[U-Boot-Users] Reading image header from linux
Hi Wolfgang,
I'm currently building in upgrade support for the linux kernel. My approach right now is just having 2 kernel partitions and communicate to u-boot via the u-boot environment the test a kernel in a partition and set a partition to default. One of the things that I like to be able to do is display the image information to the user from linux. Will mkimage have a feature to read /dev/mtdx for example to give me the image header info?
I don't know if you have considered displaying the CRC of the image as part of the info, this would help differentiate kernel builds even if the images name and size have not changed from previous builds. This is especially useful for managing multiple kernels in a system.
David
In message OF57508F94.3D951CD8-ON85256F0A.0052933B-85256F0A.00544136@nanometrics.ca you wrote:
You'd have to change the code. Currently, mkimage tries to mmap() the file, but [f]stat() on a /dev/mtd partition does not give any useful size.
That's what the timestamp is good for.
I think reading a cryptic CRC is less helpful than the actual build time of the image.
David Ho
