[U-Boot] [PATCH v2] mpc85xx: pci: Implement workaround for Erratum A007815
The read-only-write-enable bit is set by default and must be cleared to prevent overwriting read-only registers. This should be done immediately after resetting the PCI Express controller.
Reviewed-by: Hamish Martin hamish.martin@alliedtelesis.co.nz Signed-off-by: Tony O'Brien tony.obrien@alliedtelesis.co.nz
--- Note that this does not implement the whole fix for this erratum, just what is necessary for our implementation. Since we are using a fixed RC configuration, no support has been added for EP mode or any consideration of link-up/down events. --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/include/asm/config_mpc85xx.h | 1 + arch/powerpc/include/asm/fsl_pci.h | 4 +++- drivers/pci/fsl_pci_init.c | 7 +++++++ 4 files changed, 14 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 402a1ff..aabb56b 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -330,6 +330,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_A009663 puts("Work-around for Erratum A009663 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A007815 + puts("Work-around for Erratum A007815 enabled\n"); +#endif
return 0; } diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index c92bc1e..c298e44 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -785,6 +785,7 @@ defined(CONFIG_PPC_T1014) || defined(CONFIG_PPC_T1013) #define CONFIG_SYS_FSL_ERRATUM_A006593 #define CONFIG_SYS_FSL_ERRATUM_A007186 #define CONFIG_SYS_FSL_ERRATUM_A006379 +#define CONFIG_SYS_FSL_ERRATUM_A007815 #define ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE #define CONFIG_SYS_FSL_SFP_VER_3_0
diff --git a/arch/powerpc/include/asm/fsl_pci.h b/arch/powerpc/include/asm/fsl_pci.h index 8bee8ca..cad341e 100644 --- a/arch/powerpc/include/asm/fsl_pci.h +++ b/arch/powerpc/include/asm/fsl_pci.h @@ -79,7 +79,9 @@ typedef struct ccsr_pci { u32 pme_msg_dis; /* 0x024 - PCIE PME & message disable register */ u32 pme_msg_int_en; /* 0x028 - PCIE PME & message interrupt enable register */ u32 pm_command; /* 0x02c - PCIE PM Command register */ - char res4[3016]; /* (- #xbf8 #x30)3016 */ + char res3[2188]; /* (0x8bc - 0x30 = 2188) */ + u32 dbi_ro_wr_en; /* 0x8bc - DBI read only write enable reg */ + char res4[824]; /* (0xbf8 - 0x8c0 = 824) */ u32 block_rev1; /* 0xbf8 - PCIE Block Revision register 1 */ u32 block_rev2; /* 0xbfc - PCIE Block Revision register 2 */
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 52792dc..af20cf0 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -543,6 +543,13 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) pciauto_prescan_setup_bridge(hose, dev, hose->current_busno); }
+#ifdef CONFIG_SYS_FSL_ERRATUM_A007815 + /* The Read-Only Write Enable bit defaults to 1 instead of 0. + * Set to 0 to protect the read-only registers. + */ + clrbits_be32(&pci->dbi_ro_wr_en, 0x01); +#endif + /* Use generic setup_device to initialize standard pci regs, * but do not allocate any windows since any BAR found (such * as PCSRBAR) is not in this cpu's memory space.
Move SYS_FSL_ERRATUM_A007815 to Kconfig. Applied to u-boot-mpc85xx master, awaiting upstream. Thanks.
York
Tony O'Brien
york sun
