[U-Boot] [PATCH v4 1/2] ARM: kirkwood: add db-88f6281-bp board
This is Marvell's Kirkwood development board. It has the following features
- 512M DDR2 - 2 PCI connectors - 1 x1 PCI-e interface - 1 Gigabit Ethernet Port - 2 SATA Ports - USB 2.0 Interface - SDIO - 128M NAND Flash - 16M SPI Flash
It can be strapped to boot from SPI or NAND so there are two defconfigs (one per boot media).
Signed-off-by: Chris Packham judge.packham@gmail.com ---
Changes in v4: - Correctly handle external build output directories - Add entries to arch/arm/dts/Makefile
Changes in v3: - incorporate review feedback (except for DM_SERIAL) from Stefan
arch/arm/dts/Makefile | 2 + arch/arm/dts/kirkwood-db-88f6281-spi.dts | 48 +++++++++ arch/arm/dts/kirkwood-db-88f6281.dts | 26 +++++ arch/arm/dts/kirkwood-db.dtsi | 94 ++++++++++++++++++ arch/arm/mach-kirkwood/Kconfig | 4 + board/Marvell/db-88f6281-bp/.gitignore | 1 + board/Marvell/db-88f6281-bp/Kconfig | 12 +++ board/Marvell/db-88f6281-bp/MAINTAINERS | 10 ++ board/Marvell/db-88f6281-bp/Makefile | 12 +++ board/Marvell/db-88f6281-bp/db-88f6281-bp.c | 103 ++++++++++++++++++++ board/Marvell/db-88f6281-bp/kwbimage.cfg.in | 36 +++++++ configs/db-88f6281-bp-nand_defconfig | 53 ++++++++++ configs/db-88f6281-bp-spi_defconfig | 55 +++++++++++ include/configs/db-88f6281-bp.h | 99 +++++++++++++++++++ 14 files changed, 555 insertions(+) create mode 100644 arch/arm/dts/kirkwood-db-88f6281-spi.dts create mode 100644 arch/arm/dts/kirkwood-db-88f6281.dts create mode 100644 arch/arm/dts/kirkwood-db.dtsi create mode 100644 board/Marvell/db-88f6281-bp/.gitignore create mode 100644 board/Marvell/db-88f6281-bp/Kconfig create mode 100644 board/Marvell/db-88f6281-bp/MAINTAINERS create mode 100644 board/Marvell/db-88f6281-bp/Makefile create mode 100644 board/Marvell/db-88f6281-bp/db-88f6281-bp.c create mode 100644 board/Marvell/db-88f6281-bp/kwbimage.cfg.in create mode 100644 configs/db-88f6281-bp-nand_defconfig create mode 100644 configs/db-88f6281-bp-spi_defconfig create mode 100644 include/configs/db-88f6281-bp.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 8167cdb4e856..b2842580152c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -37,6 +37,8 @@ dtb-$(CONFIG_KIRKWOOD) += \ kirkwood-atl-sbx81lifxcat.dtb \ kirkwood-blackarmor-nas220.dtb \ kirkwood-d2net.dtb \ + kirkwood-db-88f6281.dtb \ + kirkwood-db-88f6281-spi.dtb \ kirkwood-dns325.dtb \ kirkwood-dockstar.dtb \ kirkwood-dreamplug.dtb \ diff --git a/arch/arm/dts/kirkwood-db-88f6281-spi.dts b/arch/arm/dts/kirkwood-db-88f6281-spi.dts new file mode 100644 index 000000000000..50b1b0d4a535 --- /dev/null +++ b/arch/arm/dts/kirkwood-db-88f6281-spi.dts @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Marvell DB-88F6281-BP Development Board Setup + * + * Saeed Bishara saeed@marvell.com + * Thomas Petazzoni thomas.petazzoni@free-electrons.com + * + */ + +/dts-v1/; + +#include "kirkwood-db-88f6281.dts" + +/ { + aliases { + spi0 = &spi0; + }; +}; + +&spi0 { + status = "okay"; + + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,m25p128", "jedec,spi-nor", "spi-flash"; + reg = <0>; + spi-max-frequency = <50000000>; + mode = <0>; + + partition@u-boot { + reg = <0x00000000 0x00c00000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x00c00000 0x00040000>; + label = "u-boot-env"; + }; + partition@unused { + reg = <0x00100000 0x00f00000>; + label = "unused"; + }; + }; +}; + +&nand { + status = "disabled"; +}; diff --git a/arch/arm/dts/kirkwood-db-88f6281.dts b/arch/arm/dts/kirkwood-db-88f6281.dts new file mode 100644 index 000000000000..2adb17c955aa --- /dev/null +++ b/arch/arm/dts/kirkwood-db-88f6281.dts @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Marvell DB-88F6281-BP Development Board Setup + * + * Saeed Bishara saeed@marvell.com + * Thomas Petazzoni thomas.petazzoni@free-electrons.com + * + */ + +/dts-v1/; + +#include "kirkwood-db.dtsi" +#include "kirkwood-6281.dtsi" + +/ { + model = "Marvell DB-88F6281-BP Development Board"; + compatible = "marvell,db-88f6281-bp", "marvell,kirkwood-88f6281", "marvell,kirkwood"; +}; + +&pciec { + status = "okay"; +}; + +&pcie0 { + status = "okay"; +}; diff --git a/arch/arm/dts/kirkwood-db.dtsi b/arch/arm/dts/kirkwood-db.dtsi new file mode 100644 index 000000000000..b81d8e8298a3 --- /dev/null +++ b/arch/arm/dts/kirkwood-db.dtsi @@ -0,0 +1,94 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Marvell DB-{88F6281,88F6282}-BP Development Board Setup + * + * Saeed Bishara saeed@marvell.com + * Thomas Petazzoni thomas.petazzoni@free-electrons.com + * + * This file contains the definitions that are common between the 6281 + * and 6282 variants of the Marvell Kirkwood Development Board. + */ + +#include "kirkwood.dtsi" + +/ { + memory { + device_type = "memory"; + reg = <0x00000000 0x20000000>; /* 512 MB */ + }; + + chosen { + bootargs = "console=ttyS0,115200n8 earlyprintk"; + stdout-path = &uart0; + }; + + aliases { + ethernet0 = ð0; + spi0 = &spi0; + }; + + ocp@f1000000 { + pin-controller@10000 { + pmx_sdio_gpios: pmx-sdio-gpios { + marvell,pins = "mpp37", "mpp38"; + marvell,function = "gpio"; + }; + }; + + serial@12000 { + status = "okay"; + }; + + sata@80000 { + nr-ports = <2>; + status = "okay"; + }; + + ehci@50000 { + status = "okay"; + }; + + mvsdio@90000 { + pinctrl-0 = <&pmx_sdio_gpios>; + pinctrl-names = "default"; + wp-gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>; + cd-gpios = <&gpio1 6 GPIO_ACTIVE_HIGH>; + status = "okay"; + }; + }; +}; + +&nand { + chip-delay = <25>; + status = "okay"; + + partition@0 { + label = "uboot"; + reg = <0x0 0x100000>; + }; + + partition@100000 { + label = "uImage"; + reg = <0x100000 0x400000>; + }; + + partition@500000 { + label = "root"; + reg = <0x500000 0x1fb00000>; + }; +}; + +&mdio { + status = "okay"; + + ethphy0: ethernet-phy@8 { + reg = <8>; + }; +}; + +ð0 { + status = "okay"; + ethernet0-port@0 { + phy-handle = <ðphy0>; + }; +}; diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index 3b860c4f55fe..7c4170399afb 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -65,6 +65,9 @@ config TARGET_SBx81LIFKW config TARGET_SBx81LIFXCAT bool "Allied Telesis SBx81GP24/SBx81GT24"
+config TARGET_DB_88F6281_BP + bool "Marvell DB-88F6281-BP" + endchoice
config SYS_SOC @@ -89,5 +92,6 @@ source "board/Seagate/nas220/Kconfig" source "board/zyxel/nsa310s/Kconfig" source "board/alliedtelesis/SBx81LIFKW/Kconfig" source "board/alliedtelesis/SBx81LIFXCAT/Kconfig" +source "board/Marvell/db-88f6281-bp/Kconfig"
endif diff --git a/board/Marvell/db-88f6281-bp/.gitignore b/board/Marvell/db-88f6281-bp/.gitignore new file mode 100644 index 000000000000..775b9346b859 --- /dev/null +++ b/board/Marvell/db-88f6281-bp/.gitignore @@ -0,0 +1 @@ +kwbimage.cfg diff --git a/board/Marvell/db-88f6281-bp/Kconfig b/board/Marvell/db-88f6281-bp/Kconfig new file mode 100644 index 000000000000..38467399e688 --- /dev/null +++ b/board/Marvell/db-88f6281-bp/Kconfig @@ -0,0 +1,12 @@ +if TARGET_DB_88F6281_BP + +config SYS_BOARD + default "db-88f6281-bp" + +config SYS_VENDOR + default "Marvell" + +config SYS_CONFIG_NAME + default "db-88f6281-bp" + +endif diff --git a/board/Marvell/db-88f6281-bp/MAINTAINERS b/board/Marvell/db-88f6281-bp/MAINTAINERS new file mode 100644 index 000000000000..acf0b051ff54 --- /dev/null +++ b/board/Marvell/db-88f6281-bp/MAINTAINERS @@ -0,0 +1,10 @@ +DB_88F6820_AMC BOARD +M: Chris Packham judge.packham@gmail.com +S: Maintained +F: arch/arm/dts/kirkwood-db-88f6281.dts +F: arch/arm/dts/kirkwood-db-88f6281-spi.dts +F: arch/arm/dts/kirkwood-db.dtsi +F: board/Marvell/db-88f6281-bp/ +F: include/configs/db-88f6281-bp.h +F: configs/db-88f6281-bp-nand_defconfig +F: configs/db-88f6281-bp-spi_defconfig diff --git a/board/Marvell/db-88f6281-bp/Makefile b/board/Marvell/db-88f6281-bp/Makefile new file mode 100644 index 000000000000..e6aa7e39a07f --- /dev/null +++ b/board/Marvell/db-88f6281-bp/Makefile @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y := db-88f6281-bp.o +extra-y := kwbimage.cfg + +quiet_cmd_sed = SED $@ + cmd_sed = sed $(SEDFLAGS_$(@F)) $< >$(dir $<)$(@F) + +SEDFLAGS_kwbimage.cfg = -e "s/^#@BOOT_FROM.*/BOOT_FROM $(if $(CONFIG_CMD_NAND),nand,spi)/" +$(src)/kwbimage.cfg: $(src)/kwbimage.cfg.in include/autoconf.mk \ + include/config/auto.conf + $(call if_changed,sed) diff --git a/board/Marvell/db-88f6281-bp/db-88f6281-bp.c b/board/Marvell/db-88f6281-bp/db-88f6281-bp.c new file mode 100644 index 000000000000..b68f2f3c895b --- /dev/null +++ b/board/Marvell/db-88f6281-bp/db-88f6281-bp.c @@ -0,0 +1,103 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <linux/io.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <asm/arch/mpp.h> +#include <asm/arch/gpio.h> + +#define DB_88F6281_OE_LOW ~(BIT(7)) +#define DB_88F6281_OE_HIGH ~(BIT(15) | BIT(14) | BIT(13) | BIT(4)) +#define DB_88F6281_OE_VAL_LOW BIT(7) +#define DB_88F6281_OE_VAL_HIGH 0 + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + mvebu_config_gpio(DB_88F6281_OE_VAL_LOW, + DB_88F6281_OE_VAL_HIGH, + DB_88F6281_OE_LOW, DB_88F6281_OE_HIGH); + + /* Multi-Purpose Pins Functionality configuration */ + static const u32 kwmpp_config[] = { +#ifdef CONFIG_CMD_NAND + MPP0_NF_IO2, + MPP1_NF_IO3, + MPP2_NF_IO4, + MPP3_NF_IO5, +#else + MPP0_SPI_SCn, + MPP1_SPI_MOSI, + MPP2_SPI_SCK, + MPP3_SPI_MISO, +#endif + MPP4_NF_IO6, + MPP5_NF_IO7, + MPP6_SYSRST_OUTn, + MPP7_GPO, + MPP8_TW_SDA, + MPP9_TW_SCK, + MPP10_UART0_TXD, + MPP11_UART0_RXD, + MPP12_SD_CLK, + MPP13_SD_CMD, + MPP14_SD_D0, + MPP15_SD_D1, + MPP16_SD_D2, + MPP17_SD_D3, + MPP18_NF_IO0, + MPP19_NF_IO1, + MPP20_SATA1_ACTn, + MPP21_SATA0_ACTn, + MPP22_GPIO, + MPP23_GPIO, + MPP24_GPIO, + MPP25_GPIO, + MPP26_GPIO, + MPP27_GPIO, + MPP28_GPIO, + MPP29_GPIO, + MPP30_GPIO, + MPP31_GPIO, + MPP32_GPIO, + MPP33_GPIO, + MPP34_GPIO, + MPP35_GPIO, + MPP36_GPIO, + MPP37_GPIO, + MPP38_GPIO, + MPP39_GPIO, + MPP40_GPIO, + MPP41_GPIO, + MPP42_GPIO, + MPP43_GPIO, + MPP44_GPIO, + MPP45_GPIO, + MPP46_GPIO, + MPP47_GPIO, + MPP48_GPIO, + MPP49_GPIO, + 0 + }; + kirkwood_mpp_conf(kwmpp_config, NULL); + + return 0; +} + +int board_init(void) +{ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +/* automatically defined by kirkwood config.h */ +void reset_phy(void) +{ +} +#endif diff --git a/board/Marvell/db-88f6281-bp/kwbimage.cfg.in b/board/Marvell/db-88f6281-bp/kwbimage.cfg.in new file mode 100644 index 000000000000..05f8b275f607 --- /dev/null +++ b/board/Marvell/db-88f6281-bp/kwbimage.cfg.in @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ + +# Boot Media configurations +#@BOOT_FROM + +DATA 0xd00100e0 0x1b1b1b9b +DATA 0xd0020134 0xbbbbbbbb +DATA 0xd0020138 0x00bbbbbb +DATA 0xd0020154 0x00000200 +DATA 0xd002014c 0x00001c00 +DATA 0xd0020148 0x00000001 + +DATA 0xd0001400 0x43000c30 +DATA 0xd0001404 0x39543000 +DATA 0xd0001408 0x22125451 +DATA 0xd000140c 0x00000833 +DATA 0xd0001410 0x000000cc +DATA 0xd0001414 0x00000000 +DATA 0xd0001418 0x00000000 +DATA 0xd000141c 0x00000c52 +DATA 0xd0001420 0x00000044 +DATA 0xd0001424 0x0000f1ff +DATA 0xd0001428 0x00085520 +DATA 0xd000147c 0x00008552 +DATA 0xd0001504 0x0ffffff1 +DATA 0xd0001508 0x10000000 +DATA 0xd000150c 0x0ffffff5 +DATA 0xd0001514 0x00000000 +DATA 0xd000151c 0x00000000 +DATA 0xd0001494 0x84210000 +DATA 0xd0001498 0x00000000 +DATA 0xd000149c 0x0000f40f +DATA 0xd0001480 0x00000001 + +# End of Header extension +DATA 0x0 0x0 diff --git a/configs/db-88f6281-bp-nand_defconfig b/configs/db-88f6281-bp-nand_defconfig new file mode 100644 index 000000000000..6360ef5e8280 --- /dev/null +++ b/configs/db-88f6281-bp-nand_defconfig @@ -0,0 +1,53 @@ +CONFIG_ARM=y +CONFIG_SYS_THUMB_BUILD=y +CONFIG_KIRKWOOD=y +CONFIG_SYS_TEXT_BASE=0x600000 +CONFIG_TARGET_DB_88F6281_BP=y +CONFIG_IDENT_STRING="\nMarvell DB-88F6281-BP" +CONFIG_NR_DRAM_BANKS=2 +# CONFIG_SYS_MALLOC_F is not set +CONFIG_BOOTDELAY=3 +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DM=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_IDE=y +CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_JFFS2=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" +CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:512K(uboot),512K(env),4M(kernel),-(rootfs)" +CONFIG_ISO_PARTITION=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-db-88f6281" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_MVSATA_IDE=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_MARVELL=y +CONFIG_DM_ETH=y +CONFIG_MVGBE=y +CONFIG_MII=y +CONFIG_DM_RTC=y +CONFIG_RTC_MV=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_KIRKWOOD_SPI=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_LZMA=y +CONFIG_LZO=y diff --git a/configs/db-88f6281-bp-spi_defconfig b/configs/db-88f6281-bp-spi_defconfig new file mode 100644 index 000000000000..54d476727996 --- /dev/null +++ b/configs/db-88f6281-bp-spi_defconfig @@ -0,0 +1,55 @@ +CONFIG_ARM=y +CONFIG_SYS_THUMB_BUILD=y +CONFIG_KIRKWOOD=y +CONFIG_SYS_TEXT_BASE=0x600000 +CONFIG_TARGET_DB_88F6281_BP=y +CONFIG_IDENT_STRING="\nMarvell DB-88F6281-BP" +CONFIG_NR_DRAM_BANKS=2 +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT=y +CONFIG_BOOTDELAY=3 +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DM=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_IDE=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_JFFS2=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" +CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:512K(uboot),512K(env),4M(kernel),-(rootfs)" +CONFIG_ISO_PARTITION=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-db-88f6281-spi" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_MVSATA_IDE=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_MARVELL=y +CONFIG_DM_ETH=y +CONFIG_MVGBE=y +CONFIG_MII=y +CONFIG_DM_RTC=y +CONFIG_RTC_MV=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_KIRKWOOD_SPI=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_LZMA=y +CONFIG_LZO=y diff --git a/include/configs/db-88f6281-bp.h b/include/configs/db-88f6281-bp.h new file mode 100644 index 000000000000..680de8f29422 --- /dev/null +++ b/include/configs/db-88f6281-bp.h @@ -0,0 +1,99 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef _CONFIG_DB_88F6281_BP_H +#define _CONFIG_DB_88F6281_BP_H + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ +#define CONFIG_KW88F6281 1 /* SOC Name */ +#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ +#define CONFIG_SYS_TCLK 166666667 +#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg +#define CONFIG_BUILD_TARGET "u-boot.kwb" + +/* additions for new ARM relocation support */ +#define CONFIG_SYS_SDRAM_BASE 0x00000000 + +#define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ +#define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 */ +#define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ +#define CONFIG_KIRKWOOD_GPIO 1 + +/* + * NS16550 Configuration + */ +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK CONFIG_SYS_TCLK +#define CONFIG_SYS_NS16550_COM1 KW_UART0_BASE + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +/* + * Serial Port configuration + * The following definitions let you select what serial you want to use + * for your console driver. + */ + +#define CONFIG_CONS_INDEX 1 /* Console on UART0 */ + +/* + * Environment variables configurations + */ +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 20000000 /* 20Mhz */ +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ +#define CONFIG_ENV_SIZE 0x01000 +#define CONFIG_ENV_OFFSET 0xC0000 + +/* + * U-Boot bootcode configuration + */ + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for monitor */ +#define CONFIG_SYS_MALLOC_LEN (4 << 20) /* Reserve 4.0 MB for malloc */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Mem map for Linux*/ + +/* size in bytes reserved for initial data */ + +#include <asm/arch/config.h> +/* There is no PHY directly connected so don't ask it for link status */ +#undef CONFIG_SYS_FAULT_ECHO_LINK_DOWN + +/* + * Other required minimal configurations + */ +#define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ +#define CONFIG_SYS_MEMTEST_START 0x00400000 /* 4M */ +#define CONFIG_SYS_MEMTEST_END 0x007fffff /* (_8M - 1) */ +#define CONFIG_SYS_RESET_ADDRESS 0xffff0000 /* Rst Vector Adr */ + +/* + * SDIO/MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MVEBU_MMC +#define CONFIG_SYS_MMC_BASE KW_SDIO_BASE +#endif /* CONFIG_CMD_MMC */ + +/* + * SATA Driver configuration + */ +#ifdef CONFIG_MVSATA_IDE +#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +#endif /*CONFIG_MVSATA_IDE*/ + +#define CONFIG_SYS_LOAD_ADDR 0x1000000 /* default location for tftp and bootm */ + +#define CONFIG_SYS_DCACHE_OFF + +#endif /* _CONFIG_DB_88F6281_BP_H */
Switch to the driver model for USB on the db-88f6281-bp board. CONFIG_BLK can't be enabled yet because mvebu_mmc.c needs converting.
Signed-off-by: Chris Packham judge.packham@gmail.com Reviewed-by: Stefan Roese sr@denx.de --- In my original patch series having this separate made sense as this wouldn't be possible without the USB changes. Now it may make sense to squash this into the previous patch.
Changes in v4: None Changes in v3: None
configs/db-88f6281-bp-nand_defconfig | 1 + configs/db-88f6281-bp-spi_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/db-88f6281-bp-nand_defconfig b/configs/db-88f6281-bp-nand_defconfig index 6360ef5e8280..a7a65df7ee7b 100644 --- a/configs/db-88f6281-bp-nand_defconfig +++ b/configs/db-88f6281-bp-nand_defconfig @@ -47,6 +47,7 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LZMA=y diff --git a/configs/db-88f6281-bp-spi_defconfig b/configs/db-88f6281-bp-spi_defconfig index 54d476727996..bafbdd3ef075 100644 --- a/configs/db-88f6281-bp-spi_defconfig +++ b/configs/db-88f6281-bp-spi_defconfig @@ -49,6 +49,7 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LZMA=y
Applied to u-boot-marvell/master.
Thanks, Stefan
- 512M DDR2
- 2 PCI connectors
- 2 SATA Ports
- USB 2.0 Interface
- SDIO
- 128M NAND Flash
- 16M SPI Flash
Thanks, Stefan
Chris Packham
Stefan Roese
