[U-Boot] [PATCH 1/1] efi_loader: AllocateAdress error handling
If AllocatePages() is called with AllocateAddress, the UEFI spec requires to return EFI_NOT_FOUND in case the memory page does not exist.
The UEFI SCT II 2017 spec additionally requires to return EFI_NOT_FOUND if the page is already allocated.
Check that *Memory refers to an unallocated page.
UEFI SCT II (2017): AllocatePages(), 5.1.2.1.9 - 5.1.2.1.10
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_memory.c | 19 +++++++++++++------ 1 file changed, 13 insertions(+), 6 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index adbeb1db6b..d6acf02a7f 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -330,10 +330,11 @@ uint64_t efi_add_memory_map(uint64_t start, uint64_t pages, int memory_type, * Page alignment is not checked as this is not a requirement of * efi_free_pool(). * - * @addr: address of page to be freed - * Return: status code + * @addr: address of page to be freed + * @must_be_allocated: return success if the page is allocated + * Return: status code */ -static efi_status_t efi_check_allocated(u64 addr) +static efi_status_t efi_check_allocated(u64 addr, bool must_be_allocated) { struct efi_mem_list *item;
@@ -344,7 +345,8 @@ static efi_status_t efi_check_allocated(u64 addr) u64 end = start + (item->desc.num_pages << EFI_PAGE_SHIFT);
if (addr >= start && addr < end) { - if (item->desc.type != EFI_CONVENTIONAL_MEMORY) + if (must_be_allocated ^ + item->desc.type == EFI_CONVENTIONAL_MEMORY) return EFI_SUCCESS; else return EFI_NOT_FOUND; @@ -438,6 +440,11 @@ efi_status_t efi_allocate_pages(int type, int memory_type, break; case EFI_ALLOCATE_ADDRESS: /* Exact address, reserve it. The addr is already in *memory. */ + r = efi_check_allocated(*memory, false); + if (r != EFI_SUCCESS) { + r = EFI_NOT_FOUND; + break; + } addr = *memory; break; default: @@ -488,7 +495,7 @@ efi_status_t efi_free_pages(uint64_t memory, efi_uintn_t pages) uint64_t r = 0; efi_status_t ret;
- ret = efi_check_allocated(memory); + ret = efi_check_allocated(memory, true); if (ret != EFI_SUCCESS) return ret;
@@ -555,7 +562,7 @@ efi_status_t efi_free_pool(void *buffer) efi_status_t ret; struct efi_pool_allocation *alloc;
- ret = efi_check_allocated((uintptr_t)buffer); + ret = efi_check_allocated((uintptr_t)buffer, true); if (ret != EFI_SUCCESS) return ret;
-- 2.20.1
