[U-Boot] [BUG] simple-bus and rsa-sw with DM_FLAG_PRE_RELOC
As of v2019.07-rc1, u-boot does fail to boot without any messages on qemu-arm64 when configured with qemu_arm64_defconfig plus CONFIG_RSA/RSA_SOFTWARE_EXP. (Note that RSA_SOFTWARE_EXP also declares itself with DM_FLAG_PRE_RELOC.)
By bisecting between v2019.04 and v2019.07, I found that the following commit triggered this regression:
commit 3a7c45f6a772 Author: Lukas Auer lukas.auer@aisec.fraunhofer.de Date: Wed Apr 10 14:46:07 2019 +0200
simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus driver
What's wrong with this?
-Takahiro Akashi
On Wed, May 15, 2019 at 1:55 PM AKASHI Takahiro takahiro.akashi@linaro.org wrote:
commit 3a7c45f6a772 Author: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Date: Wed Apr 10 14:46:07 2019 +0200 simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus driver
I just tested it and it boots for me.
$ make qemu_arm64_defconfig $ make menuconfig adding CONFIG_RSA via "Library routines" -> "Security support" -> "Use RSA Library" $ make
$ qemu-system-aarch64 -machine virt -cpu cortex-a57 -bios u-boot.bin -nographic
U-Boot 2019.07-rc1-00506-g90176e3 (May 15 2019 - 14:43:21 +0800)
DRAM: 128 MiB Flash: 128 MiB *** Warning - bad CRC, using default environment
In: pl011@9000000 Out: pl011@9000000 Err: pl011@9000000 Net: No ethernet found. Hit any key to stop autoboot: 0 =>
Regards, Bin
Thank you. I have used locally-built qemu, so I will check the configuration of my build.
-Takahiro Akashi
Regards, Bin
On Wed, May 15, 2019 at 3:12 PM AKASHI Takahiro takahiro.akashi@linaro.org wrote:
FYI
$ qemu-system-aarch64 -version QEMU emulator version 2.5.0 (Debian 1:2.5+dfsg-5ubuntu10.36), Copyright (c) 2003-2008 Fabrice Bellard
I was using Ubuntu 16.04 shipped QEMU packages.
Regards, Bin
FYI
Regards, Bin
The device tree might be different on your build. With this patch, more drivers are probed during the pre-relocation device model. This increases the size requirements of CONFIG_SYS_MALLOC_F_LEN. qemu-arm64 uses the default value for CONFIG_SYS_MALLOC_F_LEN, which is likely too small. We had similar problems on the i.MX devices, see [1]. Increasing it should fix the issue.
Thanks, Lukas
FYI
Regards, Bin
Thanks, Lukas
Ah, it was a known issue. But is there any better, or more flexible, way to fix that issue? It was very difficult for me to find out a clue for root cause.
Thanks, -Takahiro Akashi
FYI
Regards, Bin
Thanks, Lukas
One problem is that the serial console is not yet available when the out of memory error occurs. However with DEBUG_UART configured, U-Boot should print an error (I did not test this). We could also increase the default value of CONFIG_SYS_MALLOC_F_LEN, but this might not be possible on all boards.
You are right, it would be good to have a better way of fixing this, but I am not sure what the best way of doing that is.
Thanks, Lukas
On Wed, May 15, 2019 at 4:14 PM Auer, Lukas lukas.auer@aisec.fraunhofer.de wrote:
FYI
Regards, Bin
Ah yes! I think the qemu-system-aarch64 I was using is a little bit old but I did not realize that the DT might be different.
I thought it might be due to insufficient CONFIG_SYS_MALLOC_F_LEN but since I can't reproduce it my QEMU I did not suggest :)
Thanks, Lukas
Regards, Bin
AKASHI Takahiro
Auer, Lukas
Bin Meng
