to board_init() eeprom reading to be done after relocation, and move eeprom struct from data segment - move SPI/I2C init to board_init() - update README - remove unnecessary console overwrite function - fix multiline comment style and eliminate >80 char lines - eliminate unnecessary loop in board_mmc_init() - add missing copyright to clocks.cfg - avoid duplicating cfg files where no changes exist - added missing SPDX header to ventana_eeprom.h - use puts() instead of printf() for constant strings - remove messages regarding /dev/i2c-<n> - use get_ram_size() for determing ram_size - cleanup gpio configuration using tables for baseboard pinmux combinations - remove phy init errata as it doesn't pertain to use case (it is for 802.3az which IMX6 MAC does not support) - added pfuze100_pmic driver using PMIC API - moved GSC code (gsc command and i2c_read/i2c_write wrappers into own file) - allow user to quiet down some of the data displayed - remove display support for now - will revisit later - remove display of boot mode info - may revisit later - replace bitwise fields in eeprom structure with bit definitions
Tim Harvey (2): power: add PFUZE100 PMIC driver ventana: Add Gateworks Ventana family support
board/gateworks/gw_ventana/Makefile | 10 + board/gateworks/gw_ventana/README | 55 ++ board/gateworks/gw_ventana/clocks.cfg | 42 + board/gateworks/gw_ventana/gsc.c | 129 +++ board/gateworks/gw_ventana/gsc.h | 64 ++ board/gateworks/gw_ventana/gw_ventana.c | 1262 +++++++++++++++++++++++++++ board/gateworks/gw_ventana/gw_ventana.cfg | 42 + board/gateworks/gw_ventana/ventana_eeprom.h | 106 +++ boards.cfg | 5 + drivers/power/pmic/Makefile | 1 + drivers/power/pmic/pmic_pfuze100.c | 32 + include/configs/gw_ventana.h | 425 +++++++++ include/power/pfuze100_pmic.h | 96 ++ 13 files changed, 2269 insertions(+) create mode 100644 board/gateworks/gw_ventana/Makefile create mode 100644 board/gateworks/gw_ventana/README create mode 100644 board/gateworks/gw_ventana/clocks.cfg create mode 100644 board/gateworks/gw_ventana/gsc.c create mode 100644 board/gateworks/gw_ventana/gsc.h create mode 100644 board/gateworks/gw_ventana/gw_ventana.c create mode 100644 board/gateworks/gw_ventana/gw_ventana.cfg create mode 100644 board/gateworks/gw_ventana/ventana_eeprom.h create mode 100644 drivers/power/pmic/pmic_pfuze100.c create mode 100644 include/configs/gw_ventana.h create mode 100644 include/power/pfuze100_pmic.h
Signed-off-by: Tim Harvey tharvey@gateworks.com Acked-by: Stefano Babic sbabic@denx.de --- Changes in v3: - no changes
Changes in v2: - remove detect and device_id display from pmic_init()
Signed-off-by: Tim Harvey tharvey@gateworks.com --- drivers/power/pmic/Makefile | 1 + drivers/power/pmic/pmic_pfuze100.c | 32 +++++++++++++ include/power/pfuze100_pmic.h | 96 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 129 insertions(+) create mode 100644 drivers/power/pmic/pmic_pfuze100.c create mode 100644 include/power/pfuze100_pmic.h
diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 0b45ffa..4129bda 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -9,5 +9,6 @@ obj-$(CONFIG_POWER_MAX8998) += pmic_max8998.o obj-$(CONFIG_POWER_MAX8997) += pmic_max8997.o obj-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o obj-$(CONFIG_POWER_MAX77686) += pmic_max77686.o +obj-$(CONFIG_POWER_PFUZE100) += pmic_pfuze100.o obj-$(CONFIG_POWER_TPS65217) += pmic_tps65217.o obj-$(CONFIG_POWER_TPS65910) += pmic_tps65910.o diff --git a/drivers/power/pmic/pmic_pfuze100.c b/drivers/power/pmic/pmic_pfuze100.c new file mode 100644 index 0000000..22c1f15 --- /dev/null +++ b/drivers/power/pmic/pmic_pfuze100.c @@ -0,0 +1,32 @@ +/* + * Copyright (C) 2014 Gateworks Corporation + * Tim Harvey tharvey@gateworks.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> + +int pmic_init(unsigned char bus) +{ + static const char name[] = "PFUZE100_PMIC"; + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + } + + p->name = name; + p->interface = PMIC_I2C; + p->number_of_regs = PMIC_NUM_OF_REGS; + p->hw.i2c.addr = CONFIG_POWER_PFUZE100_I2C_ADDR; + p->hw.i2c.tx_num = 1; + p->bus = bus; + + return 0; +} diff --git a/include/power/pfuze100_pmic.h b/include/power/pfuze100_pmic.h new file mode 100644 index 0000000..2a9032a --- /dev/null +++ b/include/power/pfuze100_pmic.h @@ -0,0 +1,96 @@ +/* + * Copyright (C) 2014 Gateworks Corporation + * Tim Harvey tharvey@gateworks.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PFUZE100_PMIC_H_ +#define __PFUZE100_PMIC_H_ + +/* PFUZE100 registers */ +enum { + PFUZE100_DEVICEID = 0x00, + PFUZE100_REVID = 0x03, + PFUZE100_FABID = 0x04, + + PFUZE100_SW1ABVOL = 0x20, + PFUZE100_SW1CVOL = 0x2e, + PFUZE100_SW2VOL = 0x35, + PFUZE100_SW3AVOL = 0x3c, + PFUZE100_SW3BVOL = 0x43, + PFUZE100_SW4VOL = 0x4a, + PFUZE100_SWBSTCON1 = 0x66, + PFUZE100_VREFDDRCON = 0x6a, + PFUZE100_VSNVSVOL = 0x6b, + PFUZE100_VGEN1VOL = 0x6c, + PFUZE100_VGEN2VOL = 0x6d, + PFUZE100_VGEN3VOL = 0x6e, + PFUZE100_VGEN4VOL = 0x6f, + PFUZE100_VGEN5VOL = 0x70, + PFUZE100_VGEN6VOL = 0x71, + + PMIC_NUM_OF_REGS = 0x7f, +}; + +/* + * LDO Configuration + */ + +/* VGEN1/2 Voltage Configuration */ +#define LDOA_0_80V 0 +#define LDOA_0_85V 1 +#define LDOA_0_90V 2 +#define LDOA_0_95V 3 +#define LDOA_1_00V 4 +#define LDOA_1_05V 5 +#define LDOA_1_10V 6 +#define LDOA_1_15V 7 +#define LDOA_1_20V 8 +#define LDOA_1_25V 9 +#define LDOA_1_30V 10 +#define LDOA_1_35V 11 +#define LDOA_1_40V 12 +#define LDOA_1_45V 13 +#define LDOA_1_50V 14 +#define LDOA_1_55V 15 + +/* VGEN3/4/5/6 Voltage Configuration */ +#define LDOB_1_80V 0 +#define LDOB_1_90V 1 +#define LDOB_2_00V 2 +#define LDOB_2_10V 3 +#define LDOB_2_20V 4 +#define LDOB_2_30V 5 +#define LDOB_2_40V 6 +#define LDOB_2_50V 7 +#define LDOB_2_60V 8 +#define LDOB_2_70V 9 +#define LDOB_2_80V 10 +#define LDOB_2_90V 11 +#define LDOB_3_00V 12 +#define LDOB_3_10V 13 +#define LDOB_3_20V 14 +#define LDOB_3_30V 15 + +#define LDO_VOL_MASK 0xf +#define LDO_EN 4 + +/* + * Boost Regulator + */ + +/* SWBST Output Voltage */ +#define SWBST_5_00V 0 +#define SWBST_5_05V 1 +#define SWBST_5_10V 2 +#define SWBST_5_15V 3 + +#define SWBST_VOL_MASK 0x3 +#define SWBST_MODE_MASK 0x6 +#define SWBST_MODE_OFF (2 << 0) +#define SWBST_MODE_PFM (2 << 1) +#define SWBST_MODE_AUTO (2 << 2) +#define SWBST_MODE_APS (2 << 3) + +#endif
Best regards, Stefano Babic
Gateworks Ventana is a product family based on the i.MX6. This patch adds support for all boards in the Ventana family. Where possible, data from the boards EEPROM is used to determine various details about the board at runtime.
Signed-off-by: Tim Harvey tharvey@gateworks.com Cc: Stefano Babic sbabic@denx.de ---
board/gateworks/gw_ventana/Makefile | 10 + board/gateworks/gw_ventana/README | 55 ++ board/gateworks/gw_ventana/clocks.cfg | 42 + board/gateworks/gw_ventana/gsc.c | 129 +++ board/gateworks/gw_ventana/gsc.h | 64 ++ board/gateworks/gw_ventana/gw_ventana.c | 1262 +++++++++++++++++++++++++++ board/gateworks/gw_ventana/gw_ventana.cfg | 42 + board/gateworks/gw_ventana/ventana_eeprom.h | 106 +++ boards.cfg | 5 + include/configs/gw_ventana.h | 425 +++++++++ 10 files changed, 2140 insertions(+) create mode 100644 board/gateworks/gw_ventana/Makefile create mode 100644 board/gateworks/gw_ventana/README create mode 100644 board/gateworks/gw_ventana/clocks.cfg create mode 100644 board/gateworks/gw_ventana/gsc.c create mode 100644 board/gateworks/gw_ventana/gsc.h create mode 100644 board/gateworks/gw_ventana/gw_ventana.c create mode 100644 board/gateworks/gw_ventana/gw_ventana.cfg create mode 100644 board/gateworks/gw_ventana/ventana_eeprom.h create mode 100644 include/configs/gw_ventana.h
diff --git a/board/gateworks/gw_ventana/Makefile b/board/gateworks/gw_ventana/Makefile new file mode 100644 index 0000000..e8dab89 --- /dev/null +++ b/board/gateworks/gw_ventana/Makefile @@ -0,0 +1,10 @@ +# +# Copyright (C) 2012-2013, Guennadi Liakhovetski lg@denx.de +# (C) Copyright 2012-2013 Freescale Semiconductor, Inc. +# Copyright (C) 2013, Gateworks Corporation +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := gw_ventana.o gsc.o + diff --git a/board/gateworks/gw_ventana/README b/board/gateworks/gw_ventana/README new file mode 100644 index 0000000..9e697d6 --- /dev/null +++ b/board/gateworks/gw_ventana/README @@ -0,0 +1,55 @@ +U-Boot for the Gateworks Ventana Product Family boards + +This file contains information for the port of U-Boot to the Gateworks +Ventana Product family boards. + +1. Boot source, boot from NAND +------------------------------ + +The i.MX6 BOOT ROM expects some structures that provide details of NAND layout +and bad block information (referred to as 'bootstreams') which are replicated +multiple times in NAND. The number of replications is configurable through +board strapping options and eFUSE settings. The Freescale 'kobs-ng' +application from the Freescale LTIB BSP, which runs under Linux, must be used +to program the bootstream in order to setup the replicated headers correctly. + +The Gateworks Ventana boards with NAND flash have been factory programmed +such that their eFUSE settings expect 2 copies of the boostream (this is +specified by providing kobs-ng with the --search_exponent=1 argument). Once in +Linux with MTD support for the NAND on /dev/mtd0 you can program the boostream +with: + +kobs-ng init -v -x --search_exponent=1 u-boot.imx + +The kobs-ng application uses an imximage (u-boot.imx) which contains the +Image Vector Table (IVT) and Device Configuration Data (DCD) structures that +the i.MX6 BOOT ROM requires to boot. The kobs-ng adds the Firmware +Configuration Block (FCB) and Discovered Bad Block Table (DBBT). + +This information is taken from: + http://trac.gateworks.com/wiki/ventana/bootloader#NANDFLASH + +More details about the i.MX6 BOOT ROM can be found in the IMX6 reference manual. + +2. Build +-------- + +There are several Gateworks Ventana boards that share a simliar design but +vary based on CPU, Memory configuration, and subloaded devices. Although +the subloaded devices are handled dynamically in the bootloader using +factory configured EEPROM data to modify the device-tree, the CPU choice +(IMX6Q vs IMX6DL) and memory configurations are currently compile-time +options. + +The following Gateworks Ventana configurations exist: + gwventanaq1gspi: MX6Q,1GB,SPI FLASH + gwventanaq : MX6Q,512MB,NAND FLASH + gwventanaq1g : MX6Q,1GB,NAND FLASH + gwventanadl : MX6DL,512MB,NAND FLASH + gwventanadl1g : MX6DL,1GB,NAND FLASH + +To build U-Boot for the MX6Q,1GB,NAND FLASH for example: + + make gwventanaq1g_config + make + diff --git a/board/gateworks/gw_ventana/clocks.cfg b/board/gateworks/gw_ventana/clocks.cfg new file mode 100644 index 0000000..a8118a2 --- /dev/null +++ b/board/gateworks/gw_ventana/clocks.cfg @@ -0,0 +1,42 @@ +/* + * Copyright (C) 2013 Boundary Devices + * Copyright (C) 2013 Gateworks Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* set the default clock gate to save power */ +DATA 4, CCM_CCGR0, 0x00C03F3F +DATA 4, CCM_CCGR1, 0x0030FC03 +DATA 4, CCM_CCGR2, 0x0FFFC000 +DATA 4, CCM_CCGR3, 0x3FF00000 +DATA 4, CCM_CCGR4, 0xFFFFF300 /* enable NAND/GPMI/BCH clocks */ +DATA 4, CCM_CCGR5, 0x0F0000C3 +DATA 4, CCM_CCGR6, 0x000003FF + +/* enable AXI cache for VDOA/VPU/IPU */ +DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF +/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ +DATA 4, MX6_IOMUXC_GPR6, 0x007F007F +DATA 4, MX6_IOMUXC_GPR7, 0x007F007F + +/* + * Setup CCM_CCOSR register as follows: + * + * cko1_en = 1 --> CKO1 enabled + * cko1_div = 111 --> divide by 8 + * cko1_sel = 1011 --> ahb_clk_root + * + * This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz + */ +DATA 4, CCM_CCOSR, 0x000000fb diff --git a/board/gateworks/gw_ventana/gsc.c b/board/gateworks/gw_ventana/gsc.c new file mode 100644 index 0000000..37966ab --- /dev/null +++ b/board/gateworks/gw_ventana/gsc.c @@ -0,0 +1,129 @@ +/* + * Copyright (C) 2013 Gateworks Corporation + * + * Author: Tim Harvey tharvey@gateworks.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/errno.h> +#include <common.h> +#include <i2c.h> +#include <linux/ctype.h> + +#include "gsc.h" + +#define MINMAX(n, percent) ((n)*(100-percent)/100), ((n)*(100+percent)/100) + +/* + * The Gateworks System Controller will fail to ACK a master transaction if + * it is busy, which can occur during its 1HZ timer tick while reading ADC's. + * When this does occur, it will never be busy long enough to fail more than + * 2 back-to-back transfers. Thus we wrap i2c_read and i2c_write with + * 3 retries. + */ +int gsc_i2c_read(uchar chip, uint addr, int alen, uchar *buf, int len) +{ + int retry = 3; + int n = 0; + int ret; + + while (n++ < retry) { + ret = i2c_read(chip, addr, alen, buf, len); + if (!ret) + break; + debug("%s: 0x%02x 0x%02x retry%d: %d\n", __func__, chip, addr, + n, ret); + if (ret != -ENODEV) + break; + mdelay(10); + } + return ret; +} + +int gsc_i2c_write(uchar chip, uint addr, int alen, uchar *buf, int len) +{ + int retry = 3; + int n = 0; + int ret; + + while (n++ < retry) { + ret = i2c_write(chip, addr, alen, buf, len); + if (!ret) + break; + debug("%s: 0x%02x 0x%02x retry%d: %d\n", __func__, chip, addr, + n, ret); + if (ret != -ENODEV) + break; + mdelay(10); + } + mdelay(1); + return ret; +} + +#ifdef CONFIG_CMD_GSC +static void read_hwmon(const char *name, uint reg, uint size, uint low, + uint high) +{ + unsigned char buf[3]; + uint ui; + + printf("%-8s:", name); + memset(buf, 0, sizeof(buf)); + if (gsc_i2c_read(GSC_HWMON_ADDR, reg, 1, buf, size)) { + puts("fRD\n"); + } else { + ui = buf[0] | (buf[1]<<8) | (buf[2]<<16); + if (ui == 0xffffff) + printf("invalid"); + else if (ui < low) + printf("%d Failed - Low", ui); + else if (ui > high) + printf("%d Failed - High", ui); + else + printf("%d", ui); + } + puts("\n"); +} + +int do_gsc(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + const char *model = getenv("model"); + + i2c_set_bus_num(0); + read_hwmon("Temp", GSC_HWMON_TEMP, 2, 0, 9000); + read_hwmon("VIN", GSC_HWMON_VIN, 3, 8000, 60000); + read_hwmon("VBATT", GSC_HWMON_VBATT, 3, 1800, 3500); + read_hwmon("VDD_3P3", GSC_HWMON_VDD_3P3, 3, MINMAX(3300, 10)); + read_hwmon("VDD_HIGH", GSC_HWMON_VDD_HIGH, 3, MINMAX(3000, 10)); + read_hwmon("VDD_DDR", GSC_HWMON_VDD_DDR, 3, MINMAX(1500, 10)); + read_hwmon("VDD_5P0", GSC_HWMON_VDD_5P0, 3, MINMAX(5000, 10)); + read_hwmon("VDD_2P5", GSC_HWMON_VDD_2P5, 3, MINMAX(2500, 10)); + read_hwmon("VDD_1P8", GSC_HWMON_VDD_1P8, 3, MINMAX(1800, 10)); + + switch (model[3]) { + case '1': /* GW51xx */ + read_hwmon("VDD_CORE", GSC_HWMON_VDD_CORE, 3, MINMAX(1175, 10)); + read_hwmon("VDD_SOC", GSC_HWMON_VDD_SOC, 3, MINMAX(1175, 10)); + break; + case '2': /* GW52xx */ + case '3': /* GW53xx */ + read_hwmon("VDD_CORE", GSC_HWMON_VDD_CORE, 3, MINMAX(1175, 10)); + read_hwmon("VDD_SOC", GSC_HWMON_VDD_SOC, 3, MINMAX(1175, 10)); + read_hwmon("VDD_1P0", GSC_HWMON_VDD_1P0, 3, MINMAX(1000, 10)); + break; + case '4': /* GW54xx */ + read_hwmon("VDD_CORE", GSC_HWMON_VDD_CORE, 3, MINMAX(1375, 10)); + read_hwmon("VDD_SOC", GSC_HWMON_VDD_SOC, 3, MINMAX(1375, 10)); + read_hwmon("VDD_1P0", GSC_HWMON_VDD_1P0, 3, MINMAX(1000, 10)); + break; + } + return 0; +} + +U_BOOT_CMD(gsc, 1, 1, do_gsc, + "GSC test", + "" +); + +#endif /* CONFIG_CMD_GSC */ diff --git a/board/gateworks/gw_ventana/gsc.h b/board/gateworks/gw_ventana/gsc.h new file mode 100644 index 0000000..da970c3 --- /dev/null +++ b/board/gateworks/gw_ventana/gsc.h @@ -0,0 +1,64 @@ +/* + * Copyright (C) 2013 Gateworks Corporation + * + * Author: Tim Harvey tharvey@gateworks.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASSEMBLY__ + +/* i2c slave addresses */ +#define GSC_SC_ADDR 0x20 +#define GSC_RTC_ADDR 0x68 +#define GSC_HWMON_ADDR 0x29 +#define GSC_EEPROM_ADDR 0x51 + +/* System Controller registers */ +enum { + GSC_SC_CTRL0 = 0x00, + GSC_SC_CTRL1 = 0x01, + GSC_SC_STATUS = 0x0a, + GSC_SC_FWVER = 0x0e, +}; + +/* System Controller Control1 bits */ +enum { + GSC_SC_CTRL1_WDDIS = 7, /* 1 = disable watchdog */ +}; + +/* System Controller Interrupt bits */ +enum { + GSC_SC_IRQ_PB = 0, /* Pushbutton switch */ + GSC_SC_IRQ_SECURE = 1, /* Secure Key erase operation complete */ + GSC_SC_IRQ_EEPROM_WP = 2, /* EEPROM write violation */ + GSC_SC_IRQ_GPIO = 4, /* GPIO change */ + GSC_SC_IRQ_TAMPER = 5, /* Tamper detect */ + GSC_SC_IRQ_WATCHDOG = 6, /* Watchdog trip */ + GSC_SC_IRQ_PBLONG = 7, /* Pushbutton long hold */ +}; + +/* Hardware Monitor registers */ +enum { + GSC_HWMON_TEMP = 0x00, + GSC_HWMON_VIN = 0x02, + GSC_HWMON_VDD_3P3 = 0x05, + GSC_HWMON_VBATT = 0x08, + GSC_HWMON_VDD_5P0 = 0x0b, + GSC_HWMON_VDD_CORE = 0x0e, + GSC_HWMON_VDD_HIGH = 0x14, + GSC_HWMON_VDD_DDR = 0x17, + GSC_HWMON_VDD_SOC = 0x11, + GSC_HWMON_VDD_1P8 = 0x1d, + GSC_HWMON_VDD_2P5 = 0x23, + GSC_HWMON_VDD_1P0 = 0x20, +}; + +/* + * I2C transactions to the GSC are done via these functions which + * perform retries in the case of a busy GSC NAK'ing the transaction + */ +int gsc_i2c_read(uchar chip, uint addr, int alen, uchar *buf, int len); +int gsc_i2c_write(uchar chip, uint addr, int alen, uchar *buf, int len); +#endif + diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c new file mode 100644 index 0000000..f9960c7 --- /dev/null +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -0,0 +1,1262 @@ +/* + * Copyright (C) 2013 Gateworks Corporation + * + * Author: Tim Harvey tharvey@gateworks.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/sata.h> +#include <jffs2/load_kernel.h> +#include <hwconfig.h> +#include <i2c.h> +#include <linux/ctype.h> +#include <fdt_support.h> +#include <fsl_esdhc.h> +#include <miiphy.h> +#include <mmc.h> +#include <mtd_node.h> +#include <netdev.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> +#include <i2c.h> +#include <fdt_support.h> +#include <jffs2/load_kernel.h> +#include <spi_flash.h> + +#include "gsc.h" +#include "ventana_eeprom.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* GPIO's common to all baseboards */ +#define GP_PHY_RST IMX_GPIO_NR(1, 30) +#define GP_USB_OTG_PWR IMX_GPIO_NR(3, 22) +#define GP_SD3_CD IMX_GPIO_NR(7, 0) +#define GP_RS232_EN IMX_GPIO_NR(2, 11) +#define GP_MSATA_SEL IMX_GPIO_NR(2, 8) + +/* I2C bus numbers */ +#define I2C_GSC 0 +#define I2C_PMIC 1 + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define SPI_PAD_CTRL (PAD_CTL_HYS | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define DIO_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_34ohm | PAD_CTL_HYS | PAD_CTL_SRE_FAST) + +#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) + +/* + * EEPROM board info struct populated by read_eeprom so that we only have to + * read it once. + */ +static struct ventana_board_info ventana_info; + +enum { + GW54proto, /* original GW5400-A prototype */ + GW51xx, + GW52xx, + GW53xx, + GW54xx, + GW_UNKNOWN, +}; + +int board_type; + +/* UART1: Function varies per baseboard */ +iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_SD3_DAT6__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD3_DAT7__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +/* UART2: Serial Console */ +iomux_v3_cfg_t const uart2_pads[] = { + MX6_PAD_SD4_DAT7__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD4_DAT4__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) + +/* I2C1: GSC */ +struct i2c_pads_info i2c_pad_info0 = { + .scl = { + .i2c_mode = MX6_PAD_EIM_D21__I2C1_SCL | PC, + .gpio_mode = MX6_PAD_EIM_D21__GPIO3_IO21 | PC, + .gp = IMX_GPIO_NR(3, 21) + }, + .sda = { + .i2c_mode = MX6_PAD_EIM_D28__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_EIM_D28__GPIO3_IO28 | PC, + .gp = IMX_GPIO_NR(3, 28) + } +}; + +/* I2C2: PMIC/PCIe Switch/PCIe Clock/Mezz */ +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL | PC, + .gpio_mode = MX6_PAD_KEY_COL3__GPIO4_IO12 | PC, + .gp = IMX_GPIO_NR(4, 12) + }, + .sda = { + .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC, + .gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 | PC, + .gp = IMX_GPIO_NR(4, 13) + } +}; + +/* I2C3: Misc/Expansion */ +struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6_PAD_GPIO_3__I2C3_SCL | PC, + .gpio_mode = MX6_PAD_GPIO_3__GPIO1_IO03 | PC, + .gp = IMX_GPIO_NR(1, 3) + }, + .sda = { + .i2c_mode = MX6_PAD_GPIO_6__I2C3_SDA | PC, + .gpio_mode = MX6_PAD_GPIO_6__GPIO1_IO06 | PC, + .gp = IMX_GPIO_NR(1, 6) + } +}; + +/* MMC */ +iomux_v3_cfg_t const usdhc3_pads[] = { + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT5__GPIO7_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + +/* ENET */ +iomux_v3_cfg_t const enet_pads[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* PHY nRST */ + MX6_PAD_ENET_TXD0__GPIO1_IO30 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +/* NAND */ +iomux_v3_cfg_t const nfc_pads[] = { + MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +#ifdef CONFIG_CMD_NAND +static void setup_gpmi_nand(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* config gpmi nand iomux */ + imx_iomux_v3_setup_multiple_pads(nfc_pads, ARRAY_SIZE(nfc_pads)); + + /* config gpmi and bch clock to 100 MHz */ + clrsetbits_le32(&mxc_ccm->cs2cdr, + MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_PRED_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK, + MXC_CCM_CS2CDR_ENFC_CLK_PODF(0) | + MXC_CCM_CS2CDR_ENFC_CLK_PRED(3) | + MXC_CCM_CS2CDR_ENFC_CLK_SEL(3)); + + /* enable gpmi and bch clock gating */ + setbits_le32(&mxc_ccm->CCGR4, + MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET); + + /* enable apbh clock gating */ + setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK); +} +#endif + +static void setup_iomux_enet(void) +{ + imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); + + /* toggle PHY_RST# */ + gpio_direction_output(GP_PHY_RST, 0); + mdelay(2); + gpio_set_value(GP_PHY_RST, 1); +} + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); +} + +#ifdef CONFIG_USB_EHCI_MX6 +iomux_v3_cfg_t const usb_pads[] = { + MX6_PAD_GPIO_1__USB_OTG_ID | MUX_PAD_CTRL(DIO_PAD_CTRL), + MX6_PAD_KEY_COL4__USB_OTG_OC | MUX_PAD_CTRL(DIO_PAD_CTRL), + MX6_PAD_EIM_D22__GPIO3_IO22 | MUX_PAD_CTRL(DIO_PAD_CTRL), /* OTG PWR */ +}; + +int board_ehci_hcd_init(int port) +{ + struct ventana_board_info *info = &ventana_info; + + imx_iomux_v3_setup_multiple_pads(usb_pads, ARRAY_SIZE(usb_pads)); + + /* Reset USB HUB (present on GW54xx/GW53xx) */ + switch (info->model[3]) { + case '3': /* GW53xx */ + imx_iomux_v3_setup_pad(MX6_PAD_GPIO_9__GPIO1_IO09| + MUX_PAD_CTRL(NO_PAD_CTRL)); + gpio_direction_output(IMX_GPIO_NR(1, 9), 0); + mdelay(2); + gpio_set_value(IMX_GPIO_NR(1, 9), 1); + break; + case '4': /* GW54xx */ + imx_iomux_v3_setup_pad(MX6_PAD_SD1_DAT0__GPIO1_IO16 | + MUX_PAD_CTRL(NO_PAD_CTRL)); + gpio_direction_output(IMX_GPIO_NR(1, 16), 0); + mdelay(2); + gpio_set_value(IMX_GPIO_NR(1, 16), 1); + break; + } + + return 0; +} + +int board_ehci_power(int port, int on) +{ + if (port) + return 0; + gpio_set_value(GP_USB_OTG_PWR, on); + return 0; +} +#endif /* CONFIG_USB_EHCI_MX6 */ + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg usdhc_cfg = { USDHC3_BASE_ADDR }; + +int board_mmc_getcd(struct mmc *mmc) +{ + /* Card Detect */ + gpio_direction_input(GP_SD3_CD); + return !gpio_get_value(GP_SD3_CD); +} + +int board_mmc_init(bd_t *bis) +{ + /* Only one USDHC controller on Ventana */ + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + usdhc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + usdhc_cfg.max_bus_width = 4; + + return fsl_esdhc_initialize(bis, &usdhc_cfg); +} +#endif /* CONFIG_FSL_ESDHC */ + +#ifdef CONFIG_MXC_SPI +iomux_v3_cfg_t const ecspi1_pads[] = { + /* SS1 */ + MX6_PAD_EIM_D19__GPIO3_IO19 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), +}; + +static void setup_spi(void) +{ + gpio_direction_output(CONFIG_SF_DEFAULT_CS, 1); + imx_iomux_v3_setup_multiple_pads(ecspi1_pads, + ARRAY_SIZE(ecspi1_pads)); +} +#endif + +/* configure eth0 PHY board-specific LED behavior */ +int board_phy_config(struct phy_device *phydev) +{ + unsigned short val; + + /* Marvel 88E1510 */ + if (phydev->phy_id == 0x1410dd1) { + /* + * Page 3, Register 16: LED[2:0] Function Control Register + * LED[0] (SPD:Amber) R16_3.3:0 to 0111: on-GbE link + * LED[1] (LNK:Green) R16_3.7:4 to 0001: on-link, blink-activity + */ + phy_write(phydev, MDIO_DEVAD_NONE, 22, 3); + val = phy_read(phydev, MDIO_DEVAD_NONE, 16); + val &= 0xff00; + val |= 0x0017; + phy_write(phydev, MDIO_DEVAD_NONE, 16, val); + phy_write(phydev, MDIO_DEVAD_NONE, 22, 0); + } + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + setup_iomux_enet(); + +#ifdef CONFIG_FEC_MXC + cpu_eth_init(bis); +#endif + +#ifdef CONFIG_MV_UDC + /* For otg ethernet*/ + usb_eth_initialize(bis); +#endif + + return 0; +} + +/* read ventana EEPROM, check for validity, and return baseboard type */ +static int +read_eeprom(void) +{ + int i; + int chksum; + char baseboard; + int type; + struct ventana_board_info *info = &ventana_info; + unsigned char *buf = (unsigned char *)&ventana_info; + + memset(info, 0, sizeof(ventana_info)); + + /* + * On a board with a missing/depleted backup battery for GSC, the + * board may be ready to probe the GSC before its firmware is + * running. We will wait here indefinately for the GSC/EEPROM. + */ + while (1) { + if (0 == i2c_set_bus_num(I2C_GSC) && + 0 == i2c_probe(GSC_EEPROM_ADDR)) + break; + mdelay(1); + } + + /* read eeprom config section */ + if (gsc_i2c_read(GSC_EEPROM_ADDR, 0x00, 1, buf, sizeof(ventana_info))) { + puts("EEPROM: Failed to read EEPROM\n"); + info->model[0] = 0; + return GW_UNKNOWN; + } + + /* sanity checks */ + if (info->model[0] != 'G' || info->model[1] != 'W') { + puts("EEPROM: Invalid Model in EEPROM\n"); + info->model[0] = 0; + return GW_UNKNOWN; + } + + /* validate checksum */ + for (chksum = 0, i = 0; i < sizeof(*info)-2; i++) + chksum += buf[i]; + if ((info->chksum[0] != chksum>>8) || + (info->chksum[1] != (chksum&0xff))) { + puts("EEPROM: Failed EEPROM checksum\n"); + info->model[0] = 0; + return GW_UNKNOWN; + } + + /* original GW5400-A prototype */ + baseboard = info->model[3]; + if (strncasecmp((const char *)info->model, "GW5400-A", 8) == 0) + baseboard = '0'; + + switch (baseboard) { + case '0': /* original GW5400-A prototype */ + type = GW54proto; + break; + case '1': + type = GW51xx; + break; + case '2': + type = GW52xx; + break; + case '3': + type = GW53xx; + break; + case '4': + type = GW54xx; + break; + default: + printf("EEPROM: Unknown model in EEPROM: %s\n", info->model); + type = GW_UNKNOWN; + break; + } + return type; +} + +/* + * Baseboard specific GPIO + */ + +/* common to add baseboards */ +static iomux_v3_cfg_t const gw_gpio_pads[] = { + /* MSATA_EN */ + MX6_PAD_SD4_DAT0__GPIO2_IO08 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* RS232_EN# */ + MX6_PAD_SD4_DAT3__GPIO2_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +/* prototype */ +static iomux_v3_cfg_t const gwproto_gpio_pads[] = { + /* PANLEDG# */ + MX6_PAD_KEY_COL0__GPIO4_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PANLEDR# */ + MX6_PAD_KEY_ROW0__GPIO4_IO07 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* LOCLED# */ + MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* RS485_EN */ + MX6_PAD_SD3_DAT4__GPIO7_IO01 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOEXP_PWREN# */ + MX6_PAD_EIM_A19__GPIO2_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOEXP_IRQ# */ + MX6_PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* VID_EN */ + MX6_PAD_EIM_D31__GPIO3_IO31 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* DIOI2C_DIS# */ + MX6_PAD_GPIO_19__GPIO4_IO05 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PCICK_SSON */ + MX6_PAD_SD1_CLK__GPIO1_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PCI_RST# */ + MX6_PAD_ENET_TXD1__GPIO1_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const gw51xx_gpio_pads[] = { + /* PANLEDG# */ + MX6_PAD_KEY_COL0__GPIO4_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PANLEDR# */ + MX6_PAD_KEY_ROW0__GPIO4_IO07 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOEXP_PWREN# */ + MX6_PAD_EIM_A19__GPIO2_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOEXP_IRQ# */ + MX6_PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL), + + /* GPS_SHDN */ + MX6_PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* VID_PWR */ + MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PCI_RST# */ + MX6_PAD_GPIO_0__GPIO1_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const gw52xx_gpio_pads[] = { + /* PANLEDG# */ + MX6_PAD_KEY_COL0__GPIO4_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PANLEDR# */ + MX6_PAD_KEY_ROW0__GPIO4_IO07 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOEXP_PWREN# */ + MX6_PAD_EIM_A19__GPIO2_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOEXP_IRQ# */ + MX6_PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL), + + /* MX6_LOCLED# */ + MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* GPS_SHDN */ + MX6_PAD_ENET_RXD0__GPIO1_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* USBOTG_SEL */ + MX6_PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* VID_PWR */ + MX6_PAD_EIM_D31__GPIO3_IO31 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PCI_RST# */ + MX6_PAD_ENET_TXD1__GPIO1_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const gw53xx_gpio_pads[] = { + /* PANLEDG# */ + MX6_PAD_KEY_COL0__GPIO4_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PANLEDR# */ + MX6_PAD_KEY_ROW0__GPIO4_IO07 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOEXP_PWREN# */ + MX6_PAD_EIM_A19__GPIO2_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOEXP_IRQ# */ + MX6_PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL), + + /* MX6_LOCLED# */ + MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* GPS_SHDN */ + MX6_PAD_ENET_RXD0__GPIO1_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* VID_EN */ + MX6_PAD_EIM_D31__GPIO3_IO31 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PCI_RST# */ + MX6_PAD_ENET_TXD1__GPIO1_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { + /* PANLEDG# */ + MX6_PAD_KEY_COL0__GPIO4_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PANLEDR# */ + MX6_PAD_KEY_COL2__GPIO4_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* MX6_LOCLED# */ + MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* MIPI_DIO */ + MX6_PAD_SD1_DAT3__GPIO1_IO21 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* RS485_EN */ + MX6_PAD_EIM_D24__GPIO3_IO24 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOEXP_PWREN# */ + MX6_PAD_KEY_ROW0__GPIO4_IO07 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOEXP_IRQ# */ + MX6_PAD_KEY_ROW1__GPIO4_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* DIOI2C_DIS# */ + MX6_PAD_GPIO_19__GPIO4_IO05 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* DIOI2C_DIS# */ + MX6_PAD_GPIO_19__GPIO4_IO05 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PCICK_SSON */ + MX6_PAD_SD1_CLK__GPIO1_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* PCI_RST# */ + MX6_PAD_ENET_TXD1__GPIO1_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +/* + * each baseboard has 4 user configurable Digital IO lines which can + * be pinmuxed as a GPIO or in some cases a PWM + */ +struct dio_cfg { + iomux_v3_cfg_t gpio_padmux; + unsigned gpio_param; + iomux_v3_cfg_t pwm_padmux; + unsigned pwm_param; +}; + +struct ventana { + /* pinmux */ + iomux_v3_cfg_t const *gpio_pads; + int num_pads; + /* DIO pinmux/val */ + struct dio_cfg dio_cfg[4]; + /* various gpios (0 if non-existent) */ + int leds[3]; + int pcie_rst; + int mezz_pwren; + int mezz_irq; + int rs485en; + int gps_shdn; + int vidin_en; + int dioi2c_en; + int pcie_sson; + int usb_sel; +}; + +struct ventana gpio_cfg[] = { + /* GW5400proto */ + { + .gpio_pads = gw54xx_gpio_pads, + .num_pads = ARRAY_SIZE(gw54xx_gpio_pads), + .dio_cfg = { + { MX6_PAD_GPIO_9__GPIO1_IO09, IMX_GPIO_NR(1, 9), + MX6_PAD_GPIO_9__PWM1_OUT, 1 }, + { MX6_PAD_SD1_DAT2__GPIO1_IO19, IMX_GPIO_NR(1, 19), + MX6_PAD_SD1_DAT2__PWM2_OUT, 2 }, + { MX6_PAD_SD4_DAT1__GPIO2_IO09, IMX_GPIO_NR(2, 9), + MX6_PAD_SD4_DAT1__PWM3_OUT, 3 }, + { MX6_PAD_SD4_DAT2__GPIO2_IO10, IMX_GPIO_NR(2, 10), + MX6_PAD_SD4_DAT2__PWM4_OUT, 4 }, + }, + .leds = { + IMX_GPIO_NR(4, 6), + IMX_GPIO_NR(4, 10), + IMX_GPIO_NR(4, 15), + }, + .pcie_rst = IMX_GPIO_NR(1, 29), + .mezz_pwren = IMX_GPIO_NR(4, 7), + .mezz_irq = IMX_GPIO_NR(4, 9), + .rs485en = IMX_GPIO_NR(3, 24), + .dioi2c_en = IMX_GPIO_NR(4, 5), + .pcie_sson = IMX_GPIO_NR(1, 20), + }, + + /* GW51xx */ + { + .gpio_pads = gw51xx_gpio_pads, + .num_pads = ARRAY_SIZE(gw51xx_gpio_pads), + .dio_cfg = { + { MX6_PAD_SD1_DAT0__GPIO1_IO16, IMX_GPIO_NR(1, 16), + 0, 0 }, + { MX6_PAD_SD1_DAT2__GPIO1_IO19, IMX_GPIO_NR(1, 19), + MX6_PAD_SD1_DAT2__PWM2_OUT, 2 }, + { MX6_PAD_SD1_DAT1__GPIO1_IO17, IMX_GPIO_NR(1, 17), + MX6_PAD_SD1_DAT1__PWM3_OUT, 3 }, + { MX6_PAD_SD1_CMD__GPIO1_IO18, IMX_GPIO_NR(1, 18), + MX6_PAD_SD1_CMD__PWM4_OUT, 4 }, + }, + .leds = { + IMX_GPIO_NR(4, 6), + IMX_GPIO_NR(4, 10), + }, + .pcie_rst = IMX_GPIO_NR(1, 0), + .mezz_pwren = IMX_GPIO_NR(2, 19), + .mezz_irq = IMX_GPIO_NR(2, 18), + .gps_shdn = IMX_GPIO_NR(1, 2), + .vidin_en = IMX_GPIO_NR(5, 20), + }, + + /* GW52xx */ + { + .gpio_pads = gw52xx_gpio_pads, + .num_pads = ARRAY_SIZE(gw52xx_gpio_pads), + .dio_cfg = { + { MX6_PAD_SD1_DAT0__GPIO1_IO16, IMX_GPIO_NR(1, 16), + 0, 0 }, + { MX6_PAD_SD1_DAT2__GPIO1_IO19, IMX_GPIO_NR(1, 19), + MX6_PAD_SD1_DAT2__PWM2_OUT, 2 }, + { MX6_PAD_SD1_DAT1__GPIO1_IO17, IMX_GPIO_NR(1, 17), + MX6_PAD_SD1_DAT1__PWM3_OUT, 3 }, + { MX6_PAD_SD1_CLK__GPIO1_IO20, IMX_GPIO_NR(1, 20), + 0, 0 }, + }, + .leds = { + IMX_GPIO_NR(4, 6), + IMX_GPIO_NR(4, 7), + IMX_GPIO_NR(4, 15), + }, + .pcie_rst = IMX_GPIO_NR(1, 29), + .mezz_pwren = IMX_GPIO_NR(2, 19), + .mezz_irq = IMX_GPIO_NR(2, 18), + .gps_shdn = IMX_GPIO_NR(1, 27), + .vidin_en = IMX_GPIO_NR(3, 31), + .usb_sel = IMX_GPIO_NR(1, 2), + }, + + /* GW53xx */ + { + .gpio_pads = gw53xx_gpio_pads, + .num_pads = ARRAY_SIZE(gw53xx_gpio_pads), + .dio_cfg = { + { MX6_PAD_SD1_DAT0__GPIO1_IO16, IMX_GPIO_NR(1, 16), + 0, 0 }, + { MX6_PAD_SD1_DAT2__GPIO1_IO19, IMX_GPIO_NR(1, 19), + MX6_PAD_SD1_DAT2__PWM2_OUT, 2 }, + { MX6_PAD_SD1_DAT1__GPIO1_IO17, IMX_GPIO_NR(1, 17), + MX6_PAD_SD1_DAT1__PWM3_OUT, 3 }, + { MX6_PAD_SD1_CLK__GPIO1_IO20, IMX_GPIO_NR(1, 20), + 0, 0 }, + }, + .leds = { + IMX_GPIO_NR(4, 6), + IMX_GPIO_NR(4, 7), + IMX_GPIO_NR(4, 15), + }, + .pcie_rst = IMX_GPIO_NR(1, 29), + .mezz_pwren = IMX_GPIO_NR(2, 19), + .mezz_irq = IMX_GPIO_NR(2, 18), + .gps_shdn = IMX_GPIO_NR(1, 27), + .vidin_en = IMX_GPIO_NR(3, 31), + }, + + /* GW54xx */ + { + .gpio_pads = gw54xx_gpio_pads, + .num_pads = ARRAY_SIZE(gw54xx_gpio_pads), + .dio_cfg = { + { MX6_PAD_GPIO_9__GPIO1_IO09, IMX_GPIO_NR(1, 9), + MX6_PAD_GPIO_9__PWM1_OUT, 1 }, + { MX6_PAD_SD1_DAT2__GPIO1_IO19, IMX_GPIO_NR(1, 19), + MX6_PAD_SD1_DAT2__PWM2_OUT, 2 }, + { MX6_PAD_SD4_DAT1__GPIO2_IO09, IMX_GPIO_NR(2, 9), + MX6_PAD_SD4_DAT1__PWM3_OUT, 3 }, + { MX6_PAD_SD4_DAT2__GPIO2_IO10, IMX_GPIO_NR(2, 10), + MX6_PAD_SD4_DAT2__PWM4_OUT, 4 }, + }, + .leds = { + IMX_GPIO_NR(4, 6), + IMX_GPIO_NR(4, 7), + IMX_GPIO_NR(4, 15), + }, + .pcie_rst = IMX_GPIO_NR(1, 29), + .mezz_pwren = IMX_GPIO_NR(2, 19), + .mezz_irq = IMX_GPIO_NR(2, 18), + .rs485en = IMX_GPIO_NR(7, 1), + .vidin_en = IMX_GPIO_NR(3, 31), + .dioi2c_en = IMX_GPIO_NR(4, 5), + .pcie_sson = IMX_GPIO_NR(1, 20), + }, +}; + +/* setup GPIO pinmux and default configuration per baseboard */ +static void setup_board_gpio(int board) +{ + struct ventana_board_info *info = &ventana_info; + const char *s; + char arg[10]; + size_t len; + int i; + int quiet = simple_strtol(getenv("quiet"), NULL, 10); + + if (board >= GW_UNKNOWN) + return; + + /* RS232_EN# */ + gpio_direction_output(GP_RS232_EN, (hwconfig("rs232")) ? 0 : 1); + + /* MSATA Enable */ + if (is_cpu_type(MXC_CPU_MX6Q) && + test_bit(EECONFIG_SATA, info->config)) { + gpio_direction_output(GP_MSATA_SEL, + (hwconfig("msata")) ? 1 : 0); + } else { + gpio_direction_output(GP_MSATA_SEL, 0); + } + + /* + * assert PCI_RST# (released by OS when clock is valid) + * TODO: figure out why leaving this de-asserted from PCI scan on boot + * causes linux pcie driver to hang during enumeration + */ + gpio_direction_output(gpio_cfg[board].pcie_rst, 0); + + /* turn off (active-high) user LED's */ + for (i = 0; i < 4; i++) { + if (gpio_cfg[board].leds[i]) + gpio_direction_output(gpio_cfg[board].leds[i], 1); + } + + /* Expansion Mezzanine IO */ + gpio_direction_output(gpio_cfg[board].mezz_pwren, 0); + gpio_direction_input(gpio_cfg[board].mezz_irq); + + /* RS485 Transmit Enable */ + if (gpio_cfg[board].rs485en) + gpio_direction_output(gpio_cfg[board].rs485en, 0); + + /* GPS_SHDN */ + if (gpio_cfg[board].gps_shdn) + gpio_direction_output(gpio_cfg[board].gps_shdn, 1); + + /* Analog video codec power enable */ + if (gpio_cfg[board].vidin_en) + gpio_direction_output(gpio_cfg[board].vidin_en, 1); + + /* DIOI2C_DIS# */ + if (gpio_cfg[board].dioi2c_en) + gpio_direction_output(gpio_cfg[board].dioi2c_en, 0); + + /* PCICK_SSON: disable spread-spectrum clock */ + if (gpio_cfg[board].pcie_sson) + gpio_direction_output(gpio_cfg[board].pcie_sson, 0); + + /* USBOTG Select (PCISKT or FrontPanel) */ + if (gpio_cfg[board].usb_sel) + gpio_direction_output(gpio_cfg[board].usb_sel, 0); + + /* + * Configure DIO pinmux/padctl registers + * see IMX6DQRM/IMX6SDLRM IOMUXC_SW_PAD_CTL_PAD_* register definitions + */ + for (i = 0; i < 4; i++) { + struct dio_cfg *cfg = &gpio_cfg[board].dio_cfg[i]; + unsigned ctrl = DIO_PAD_CTRL; + + sprintf(arg, "dio%d", i); + if (!hwconfig(arg)) + continue; + s = hwconfig_subarg(arg, "padctrl", &len); + if (s) + ctrl = simple_strtoul(s, NULL, 16) & 0x3ffff; + if (hwconfig_subarg_cmp(arg, "mode", "gpio")) { + if (!quiet) { + printf("DIO%d: GPIO%d_IO%02d (gpio-%d)\n", i, + (cfg->gpio_param/32)+1, + cfg->gpio_param%32, + cfg->gpio_param); + } + imx_iomux_v3_setup_pad(cfg->gpio_padmux | + MUX_PAD_CTRL(ctrl)); + gpio_direction_input(cfg->gpio_param); + } else if (hwconfig_subarg_cmp("dio2", "mode", "pwm") && + cfg->pwm_padmux) { + if (!quiet) + printf("DIO%d: pwm%d\n", i, cfg->pwm_param); + imx_iomux_v3_setup_pad(cfg->pwm_padmux | + MUX_PAD_CTRL(ctrl)); + } + } + + if (!quiet) { + if (is_cpu_type(MXC_CPU_MX6Q) && + (test_bit(EECONFIG_SATA, info->config))) { + printf("MSATA: %s\n", (hwconfig("msata") ? + "enabled" : "disabled")); + } + printf("RS232: %s\n", (hwconfig("rs232")) ? + "enabled" : "disabled"); + } +} + +#if defined(CONFIG_CMD_PCI) +int imx6_pcie_toggle_reset(void) +{ + if (board_type < GW_UNKNOWN) { + gpio_direction_output(gpio_cfg[board_type].pcie_rst, 0); + mdelay(50); + gpio_direction_output(gpio_cfg[board_type].pcie_rst, 1); + } + return 0; +} +#endif /* CONFIG_CMD_PCI */ + +#ifdef CONFIG_SERIAL_TAG +/* + * called when setting up ATAGS before booting kernel + * populate serialnum from the following (in order of priority): + * serial# env var + * eeprom + */ +void get_board_serial(struct tag_serialnr *serialnr) +{ + char *serial = getenv("serial#"); + + if (serial) { + serialnr->high = 0; + serialnr->low = simple_strtoul(serial, NULL, 10); + } else if (ventana_info.model[0]) { + serialnr->high = 0; + serialnr->low = ventana_info.serial; + } else { + serialnr->high = 0; + serialnr->low = 0; + } +} +#endif + +/* + * Board Support + */ + +int board_early_init_f(void) +{ + setup_iomux_uart(); + gpio_direction_output(GP_USB_OTG_PWR, 0); /* OTG power off */ + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, + CONFIG_DDR_MB*1024*1024); + + return 0; +} + +int board_init(void) +{ + struct iomuxc_base_regs *const iomuxc_regs + = (struct iomuxc_base_regs *)IOMUXC_BASE_ADDR; + + clrsetbits_le32(&iomuxc_regs->gpr[1], + IOMUXC_GPR1_OTG_ID_MASK, + IOMUXC_GPR1_OTG_ID_GPIO1); + + /* address of linux boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + +#ifdef CONFIG_CMD_NAND + setup_gpmi_nand(); +#endif +#ifdef CONFIG_MXC_SPI + setup_spi(); +#endif + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0); + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); + +#ifdef CONFIG_CMD_SATA + setup_sata(); +#endif + /* read Gateworks EEPROM into global struct (used later) */ + board_type = read_eeprom(); + + /* board-specifc GPIO iomux */ + if (board_type < GW_UNKNOWN) { + imx_iomux_v3_setup_multiple_pads(gw_gpio_pads, + ARRAY_SIZE(gw_gpio_pads)); + imx_iomux_v3_setup_multiple_pads(gpio_cfg[board_type].gpio_pads, + gpio_cfg[board_type].num_pads); + } + + return 0; +} + +#if defined(CONFIG_DISPLAY_BOARDINFO_LATE) +/* + * called during late init (after relocation and after board_init()) + * by virtue of CONFIG_DISPLAY_BOARDINFO_LATE as we needed i2c initialized and + * EEPROM read. + */ +int checkboard(void) +{ + struct ventana_board_info *info = &ventana_info; + unsigned char buf[4]; + const char *p; + int quiet; /* Quiet or minimal output mode */ + + quiet = 0; + p = getenv("quiet"); + if (p) + quiet = simple_strtol(p, NULL, 10); + else + setenv("quiet", "0"); + + puts("\nGateworks Corporation Copyright 2014\n"); + if (info->model[0]) { + printf("Model: %s\n", info->model); + printf("MFGDate: %02x-%02x-%02x%02x\n", + info->mfgdate[0], info->mfgdate[1], + info->mfgdate[2], info->mfgdate[3]); + printf("Serial:%d\n", info->serial); + } else { + puts("Invalid EEPROM - board will not function fully\n"); + } + if (quiet) + return 0; + + /* Display GSC firmware revision/CRC/status */ + i2c_set_bus_num(I2C_GSC); + if (!gsc_i2c_read(GSC_SC_ADDR, GSC_SC_FWVER, 1, buf, 1)) { + printf("GSC: v%d", buf[0]); + if (!gsc_i2c_read(GSC_SC_ADDR, GSC_SC_STATUS, 1, buf, 4)) { + printf(" 0x%04x", buf[2] | buf[3]<<8); /* CRC */ + printf(" 0x%02x", buf[0]); /* irq status */ + } + puts("\n"); + } + /* Display RTC */ + if (!gsc_i2c_read(GSC_RTC_ADDR, 0x00, 1, buf, 4)) { + printf("RTC: %d\n", + buf[0] | buf[1]<<8 | buf[2]<<16 | buf[3]<<24); + } + + return 0; +} +#endif + +#ifdef CONFIG_CMD_BMODE +/* + * BOOT_CFG1, BOOT_CFG2, BOOT_CFG3, BOOT_CFG4 + * see Table 8-11 and Table 5-9 + * BOOT_CFG1[7] = 1 (boot from NAND) + * BOOT_CFG1[5] = 0 - raw NAND + * BOOT_CFG1[4] = 0 - default pad settings + * BOOT_CFG1[3:2] = 00 - devices = 1 + * BOOT_CFG1[1:0] = 00 - Row Address Cycles = 3 + * BOOT_CFG2[4:3] = 00 - Boot Search Count = 2 + * BOOT_CFG2[2:1] = 01 - Pages In Block = 64 + * BOOT_CFG2[0] = 0 - Reset time 12ms + */ +static const struct boot_mode board_boot_modes[] = { + /* NAND: 64pages per block, 3 row addr cycles, 2 copies of FCB/DBBT */ + { "nand", MAKE_CFGVAL(0x80, 0x02, 0x00, 0x00) }, + { NULL, 0 }, +}; +#endif + +/* late init */ +int misc_init_r(void) +{ + struct ventana_board_info *info = &ventana_info; + unsigned char reg; + + /* set env vars based on EEPROM data */ + if (ventana_info.model[0]) { + char str[16], fdt[36]; + char *p; + const char *cputype = ""; + int i; + + /* + * FDT name will be prefixed with CPU type. Three versions + * will be created each increasingly generic and bootloader + * env scripts will try loading each from most specific to + * least. + */ + if (is_cpu_type(MXC_CPU_MX6Q)) + cputype = "imx6q"; + else if (is_cpu_type(MXC_CPU_MX6DL)) + cputype = "imx6dl"; + memset(str, 0, sizeof(str)); + for (i = 0; i < (sizeof(str)-1) && info->model[i]; i++) + str[i] = tolower(info->model[i]); + if (!getenv("model")) + setenv("model", str); + if (!getenv("fdt_file")) { + sprintf(fdt, "%s-%s.dtb", cputype, str); + setenv("fdt_file", fdt); + } + p = strchr(str, '-'); + if (p) { + *p++ = 0; + + setenv("model_base", str); + if (!getenv("fdt_file1")) { + sprintf(fdt, "%s-%s.dtb", cputype, str); + setenv("fdt_file1", fdt); + } + str[4] = 'x'; + str[5] = 'x'; + str[6] = 0; + if (!getenv("fdt_file2")) { + sprintf(fdt, "%s-%s.dtb", cputype, str); + setenv("fdt_file2", fdt); + } + } + + /* initialize env from EEPROM */ + if (test_bit(EECONFIG_ETH0, info->config) && + !getenv("ethaddr")) { + eth_setenv_enetaddr("ethaddr", info->mac0); + } + if (test_bit(EECONFIG_ETH1, info->config) && + !getenv("eth1addr")) { + eth_setenv_enetaddr("eth1addr", info->mac1); + } + + /* board serial-number */ + sprintf(str, "%6d", info->serial); + setenv("serial#", str); + } + + /* configure PFUZE100 PMIC (not used on Ventana baseboards) */ + if (!pmic_init(I2C_PMIC)) { + struct pmic *p = pmic_get("PFUZE100_PMIC"); + u32 reg; + if (p && !pmic_probe(p)) { + pmic_reg_read(p, PFUZE100_DEVICEID, ®); + printf("PMIC: PFUZE100 ID=0x%02x\n", reg); + + /* Set VGEN1 to 1.5V and enable */ + pmic_reg_read(p, PFUZE100_VGEN1VOL, ®); + reg &= ~(LDO_VOL_MASK); + reg |= (LDOA_1_50V | LDO_EN); + pmic_reg_write(p, PFUZE100_VGEN1VOL, reg); + + /* Set SWBST to 5.0V and enable */ + pmic_reg_read(p, PFUZE100_SWBSTCON1, ®); + reg &= ~(SWBST_MODE_MASK | SWBST_VOL_MASK); + reg |= (SWBST_5_00V | SWBST_MODE_AUTO); + pmic_reg_write(p, PFUZE100_SWBSTCON1, reg); + } + } + + /* setup baseboard specific GPIO pinmux and config */ + setup_board_gpio(board_type); + +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + + /* + * The Gateworks System Controller implements a boot + * watchdog (always enabled) as a workaround for IMX6 boot related + * errata such as: + * ERR005768 - no fix + * ERR006282 - fixed in silicon r1.3 + * ERR007117 - fixed in silicon r1.3 + * ERR007220 - fixed in silicon r1.3 + * see http://cache.freescale.com/files/32bit/doc/errata/IMX6DQCE.pdf + * + * Disable the boot watchdog and display/clear the timeout flag if set + */ + i2c_set_bus_num(I2C_GSC); + if (!gsc_i2c_read(GSC_SC_ADDR, GSC_SC_CTRL1, 1, ®, 1)) { + reg |= (1 << GSC_SC_CTRL1_WDDIS); + if (gsc_i2c_write(GSC_SC_ADDR, GSC_SC_CTRL1, 1, ®, 1)) + puts("Error: could not disable GSC Watchdog\n"); + } else { + puts("Error: could not disable GSC Watchdog\n"); + } + if (!gsc_i2c_read(GSC_SC_ADDR, GSC_SC_STATUS, 1, ®, 1)) { + if (reg & (1 << GSC_SC_IRQ_WATCHDOG)) { /* watchdog timeout */ + puts("GSC boot watchdog timeout detected"); + reg &= ~(1 << GSC_SC_IRQ_WATCHDOG); /* clear flag */ + gsc_i2c_write(GSC_SC_ADDR, GSC_SC_STATUS, 1, ®, 1); + } + } + + return 0; +} + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) + +/* FDT aliases associated with EEPROM config bits */ +const char *fdt_aliases[] = { + "ethernet0", + "ethernet1", + "hdmi_out", + "ahci0", + "pcie", + "ssi0", + "ssi1", + "lcd0", + "lvds0", + "lvds1", + "usb0", + "usb1", + "mmc0", + "mmc1", + "mmc2", + "mmc3", + "uart0", + "uart1", + "uart2", + "uart3", + "uart4", + "ipu0", + "ipu1", + "can0", + "mipi_dsi", + "mipi_csi", + "tzasc0", + "tzasc1", + "i2c0", + "i2c1", + "i2c2", + "vpu", + "csi0", + "csi1", + "caam", + NULL, + NULL, + NULL, + NULL, + NULL, + "spi0", + "spi1", + "spi2", + "spi3", + "spi4", + "spi5", + NULL, + NULL, + "pps", + NULL, + NULL, + NULL, + "hdmi_in", + "cvbs_out", + "cvbs_in", + "nand", + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, +}; + +/* + * called prior to booting kernel or by 'fdt boardsetup' command + * + * unless 'fdt_noauto' env var is set we will update the following in the DTB: + * - mtd partitions based on mtdparts/mtdids env + * - system-serial (board serial num from EEPROM) + * - board (full model from EEPROM) + * - peripherals removed from DTB if not loaded on board (per EEPROM config) + */ +void ft_board_setup(void *blob, bd_t *bd) +{ + int bit; + struct ventana_board_info *info = &ventana_info; + struct node_info nodes[] = { + { "sst,w25q256", MTD_DEV_TYPE_NOR, }, /* SPI flash */ + { "fsl,imx6q-gpmi-nand", MTD_DEV_TYPE_NAND, }, /* NAND flash */ + }; + const char *model = getenv("model"); + + if (getenv("fdt_noauto")) { + puts(" Skiping ft_board_setup (fdt_noauto defined)\n"); + return; + } + + /* Update partition nodes using info from mtdparts env var */ + puts(" Updating MTD partitions...\n"); + fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); + + if (!model) { + puts("invalid board info: Leaving FDT fully enabled\n"); + return; + } + printf(" Adjusting FDT per EEPROM for %s...\n", model); + + /* board serial number */ + fdt_setprop(blob, 0, "system-serial", getenv("serial#"), + strlen(getenv("serial#") + 1)); + + /* board (model contains model from device-tree) */ + fdt_setprop(blob, 0, "board", info->model, + strlen((const char *)info->model) + 1); + + /* + * Peripheral Config: + * remove nodes by alias path if EEPROM config tells us the + * peripheral is not loaded on the board. + */ + for (bit = 0; bit < 64; bit++) { + if (!test_bit(bit, info->config)) + fdt_del_node_and_alias(blob, fdt_aliases[bit]); + } +} +#endif /* defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) */ + diff --git a/board/gateworks/gw_ventana/gw_ventana.cfg b/board/gateworks/gw_ventana/gw_ventana.cfg new file mode 100644 index 0000000..6618fb9 --- /dev/null +++ b/board/gateworks/gw_ventana/gw_ventana.cfg @@ -0,0 +1,42 @@ +/* + * Copyright (C) 2013 Gateworks Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer doc/README.imximage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd, nand, sata + */ +#ifdef CONFIG_SPI_FLASH +BOOT_FROM spi +#else +BOOT_FROM nand +#endif + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +/* Memory configuration (size is overridden via eeprom config) */ +#include "../../boundary/nitrogen6x/ddr-setup.cfg" +#if defined(CONFIG_MX6Q) && CONFIG_DDR_MB == 1024 + #include "../../boundary/nitrogen6x/1066mhz_4x128mx16.cfg" +#elif defined(CONFIG_MX6DL) && CONFIG_DDR_MB == 1024 + #include "../../boundary/nitrogen6x/800mhz_4x128mx16.cfg" +#elif defined(CONFIG_MX6DL) && CONFIG_DDR_MB == 512 + #include "../../boundary/nitrogen6x/800mhz_2x128mx16.cfg" +#else + #error "Unsupported CPU/Memory configuration" +#endif +#include "clocks.cfg" diff --git a/board/gateworks/gw_ventana/ventana_eeprom.h b/board/gateworks/gw_ventana/ventana_eeprom.h new file mode 100644 index 0000000..d310bfd --- /dev/null +++ b/board/gateworks/gw_ventana/ventana_eeprom.h @@ -0,0 +1,106 @@ +/* + * Copyright (C) 2013 Gateworks Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _VENTANA_EEPROM_ +#define _VENTANA_EEPROM_ + +struct ventana_board_info { + u8 mac0[6]; /* 0x00: MAC1 */ + u8 mac1[6]; /* 0x06: MAC2 */ + u8 res0[12]; /* 0x0C: reserved */ + u32 serial; /* 0x18: Serial Number (read only) */ + u8 res1[4]; /* 0x1C: reserved */ + u8 mfgdate[4]; /* 0x20: MFG date (read only) */ + u8 res2[7]; /* 0x24 */ + /* sdram config */ + u8 sdram_size; /* 0x2B: enum (512,1024,2048) MB */ + u8 sdram_speed; /* 0x2C: enum (100,133,166,200,267,333,400) MHz */ + u8 sdram_width; /* 0x2D: enum (32,64) bit */ + /* cpu config */ + u8 cpu_speed; /* 0x2E: enum (800,1000,1200) MHz */ + u8 cpu_type; /* 0x2F: enum (imx6q,imx6d,imx6dl,imx6s) */ + u8 model[16]; /* 0x30: model string */ + /* FLASH config */ + u8 nand_flash_size; /* 0x40: enum (4,8,16,32,64,128) MB */ + u8 spi_flash_size; /* 0x41: enum (4,8,16,32,64,128) MB */ + + /* Config1: SoC Peripherals */ + u8 config[8]; /* 0x42: loading options */ + + u8 res3[4]; /* 0x4A */ + + u8 chksum[2]; /* 0x4E */ +}; + +/* config bits */ +enum { + EECONFIG_ETH0, + EECONFIG_ETH1, + EECONFIG_HDMI_OUT, + EECONFIG_SATA, + EECONFIG_PCIE, + EECONFIG_SSI0, + EECONFIG_SSI1, + EECONFIG_LCD, + EECONFIG_LVDS0, + EECONFIG_LVDS1, + EECONFIG_USB0, + EECONFIG_USB1, + EECONFIG_SD0, + EECONFIG_SD1, + EECONFIG_SD2, + EECONFIG_SD3, + EECONFIG_UART0, + EECONFIG_UART1, + EECONFIG_UART2, + EECONFIG_UART3, + EECONFIG_UART4, + EECONFIG_IPU0, + EECONFIG_IPU1, + EECONFIG_FLEXCAN, + EECONFIG_MIPI_DSI, + EECONFIG_MIPI_CSI, + EECONFIG_TZASC0, + EECONFIG_TZASC1, + EECONFIG_I2C0, + EECONFIG_I2C1, + EECONFIG_I2C2, + EECONFIG_VPU, + EECONFIG_CSI0, + EECONFIG_CSI1, + EECONFIG_CAAM, + EECONFIG_MEZZ, + EECONFIG_RES1, + EECONFIG_RES2, + EECONFIG_RES3, + EECONFIG_RES4, + EECONFIG_ESPCI0, + EECONFIG_ESPCI1, + EECONFIG_ESPCI2, + EECONFIG_ESPCI3, + EECONFIG_ESPCI4, + EECONFIG_ESPCI5, + EECONFIG_RES5, + EECONFIG_RES6, + EECONFIG_GPS, + EECONFIG_SPIFL0, + EECONFIG_SPIFL1, + EECONFIG_GSPBATT, + EECONFIG_HDMI_IN, + EECONFIG_VID_OUT, + EECONFIG_VID_IN, + EECONFIG_NAND, + EECONFIG_RES8, + EECONFIG_RES9, + EECONFIG_RES10, + EECONFIG_RES11, + EECONFIG_RES12, + EECONFIG_RES13, + EECONFIG_RES14, + EECONFIG_RES15, +}; + +#endif diff --git a/boards.cfg b/boards.cfg index 2dfd2b4..b20a161 100644 --- a/boards.cfg +++ b/boards.cfg @@ -310,6 +310,11 @@ Active arm armv7 mx6 freescale mx6qsabreauto Active arm armv7 mx6 freescale mx6sabresd mx6dlsabresd mx6sabresd:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 freescale mx6sabresd mx6qsabresd mx6sabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 freescale mx6slevk mx6slevk mx6slevk:IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 gateworks gw_ventana gwventanadl gw_ventana:IMX_CONFIG=board/gateworks/gw_ventana/gw_ventana.cfg,MX6DL,DDR_MB=512 Tim Harvey tharvey@gateworks.com +Active arm armv7 mx6 gateworks gw_ventana gwventanadl1g gw_ventana:IMX_CONFIG=board/gateworks/gw_ventana/gw_ventana.cfg,MX6DL,DDR_MB=1024 Tim Harvey tharvey@gateworks.com +Active arm armv7 mx6 gateworks gw_ventana gwventanaq gw_ventana:IMX_CONFIG=board/gateworks/gw_ventana/gw_ventana.cfg,MX6Q,DDR_MB=512 Tim Harvey tharvey@gateworks.com +Active arm armv7 mx6 gateworks gw_ventana gwventanaq1g gw_ventana:IMX_CONFIG=board/gateworks/gw_ventana/gw_ventana.cfg,MX6Q,DDR_MB=1024 Tim Harvey tharvey@gateworks.com +Active arm armv7 mx6 gateworks gw_ventana gwventanaq1gspi gw_ventana:IMX_CONFIG=board/gateworks/gw_ventana/gw_ventana.cfg,MX6Q,DDR_MB=1024,SPI_FLASH Tim Harvey tharvey@gateworks.com Active arm armv7 mx6 solidrun hummingboard hummingboard_solo hummingboard:IMX_CONFIG=board/solidrun/hummingboard/solo.cfg,MX6S,DDR_MB=512 Jon Nettleton jon.nettleton@gmail.com Active arm armv7 omap3 - overo omap3_overo - Steve Sakoman sakoman@gmail.com Active arm armv7 omap3 - pandora omap3_pandora - Grazvydas Ignotas notasas@gmail.com diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h new file mode 100644 index 0000000..e9e9e16 --- /dev/null +++ b/include/configs/gw_ventana.h @@ -0,0 +1,425 @@ +/* + * Copyright (C) 2013 Gateworks Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include "mx6_common.h" +#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO /* display cpu info */ +#define CONFIG_DISPLAY_BOARDINFO_LATE /* display board info (after reloc) */ + +#define CONFIG_MACH_TYPE 4520 /* Gateworks Ventana Platform */ + +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + +/* ATAGs */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_SERIAL_TAG +#define CONFIG_REVISION_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024) + +/* Init Functions */ +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MISC_INIT_R + +/* GPIO */ +#define CONFIG_MXC_GPIO + +/* Serial */ +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART2_BASE + +#ifdef CONFIG_SPI_FLASH + +/* SPI */ +#define CONFIG_CMD_SF +#ifdef CONFIG_CMD_SF + #define CONFIG_MXC_SPI + #define CONFIG_SPI_FLASH_MTD + #define CONFIG_SPI_FLASH_BAR + #define CONFIG_SPI_FLASH_WINBOND + #define CONFIG_SF_DEFAULT_BUS 0 + #define CONFIG_SF_DEFAULT_CS (0|(IMX_GPIO_NR(3, 19)<<8)) + /* GPIO 3-19 (21248) */ + #define CONFIG_SF_DEFAULT_SPEED 30000000 + #define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) +#endif + +#else +/* Enable NAND support */ +#define CONFIG_CMD_TIME +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS +#ifdef CONFIG_CMD_NAND + #define CONFIG_NAND_MXS + #define CONFIG_SYS_MAX_NAND_DEVICE 1 + #define CONFIG_SYS_NAND_BASE 0x40000000 + #define CONFIG_SYS_NAND_5_ADDR_CYCLE + #define CONFIG_SYS_NAND_ONFI_DETECTION + + /* DMA stuff, needed for GPMI/MXS NAND support */ + #define CONFIG_APBH_DMA + #define CONFIG_APBH_DMA_BURST + #define CONFIG_APBH_DMA_BURST8 +#endif + +#endif /* CONFIG_SPI_FLASH */ + +/* Flattened Image Tree Suport */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE + +/* I2C Configs */ +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_SPEED 100000 + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER + +/* Filesystem support */ +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_UBIFS +#define CONFIG_DOS_PARTITION + +/* Network config - Allow larger/faster download for TFTP/NFS */ +#define CONFIG_IP_DEFRAG +#define CONFIG_TFTP_BLOCKSIZE 4096 +#define CONFIG_NFS_READ_SIZE 4096 + +/* + * SATA Configs + */ +#define CONFIG_CMD_SATA +#ifdef CONFIG_CMD_SATA + #define CONFIG_DWC_AHSATA + #define CONFIG_SYS_SATA_MAX_DEVICE 1 + #define CONFIG_DWC_AHSATA_PORT_ID 0 + #define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR + #define CONFIG_LBA48 + #define CONFIG_LIBATA +#endif + +/* + * PCI express + */ +#define CONFIG_CMD_PCI +#ifdef CONFIG_CMD_PCI +#define CONFIG_PCI +#define CONFIG_PCI_PNP +#define CONFIG_PCI_SCAN_SHOW +#define CONFIG_PCIE_IMX +#endif + +/* + * PMIC + */ +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_PFUZE100 +#define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 + +/* Various command support */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_CMD_BMODE /* set eFUSE shadow for a boot dev and reset */ +#define CONFIG_CMD_HDMIDETECT /* detect HDMI output device */ +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_GSC +#define CONFIG_CMD_UBI +#define CONFIG_RBTREE +#define CONFIG_LZO +#define CONFIG_CMD_FUSE /* eFUSE read/write support */ +#ifdef CONFIG_CMD_FUSE +#define CONFIG_MXC_OCOTP +#endif + + +/* Ethernet support */ +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0 +#define CONFIG_PHYLIB +#define CONFIG_ARP_TIMEOUT 200UL + +/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */ +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_KEYBOARD +#define CONFIG_MV_UDC +#define CONFIG_USBD_HS +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_ETHER +#define CONFIG_USB_ETH_CDC +#define CONFIG_NETCONSOLE +#define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP +#define CONFIG_USB_HUB_MIN_POWER_ON_DELAY 1200 + +/* serial console (ttymxc1,115200) */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "Ventana > " +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_HWCONFIG + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* Memory configuration */ +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x10010000 +#define CONFIG_SYS_MEMTEST_SCRATCH 0x10800000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 +#define CONFIG_SYS_LOAD_ADDR 0x12000000 + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH /* no NOR flash */ + +/* + * MTD Command for mtdparts + */ +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#ifdef CONFIG_SPI_FLASH +#define MTDIDS_DEFAULT "nor0=nor" +#define MTDPARTS_DEFAULT \ + "mtdparts=nor:512k(uboot),64k(env),2m(kernel),-(rootfs)" +#else +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:16m(uboot),1m(env),-(rootfs)" +#endif + +/* Persistent Environment Config */ +#define CONFIG_ENV_OVERWRITE /* allow to overwrite serial and ethaddr */ +#ifdef CONFIG_SPI_FLASH +#define CONFIG_ENV_IS_IN_SPI_FLASH +#else +#define CONFIG_ENV_IS_IN_NAND +#endif +#if defined(CONFIG_ENV_IS_IN_MMC) + #define CONFIG_ENV_OFFSET (6 * 64 * 1024) + #define CONFIG_ENV_SIZE (8 * 1024) + #define CONFIG_SYS_MMC_ENV_DEV 0 +#elif defined(CONFIG_ENV_IS_IN_NAND) + #define CONFIG_ENV_OFFSET (16 << 20) + #define CONFIG_ENV_SECT_SIZE (128 << 10) + #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE + #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + (512 << 10)) + #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) + #define CONFIG_ENV_OFFSET (512 * 1024) + #define CONFIG_ENV_SECT_SIZE (64 * 1024) + #define CONFIG_ENV_SIZE (8 * 1024) + #define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS + #define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS + #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE + #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#endif + +/* Environment */ +#define CONFIG_BOOTDELAY 3 +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR +#define CONFIG_IPADDR 192.168.1.1 +#define CONFIG_SERVERIP 192.168.1.146 +#define HWCONFIG_DEFAULT \ + "hwconfig=rs232;" \ + "dio0:mode=gpio;dio1:mode=gpio;dio2:mode=gpio;dio3:mode=gpio\0" \ + +#define CONFIG_EXTRA_ENV_SETTINGS_COMMON \ + "console=ttymxc1\0" \ + "bootdevs=usb mmc sata flash\0" \ + HWCONFIG_DEFAULT \ + "video=\0" \ + \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + \ + "fdt_high=0xffffffff\0" \ + "fdt_addr=0x18000000\0" \ + "loadfdt=" \ + "if ${fsload} ${fdt_addr} boot/${fdt_file}; then " \ + "echo Loaded DTB from boot/${fdt_file}; " \ + "elif ${fsload} ${fdt_addr} boot/${fdt_file1}; then " \ + "echo Loaded DTB from boot/${fdt_file1}; " \ + "elif ${fsload} ${fdt_addr} boot/${fdt_file2}; then " \ + "echo Loaded DTB from boot/${fdt_file2}; " \ + "fi\0" \ + \ + "script=boot/6x_bootscript-ventana\0" \ + "loadscript=" \ + "if ${fsload} ${loadaddr} ${script}; then " \ + "source; " \ + "fi\0" \ + \ + "uimage=boot/uImage\0" \ + "mmc_root=/dev/mmcblk0p1 rootfstype=ext4 rootwait rw\0" \ + "mmc_boot=" \ + "setenv fsload 'ext2load mmc 0:1'; " \ + "mmc dev 0 && mmc rescan && " \ + "run loadscript; " \ + "if ${fsload} ${loadaddr} ${uimage}; then " \ + "setenv bootargs console=${console},${baudrate} " \ + "root=/dev/mmcblk0p1 rootfstype=ext4 " \ + "rootwait rw ${video} ${extra}; " \ + "if run loadfdt && fdt addr ${fdt_addr}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "bootm; " \ + "fi; " \ + "fi\0" \ + \ + "sata_boot=" \ + "setenv fsload 'ext2load sata 0:1'; sata init && " \ + "run loadscript; " \ + "if ${fsload} ${loadaddr} ${uimage}; then " \ + "setenv bootargs console=${console},${baudrate} " \ + "root=/dev/sda1 rootfstype=ext4 " \ + "rootwait rw ${video} ${extra}; " \ + "if run loadfdt && fdt addr ${fdt_addr}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "bootm; " \ + "fi; " \ + "fi\0" \ + "usb_boot=" \ + "setenv fsload 'ext2load usb 0:1'; usb start && usb dev 0 && " \ + "run loadscript; " \ + "if ${fsload} ${loadaddr} ${uimage}; then " \ + "setenv bootargs console=${console},${baudrate} " \ + "root=/dev/sda1 rootfstype=ext4 " \ + "rootwait rw ${video} ${extra}; " \ + "if run loadfdt && fdt addr ${fdt_addr}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "bootm; " \ + "fi; " \ + "fi\0" + +#ifdef CONFIG_SPI_FLASH + #define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_EXTRA_ENV_SETTINGS_COMMON \ + "image_os=ventana/openwrt-imx6-imx6q-gw5400-a-squashfs.bin\0" \ + "image_uboot=ventana/u-boot_spi.imx\0" \ + \ + "spi_koffset=0x90000\0" \ + "spi_klen=0x200000\0" \ + \ + "spi_updateuboot=echo Updating uboot from " \ + "${serverip}:${image_uboot}...; " \ + "tftpboot ${loadaddr} ${image_uboot} && " \ + "sf probe && sf erase 0 80000 && " \ + "sf write ${loadaddr} 400 ${filesize}\0" \ + "spi_update=echo Updating OS from ${serverip}:${image_os} " \ + "to ${spi_koffset} ...; " \ + "tftp ${loadaddr} ${image_os} && " \ + "sf probe && " \ + "sf update ${loadaddr} ${spi_koffset} ${filesize}\0" \ + \ + "flash_boot=" \ + "if sf probe && " \ + "sf read ${loadaddr} ${spi_koffset} ${spi_klen}; then " \ + "setenv bootargs console=${console},${baudrate} " \ + "root=/dev/mtdblock3 " \ + "rootfstype=squashfs,jffs2 " \ + "${video} ${extra}; " \ + "bootm; " \ + "fi\0" +#else + #define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_EXTRA_ENV_SETTINGS_COMMON \ + "image_rootfs=openwrt-imx6-ventana-rootfs.ubi\0" \ + \ + "nand_update=echo Updating NAND from ${serverip}:${image_rootfs}...; " \ + "tftp ${loadaddr} ${image_rootfs} && " \ + "nand erase.part rootfs && " \ + "nand write ${loadaddr} rootfs ${filesize}\0" \ + \ + "flash_boot=" \ + "setenv fsload 'ubifsload'; " \ + "ubi part rootfs && ubifsmount ubi0:rootfs; " \ + "run loadscript; " \ + "if ${fsload} ${loadaddr} ${uimage}; then " \ + "setenv bootargs console=${console},${baudrate} " \ + "root=ubi0:rootfs ubi.mtd=2 " \ + "rootfstype=ubifs ${video} ${extra}; " \ + "if run loadfdt && fdt addr ${fdt_addr}; then " \ + "ubifsumount; " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "ubifsumount; bootm; " \ + "fi; " \ + "fi\0" +#endif + +#define CONFIG_BOOTCOMMAND \ + "for btype in ${bootdevs}; do " \ + "echo; echo Attempting ${btype} boot...; " \ + "if run ${btype}_boot; then; fi; " \ + "done" + +/* Device Tree Support */ +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_LIBFDT +#define CONFIG_FDT_FIXUP_PARTITIONS + +#ifndef CONFIG_SYS_DCACHE_OFF + #define CONFIG_CMD_CACHE +#endif + +#endif /* __CONFIG_H */
Hi Tim,
On 13/02/2014 08:48, Tim Harvey wrote:
Gateworks Ventana is a product family based on the i.MX6. This patch adds support for all boards in the Ventana family. Where possible, data from the boards EEPROM is used to determine various details about the board at runtime.
Signed-off-by: Tim Harvey tharvey@gateworks.com Cc: Stefano Babic sbabic@denx.de
Changes in v4:
- fixed FP calculation
- fixed invalid return type for read_eeprom()
- use enum and defines for GSC HWMON registers/bits
- removed unused CONFIG_SPI_FLASH_WINBOND_ERASESIZE
- use defines for I2C bus numbers
- added PCIE support
- moved board-specific gpio iomux to board_init as imx6_pcie_toggle_reset needs it
Changes in v3:
- update README fixing typo and removing Freescale document link
- use debug() instead of printf()
- be more explicit with hwmon error output and use macro for min/max percent
- use #defines for GSC slave address and registers
- remove extern from function prototype
- moved gpio config into structure for better readability
- use enum for eeprom bit configs and array to map to fdt property alias
- add SATA regardless of cpu type
- add FIT support regardless of flash type
- display PMIC and device id in misc_init_r() instead of pmic driver
Changes in v2:
- rebase on top of u-boot-imx
- use switch..case for model specific init instead of strcmps
- move checkboard to late init allowing i2c_setup to be moved to board_init() eeprom reading to be done after relocation, and move eeprom struct from data segment
- move SPI/I2C init to board_init()
- update README
- remove unnecessary console overwrite function
- fix multiline comment style and eliminate >80 char lines
- eliminate unnecessary loop in board_mmc_init()
- add missing copyright to clocks.cfg
- avoid duplicating cfg files where no changes exist
- added missing SPDX header to ventana_eeprom.h
- use puts() instead of printf() for constant strings
- remove messages regarding /dev/i2c-<n>
- use get_ram_size() for determing ram_size
- cleanup gpio configuration using tables for baseboard pinmux combinations
- remove phy init errata as it doesn't pertain to use case (it is for 802.3az which IMX6 MAC does not support)
- added pfuze100_pmic driver using PMIC API
- moved GSC code (gsc command and i2c_read/i2c_write wrappers into own file)
- allow user to quiet down some of the data displayed
- remove display support for now - will revisit later
- remove display of boot mode info - may revisit later
- replace bitwise fields in eeprom structure with bit definitions
board/gateworks/gw_ventana/Makefile | 10 + board/gateworks/gw_ventana/README | 55 ++ board/gateworks/gw_ventana/clocks.cfg | 42 + board/gateworks/gw_ventana/gsc.c | 129 +++ board/gateworks/gw_ventana/gsc.h | 64 ++ board/gateworks/gw_ventana/gw_ventana.c | 1262 +++++++++++++++++++++++++++ board/gateworks/gw_ventana/gw_ventana.cfg | 42 + board/gateworks/gw_ventana/ventana_eeprom.h | 106 +++ boards.cfg | 5 + include/configs/gw_ventana.h | 425 +++++++++ 10 files changed, 2140 insertions(+) create mode 100644 board/gateworks/gw_ventana/Makefile create mode 100644 board/gateworks/gw_ventana/README create mode 100644 board/gateworks/gw_ventana/clocks.cfg create mode 100644 board/gateworks/gw_ventana/gsc.c create mode 100644 board/gateworks/gw_ventana/gsc.h create mode 100644 board/gateworks/gw_ventana/gw_ventana.c create mode 100644 board/gateworks/gw_ventana/gw_ventana.cfg create mode 100644 board/gateworks/gw_ventana/ventana_eeprom.h create mode 100644 include/configs/gw_ventana.h
diff --git a/board/gateworks/gw_ventana/Makefile b/board/gateworks/gw_ventana/Makefile new file mode 100644 index 0000000..e8dab89 --- /dev/null +++ b/board/gateworks/gw_ventana/Makefile @@ -0,0 +1,10 @@ +# +# Copyright (C) 2012-2013, Guennadi Liakhovetski lg@denx.de +# (C) Copyright 2012-2013 Freescale Semiconductor, Inc. +# Copyright (C) 2013, Gateworks Corporation +# +# SPDX-License-Identifier: GPL-2.0+ +#
+obj-y := gw_ventana.o gsc.o
diff --git a/board/gateworks/gw_ventana/README b/board/gateworks/gw_ventana/README new file mode 100644 index 0000000..9e697d6 --- /dev/null +++ b/board/gateworks/gw_ventana/README @@ -0,0 +1,55 @@ +U-Boot for the Gateworks Ventana Product Family boards
+This file contains information for the port of U-Boot to the Gateworks +Ventana Product family boards.
+1. Boot source, boot from NAND +------------------------------
+The i.MX6 BOOT ROM expects some structures that provide details of NAND layout +and bad block information (referred to as 'bootstreams') which are replicated +multiple times in NAND. The number of replications is configurable through +board strapping options and eFUSE settings. The Freescale 'kobs-ng' +application from the Freescale LTIB BSP, which runs under Linux, must be used +to program the bootstream in order to setup the replicated headers correctly.
+The Gateworks Ventana boards with NAND flash have been factory programmed +such that their eFUSE settings expect 2 copies of the boostream (this is +specified by providing kobs-ng with the --search_exponent=1 argument). Once in +Linux with MTD support for the NAND on /dev/mtd0 you can program the boostream +with:
+kobs-ng init -v -x --search_exponent=1 u-boot.imx
+The kobs-ng application uses an imximage (u-boot.imx) which contains the +Image Vector Table (IVT) and Device Configuration Data (DCD) structures that +the i.MX6 BOOT ROM requires to boot. The kobs-ng adds the Firmware +Configuration Block (FCB) and Discovered Bad Block Table (DBBT).
+This information is taken from:
+More details about the i.MX6 BOOT ROM can be found in the IMX6 reference manual.
+2. Build +--------
+There are several Gateworks Ventana boards that share a simliar design but +vary based on CPU, Memory configuration, and subloaded devices. Although +the subloaded devices are handled dynamically in the bootloader using +factory configured EEPROM data to modify the device-tree, the CPU choice +(IMX6Q vs IMX6DL) and memory configurations are currently compile-time +options.
+The following Gateworks Ventana configurations exist:
- gwventanaq1gspi: MX6Q,1GB,SPI FLASH
- gwventanaq : MX6Q,512MB,NAND FLASH
- gwventanaq1g : MX6Q,1GB,NAND FLASH
- gwventanadl : MX6DL,512MB,NAND FLASH
- gwventanadl1g : MX6DL,1GB,NAND FLASH
+To build U-Boot for the MX6Q,1GB,NAND FLASH for example:
- make gwventanaq1g_config
- make
diff --git a/board/gateworks/gw_ventana/clocks.cfg b/board/gateworks/gw_ventana/clocks.cfg new file mode 100644 index 0000000..a8118a2 --- /dev/null +++ b/board/gateworks/gw_ventana/clocks.cfg @@ -0,0 +1,42 @@ +/*
- Copyright (C) 2013 Boundary Devices
- Copyright (C) 2013 Gateworks Corporation
- Device Configuration Data (DCD)
- Each entry must have the format:
- Addr-type Address Value
- where:
Addr-type register length (1,2 or 4 bytes)
Address absolute address of the register
value value to be stored in the register
+/* set the default clock gate to save power */ +DATA 4, CCM_CCGR0, 0x00C03F3F +DATA 4, CCM_CCGR1, 0x0030FC03 +DATA 4, CCM_CCGR2, 0x0FFFC000 +DATA 4, CCM_CCGR3, 0x3FF00000 +DATA 4, CCM_CCGR4, 0xFFFFF300 /* enable NAND/GPMI/BCH clocks */ +DATA 4, CCM_CCGR5, 0x0F0000C3 +DATA 4, CCM_CCGR6, 0x000003FF
+/* enable AXI cache for VDOA/VPU/IPU */ +DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF +/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ +DATA 4, MX6_IOMUXC_GPR6, 0x007F007F +DATA 4, MX6_IOMUXC_GPR7, 0x007F007F
- Setup CCM_CCOSR register as follows:
- cko1_en = 1 --> CKO1 enabled
- cko1_div = 111 --> divide by 8
- cko1_sel = 1011 --> ahb_clk_root
- This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz
+DATA 4, CCM_CCOSR, 0x000000fb diff --git a/board/gateworks/gw_ventana/gsc.c b/board/gateworks/gw_ventana/gsc.c new file mode 100644 index 0000000..37966ab --- /dev/null +++ b/board/gateworks/gw_ventana/gsc.c @@ -0,0 +1,129 @@ +/*
- Author: Tim Harvey tharvey@gateworks.com
+#include <asm/errno.h> +#include <common.h> +#include <i2c.h> +#include <linux/ctype.h>
+#include "gsc.h"
+#define MINMAX(n, percent) ((n)*(100-percent)/100), ((n)*(100+percent)/100)
- The Gateworks System Controller will fail to ACK a master transaction if
- it is busy, which can occur during its 1HZ timer tick while reading ADC's.
- When this does occur, it will never be busy long enough to fail more than
- 2 back-to-back transfers. Thus we wrap i2c_read and i2c_write with
- 3 retries.
+int gsc_i2c_read(uchar chip, uint addr, int alen, uchar *buf, int len) +{
- int retry = 3;
- int n = 0;
- int ret;
- while (n++ < retry) {
ret = i2c_read(chip, addr, alen, buf, len);
if (!ret)
break;
debug("%s: 0x%02x 0x%02x retry%d: %d\n", __func__, chip, addr,
n, ret);
if (ret != -ENODEV)
break;
mdelay(10);
- return ret;
+int gsc_i2c_write(uchar chip, uint addr, int alen, uchar *buf, int len) +{
- int retry = 3;
- int n = 0;
- int ret;
ret = i2c_write(chip, addr, alen, buf, len);
if (!ret)
break;
n, ret);
if (ret != -ENODEV)
break;
mdelay(10);
- mdelay(1);
- return ret;
+#ifdef CONFIG_CMD_GSC +static void read_hwmon(const char *name, uint reg, uint size, uint low,
uint high)
- unsigned char buf[3];
- uint ui;
- printf("%-8s:", name);
- memset(buf, 0, sizeof(buf));
- if (gsc_i2c_read(GSC_HWMON_ADDR, reg, 1, buf, size)) {
puts("fRD\n");
- } else {
ui = buf[0] | (buf[1]<<8) | (buf[2]<<16);
if (ui == 0xffffff)
printf("invalid");
else if (ui < low)
printf("%d Failed - Low", ui);
else if (ui > high)
printf("%d Failed - High", ui);
else
printf("%d", ui);
- puts("\n");
+int do_gsc(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{
- const char *model = getenv("model");
- i2c_set_bus_num(0);
- read_hwmon("Temp", GSC_HWMON_TEMP, 2, 0, 9000);
- read_hwmon("VIN", GSC_HWMON_VIN, 3, 8000, 60000);
- read_hwmon("VBATT", GSC_HWMON_VBATT, 3, 1800, 3500);
- read_hwmon("VDD_3P3", GSC_HWMON_VDD_3P3, 3, MINMAX(3300, 10));
- read_hwmon("VDD_HIGH", GSC_HWMON_VDD_HIGH, 3, MINMAX(3000, 10));
- read_hwmon("VDD_DDR", GSC_HWMON_VDD_DDR, 3, MINMAX(1500, 10));
- read_hwmon("VDD_5P0", GSC_HWMON_VDD_5P0, 3, MINMAX(5000, 10));
- read_hwmon("VDD_2P5", GSC_HWMON_VDD_2P5, 3, MINMAX(2500, 10));
- read_hwmon("VDD_1P8", GSC_HWMON_VDD_1P8, 3, MINMAX(1800, 10));
- switch (model[3]) {
- case '1': /* GW51xx */
read_hwmon("VDD_CORE", GSC_HWMON_VDD_CORE, 3, MINMAX(1175, 10));
read_hwmon("VDD_SOC", GSC_HWMON_VDD_SOC, 3, MINMAX(1175, 10));
break;
- case '2': /* GW52xx */
- case '3': /* GW53xx */
read_hwmon("VDD_1P0", GSC_HWMON_VDD_1P0, 3, MINMAX(1000, 10));
break;
- case '4': /* GW54xx */
read_hwmon("VDD_CORE", GSC_HWMON_VDD_CORE, 3, MINMAX(1375, 10));
read_hwmon("VDD_SOC", GSC_HWMON_VDD_SOC, 3, MINMAX(1375, 10));
break;
+U_BOOT_CMD(gsc, 1, 1, do_gsc,
"GSC test",
+#endif /* CONFIG_CMD_GSC */ diff --git a/board/gateworks/gw_ventana/gsc.h b/board/gateworks/gw_ventana/gsc.h new file mode 100644 index 0000000..da970c3 --- /dev/null +++ b/board/gateworks/gw_ventana/gsc.h @@ -0,0 +1,64 @@ +/*
+#ifndef __ASSEMBLY__
+/* i2c slave addresses */ +#define GSC_SC_ADDR 0x20 +#define GSC_RTC_ADDR 0x68 +#define GSC_HWMON_ADDR 0x29 +#define GSC_EEPROM_ADDR 0x51
+/* System Controller registers */ +enum {
- GSC_SC_CTRL0 = 0x00,
- GSC_SC_CTRL1 = 0x01,
- GSC_SC_STATUS = 0x0a,
- GSC_SC_FWVER = 0x0e,
+/* System Controller Control1 bits */ +enum {
- GSC_SC_CTRL1_WDDIS = 7, /* 1 = disable watchdog */
+/* System Controller Interrupt bits */ +enum {
- GSC_SC_IRQ_PB = 0, /* Pushbutton switch */
- GSC_SC_IRQ_SECURE = 1, /* Secure Key erase operation complete */
- GSC_SC_IRQ_EEPROM_WP = 2, /* EEPROM write violation */
- GSC_SC_IRQ_GPIO = 4, /* GPIO change */
- GSC_SC_IRQ_TAMPER = 5, /* Tamper detect */
- GSC_SC_IRQ_WATCHDOG = 6, /* Watchdog trip */
- GSC_SC_IRQ_PBLONG = 7, /* Pushbutton long hold */
+/* Hardware Monitor registers */ +enum {
- GSC_HWMON_TEMP = 0x00,
- GSC_HWMON_VIN = 0x02,
- GSC_HWMON_VDD_3P3 = 0x05,
- GSC_HWMON_VBATT = 0x08,
- GSC_HWMON_VDD_5P0 = 0x0b,
- GSC_HWMON_VDD_CORE = 0x0e,
- GSC_HWMON_VDD_HIGH = 0x14,
- GSC_HWMON_VDD_DDR = 0x17,
- GSC_HWMON_VDD_SOC = 0x11,
- GSC_HWMON_VDD_1P8 = 0x1d,
- GSC_HWMON_VDD_2P5 = 0x23,
- GSC_HWMON_VDD_1P0 = 0x20,
- I2C transactions to the GSC are done via these functions which
- perform retries in the case of a busy GSC NAK'ing the transaction
+int gsc_i2c_read(uchar chip, uint addr, int alen, uchar *buf, int len); +int gsc_i2c_write(uchar chip, uint addr, int alen, uchar *buf, int len); +#endif
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c new file mode 100644 index 0000000..f9960c7 --- /dev/null +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -0,0 +1,1262 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/sata.h> +#include <jffs2/load_kernel.h> +#include <hwconfig.h> +#include <i2c.h> +#include <linux/ctype.h> +#include <fdt_support.h> +#include <fsl_esdhc.h> +#include <miiphy.h> +#include <mmc.h> +#include <mtd_node.h> +#include <netdev.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> +#include <i2c.h> +#include <fdt_support.h> +#include <jffs2/load_kernel.h> +#include <spi_flash.h>
+#include "gsc.h" +#include "ventana_eeprom.h"
+DECLARE_GLOBAL_DATA_PTR;
+/* GPIO's common to all baseboards */ +#define GP_PHY_RST IMX_GPIO_NR(1, 30) +#define GP_USB_OTG_PWR IMX_GPIO_NR(3, 22) +#define GP_SD3_CD IMX_GPIO_NR(7, 0) +#define GP_RS232_EN IMX_GPIO_NR(2, 11) +#define GP_MSATA_SEL IMX_GPIO_NR(2, 8)
+/* I2C bus numbers */ +#define I2C_GSC 0 +#define I2C_PMIC 1
+#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
- PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \
- PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
+#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
- PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \
- PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
+#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
- PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
+#define SPI_PAD_CTRL (PAD_CTL_HYS | \
- PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \
- PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST)
+#define DIO_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
- PAD_CTL_DSE_34ohm | PAD_CTL_HYS | PAD_CTL_SRE_FAST)
+#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \
- PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \
- PAD_CTL_ODE | PAD_CTL_SRE_FAST)
- EEPROM board info struct populated by read_eeprom so that we only have to
- read it once.
+static struct ventana_board_info ventana_info;
+enum {
- GW54proto, /* original GW5400-A prototype */
- GW51xx,
- GW52xx,
- GW53xx,
- GW54xx,
- GW_UNKNOWN,
+int board_type;
+/* UART1: Function varies per baseboard */ +iomux_v3_cfg_t const uart1_pads[] = {
- MX6_PAD_SD3_DAT6__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_SD3_DAT7__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
+/* UART2: Serial Console */ +iomux_v3_cfg_t const uart2_pads[] = {
- MX6_PAD_SD4_DAT7__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_SD4_DAT4__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
+#define PC MUX_PAD_CTRL(I2C_PAD_CTRL)
+/* I2C1: GSC */ +struct i2c_pads_info i2c_pad_info0 = {
- .scl = {
.i2c_mode = MX6_PAD_EIM_D21__I2C1_SCL | PC,
.gpio_mode = MX6_PAD_EIM_D21__GPIO3_IO21 | PC,
.gp = IMX_GPIO_NR(3, 21)
- .sda = {
.i2c_mode = MX6_PAD_EIM_D28__I2C1_SDA | PC,
.gpio_mode = MX6_PAD_EIM_D28__GPIO3_IO28 | PC,
.gp = IMX_GPIO_NR(3, 28)
+/* I2C2: PMIC/PCIe Switch/PCIe Clock/Mezz */ +struct i2c_pads_info i2c_pad_info1 = {
- .scl = {
.i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL | PC,
.gpio_mode = MX6_PAD_KEY_COL3__GPIO4_IO12 | PC,
.gp = IMX_GPIO_NR(4, 12)
- .sda = {
.i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC,
.gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 | PC,
.gp = IMX_GPIO_NR(4, 13)
+/* I2C3: Misc/Expansion */ +struct i2c_pads_info i2c_pad_info2 = {
- .scl = {
.i2c_mode = MX6_PAD_GPIO_3__I2C3_SCL | PC,
.gpio_mode = MX6_PAD_GPIO_3__GPIO1_IO03 | PC,
.gp = IMX_GPIO_NR(1, 3)
- .sda = {
.i2c_mode = MX6_PAD_GPIO_6__I2C3_SDA | PC,
.gpio_mode = MX6_PAD_GPIO_6__GPIO1_IO06 | PC,
.gp = IMX_GPIO_NR(1, 6)
+/* MMC */ +iomux_v3_cfg_t const usdhc3_pads[] = {
- MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD3_DAT5__GPIO7_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */
+/* ENET */ +iomux_v3_cfg_t const enet_pads[] = {
- MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL),
- /* PHY nRST */
- MX6_PAD_ENET_TXD0__GPIO1_IO30 | MUX_PAD_CTRL(NO_PAD_CTRL),
+/* NAND */ +iomux_v3_cfg_t const nfc_pads[] = {
- MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(NO_PAD_CTRL),
+#ifdef CONFIG_CMD_NAND +static void setup_gpmi_nand(void) +{
- struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- /* config gpmi nand iomux */
- imx_iomux_v3_setup_multiple_pads(nfc_pads, ARRAY_SIZE(nfc_pads));
- /* config gpmi and bch clock to 100 MHz */
- clrsetbits_le32(&mxc_ccm->cs2cdr,
MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK |
MXC_CCM_CS2CDR_ENFC_CLK_PRED_MASK |
MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK,
MXC_CCM_CS2CDR_ENFC_CLK_PODF(0) |
MXC_CCM_CS2CDR_ENFC_CLK_PRED(3) |
MXC_CCM_CS2CDR_ENFC_CLK_SEL(3));
- /* enable gpmi and bch clock gating */
- setbits_le32(&mxc_ccm->CCGR4,
MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK |
MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK |
MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK |
MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK |
MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET);
- /* enable apbh clock gating */
- setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK);
+} +#endif
+static void setup_iomux_enet(void) +{
- imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads));
- /* toggle PHY_RST# */
- gpio_direction_output(GP_PHY_RST, 0);
- mdelay(2);
- gpio_set_value(GP_PHY_RST, 1);
+static void setup_iomux_uart(void) +{
- imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads));
- imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads));
+#ifdef CONFIG_USB_EHCI_MX6 +iomux_v3_cfg_t const usb_pads[] = {
- MX6_PAD_GPIO_1__USB_OTG_ID | MUX_PAD_CTRL(DIO_PAD_CTRL),
- MX6_PAD_KEY_COL4__USB_OTG_OC | MUX_PAD_CTRL(DIO_PAD_CTRL),
- MX6_PAD_EIM_D22__GPIO3_IO22 | MUX_PAD_CTRL(DIO_PAD_CTRL), /* OTG PWR */
+int board_ehci_hcd_init(int port) +{
- struct ventana_board_info *info = &ventana_info;
- imx_iomux_v3_setup_multiple_pads(usb_pads, ARRAY_SIZE(usb_pads));
- /* Reset USB HUB (present on GW54xx/GW53xx) */
- switch (info->model[3]) {
imx_iomux_v3_setup_pad(MX6_PAD_GPIO_9__GPIO1_IO09|
MUX_PAD_CTRL(NO_PAD_CTRL));
gpio_direction_output(IMX_GPIO_NR(1, 9), 0);
mdelay(2);
gpio_set_value(IMX_GPIO_NR(1, 9), 1);
break;
imx_iomux_v3_setup_pad(MX6_PAD_SD1_DAT0__GPIO1_IO16 |
gpio_direction_output(IMX_GPIO_NR(1, 16), 0);
mdelay(2);
gpio_set_value(IMX_GPIO_NR(1, 16), 1);
break;
+int board_ehci_power(int port, int on) +{
- if (port)
- gpio_set_value(GP_USB_OTG_PWR, on);
+} +#endif /* CONFIG_USB_EHCI_MX6 */
+#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg usdhc_cfg = { USDHC3_BASE_ADDR };
+int board_mmc_getcd(struct mmc *mmc) +{
- /* Card Detect */
- gpio_direction_input(GP_SD3_CD);
- return !gpio_get_value(GP_SD3_CD);
+int board_mmc_init(bd_t *bis) +{
- /* Only one USDHC controller on Ventana */
- imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads));
- usdhc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK);
- usdhc_cfg.max_bus_width = 4;
- return fsl_esdhc_initialize(bis, &usdhc_cfg);
+} +#endif /* CONFIG_FSL_ESDHC */
+#ifdef CONFIG_MXC_SPI +iomux_v3_cfg_t const ecspi1_pads[] = {
- /* SS1 */
- MX6_PAD_EIM_D19__GPIO3_IO19 | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL),
+static void setup_spi(void) +{
- gpio_direction_output(CONFIG_SF_DEFAULT_CS, 1);
- imx_iomux_v3_setup_multiple_pads(ecspi1_pads,
ARRAY_SIZE(ecspi1_pads));
+} +#endif
+/* configure eth0 PHY board-specific LED behavior */ +int board_phy_config(struct phy_device *phydev) +{
- unsigned short val;
- /* Marvel 88E1510 */
- if (phydev->phy_id == 0x1410dd1) {
* Page 3, Register 16: LED[2:0] Function Control Register
* LED[0] (SPD:Amber) R16_3.3:0 to 0111: on-GbE link
* LED[1] (LNK:Green) R16_3.7:4 to 0001: on-link, blink-activity
phy_write(phydev, MDIO_DEVAD_NONE, 22, 3);
val = phy_read(phydev, MDIO_DEVAD_NONE, 16);
val &= 0xff00;
val |= 0x0017;
phy_write(phydev, MDIO_DEVAD_NONE, 16, val);
phy_write(phydev, MDIO_DEVAD_NONE, 22, 0);
- if (phydev->drv->config)
phydev->drv->config(phydev);
+int board_eth_init(bd_t *bis) +{
- setup_iomux_enet();
+#ifdef CONFIG_FEC_MXC
- cpu_eth_init(bis);
+#ifdef CONFIG_MV_UDC
- /* For otg ethernet*/
- usb_eth_initialize(bis);
+/* read ventana EEPROM, check for validity, and return baseboard type */ +static int +read_eeprom(void) +{
- int i;
- int chksum;
- char baseboard;
- int type;
- unsigned char *buf = (unsigned char *)&ventana_info;
- memset(info, 0, sizeof(ventana_info));
* On a board with a missing/depleted backup battery for GSC, the
* board may be ready to probe the GSC before its firmware is
* running. We will wait here indefinately for the GSC/EEPROM.
- while (1) {
if (0 == i2c_set_bus_num(I2C_GSC) &&
0 == i2c_probe(GSC_EEPROM_ADDR))
break;
mdelay(1);
- /* read eeprom config section */
- if (gsc_i2c_read(GSC_EEPROM_ADDR, 0x00, 1, buf, sizeof(ventana_info))) {
puts("EEPROM: Failed to read EEPROM\n");
info->model[0] = 0;
return GW_UNKNOWN;
- /* sanity checks */
- if (info->model[0] != 'G' || info->model[1] != 'W') {
puts("EEPROM: Invalid Model in EEPROM\n");
info->model[0] = 0;
return GW_UNKNOWN;
- /* validate checksum */
- for (chksum = 0, i = 0; i < sizeof(*info)-2; i++)
chksum += buf[i];
- if ((info->chksum[0] != chksum>>8) ||
(info->chksum[1] != (chksum&0xff))) {
puts("EEPROM: Failed EEPROM checksum\n");
info->model[0] = 0;
return GW_UNKNOWN;
- /* original GW5400-A prototype */
- baseboard = info->model[3];
- if (strncasecmp((const char *)info->model, "GW5400-A", 8) == 0)
baseboard = '0';
- switch (baseboard) {
- case '0': /* original GW5400-A prototype */
type = GW54proto;
break;
- case '1':
type = GW51xx;
break;
- case '2':
type = GW52xx;
break;
- case '3':
type = GW53xx;
break;
- case '4':
type = GW54xx;
break;
- default:
printf("EEPROM: Unknown model in EEPROM: %s\n", info->model);
type = GW_UNKNOWN;
break;
- return type;
- Baseboard specific GPIO
+/* common to add baseboards */ +static iomux_v3_cfg_t const gw_gpio_pads[] = {
- /* MSATA_EN */
- MX6_PAD_SD4_DAT0__GPIO2_IO08 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* RS232_EN# */
- MX6_PAD_SD4_DAT3__GPIO2_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL),
+/* prototype */ +static iomux_v3_cfg_t const gwproto_gpio_pads[] = {
- /* PANLEDG# */
- MX6_PAD_KEY_COL0__GPIO4_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* PANLEDR# */
- MX6_PAD_KEY_ROW0__GPIO4_IO07 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* LOCLED# */
- MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* RS485_EN */
- MX6_PAD_SD3_DAT4__GPIO7_IO01 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* IOEXP_PWREN# */
- MX6_PAD_EIM_A19__GPIO2_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* IOEXP_IRQ# */
- MX6_PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* VID_EN */
- MX6_PAD_EIM_D31__GPIO3_IO31 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* DIOI2C_DIS# */
- MX6_PAD_GPIO_19__GPIO4_IO05 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* PCICK_SSON */
- MX6_PAD_SD1_CLK__GPIO1_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* PCI_RST# */
- MX6_PAD_ENET_TXD1__GPIO1_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL),
+static iomux_v3_cfg_t const gw51xx_gpio_pads[] = {
- /* PANLEDG# */
- /* PANLEDR# */
- /* IOEXP_IRQ# */
- /* GPS_SHDN */
- MX6_PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* VID_PWR */
- MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* PCI_RST# */
- MX6_PAD_GPIO_0__GPIO1_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL),
+static iomux_v3_cfg_t const gw52xx_gpio_pads[] = {
- /* PANLEDG# */
- /* PANLEDR# */
- /* IOEXP_IRQ# */
- /* MX6_LOCLED# */
- /* GPS_SHDN */
- MX6_PAD_ENET_RXD0__GPIO1_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* USBOTG_SEL */
- /* VID_PWR */
- /* PCI_RST# */
+static iomux_v3_cfg_t const gw53xx_gpio_pads[] = {
- /* PANLEDG# */
- /* PANLEDR# */
- /* IOEXP_IRQ# */
- /* MX6_LOCLED# */
- /* GPS_SHDN */
- /* VID_EN */
- /* PCI_RST# */
+static iomux_v3_cfg_t const gw54xx_gpio_pads[] = {
- /* PANLEDG# */
- /* PANLEDR# */
- MX6_PAD_KEY_COL2__GPIO4_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* MX6_LOCLED# */
- /* MIPI_DIO */
- MX6_PAD_SD1_DAT3__GPIO1_IO21 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* RS485_EN */
- MX6_PAD_EIM_D24__GPIO3_IO24 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* IOEXP_IRQ# */
- MX6_PAD_KEY_ROW1__GPIO4_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* DIOI2C_DIS# */
- /* DIOI2C_DIS# */
- /* PCICK_SSON */
- /* PCI_RST# */
- each baseboard has 4 user configurable Digital IO lines which can
- be pinmuxed as a GPIO or in some cases a PWM
+struct dio_cfg {
- iomux_v3_cfg_t gpio_padmux;
- unsigned gpio_param;
- iomux_v3_cfg_t pwm_padmux;
- unsigned pwm_param;
+struct ventana {
- /* pinmux */
- iomux_v3_cfg_t const *gpio_pads;
- int num_pads;
- /* DIO pinmux/val */
- struct dio_cfg dio_cfg[4];
- /* various gpios (0 if non-existent) */
- int leds[3];
- int pcie_rst;
- int mezz_pwren;
- int mezz_irq;
- int rs485en;
- int gps_shdn;
- int vidin_en;
- int dioi2c_en;
- int pcie_sson;
- int usb_sel;
+struct ventana gpio_cfg[] = {
- /* GW5400proto */
.dio_cfg = {
.leds = {
IMX_GPIO_NR(4, 6),
IMX_GPIO_NR(4, 10),
IMX_GPIO_NR(4, 15),
.mezz_pwren = IMX_GPIO_NR(4, 7),
.mezz_irq = IMX_GPIO_NR(4, 9),
.rs485en = IMX_GPIO_NR(3, 24),
- /* GW51xx */
.gpio_pads = gw51xx_gpio_pads,
.num_pads = ARRAY_SIZE(gw51xx_gpio_pads),
.dio_cfg = {
{ MX6_PAD_SD1_DAT0__GPIO1_IO16, IMX_GPIO_NR(1, 16),
0, 0 },
{ MX6_PAD_SD1_DAT1__GPIO1_IO17, IMX_GPIO_NR(1, 17),
MX6_PAD_SD1_DAT1__PWM3_OUT, 3 },
{ MX6_PAD_SD1_CMD__GPIO1_IO18, IMX_GPIO_NR(1, 18),
MX6_PAD_SD1_CMD__PWM4_OUT, 4 },
.leds = {
IMX_GPIO_NR(4, 6),
IMX_GPIO_NR(4, 10),
.pcie_rst = IMX_GPIO_NR(1, 0),
.gps_shdn = IMX_GPIO_NR(1, 2),
.vidin_en = IMX_GPIO_NR(5, 20),
- /* GW52xx */
.gpio_pads = gw52xx_gpio_pads,
.num_pads = ARRAY_SIZE(gw52xx_gpio_pads),
.dio_cfg = {
0, 0 },
{ MX6_PAD_SD1_DAT2__GPIO1_IO19, IMX_GPIO_NR(1, 19),
MX6_PAD_SD1_DAT2__PWM2_OUT, 2 },
{ MX6_PAD_SD1_CLK__GPIO1_IO20, IMX_GPIO_NR(1, 20),
0, 0 },
.leds = {
IMX_GPIO_NR(4, 6),
IMX_GPIO_NR(4, 7),
IMX_GPIO_NR(4, 15),
.gps_shdn = IMX_GPIO_NR(1, 27),
.usb_sel = IMX_GPIO_NR(1, 2),
- /* GW53xx */
.gpio_pads = gw53xx_gpio_pads,
.num_pads = ARRAY_SIZE(gw53xx_gpio_pads),
.dio_cfg = {
0, 0 },
0, 0 },
.leds = {
IMX_GPIO_NR(4, 6),
IMX_GPIO_NR(4, 7),
IMX_GPIO_NR(4, 15),
.pcie_rst = IMX_GPIO_NR(1, 29),
.mezz_pwren = IMX_GPIO_NR(2, 19),
.mezz_irq = IMX_GPIO_NR(2, 18),
.vidin_en = IMX_GPIO_NR(3, 31),
- /* GW54xx */
.gpio_pads = gw54xx_gpio_pads,
.num_pads = ARRAY_SIZE(gw54xx_gpio_pads),
.dio_cfg = {
{ MX6_PAD_GPIO_9__GPIO1_IO09, IMX_GPIO_NR(1, 9),
MX6_PAD_GPIO_9__PWM1_OUT, 1 },
{ MX6_PAD_SD4_DAT1__GPIO2_IO09, IMX_GPIO_NR(2, 9),
MX6_PAD_SD4_DAT1__PWM3_OUT, 3 },
{ MX6_PAD_SD4_DAT2__GPIO2_IO10, IMX_GPIO_NR(2, 10),
MX6_PAD_SD4_DAT2__PWM4_OUT, 4 },
.leds = {
IMX_GPIO_NR(4, 6),
IMX_GPIO_NR(4, 7),
IMX_GPIO_NR(4, 15),
.rs485en = IMX_GPIO_NR(7, 1),
.dioi2c_en = IMX_GPIO_NR(4, 5),
.pcie_sson = IMX_GPIO_NR(1, 20),
+/* setup GPIO pinmux and default configuration per baseboard */ +static void setup_board_gpio(int board) +{
- const char *s;
- char arg[10];
- size_t len;
- int i;
- int quiet = simple_strtol(getenv("quiet"), NULL, 10);
- if (board >= GW_UNKNOWN)
return;
- /* RS232_EN# */
- gpio_direction_output(GP_RS232_EN, (hwconfig("rs232")) ? 0 : 1);
- /* MSATA Enable */
- if (is_cpu_type(MXC_CPU_MX6Q) &&
test_bit(EECONFIG_SATA, info->config)) {
gpio_direction_output(GP_MSATA_SEL,
(hwconfig("msata")) ? 1 : 0);
- } else {
gpio_direction_output(GP_MSATA_SEL, 0);
* assert PCI_RST# (released by OS when clock is valid)
* TODO: figure out why leaving this de-asserted from PCI scan on boot
* causes linux pcie driver to hang during enumeration
- gpio_direction_output(gpio_cfg[board].pcie_rst, 0);
- /* turn off (active-high) user LED's */
- for (i = 0; i < 4; i++) {
if (gpio_cfg[board].leds[i])
gpio_direction_output(gpio_cfg[board].leds[i], 1);
- /* Expansion Mezzanine IO */
- gpio_direction_output(gpio_cfg[board].mezz_pwren, 0);
- gpio_direction_input(gpio_cfg[board].mezz_irq);
- /* RS485 Transmit Enable */
- if (gpio_cfg[board].rs485en)
gpio_direction_output(gpio_cfg[board].rs485en, 0);
- /* GPS_SHDN */
- if (gpio_cfg[board].gps_shdn)
gpio_direction_output(gpio_cfg[board].gps_shdn, 1);
- /* Analog video codec power enable */
- if (gpio_cfg[board].vidin_en)
gpio_direction_output(gpio_cfg[board].vidin_en, 1);
- /* DIOI2C_DIS# */
- if (gpio_cfg[board].dioi2c_en)
gpio_direction_output(gpio_cfg[board].dioi2c_en, 0);
- /* PCICK_SSON: disable spread-spectrum clock */
- if (gpio_cfg[board].pcie_sson)
gpio_direction_output(gpio_cfg[board].pcie_sson, 0);
- /* USBOTG Select (PCISKT or FrontPanel) */
- if (gpio_cfg[board].usb_sel)
gpio_direction_output(gpio_cfg[board].usb_sel, 0);
* Configure DIO pinmux/padctl registers
* see IMX6DQRM/IMX6SDLRM IOMUXC_SW_PAD_CTL_PAD_* register definitions
struct dio_cfg *cfg = &gpio_cfg[board].dio_cfg[i];
unsigned ctrl = DIO_PAD_CTRL;
sprintf(arg, "dio%d", i);
if (!hwconfig(arg))
continue;
s = hwconfig_subarg(arg, "padctrl", &len);
if (s)
ctrl = simple_strtoul(s, NULL, 16) & 0x3ffff;
if (hwconfig_subarg_cmp(arg, "mode", "gpio")) {
if (!quiet) {
printf("DIO%d: GPIO%d_IO%02d (gpio-%d)\n", i,
(cfg->gpio_param/32)+1,
cfg->gpio_param%32,
cfg->gpio_param);
imx_iomux_v3_setup_pad(cfg->gpio_padmux |
MUX_PAD_CTRL(ctrl));
gpio_direction_input(cfg->gpio_param);
} else if (hwconfig_subarg_cmp("dio2", "mode", "pwm") &&
cfg->pwm_padmux) {
if (!quiet)
printf("DIO%d: pwm%d\n", i, cfg->pwm_param);
imx_iomux_v3_setup_pad(cfg->pwm_padmux |
- if (!quiet) {
(test_bit(EECONFIG_SATA, info->config))) {
printf("MSATA: %s\n", (hwconfig("msata") ?
"enabled" : "disabled"));
printf("RS232: %s\n", (hwconfig("rs232")) ?
"enabled" : "disabled");
+#if defined(CONFIG_CMD_PCI) +int imx6_pcie_toggle_reset(void) +{
- if (board_type < GW_UNKNOWN) {
gpio_direction_output(gpio_cfg[board_type].pcie_rst, 0);
mdelay(50);
gpio_direction_output(gpio_cfg[board_type].pcie_rst, 1);
+} +#endif /* CONFIG_CMD_PCI */
+#ifdef CONFIG_SERIAL_TAG +/*
- called when setting up ATAGS before booting kernel
- populate serialnum from the following (in order of priority):
- serial# env var
- eeprom
+void get_board_serial(struct tag_serialnr *serialnr) +{
- char *serial = getenv("serial#");
- if (serial) {
serialnr->high = 0;
serialnr->low = simple_strtoul(serial, NULL, 10);
- } else if (ventana_info.model[0]) {
serialnr->high = 0;
serialnr->low = ventana_info.serial;
- } else {
serialnr->high = 0;
serialnr->low = 0;
+} +#endif
- Board Support
+int board_early_init_f(void) +{
- setup_iomux_uart();
- gpio_direction_output(GP_USB_OTG_PWR, 0); /* OTG power off */
+int dram_init(void) +{
- gd->ram_size = get_ram_size((void *)PHYS_SDRAM,
CONFIG_DDR_MB*1024*1024);
+int board_init(void) +{
- struct iomuxc_base_regs *const iomuxc_regs
= (struct iomuxc_base_regs *)IOMUXC_BASE_ADDR;
- clrsetbits_le32(&iomuxc_regs->gpr[1],
IOMUXC_GPR1_OTG_ID_MASK,
IOMUXC_GPR1_OTG_ID_GPIO1);
- /* address of linux boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- setup_gpmi_nand();
+#endif +#ifdef CONFIG_MXC_SPI
- setup_spi();
- setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0);
- setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1);
- setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2);
- setup_sata();
- /* read Gateworks EEPROM into global struct (used later) */
- board_type = read_eeprom();
- /* board-specifc GPIO iomux */
imx_iomux_v3_setup_multiple_pads(gw_gpio_pads,
ARRAY_SIZE(gw_gpio_pads));
imx_iomux_v3_setup_multiple_pads(gpio_cfg[board_type].gpio_pads,
gpio_cfg[board_type].num_pads);
+#if defined(CONFIG_DISPLAY_BOARDINFO_LATE) +/*
- called during late init (after relocation and after board_init())
- by virtue of CONFIG_DISPLAY_BOARDINFO_LATE as we needed i2c initialized and
- EEPROM read.
+int checkboard(void) +{
- unsigned char buf[4];
- const char *p;
- int quiet; /* Quiet or minimal output mode */
- quiet = 0;
- p = getenv("quiet");
- if (p)
quiet = simple_strtol(p, NULL, 10);
- else
setenv("quiet", "0");
- puts("\nGateworks Corporation Copyright 2014\n");
- if (info->model[0]) {
printf("Model: %s\n", info->model);
printf("MFGDate: %02x-%02x-%02x%02x\n",
info->mfgdate[0], info->mfgdate[1],
info->mfgdate[2], info->mfgdate[3]);
- } else {
- if (quiet)
- /* Display GSC firmware revision/CRC/status */
- i2c_set_bus_num(I2C_GSC);
- if (!gsc_i2c_read(GSC_SC_ADDR, GSC_SC_FWVER, 1, buf, 1)) {
puts("\n");
- /* Display RTC */
- if (!gsc_i2c_read(GSC_RTC_ADDR, 0x00, 1, buf, 4)) {
printf("RTC: %d\n",
+} +#endif
- BOOT_CFG1, BOOT_CFG2, BOOT_CFG3, BOOT_CFG4
- see Table 8-11 and Table 5-9
- BOOT_CFG1[7] = 1 (boot from NAND)
- BOOT_CFG1[5] = 0 - raw NAND
- BOOT_CFG1[4] = 0 - default pad settings
- BOOT_CFG1[3:2] = 00 - devices = 1
- BOOT_CFG1[1:0] = 00 - Row Address Cycles = 3
- BOOT_CFG2[4:3] = 00 - Boot Search Count = 2
- BOOT_CFG2[2:1] = 01 - Pages In Block = 64
- BOOT_CFG2[0] = 0 - Reset time 12ms
- /* NAND: 64pages per block, 3 row addr cycles, 2 copies of FCB/DBBT */
- { "nand", MAKE_CFGVAL(0x80, 0x02, 0x00, 0x00) },
- { NULL, 0 },
+}; +#endif
- unsigned char reg;
- /* set env vars based on EEPROM data */
- if (ventana_info.model[0]) {
char *p;
int i;
* least.
cputype = "imx6q";
cputype = "imx6dl";
if (p) {
*p++ = 0;
str[4] = 'x';
str[5] = 'x';
str[6] = 0;
- /* configure PFUZE100 PMIC (not used on Ventana baseboards) */
- if (!pmic_init(I2C_PMIC)) {
u32 reg;
- /* setup baseboard specific GPIO pinmux and config */
- setup_board_gpio(board_type);
- add_board_boot_modes(board_boot_modes);
* errata such as:
- if (!gsc_i2c_read(GSC_SC_ADDR, GSC_SC_CTRL1, 1, ®, 1)) {
- } else {
- if (!gsc_i2c_read(GSC_SC_ADDR, GSC_SC_STATUS, 1, ®, 1)) {
- "ethernet0",
- "ethernet1",
- "hdmi_out",
- "ahci0",
- "pcie",
- "ssi0",
- "ssi1",
- "lcd0",
- "lvds0",
- "lvds1",
- "usb0",
- "usb1",
- "mmc0",
- "mmc1",
- "mmc2",
- "mmc3",
- "uart0",
- "uart1",
- "uart2",
- "uart3",
- "uart4",
- "ipu0",
- "ipu1",
- "can0",
- "mipi_dsi",
- "mipi_csi",
- "tzasc0",
- "tzasc1",
- "i2c0",
- "i2c1",
- "i2c2",
- "vpu",
- "csi0",
- "csi1",
- "caam",
- NULL,
- NULL,
- NULL,
- NULL,
- NULL,
- "spi0",
- "spi1",
- "spi2",
- "spi3",
- "spi4",
- "spi5",
- NULL,
- NULL,
- "pps",
- NULL,
- NULL,
- NULL,
- "hdmi_in",
- "cvbs_out",
- "cvbs_in",
- "nand",
- NULL,
- NULL,
- NULL,
- NULL,
- NULL,
- NULL,
- NULL,
- NULL,
- called prior to booting kernel or by 'fdt boardsetup' command
- unless 'fdt_noauto' env var is set we will update the following in the DTB:
- int bit;
- struct node_info nodes[] = {
- if (getenv("fdt_noauto")) {
return;
- /* Update partition nodes using info from mtdparts env var */
- puts(" Updating MTD partitions...\n");
- fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes));
- if (!model) {
return;
- printf(" Adjusting FDT per EEPROM for %s...\n", model);
- /* board serial number */
- fdt_setprop(blob, 0, "system-serial", getenv("serial#"),
- /* board (model contains model from device-tree) */
- fdt_setprop(blob, 0, "board", info->model,
- for (bit = 0; bit < 64; bit++) {
- Refer doc/README.imximage for more details about how-to configure
- and create imximage boot image
- The syntax is taken as close as possible with the kwbimage
- Boot Device : one of
- spi, sd, nand, sata
- #include "../../boundary/nitrogen6x/1066mhz_4x128mx16.cfg"
- #include "../../boundary/nitrogen6x/800mhz_4x128mx16.cfg"
- #include "../../boundary/nitrogen6x/800mhz_2x128mx16.cfg"
+#else
- #error "Unsupported CPU/Memory configuration"
- u8 mac0[6]; /* 0x00: MAC1 */
- u8 mac1[6]; /* 0x06: MAC2 */
- u8 res0[12]; /* 0x0C: reserved */
- u32 serial; /* 0x18: Serial Number (read only) */
- u8 res1[4]; /* 0x1C: reserved */
- u8 mfgdate[4]; /* 0x20: MFG date (read only) */
- u8 res2[7]; /* 0x24 */
- /* sdram config */
- u8 sdram_size; /* 0x2B: enum (512,1024,2048) MB */
- u8 sdram_speed; /* 0x2C: enum (100,133,166,200,267,333,400) MHz */
- u8 sdram_width; /* 0x2D: enum (32,64) bit */
- /* cpu config */
- u8 cpu_speed; /* 0x2E: enum (800,1000,1200) MHz */
- u8 cpu_type; /* 0x2F: enum (imx6q,imx6d,imx6dl,imx6s) */
- u8 model[16]; /* 0x30: model string */
- /* FLASH config */
- u8 nand_flash_size; /* 0x40: enum (4,8,16,32,64,128) MB */
- u8 spi_flash_size; /* 0x41: enum (4,8,16,32,64,128) MB */
- /* Config1: SoC Peripherals */
- u8 config[8]; /* 0x42: loading options */
- u8 res3[4]; /* 0x4A */
- u8 chksum[2]; /* 0x4E */
- EECONFIG_ETH0,
- EECONFIG_ETH1,
- EECONFIG_HDMI_OUT,
- EECONFIG_SATA,
- EECONFIG_PCIE,
- EECONFIG_SSI0,
- EECONFIG_SSI1,
- EECONFIG_LCD,
- EECONFIG_LVDS0,
- EECONFIG_LVDS1,
- EECONFIG_USB0,
- EECONFIG_USB1,
- EECONFIG_SD0,
- EECONFIG_SD1,
- EECONFIG_SD2,
- EECONFIG_SD3,
- EECONFIG_UART0,
- EECONFIG_UART1,
- EECONFIG_UART2,
- EECONFIG_UART3,
- EECONFIG_UART4,
- EECONFIG_IPU0,
- EECONFIG_IPU1,
- EECONFIG_FLEXCAN,
- EECONFIG_MIPI_DSI,
- EECONFIG_MIPI_CSI,
- EECONFIG_TZASC0,
- EECONFIG_TZASC1,
- EECONFIG_I2C0,
- EECONFIG_I2C1,
- EECONFIG_I2C2,
- EECONFIG_VPU,
- EECONFIG_CSI0,
- EECONFIG_CSI1,
- EECONFIG_CAAM,
- EECONFIG_MEZZ,
- EECONFIG_RES1,
- EECONFIG_RES2,
- EECONFIG_RES3,
- EECONFIG_RES4,
- EECONFIG_ESPCI0,
- EECONFIG_ESPCI1,
- EECONFIG_ESPCI2,
- EECONFIG_ESPCI3,
- EECONFIG_ESPCI4,
- EECONFIG_ESPCI5,
- EECONFIG_RES5,
- EECONFIG_RES6,
- EECONFIG_GPS,
- EECONFIG_SPIFL0,
- EECONFIG_SPIFL1,
- EECONFIG_GSPBATT,
- EECONFIG_HDMI_IN,
- EECONFIG_VID_OUT,
- EECONFIG_VID_IN,
- EECONFIG_NAND,
- EECONFIG_RES8,
- EECONFIG_RES9,
- EECONFIG_RES10,
- EECONFIG_RES11,
- EECONFIG_RES12,
- EECONFIG_RES13,
- EECONFIG_RES14,
- EECONFIG_RES15,
- #define CONFIG_MXC_SPI
- #define CONFIG_SPI_FLASH_MTD
- #define CONFIG_SPI_FLASH_BAR
- #define CONFIG_SPI_FLASH_WINBOND
- #define CONFIG_SF_DEFAULT_BUS 0
- #define CONFIG_SF_DEFAULT_CS (0|(IMX_GPIO_NR(3, 19)<<8))
- #define CONFIG_SF_DEFAULT_SPEED 30000000
- #define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0)
- #define CONFIG_NAND_MXS
- #define CONFIG_SYS_MAX_NAND_DEVICE 1
- #define CONFIG_SYS_NAND_BASE 0x40000000
- #define CONFIG_SYS_NAND_5_ADDR_CYCLE
- #define CONFIG_SYS_NAND_ONFI_DETECTION
- /* DMA stuff, needed for GPMI/MXS NAND support */
- #define CONFIG_APBH_DMA
- #define CONFIG_APBH_DMA_BURST
- #define CONFIG_APBH_DMA_BURST8
- SATA Configs
- #define CONFIG_DWC_AHSATA
- #define CONFIG_SYS_SATA_MAX_DEVICE 1
- #define CONFIG_DWC_AHSATA_PORT_ID 0
- #define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR
- #define CONFIG_LBA48
- #define CONFIG_LIBATA
- PCI express
- PMIC
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
- MTD Command for mtdparts
- "mtdparts=nor:512k(uboot),64k(env),2m(kernel),-(rootfs)"
- #define CONFIG_ENV_OFFSET (6 * 64 * 1024)
- #define CONFIG_ENV_SIZE (8 * 1024)
- #define CONFIG_SYS_MMC_ENV_DEV 0
- #define CONFIG_ENV_OFFSET (16 << 20)
- #define CONFIG_ENV_SECT_SIZE (128 << 10)
- #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE
- #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + (512 << 10))
- #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
- #define CONFIG_ENV_OFFSET (512 * 1024)
- #define CONFIG_ENV_SECT_SIZE (64 * 1024)
- #define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS
- #define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS
- #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE
- #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
- "hwconfig=rs232;" \
- "dio0:mode=gpio;dio1:mode=gpio;dio2:mode=gpio;dio3:mode=gpio\0" \
- "console=ttymxc1\0" \
- "bootdevs=usb mmc sata flash\0" \
- HWCONFIG_DEFAULT \
- "video=\0" \
- "mtdparts=" MTDPARTS_DEFAULT "\0" \
- "mtdids=" MTDIDS_DEFAULT "\0" \
- "fdt_high=0xffffffff\0" \
- "fdt_addr=0x18000000\0" \
- "loadfdt=" \
"fi\0" \
- "script=boot/6x_bootscript-ventana\0" \
- "loadscript=" \
"source; " \
"fi\0" \
- "uimage=boot/uImage\0" \
- "mmc_root=/dev/mmcblk0p1 rootfstype=ext4 rootwait rw\0" \
- "mmc_boot=" \
"else " \
"bootm; " \
"fi; " \
"fi\0" \
- "sata_boot=" \
"else " \
"bootm; " \
"fi; " \
"fi\0" \
- "usb_boot=" \
"else " \
"bootm; " \
"fi; " \
"fi\0"
- #define CONFIG_EXTRA_ENV_SETTINGS \
- CONFIG_EXTRA_ENV_SETTINGS_COMMON \
- "image_os=ventana/openwrt-imx6-imx6q-gw5400-a-squashfs.bin\0" \
- "image_uboot=ventana/u-boot_spi.imx\0" \
- "spi_koffset=0x90000\0" \
- "spi_klen=0x200000\0" \
- "spi_updateuboot=echo Updating uboot from " \
- "spi_update=echo Updating OS from ${serverip}:${image_os} " \
"sf probe && " \
- "flash_boot=" \
"if sf probe && " \
"bootm; " \
"fi\0"
+#else
- "image_rootfs=openwrt-imx6-ventana-rootfs.ubi\0" \
- "nand_update=echo Updating NAND from ${serverip}:${image_rootfs}...; " \
- "flash_boot=" \
"ubifsumount; " \
"else " \
"fi; " \
"fi\0"
- "for btype in ${bootdevs}; do " \
- "done"
- #define CONFIG_CMD_CACHE
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Hi Stefano,
On Fri, Feb 14, 2014 at 12:44 PM, Stefano Babic sbabic@denx.de wrote:
Hi Tim,
I noticed that this series is not part of your latest pull request to Albert.
I would like to add support for PF100 PMIC into some boards, so it would be nice to have this series applied in your tree.
Regards,
Fabio Estevam
Hi Fabio,
On 19/02/2014 12:35, Fabio Estevam wrote:
Hi Stefano,
Hi Tim,
Right, I left this one in the queue. I applied only the older ones.
ok - I have not open points with the patch, and I do not think there will be more comments. I will apply it soon.
Regards, Stefano
Hi Fabio,
Hi Stefano,
Hi Tim,
I see now in patchworks that PF100's patch is assigned to Tom - this makes sense because it is not strictly i.MX code. I can apply it myself if Tom agrees.
Regards, Stefano
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 02/19/2014 06:51 AM, Stefano Babic wrote:
Hi Fabio,
Hi Stefano,
Hi Tim,
Go ahead and take it, thanks!
- -- Tom
Hi Stefano,
Will PF100 PMIC support enter into 2014.04 release?
Thanks,
Fabio Estevam
On 02/24/2014 11:09 AM, Fabio Estevam wrote:
Hi Stefano,
I am agreeable to this, yes.
- -- Tom
Hi Tim,
I merged but not yet pushed to the server. I have found an issue: gwventanaq cannot be compiled. In fact, the combination quad + 512MB RAM is not covered in /gw_ventana.cfg:
/home/stefano/Projects/imx/u-boot-imx/board/gateworks/gw_ventana/gw_ventana.cfg:40:4: error: #error "Unsupported CPU/Memory configuration"
Can you fix and resubmit ? Thanks !
On Wed, Mar 5, 2014 at 3:22 AM, Stefano Babic sbabic@denx.de wrote:
Hi Tim,
Stefano,
Sorry about that - yes I realized that issue as well a few days back. I posted a v5 patch yesterday. Let me know if there is anything else needed.
Thanks,
Tim
Fabio Estevam
Stefano Babic
Tim Harvey
