Wolfgang,
The following changes since commit 54841ab50c20d6fa6c9cc3eb826989da3a22d934: Wolfgang Denk (1): Make sure that argv[] argument pointers are not modified.
git://git.denx.de/u-boot-net.git master
Albert Aribaud (7): kirkwood_egiga: bugfix: add DMA sequence points kirkwood_egiga: updates: fix DRAM mapping and typo kirkwood_egiga: CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION net: rename: kirkwood_egiga as mvgbe mvgbe: support SoCs other than kirkwood mvgbe: add support for orion5x GbE controller edminiv2: add ethernet support
Ben Warren (1): Write MAC address automatically on MACB-based boards
Eric Bénard (2): at91_emac: Write MAC address automatically cpuat91: unbreak ethernet
Heiko Schocher (1): tsec: add micrel ksz804 phy
Hoan Hoang (3): AX88180: fix media typos AX88180: add support for the Marvell 88E1118 phy AX88180: make OUTW handle 32bit/16bit defines too
Juergen Kilb (1): smc91xx_eeprom: Correct chip detection check.
Mike Frysinger (7): net: dm9000x: re-add casts to I/O pointers to fix gcc warnings AX88180: add missing init prototype AX88180: improve phy searching AX88180: switch to common mii.h header net: warn about spaces in device names uli526x: drop newlines from device name AX88180: use standard I/O accessors
Stefan Roese (1): net: Add option to disable fiber on M88E1111 PHY for PPC4xx
Timur Tabi (1): tsec: fix the return value for tsec_eth_init()
Vipin KUMAR (1): SPEAr : Network driver support added
arch/arm/cpu/arm926ejs/kirkwood/cpu.c | 4 +- arch/arm/cpu/arm926ejs/orion5x/cpu.c | 8 + arch/arm/include/asm/arch-kirkwood/kirkwood.h | 5 + arch/arm/include/asm/arch-orion5x/orion5x.h | 4 + board/LaCie/edminiv2/edminiv2.c | 36 ++ board/LaCie/edminiv2/edminiv2.h | 41 ++ board/afeb9260/afeb9260.c | 7 - board/atmel/at91cap9adk/at91cap9adk.c | 7 - board/atmel/at91sam9260ek/at91sam9260ek.c | 7 - board/atmel/at91sam9263ek/at91sam9263ek.c | 7 - board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 7 - board/calao/sbc35_a9g20/sbc35_a9g20.c | 7 - board/eukrea/cpu9260/cpu9260.c | 7 - board/ronetix/pm9263/pm9263.c | 7 - doc/README.designware_eth | 25 + drivers/net/4xx_enet.c | 5 + drivers/net/Makefile | 3 +- drivers/net/at91_emac.c | 60 ++- drivers/net/ax88180.c | 137 ++++--- drivers/net/ax88180.h | 104 ++--- drivers/net/designware.c | 531 +++++++++++++++++++++++ drivers/net/designware.h | 264 +++++++++++ drivers/net/dm9000x.c | 12 +- drivers/net/kirkwood_egiga.h | 505 --------------------- drivers/net/macb.c | 23 +- drivers/net/{kirkwood_egiga.c => mvgbe.c} | 377 +++++++++-------- drivers/net/mvgbe.h | 505 +++++++++++++++++++++ drivers/net/tsec.c | 37 ++- drivers/net/uli526x.c | 2 +- examples/standalone/smc911x_eeprom.c | 2 +- include/configs/cpuat91.h | 9 +- include/configs/edminiv2.h | 19 +- include/configs/guruplug.h | 4 +- include/configs/km_arm.h | 4 +- include/configs/mv88f6281gtw_ge.h | 4 +- include/configs/openrd_base.h | 4 +- include/configs/rd6281a.h | 4 +- include/configs/sheevaplug.h | 4 +- include/netdev.h | 4 +- net/eth.c | 3 + 40 files changed, 1898 insertions(+), 907 deletions(-) create mode 100644 board/LaCie/edminiv2/edminiv2.h create mode 100644 doc/README.designware_eth create mode 100644 drivers/net/designware.c create mode 100644 drivers/net/designware.h delete mode 100644 drivers/net/kirkwood_egiga.h rename drivers/net/{kirkwood_egiga.c => mvgbe.c} (60%) create mode 100644 drivers/net/mvgbe.h
Dear Ben Warren,
In message 4C3C0B91.40205@gmail.com you wrote:
Wolfgang,
Applied, thanks.
Ben Warren
