[U-Boot] [PATCH] Fix zynq returning a wrong retval in read_rom_hwaddr
As described in the commit, I think because the return value is never checked, it just worked. I cleaned it up a bit so should at least return the intended value.
The .read_rom_hwaddr net_ops hook does not check the return value, which is why it was never caught that we are currently returning 0 if the read_rom_hwaddr function return -ENOSYS and -ENOSYS otherwise.
In this case we can simplify this by just returning the result of the function.
Signed-off-by: Olliver Schinagl oliver@schinagl.nl --- drivers/net/zynq_gem.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 8b7c1be..04a3fd4 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -593,14 +593,12 @@ __weak int zynq_board_read_rom_ethaddr(unsigned char *ethaddr)
static int zynq_gem_read_rom_mac(struct udevice *dev) { - int retval; struct eth_pdata *pdata = dev_get_platdata(dev);
- retval = zynq_board_read_rom_ethaddr(pdata->enetaddr); - if (retval == -ENOSYS) - retval = 0; + if (!dev) + return -ENOSYS;
- return retval; + return zynq_board_read_rom_ethaddr(pdata->enetaddr); }
static int zynq_gem_miiphy_read(struct mii_dev *bus, int addr,
retval = 0;
- if (!dev)
return -ENOSYS;
- return retval;
- return zynq_board_read_rom_ethaddr(pdata->enetaddr);
Not a problem with the patch above but I hope to get rid of this whole function by using MAC reading from eeprom.
Also board specific functions should return error value when read is not possible.
Acked-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
retval = 0;
- if (!dev)
return -ENOSYS;
- return retval;
Yeah I agree, once the eeprom bit has matured, this could (in your case for your board) be dropped.
As an unwritten rule you mean? I think the intention is that *_board_read_rom_hwaddr returns 0 on success < 0 on error.
Thanks, Michal
retval = 0;
if (!dev)
return -ENOSYS;
return retval;
You should check the pdata ptr for NULL before dereferencing.
2.10.2
Hey Joe,
retval = 0;
if (!dev)
return -ENOSYS;
return retval;
Actually, is this not violating the whole point subclassed drivers? (I admit I have not checked into more details of the zynq_gem to see if it is not allready a subclassed driver).
Even so, I can send an updated patch for this to fix this issue separate of the rest so atleast this function behaves properly.
2.10.2
Joe Hershberger
Michal Simek
Olliver Schinagl
